View Full Version : Project Guidance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15]
  1. suggestion for multiple 0.96" OLED (Radio/Nav panel)
  2. TSPISlave Library
  3. Mouse Movement from PS2 Trackpad
  4. Monome 512-esque button matrix with OctoWS2811
  5. Triage a possible short
  6. Live Setlist Midi Controller
  7. audio adapter audio lines
  8. Trouble with 2 SPI devices
  9. Helmet Visor with led screen suggestions
  10. Assistance with Teensy 3.6, WS2812B 144 LEDs/m Strips
  11. looking for a larger tft screen
  12. Very Fast Interval Timer
  13. Dual Joystick HID on Teensy ++ 2.0
  14. Total Novice wants to build atmospheric sensor
  15. FONA Feather to teensy 3.2?
  16. Teensey 3.6 + OctoWS2811 + 50+ WS2812b strips behind wall
  17. SD-card time/date sort
  18. Prevent anyone from reading your code on Teensy 3.6
  19. Generating serial line break for LIN-bus
  20. Teensy 3.2 BLE Connection
  21. MIDI over USB middleman (MIDI message sniffing)
  22. Teensy Midi Controller
  23. Packet Switched Networking
  24. Will Teensy 3.6 suffice for my project?
  25. Migrating from Mega 2560 to Teensy 3.6
  26. Can ADC running PDB be polled?
  27. Invert output Teensy 2.0
  28. USB Zapper Mouse
  29. Robot Controller board using Teensy 3.5/6
  30. HELP! Teensyduino Piezo Sensor Multi-Input
  31. ISA -> SPI adaptor
  32. Movie2Serial on Raspberry Pi (LED array)
  33. Timer Project
  34. Remote weather station, first hardware project
  35. Creating pulse 5us width
  36. Digitally enabled amp chips and switching jack
  37. USBHost_T36, hosting USB MIDI devices with virtual cables (ports)?
  38. Vienna Audio model 601
  39. Teensy Audio without audioshield
  40. Teensy 3.6 as a USB webcam host (to detect alpha particles)
  41. Teensy 3.5 5v output
  42. MIDI Sequencer / Sampler
  43. Teensy LC / XINPUT and Neopixel strips
  44. newbie don't want to fry it's Teensy 3.5 with SSR's
  45. Stategy for Programming a DIY foot controller
  46. Midi serial buffer
  47. while (midi.read())
  48. Is a Teensy a good choice for my USB midi project? Details inside.
  49. Changeable timer interrupt overflow
  50. Connecting two PCBs together
  51. SAE J1939 CAN to teensy 3.6
  52. conjunction of projects - OHMS LAW help?
  53. Customizing CRGB Colors using FastLED 3.1's OctoWS2811 Controller
  54. OLED display with Teensy 3.2 and Audio Board, pros/cons and maximizing input options
  55. reading pots to adjust delay or delayext
  56. Teensy 3.2 & Prop LC: Toy audio reconstruction
  57. How-to: Clean Custom USB Mode?
  58. 2.8" TFT touchscreen + Teensy++ 2.0
  59. remote disk using teensy 3.2?
  60. High speed two channel data/signal logger (to a hard drive?)
  61. Interrupt on Rising and Falling on the same pin
  62. 2019 Teensy 3.6 lcd/touch screen larger than ili9341
  63. Teensy 3.2 - Add 32.468 khz crystal for Real Time Clock
  64. Audio Recording to CF options
  65. Calling attachInterrupt() inside a C++ class
  66. real bass drum by midi
  67. A couple of questions to help me on my way
  68. Optimized ILI9341 TFT Library
  69. Midi, Windows, USB, Teensy and Synths
  70. Shield wiring between connector
  71. High Quality APA102 LED Strips?
  72. Teensy 8 Channel Audio Interface
  73. Remotely update firmware via ethernet
  74. Condor flight simulator interface
  75. high speed particle sorting using fluorescence
  76. short & long Teensy footprint / pin compatibility?
