View Full Version : Project Guidance
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. LCD touch based Teensy 3.1 based controller of Printrbot Simple 2016 made open source
  2. Wireless Transmission / Bluetooth or Something Else?
  3. Incremental Encoder Question
  4. powering VBAT on Teenst 3.6
  5. Interfacing with 24V industrial system
  6. Custom Teensy 3.2 Board programs but disappears
  7. Dual Programs Possible?
  8. Good MCU-MCU Protocol to use?
  9. Using the second USB port Teensey 3.6
  10. Using Teensy 3.x with external 3.3v 5A Switching Power Supply
  11. Automotive power supply for Teensy
  12. Using a Teensy 3.2 and Huzzah ESP2866; how to divide tasks?
  13. noob question about teensy 3.2 usage
  14. Using the PRJC PS2 library for multiple keyboards and mice
  15. Programming Teensy 3.5/6 form scratch.
  16. two teensys and serial data
  17. Synchronizing DAC and ADC for simultaneous use - Teensy 3.2/3.6
  18. Teensy 3.2 with Octo2812 with 2 different Led runs
  19. 3.6 as a Modular Synthesizer DSP
  20. Teensy 3.2 - Varying duty cycle in output compare toggle
  21. Use of PS5 Controller with Teensy 3.5
  22. Detect Teensy power failing in time to save data?
  23. SPI based project
  24. Using an ADS1256 board with the Teensy 3.6
  25. Read two IMUs with one Teensy 3.2
  26. Possible to increase dynamic memory?
  27. Modifying Audio Library for Fast ADC Measurement
  28. Eight pots (10k each) from 3.3v
  29. SH1106 with Hardware SPI 3.2
  30. College Project using Teensy
  31. Ultrasonic PWM with Teensy 2.0++ 20kHz required
  32. Hex file to EEprom
  33. help with wireless midi via Xbees
  34. Teensy 3.2 for 2D MIDI foot controller -- RTOS necessary?
  35. IoT -- Server-side software?
  36. Teensy 3.6 and WS2812b LED Strip
  37. Putting two Teensys on a PCB
  38. Reading bytes from BNO055 motion sensor in chunks vs. all at once via I2C
  39. Ethernet stream to serial interface
  40. Advantage of HardareSerial over Serial?
  41. 3.2 Midi controller help
  42. LFO using waveform object
  43. EMG using Myoware Muscle Sensor Raw output
  44. PCB Designer
  45. *PCB Designer / Programmers Needed*
  46. Sketch time & date stamp
  47. Eurorackmodular Teensy/Arduino Sequencer?
  48. Teensy 3.2 as USB KYBD NKRO more than 6 keys
  49. Teensy 3.2, Using AGND or GND when using external AREF?
  50. Daisy Chain 8 off 8x2 Character LCD Display Modules
  51. Teensy 3.x and SH1106 OLED via SPI
  52. Adding sync input to the audio library
  53. USB host mode cap
  54. RS232 to TTL Converter
  55. debug capacitive touch sense with graphical tool
  56. Powering USB Host Boards from Teensy
  57. Power switch when using USB for power (Teensy 3.2)
  58. 8.8v differential
  59. Getting +/-5v audio signals into the Teensy 3.x analog inputs
  60. Very odd behavior of Joystick code when also using Serial1 on teensy.
  61. ADC input voltage range and source impedance questions
  62. OV7670 w/FIFO FPS
  63. Convert Ethernet, Bluetooth, or WiFi Directly to 3G CDMA or 4G LET Cellular
  64. Different Watchdog timer ISRs
  65. Advice: Soldering boards directly onto another board without headers and other things
  66. Realtime Audio Streaming using Teensy 3.2
  67. Multichannel USB audio with Teensy 3.6?
  68. Using Teensyduino's USB library
  69. Building a bigger octo board, is this fairchild chip the right 74HCT245?
  70. Getting distorted image from movie2Serail and Teensy 3.2
  71. Bluetooth or wifi recommendations ?
  72. Serial Protocols, Links and Suggestions Wanted
  73. Video and information data to Phone via USB
  74. Audio Adaptor Board for Teensy - soldering
  75. USB mixed host/device
  76. Ecto-1 Pinewood derby car
  77. any gotchas using attachInterrupt(digitalPinToInterrupt()) and Snooze deepSleep?
