View Full Version : Project Guidance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15
  1. Custom USB device based on teensy 3.2
  2. Pin change interrupt - minimum duration?
  3. Can I use the RESET pin as a ON/OFF switch?
  4. ISR / Millis or alternative
  5. Teensy 3.2 + WS2812b project
  6. converting total seconds to hours, minutes and seconds...
  7. Teensy 3.6... OLED display.. SPI or I2C?
  8. Teensy 3.2 + OSC + Reaper
  9. Alternatives to FLIR Lepton/Lepton 3?
  10. Need to improve 2x Encoder performance on Arduino Uno
  11. How many rgb LEDs from USB power with tlc5940?
  12. Teensy + Hall sensor + Stepper motor = working mechanical speedo...
  13. Teensy 3.6 connecting a 3.5mm Jack
  14. How to wire membrane potentiometer and other sensors for a MIDI controller
  15. Multiple Seedstudio grove 4-digit displays on Teensy 3.6
  16. Use MK22 instead of MK20
  17. Round/Circle LED Display using Teensy
  18. Teensy did not respond to a USB-based request to enter program mode.
  19. OLED updating slowing down motors
  20. Adding a charging circuit to a project.
  21. How to use Octows2811 and SPI ?
  22. [Solved] External usb port to charge and program teensy
  23. Analog max voltage?
  24. 3.5/6 Stacking pins/sockets that fit?
  25. Teensy 3.2 custom USB Type
  26. Need a Fresh Eye on a Schematic
  27. TWCR register not defined on Teensy?
  28. Teensy Audio Adapter board together with OctoWS2811
  29. Teensy 3.6 as USBMIDI-to-SerialMIDI adapter
  30. How to connect DotStar LEDs to a Teensy 3.2 with a prop shield?
  31. usbMidi: How to get information from the DAW?
  32. Connecting Prop Shield to ESP32 Feather via Feather Wing
  33. first Teensy 3.6 saber install
  34. Teensy 3.2 not receiving RX data
  35. USB Voltage Clarification
  36. I2C pullup resistors with the audio board and other devices.
  37. Serial PFC Flight Console to USB
  38. Dance beat/rythm/tempo detector
  39. In search of help making a eurorack module from teensy 3.6
  40. Lua interpreter example?
  41. Teensy Midi Foot Controller LCD Help
  42. Simple HTTP-Webserver
  43. Teensy 3.6 with WINC1500 on SPI1...is this a good data rate?
  44. Virtual MIDIx4
  45. teensey 3.2 n OLED screen
  46. Small project turned large, suggestions on pcb cad etc?
  47. mpr121 sensor test code won't work
  48. OctoWS2811 LED Library with Realtime video source?
  49. Teensy 3.6 whit 74hc595 - Pinout and power
  50. how to specify usb HID id?
