Results 1 to 3 of 3
Thread: OneWire library for Teensy 3 (DS18B20)
    351
    I've been trying to get the OneWire library working so that I can use a DS18B20 and have finally succeeded. I started with Paul's OneWire library V2.1 for the Arduino which can be downloaded here: http://www.pjrc.com/teensy/td_libs_OneWire.html
    Unzip it into your libraries directory.
    In OneWire.cpp two changes are required to remove the use of PROGMEM from the original Arduino code.
    - at line 439 remove PROGMEM from the declaration.
    - change line 469 from this:
    		crc = pgm_read_byte(dscrc_table + (crc ^ *addr++));
    to this:
    		crc = dscrc_table[crc ^ *addr++];
    In OneWire.h at line 77 is this code:
    #else
    //#error "Please define I/O register types here"
    Change those three lines to this:
    #else
    // PAH - add 1Wire for Teensy 3 (works with DS18B20)
    #define PIN_TO_BASEREG(pin)             (digital_pin_to_info_PGM[(pin)].reg)
    #define PIN_TO_BITMASK(pin)             (1)
    #define IO_REG_TYPE uint32_t
    #define IO_REG_ASM
    #define DIRECT_READ(base, mask)         (*(base+128))
    #define DIRECT_MODE_INPUT(base, mask)   (*(base+160) = PORT_PCR_MUX(1))
    #define DIRECT_MODE_OUTPUT(base, mask)  (*(base+160) = 1)
    #define DIRECT_WRITE_LOW(base, mask)    (*(base+64) = 1)
    #define DIRECT_WRITE_HIGH(base, mask)   (*(base+32) = 1)
    I've only tested it with the DS18B20 but the device is found and the temperature is read so it's at least a good start :-)
    When Paul has time perhaps he can cast his experienced eye over my fixes to make sure I've done this properly and haven't missed anything.
    Pete
    4,291
    I am working on OneWire 2.2, with support for Teensy 3.0 and several small improvements.
    Here's a pre-release copy. Please let me know how it works if you try it?
    http://www.pjrc.com/teensy/beta/OneW...22_17jan13.zip
    351
    It works with the DS18B20 which is the only onewire device I have.
    Pete
