wayneandlayne
New member
Hello everyone,
I have been trying to integrate the PJRC Encoder class inside my own motor control class library, but I've been having some troubles, probably related to interrupts or volatile variables or atomic access of multi-byte variables or something like that. This is with stock Arduino 1.0.5 on Ubuntu 12.04, using a LEGO Mindstorms NXT motor as the encoder inputs.
Code posted here: https://github.com/matthewbeckler/EncoderWrapper
EncoderWrapper.h
EncoderWrapper.cpp
You can see that this class is very simple. It has a local instance of Encoder (_encoder), which is initialized in the initializer list of the constructor. The getPosition() function is a single-line wrapper around Encoder's read() function.
Here is a quick sketch to demonstrate the issue:
When I run the sketch with an encoder connected to pins 3 and 4 on the Arduino, the second Serial.println() statement prints the correct position value from the Encoder instance. The first Serial.println() statement prints garbage that seems to increment over time? Here's some sample output:
So, that's pretty weird. I'm not sure why using the wrapper function produces garbage data, but calling the read() function directly works perfectly. Does anyone have any idea?
Thanks much,
Matthew Beckler
Wayne and Layne, LLC
EncoderWrapper.h
// Arduino header files
#include <stdint.h>
#include "Arduino.h"
// Library header files
#include <Encoder.h>
class EncoderWrapper
public:
EncoderWrapper(uint8_t pin1, uint8_t pin2);
// Read the encoder's current position.
int32_t getPosition(void);
// Write the encoder's current position
void setPosition(int32_t pos);
// Tracks the position of the motor
Encoder _encoder;
EncoderWrapper.cpp
#include "EncoderWrapper.h"
EncoderWrapper::EncoderWrapper(uint8_t pin1, uint8_t pin2):
_encoder(pin1, pin2)
// Nothing to do here
int32_t EncoderWrapper::getPosition(void)
return _encoder.read();
void EncoderWrapper::setPosition(int32_t pos)
_encoder.write(pos);
#include <EncoderWrapper.h>
EncoderWrapper w = EncoderWrapper(3, 4);
void setup(void)
void loop(void)
Serial.println("-----------------------------");
Serial.println(w.getPosition(), HEX);
Serial.println(w._encoder.read(), HEX);
0
C50154
0
1270154
0
12E
1
1EC0154
C
24E0154
24
12E
3F
12E
5B
3760154
76
3D80154
92
12E
AD
49D0154
C4
5000154
D4
5620154
D8
5C50154
CD
12E
B6
68A0154
93
12E
6A
12E
40
12E
1A
12E
FFFFFFF8
12E
FFFFFFD8
12E
FFFFFFBC
12E
FFFFFFA4
12E
FFFFFF94
12E
FFFFFF8E
Thanks much,
Matthew Beckler