  78. Copy data from Serial port
  79. Some questions. Octows2811 related, watchdog, memory, etc
  80. Input with LED switches
  81. 50Hz Noise on Microphone input (Teensy 3.2 + Audio Adapter + Amplifier)
  82. Problem with interrupts on Teensy 3.2
  83. Wiring USB keyboard direct to Teensy for MIDI control.
  84. Phone Compatible Game Controller Using Teensy 3.6
  85. How to make a stereo amplifier IC circuit?
  86. High speed (10Mhz) parallel transfers from a 10MSPS ADC on a Teensy 3.6?
  87. Which RTC and lib to use with Teesy 3.2? (or 3.5)
  88. Need Solution: Teensy 3.2 and Fingerprint Scanner - TTL (GT-511C3)
  89. Would like advice on feasible low power targets
  90. Three phase motor control with Teensy 3.2
  91. reading MISO
  92. fail-safe for a robot
  93. Project with Teensy 3.2 and SD Card
  94. Muitple HD44780 LCD displays
  95. Which SPI library to use ?
  96. touchRead() speed
  97. How to read analog input on T3.5
  98. Starting with LED & Teensy
  99. Disconnecting Analog unput resets Teensy 3.6
  100. Teensy 3.6 Pin Alternates
  101. How do I wire the LED strips correctly?
  102. Sporadic sysEx msg broadcast/capture
  103. Open-collector question
  104. DSP for 7.8 Hz Schumann Earth Cavity signals.
  105. Large LED Displays - Multiple questions, ie. 12v strip, octo output link limit, et
  106. Setting up a Teensy 3.6 OctoAdapter, Sd card, display with button video switching
  107. Which Teensy is best for Ethernet to USB HID Keyboard device? (re: speed)
  108. Teensy LC button Box and Encoder wiring
  109. Teensy 3.6 CAN LIN Board
  110. Audio Adapter -- 4/6/8 Channel Possible?
  111. Teensy 3.6 HID with bluetooth
  112. LED Display Panel // Mirror image onto a second panel?
  113. High powered LED project guidance
  114. SPI Colour OLED Getting Started
  115. Phase vocoder
  116. Audio Adaptor flash chip playback length, Teensy 3.2 to a 2.8v I2C chip
  117. Multi Switch/button controller
  118. Teensy 3.2: Unable to get a successful CAN Bus read
  119. Dock board for Teensy
  120. using a teensy to "correct" a hall effect sensor output frequency
  121. Using the teensy on can bus
  122. reading an encoder & java error: out of memory!
  123. Auto-Updating Teensy 3.2 firmware
  124. First Project(s) - Midi controllers with 4051 Mux and 595 controlled LEDs
  125. Measure 2 frequency signals using arduino mega
  126. connecting apple / samsung headsets 4 poles
  127. USB drive ejector
  128. Choose teensy 3.6 for project
  129. Idea of using more pushbuttons than analog ports, will it work?
  130. Teensy Keyboard Need Help
  131. Are the SWDIO and SWCLK pins wired to pins on the PCB of the Teensy 3.6?
  132. Advice on Teensy 3.5 vs Mega for remote monitoring
  133. Monitoring the status of a computer
  134. Push button DMX commands
  135. port expander SX1509 and keyScan
  136. Auto-Upload without pressing program button
  137. Can audio board share I2C bus?
  138. Request for comments about implementation of missing SPI functionalities
  139. Using two Teensy as one
  140. Input Pins Teensy ++ 2.0
  141. Read binary values from SD card - teensy3.6
  142. PWM phase shift - help
  143. What radio to use for a project
  144. Initialise member array using const
  145. Automated Builds
  146. First Post - Question About Audio Project Feasibility
  147. Send/Receive data to Teensy++2.0 and android over Bluetooth
  148. DJ controller, not just a midi controller
  149. Extensive MIDI controller feasibility
  150. The ultimate Teensy 3.5/3.6 audio board: any ideas?
  151. Midi controller relay - noise problem
  152. Phantom powered Teensy
  153. DMX 512 devices won't work
  154. Ambitious MIDI DotStar project runs poorly
  155. Adding WiFi to Teensy 3.x
  156. Same codebase for a project on Teensy 3.2 and 3.6 that uses CAN Bus
  157. Relocating a customized serial1.c?
  158. PS2Keyboard library questions
  159. Help powering Android phone and Teensy 3.2 simulatneously
  160. Panel mount USB options
  161. Teensy LC with mono DAC sine and NeoPixel
  162. Teensy 3.2 or 3.6 used for High Speed DAQ
  163. Time position pulses (I Think)
  164. Does the Teensy 3.6 support multiple USB ports and/or software RS232?
  165. hid_listen.mac + cores-master/usb_midi/usb.c ? Or not?
