Results 1 to 4 of 4
Thread: Using the Encoder library with pointers
    Apr 2013
    13
    First off, thanks for this awesome encoder library. Writing encoder-code from scratch is a total pain. I tried once, and failed terribly.
    I having some unexpected behavior when using the Encoder as a pointer.
    I am using Teensy2++ with Arduino0022
    Everything works fine if both pins are interrupt enabled:
    #include <Encoder.h>
    Encoder *encoderArray[1];
      encoderArray[0] = new Encoder(0,1); //use pins 0 and 1, both interrupt
      Serial.println("Basic Encoder Test:");
    long oldPosition  = -999;
      long newPosition = encoderArray[0]->read();
      if (newPosition != oldPosition) {
        oldPosition = newPosition;
        Serial.println(newPosition);
    Output (as expected):
    Basic Encoder Test:
    0
    1
    0
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    However, the output goes goofy when one of the pins is not interrupt enabled:
      encoderArray[0] = new Encoder(1,5); //use pins 1 and 5, only pin 1 is interrupt enabled
    Output (goofy):
    Basic Encoder Test:
    -672138537
    2143535054
    -672138537
    2143535054
    -672138537
    2143535054
    -672138537
    2143535054
    -672138537
    Apr 2013
    13
    More weirdness...
    I switched from a pointer to an array. Now even stranger stuff is happening...
    When only the first pin is interrupt enabled, everything works as expected
    //ONLY FIRST PIN IS INT ENABLED
    Encoder e0(18,35);
    Encoder e1(19,34);
    Encoder myEncoders[] = {e0,e1};
    long pos[] = {-999,-999};
      Serial.println("TwoKnobs Encoder Test:");
      long newLeft, newRight;
      newLeft = myEncoders[0].read();
      newRight = myEncoders[1].read();
      if (newLeft != pos[0] || newRight != pos[1]) {
        Serial.print("Left = ");
        Serial.print(newLeft);
        Serial.print(", Right = ");
        Serial.print(newRight);
        pos[0] = newLeft;
        pos[1] = newRight;
      // if a character is sent from the serial monitor,
      // reset both back to zero.
      if (Serial.available()) {
        Serial.read();
        Serial.println("Reset both knobs to zero");
        myEncoders[0].write(0);
        myEncoders[1].write(0);
    OUTPUT:
    Left = -52, Right = 8
    Left = -52, Right = 9
    Left = -52, Right = 10
    Left = -52, Right = 11
    Left = -52, Right = 12
    Left = -52, Right = 13
    Left = -52, Right = 14
    Left = -52, Right = 15
    Left = -52, Right = 16
    Left = -52, Right = 17
    Left = -52, Right = 18
    Left = -52, Right = 19
    Left = -52, Right = 20
    Left = -52, Right = 21
    Left = -52, Right = 22
    Left = -53, Right = 22
    Left = -54, Right = 22
    Left = -55, Right = 22
    Left = -56, Right = 22
    Left = -57, Right = 22
    Left = -58, Right = 22
    Left = -59, Right = 22
    Left = -60, Right = 22
    Left = -61, Right = 22
    Left = -62, Right = 22
    Left = -63, Right = 22
    Left = -64, Right = 22
    Left = -65, Right = 22
    Left = -66, Right = 22
    Left = -67, Right = 22
    But when both pins are interrupt enabled, there is NO OUTPUT, ie,
    'if (newLeft != positionLeft || newRight != positionRight)' is never true
    Encoder e0(0,1);
    Encoder e1(36,37);
        pos[0] = newLeft;
        pos[1] = newRight;
        Serial.read();
    If I use Pauls regular (dual encoder) code with the same encoders, everything works perfectly again.
    /* Encoder Library - TwoKnobs Example
     * http://www.pjrc.com/teensy/td_libs_Encoder.html
     * This example code is in the public domain.
    // Change these pin numbers to the pins connected to your encoder.
    //   Best Performance: both pins have interrupt capability
    //   Good Performance: only the first pin has interrupt capability
    //   Low Performance:  neither pin has interrupt capability
    Encoder knobLeft(0,1);
    Encoder knobRight(36,37);
    //   avoid using pins with LEDs attached
    long positionLeft  = -999;
    long positionRight = -999;
      newLeft = knobLeft.read();
      newRight = knobRight.read();
      if (newLeft != positionLeft || newRight != positionRight) {
        positionLeft = newLeft;
        positionRight = newRight;
        Serial.read();
        knobLeft.write(0);
        knobRight.write(0);
    ...What is going on here?
    3,660
    A very good question....
    This is going to take me some time to investigate. I will look into this, but right now I'm occupied prepping for releasing Teensyduino 1.14 when Arduino 1.0.5 releases (any day now).
    Apr 2013
    13
    It's been a while. Really hoping this can get resolved soon. Need this for TeensyMonster, which is launching very soon.
