I don't have a Teensy 3.1 yet; nor do I have Audio Adaptor Board for Teensy 3.0 & 3.1 (audio shield) yet - but I may have to work with them, so I thought I'd try and compile some programs at home, just to see how it goes.
I already had Arduino IDE 1.0.5 from before (installed in, say,
); working on Ubuntu Natty 11.04. Since the latest Download Teensyduino, Version 1.19 doesn't work with the latest Audio Library For Teensy 3 on github, I got the Teensyduino 1.20 Release Candidate #2:
The install seems to finish fine; then I get the Audio library:
This seems to pass fine. Then, from the page Teensyduino > Libraries > Audio > Play > Memory > Audio 4 Channel Mixer, I gather this:
... however, it turns out PlayFromSketch has been removed in commit 98ee40d5965c6dccae95f73aae78e2dd53848bea, and apparently renamed as SamplePlayer.
So, I try to open the Arduino IDE, choose Teensy 3.1 as the target, and load SamplePlayer from File / Examples / Audio / SamplePlayer (in the IDE). File loads, then I build, but the process ultimately fails. I enabled
in
, and I got a verbose build log, which is attached.
Just like in TeensyLoader seems to choke on large .hex files, it ends with:
Weird, because it seems that SamplePlayer.cpp is indeed there?:
Then I realize the Teensy Window that starts up, says: "SamplePlayer.cpp.hex (too large);", going in there to Help/Verbose Info, I get
Right, so apparently here the .hex file is too big?! (Btw, I think I tried some other non-Audio Teensy examples from the IDE, they compiled fine if I recall correctly...)
So my question is - how can I get SamplePlayer to compile, preferably without having to have a Teensy with me? Could I somehow "fake" the amount of available memory? What sort of environment is SamplePlayer otherwise supposed to compile in?
Many thanks in advance for any answers,
Cheers!
The full build log is attached here:
View attachment Teensy3_Audio_SamplePlayer_verbosebuildlog.txt
/path/to/arduino-1.0.5
wget http://www.pjrc.com/teensy/td_120-rc2/teensyduino.32bit -O teensyduino-1.20rc2.32bit
chmod +x teensyduino-1.20rc2.32bit
./teensyduino-1.20rc2.32bit
git clone https://github.com/PaulStoffregen/Audio.git Teensy3_Audio_git
ln -s $(readlink -f Teensy3_Audio_git) /path/to/arduino-1.0.5/libraries/Audio
AudioMixer4 is used in File > Examples > Audio > PlayFromSketch to combine 6 memory players, so all 6 sounds can play simultaneously.
build.verbose=true
~/.arduino/preferences.txt
/tmp/build339863402923666416.tmp/SamplePlayer.cpp.elf /tmp/build339863402923666416.tmp/SamplePlayer.cpp.hex
Opening Teensy Loader...
Teensy Loader could not find the file SamplePlayer.cpp
$ ls -la /tmp/build339863402923666416.tmp/SamplePlayer.cpp
-rw-r--r-- 1 user user 4068 2014-09-10 23:28 /tmp/build339863402923666416.tmp/SamplePlayer.cpp
23:29:08: Teensy Loader 1.20-rc2, begin program
23:29:08: File "SamplePlayer.cpp.hex". 210760 bytes, 327% used
23:29:08: File contains data beyond chip size, yikes!
23:29:08: Listening for remote control on port 3149
23:29:08: initialized, showing main window
23:29:08: remote connection opened
23:29:08: remote cmd: "comment: Teensyduino 1.20-rc2 - LINUX32"
23:29:08: remote cmd: "dir:/tmp/build339863402923666416.tmp/"
23:29:08: remote cmd: "file:SamplePlayer.cpp.hex"
23:29:09: File "SamplePlayer.cpp.hex". 210760 bytes, 327% used
23:29:09: File contains data beyond chip size, yikes!
23:29:09: remote connection closed
23:34:49: Verbose Info event
Cheers!