  51. Is there a way to get the feedback signal out of computer games
  52. Teensy 3.2 I/O interface with AMI based Protocol
  53. Best practice to follow when doing a medium-large project
  54. DIY Teensy LC, will the QFP package work?
  55. Library Conversion From UNO to Teensy
  56. ATMEGA32u4 for keyboard
  57. Use variable as input to audio library.
  58. Changing hardware serial buffer size
  59. Fixed-point known size matrix multiplication on teensy 3.2, 3.5
  60. Teensy 3.6 max input voltage
  61. Createing Large Wall Project
  62. Pullup voltages with Teensy and Arduino on I2C circuit
  63. DMX to WS2811, multiple fixtures with minimal wire
  64. Options for 7" LCD screens for dashboard
  65. Power
  66. DFT using analog read in Teensy 3.2
  67. MIDI Foot Controller
  68. Best way to do electronic flute?
  69. Teensy RawHID Device with hidapi library from desktop host?
  70. Wireless sound/knock to USB HID spacebar signal.
  71. Teensy connected to Olimex Lime2
  72. remote update for teensy 3.2 with rebootor or alternate
  73. Memory tester (self test) (Teensy3.6)
  74. Ethernet Daisy Chain with Teensy 3.6
  75. Hiletgo 128x64 and Teensy LC
  76. Array Confusion
  77. Usb power Teensy 3.6 and small WS2812b strip
  78. Max 7219 pins on 3.6
  79. Serial's and Teensy 3.1 to Teensy 3.5
  80. Considering different strategies for supporting Audio, Touch sensing, motion, leds..
  81. Exact meaning of '5V tolerant' and abbillity to work with 5v LEDS
  82. Teensy Midi Controller Project Advice/Journal
  83. dSnake Adapter
  84. Store a midi keyboard value
  85. PT 8211 and teensy 3.2
  86. Phase shift measurement with Tennsy 3.6
  87. 7 segment LED display with Teensy 3.6
  88. Mesh network: Power + data on a single wire?
  89. POU Hot Water Source (beer brewing)
  90. Fastest digital/analog input sampling with T3.6
  91. Standalone Drum Machine with Teensy3.5 + Adafruit's MAX98357A I2S Amplifier
  92. Nextion 3.2" and Teensy 3.2 no communication
  93. MK20 (Teensy 3.2) Low Level Pin Capabilities Map
  94. running two macs with 2 teensy and Qlab
  95. Power loss through brass bolt terminal lugs, gut feeling?
  96. Trace Width for MK64FX512VMD12
  97. Teensy + Laser + Solar Panel = ?
  98. Excessive number pull-ups?
  99. Receive Pitch Bend data (Mackie HUI Protocol)
  100. How to Connect ITEAD 2.8 TFT to Teensy 3.6?
  101. Convert Foot Controller to USB MIDI
  102. Self Contained Sample Player using Teensy 3.6
  103. Sonar / Cakewalk Mackie SysEx
  104. Teensy 3.6 Question
  105. Spectrum display - 20 bands
  106. 2 ethernet ports
  107. Advice? Teensy 3.6, build an audio recording device that also does pitch shifiting
  108. MIDI over USB and 5pin using Altsoftserial Library
  109. CSAC + Teensy
  110. FSR pedal
  111. github.com/PaulStoffregen/Ethernet but Wireless?
  112. Radar Distance Mesurement, Start FFT directly from the ADC? Newbie ;)
  113. GUI that supports many TFT/GFX libraries
  114. Arduino (Teensy) controlled sound mixer
  115. Analog Mixer with motorized Faders
  116. Teensy 3.6 -> Feather Board Orientation
  117. PGA2310 2x1 Mixer Project
  118. Optoisolator Selection/Circuit Config
  119. How to add a pre-compiled library?
  120. USB device libary?
  121. Amplitude Modulation Effect Unit Project
  122. Teensy 3.6 audio board
  123. Prog Gain Amp Example
  124. Using USB Midi Control Change info to control a LEDs
  125. Mobile Phone Battery + Teensy 3.6?
  126. midi file library and sdfat library question
  127. Hard wiring Teensy 3.2 directly to the Raspberry Pi 3 via USB?
  128. Sending and Receiving with usbMIDI.read
  129. New Guy Here...First Micro Controller Project - Teensy LC Midi
  130. Teensy 3.6 not detected as serial port in Ubuntu
  131. Teensy 3.2 - keyboard press only working in the selected/active program
  132. Multi-universe DMX out from Teensy
  133. Teensy 3.6 & Hotel WiFi?
  134. A few questions about Piezo triggers
  135. Teensy 2.0 with DIN
  136. Help needed with making a pov display for a 3d music visualization development kit
  137. Audio Recorder to SD card
  138. Having trouble with HX8357_t3 library
  139. Optional/Switchable pull-up resistors for I2C driven by single GPIO
  140. Battery Monitor Question
  141. Help with Audio Board and wifi Atwin1500C
  142. need advice if feasible, distinguish sound input using max 4466 and elec mic.
