LetZweindaut
New member
Hi guys,
First and foremost, my adventure with electronics started not so long ago and I'm still learning, so if I'm doing something completely wrong or if I missed something obvious, please let me know.
I'm working on an intervalometer for my Canon camera and initially Teensy was perfect for the job. However, I thought it would be a nice idea to make the whole project even smaller and to use an Attiny microcontroller instead. I read that people are using their Teensies to program AVR MCUs so I thought I could do the same. I got the Arduino ISP working on my Teensy 3.1 (well, at least I think so - it was uploaded correctly and I'm getting the heartbeat signal), please see below:
I downloaded the Arduino-tiny from here: https://code.google.com/p/arduino-tiny/ and installed, I think, correctly, because the Attiny85 appeared on the list of available boards:
*on the screenshot, the Attiny45 is selected, but I actually use Attiny85 @ 1MHz
I connected the Attiny as shown below:
But when I try to upload a basic Blink sketch (I changed pin 13 to 0), avrdude complains about Attiny's missing signature:
I reconnected it several times hoping I got the pins wrong, but with no luck. What am I missing?
Thanks a lot for your time!
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\Piotr\Documents\teensy\arduino-1.0.5-r2-windows\arduino-1.0.5-r2\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM5
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATtiny45
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 256 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 4096 64 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [01] . [00] . [00] . [00] . [10] . [00] [20]
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny45
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00] [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00] [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00] [20]
################################## | 100% 0.06s
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
