There's a general problem:
An access to adress 0x1FFFFFFF with more than a byte (int16_t or bigger) causes a fault.
I found,that this is documented in the Reference Manual in chapter 3.5.3.4, too:
This can(!) cause problems, because normally you don't know where a variable is stored.
Solution: All variables (> 1 Byte, including arrays and structures, stack and heap) located in this region should be aligned to - at minimum- 2 (i think this is not possible)
- or - the linker script has to define two (RAM) memory regions
- or - ignore it and hope that your program works as expected if it uses more than 32kB RAM(Teensy 3.1)
This took me some time....
Burst-access cannot occur across the 0x2000_0000 boundary
that separates the two SRAM arrays. The two arrays should be
treated as separate memory ranges for burst accesses.
