JohannGambolputtyEtc
New member
Hi Paul/Forum,
I've noticed some strange behavior of analogread. Changing the voltage at one pin influences the readout of the next pin being read.
The circuit consists of 4 potentiometers (104k) wired to analog pins 0 to 3. The graphs are made with Processing using a modified version of the sketch included in the teensyduino graph example.
First the teensy reads all 4 pins and you can see the effect of each potmeter on the next pin being read (the large value changes are of course me rotating the pots), with pin 3 affecting pin 0. But if I simply change the sketch to only read pins 0 and 2, using the same circuit, the same effect occurs. This time ignoring the pins not being read (with 0 affecting 2 and vice versa). This behavior occurs all the way to pin 9.
I doubt this behavior is normal and being a total newb I have probably tortured my T3.0 many times by making some wrong connections and also doing the teensyduino tutorials at 5V instead of 3.3V. Any clarification on this issue? Did I cripple my poor T3.0? Thanks in advance!
Serial.print(analogRead(0));
Serial.print(",");
Serial.print(analogRead(1));
Serial.print(",");
Serial.print(analogRead(2));
Serial.print(",");
Serial.println(analogRead(3));
delay(50);
Serial.print(",");
Serial.println(analogRead(2));
delay(50);