  166. 24 pin header for Teensy 3.5/3.6 plus audio board?
  167. Experience with the Video Experimenters Shield???
  168. 4 Audio Inputs on Teensy?
  169. reduced RAM serial library for Teensy LC?
  170. Multi teensy OctoWS2811 suggestion
  171. Teensy 3.2 Raspberry Pi Glediator
  172. CAN transceiver PCB for Teensy 3.6
  173. Led Array Coding????
  174. Measing distance with capacitive touch
  175. Teensy 3.5 driving a piezo buzzer
  176. Question for one of the Senior Devs... Teensy 3.6 + RFM95 breakout
  177. Teensy Shift Register issue
  178. Configure WiFi scenario?
  179. Repetier firmware on Teensy 3
  180. Device provisioning iot - general project experiences
  181. SPI drivers that prefer hardware CS/DC pins.
  182. Teensy 3.2 to ATtiny with 16-bit ADC?
  183. A custom keyboard of sorts?
  184. Cap touchscreen TFT 3-5"
  185. drum pad brain
  186. Libraries compatible on ATtiny ?
  187. Teensy 3.6 connect 63 push buttons
  188. WiFi question
  189. Can Teensy recognize voltage somewhere in the circuit?
  190. Newbie - help appreciated with audio/WavFilePlayer example (Teensy 3.6)
  191. Porting code from Arduino Mega2560
  192. Using teensy 3.6 for PID controlling six dc motors
  193. Midi controller for Ableton
  194. Feasibility of Dual Adafruit RA8875 Controllers and displays on a single Teensy 3.6
  195. Interval Timer guidance / usage
  196. simple midi contoller
  197. Stand alone, programable, DMX controller.
  198. ...is the teensy the right choice for me (how to switch high current AC load safely)
  199. SPI MCP23S17 and RGB Rotary Encorders
  200. Please suggest a quality RS232 interface
  201. wiz820io and 595 sharing spi
  202. Footpedal to use with Behringer XR18 for FX and Tap
  203. WIZ850io + FastLED APA102
  204. Teensy 3.2 Serial comms at 1.5Mbps
  205. Validating a new breadboard break out board.
  206. Arduino HC-05
  207. Possible to get some use out of Flexbus on teensy 3.6?
  208. Low priority high priority interrupts vs state machine
  209. Bluetooth BLE to another Bluetooth BLE or 2.
  210. Big LED installation, network wiring advices
  211. Timer/Counter Guidance
  212. Prop Shield Compatibility with Teensy 3.0?
  213. Add support for Teensy to MySensors library
  214. multiple drum-trigger piezos seem to be interfering with each other
  215. Long term availability of Teensy boards
  216. Pi to Teensy Communication?
  217. Audio wave board using Teensy + Prop Shield
  218. Spectra Symbol Position Sensors HotPot 150mm how to read on analog pin teensy 3.2
  219. Firmata on Tennsy 3.2
  220. Multiple MIDI Input
  221. Teensy LC reading RPM stopped working
  222. MIDI CC Curve
  223. USB MP3 browser/player
  224. Which Teensy would work best as an arcade controller (Xinput) and LED controls
  225. PWM Interrupt
  226. 3.3V Midi on Teensy: Official Midi specs vs Teensy recomendations
  227. Teensy 3.6 Simple Vector-Network-Analyser-type-thing.
  228. Teensy 3.2 minimal analog input voltage
  229. ADC issues with Teensy 3.6
  230. ADNS-3080 optical flow sensor, high speed camera
  231. I'm considering Teensy 3.5 for next work project. Am I OK doing this?
  232. Signal SD Read/Write
  233. Teensy LC used to control VS1053 codec +sd mp3/wav/midi play and rec
  234. Line level converter between pi and teensy
  235. Help needed with code please
  236. Help with 595
  237. Teensy 3.6 servo wiring
  238. RetroPie Joystick
  239. Need help storing last button press please
  240. 2 channel relay - teensy 3.6 digital signal flashing, relay not opening
  241. Help with custom Teensy 3.2
  242. Music Controlled Water fountain
  243. Running the teensy prop shield with 3.7v
  244. Can I use a hot glue gun, thermoplastic, or suguru to protect contacts?
  245. Teensy LC to read input from a peripheral and create a usb HID
  246. Teensy 3.6 reading USB memory stick
  247. APA102 investigation. Different libraries, shared clock pin, etc.
  248. how to change PIT clock frequency in teensy 3.6
  249. SPI with simulated chip select
  250. Protecting an analog output