  143. need advise on project aux audio in
  144. Need a small language or script interpreter to embed in Teensy
  145. Automatic lap tracking for a go cart
  146. Driving 9 IR Leds with Teensy LC
  147. Eurorack Teensy Power
  148. Portable audio output setup with GUI?
  149. The right approach of driving LCD's in time critical Applications.
  150. How to generate USB MIDI clock with Teensy 2.0
  151. Teensy 3.1 -> Ableton Push Display Interface
  152. Integrating Teensy - questions about PCB fab and open source
  153. USB Serial Checking and Speed
  154. Midi Foot Controller
  155. Fastest Analog Midi Input possible?
  156. ArtNet to WS2812 (directly via SPI)
  157. Teensyduino installation
  158. Let's Talk Pinball
  159. Microphone pre-processor for a Canon 7D
  160. Amateur Radio Repeater Monitoring System
  161. APA102 -- how many is too many
  162. Fastest port manipulation ?
  163. Help with encoders increase decrease value
  164. Cascading audio ducking using teensy?
  165. MAybe a dumb ? Steppers and serial print
  166. Okay, I have a question, I need to controll 6 servos for a costume wingpack
  167. Teensy++ 2.0 USB out via pins rather than port?
  168. MIDI lighting messages!
  169. Filter BLock
  170. LED display for outdoor usage
  171. Synchronised position measurement
  172. OctoWS2811 LED Lib and Audio Lib - Freq/Amplitude driving LED color and brightness
  173. Programming Teensy3.x attached to MIPS OpenWRT wireless router
  174. Teensy 3.2, Audio Shield, Octows2811 Adaptor, ~1000 leds.
  175. VUSB or External Power Supply?
  176. Power and Signal cable length in an LED project
  177. Sending signal through I2S on Teensy 3.2
  178. RGB LED CUBE with teensy
  179. Switch Inputs
  180. sub microsecond timing for GPS disciplined device
  181. need more information on sethandleStop, sethandleStart, setHandleContinue for usbMIDI
  182. Teensy Audio Board fried by external amp - recommended amp specs?
  183. Prop shield & WS2812b Fill_Gradient question
  184. 6v on Teensy3.2 & PropShield via x2 2032
  185. Teensy 3.6 led not glowing
  186. Rotating Torque Sensing
  187. Artnet node to SK9822
  188. OctoWS2811 moved to other pins to use as a simple buffer
  189. Question about PulsePosition for same pin I/O
  190. Teensy3.0 interface with ADC Code problem
  191. Do I really need a 5v signal for the Data pin on WS2812b's? (Teensy 3.2/Audio shield)
  192. "Absolute" positioning
  193. Control Position of Only a Section of Long LED Strip in Real-Time
  194. A Teensier Teensy (Final product board/Collab/Feedback welcome)
  195. Teensy Audio question
  196. PI hat skywriter help
  197. USB keyboard hardware proxy
  198. Yet another post about interrupts.
  199. high-res MIPI display
  200. Advanced Midi questions
  201. Make a program to upload images to a Teensy 3.2
  202. LED Sequence project
  203. Question from a noob about audio input
  204. Teensy and velodine lidar
  205. Surface-Mounting Teensy 3.2 to PCB
  206. Connecting one Teensy 3.x digital output to many IC's input
  207. Scanner sensor reading
  208. Midi Joystick Callibration
  209. Casio USB-MIDI to Class-Compliant USB-MIDI Converter
  210. A question about notefreq()
  211. optical mark reader that uses a Teensy 3.5
  212. frequency analysis
  213. General help on schematic and the terrifying routing stage.
  214. Pulse multiplication
  215. Ideas for keeping track of the state of individual switches within a matrix?
  216. CANBus protocol design
  217. Octows2811 adaptor and nrf24l01
  218. teensy 3.6 and lcd display
  219. Powering Teensy and other stuff together
  220. Which radio protocol?
  221. How many USB end points does it have?
  222. Interrupt controlled measurement of analogue values with TEENSY 3.6, FFT
  223. usb controller hid for windows with shuttle jog dial directional buttons pad and lcd
  224. Recommendations for external flash?
  225. Teensy 3.2 + OctoWS2811 + playing Quick Time Movie from SD Card
  226. Possible to run Teensyduino code directly on Arduino MEGA?
  227. Analog Output over HID
  228. Find my way in all midi covering threads and options
  229. Teensy project outline, need BOM recommendations/references for modules/shields
  230. I have a question
  231. Using Teensy 3.2 in a car
  232. Programming Teensy 3.6 through Host USB line
  233. Use teensy to create engine sound generator
  234. measuring Temperature LM35
  235. DSP block - Optimize FIR filters?
  236. How much current on LC and 3.6 for 3V3 ?
  237. Simplest accelerometer+magnetometer breakout?
  238. USB MIDI with Teensy
  239. Send string from PC to Teensy LC via RawHID
  240. teensy3.2 touchRead() readings range increases randomly up to ten times
  241. How can I support multiple keyboard layouts?
  242. PC-connected Teensy(s) for 30+ feet - connection, power, signal ?
  243. Using Teensy 3.6 to Drive Multiple Integrated Steppers
  244. 1st generation iPod Click Wheel repurposing
  245. custom shortcut keyboard for Photoshop
  246. MIDI DJ Controller using Teensy 3.6 - am I doing this right?
  247. How to wirelessly interconnect Teensy devices?
  248. BOM's are killing me
  249. I will pay for build of ...
  250. Read 16 pins with DMA on 3.5/3.6