  77. A couple of questions
  78. Controlling Motor Controller via CAN Bus
  79. Microcontroller from scratch
  80. probably a simple I2C question
  81. SPI Slave
  82. Teensy 3.5 audio over nRF24 -- Is it possible?
  83. Trying to get "beyond" 16 steps. Compiler/Dynamic Memory question.
  84. SD Datalogging - Best Practice in 2019
  85. prevent RGB led from lighting up on boot up
  86. MIDI Faderbox fader choice
  87. Teensy 3.6 Triggered Signal Averaging and Buffered Acquisition
  88. Reading pots in Teensy 3.6 and midi
  89. IMU Based Head Tracker
  90. Teensy LC with relay board
  91. AC Mains Cycle Phase Control
  92. High humidity environment
  93. Xbox 360 Wireless Receiver
  94. Animated images on Teensy 3.5 & ILI9341
  95. Dmx triggered Video files on Teensy 3.6 SD card to output on addressable LED
  96. Need help for my first teensy project
  97. PinSim with Extras. PCB design OK?
  98. Looking for the Eagle/Kicad source files for ILI9341 "purple test board"
  99. Flexible Analog Signal Conditioning
  100. Software to put LED patterns on Teensy
  101. Teensy 3.6 installer + Arduino 1.8.8 + Mac OX = Error
  102. I2C between Teensy 3.6 slave and ARM master
  103. Serial and SoftSerial libraries and timeout marker?
  104. PAID help needed, please delete if this is inappropriate for this forum
  105. How to use Serial2 on Teensy 3.2
  106. Led step lamp
  107. Control Voltage and the Eurorack Ecosystem
  108. Communicating USB MIDI Board with teensy 3.6
  109. Custom teensy 3.6 not work
  110. Multi network and sensor automotive datalogging
  111. Issue with micros() in an ISR
  112. FastLED not turning on my Ws2812b Led Strip (using teensy 3.6)
  113. How are you all powering your led matrices?
  114. How to tell if TeensyStep controller is still moving, or has reached its setPoint?
  115. Advice on using SD card 3.5 teensy for bootup
  116. Logic level converter for teensy 3.6
  117. A Steering wheel, hall effect, and LEDs....please help me interrupt
  118. Teensy to teensy USB
  119. reading - writing two bitmap files to 3.5 teensy
  120. Teensy LC EEPROM Write Speed
  121. LED Strip Fuse Box with Teensy 3.5 & OctoWS2811 implation
  122. Trying to mix multiple audio files from an SD card via PWM(Audio Quality Upgrade?)
  123. driving a 3W LED (700mA approx 3.5V fc)
  124. Teensy 3.6 to try to hear osteoarthritis
  125. Measuring frequencies on two separate pins??
  126. FlexCAN for Teensy 3.5 for Car OBDII?
  127. A 30 year old 24-Channel Analog Mixer goes MIDI
  128. Teensy with a 5V step-up transformer?
  129. Noob question regarding buttons and wires
  130. I2C problem
  131. Creating 4 different frequencies while measuring 8 different duty cycles
  132. Using a Teensy to drive a video or slideshow LCD
  133. Teensy 3.6 with nRF24 like transceiver
  134. OTA Sketch Updates for Teensy
  135. Fastest way to read 12 analog channels
  136. Audio Out - amplifier for headphone and speakers?
  137. How to use Amplifier and Bandpass Filter in Teensey-3.6 + Arduino?
  138. Isolate teensy from switching power supply
  139. Coincidences Counter (two pulse sources)
  140. Need some simple guidance for a (hopefully) simple project.
  141. Problem with Encoder and Pushbutton Polling SSD1327 Screen and Countdowntimer
  142. Sgtl 5000 7-Band programmable EQ
  143. Schematics for Teensy for Autodesk Eagle
  144. Large Led Matrix (TLC5940)
  145. Need assistance with sound project
  146. Usb or not ?
  147. Mount pressure sensor on Teensy 3.6
  148. DMX control with teensy3.6 or External software (Max)
  149. Digital Delay Line
  150. Low Power with Teensey 3.6 + Arduino
  151. Elite Dangerous (and others) Button Box with state change
  152. Teensy 3.6 crystal accuracy and how to improve it
  153. Porting Ardunio-CNC Firmware to Teensy 3.5 - Advice on Pin Usage Requested
  154. An action when 2 buttons pressed - MIDI
  155. How to run PWM output for predefined number of pulses?
  156. How to control SMD-LED WS2812B (WS2811 Controller) with Teensy 3.6
  157. choosing FET for fuel gauge
  158. Accessing the Teensy 3.2 Compatators to create zero crossing interrupts
  159. Lights and sounds for prop setup
  160. very narrbandpass filter needed
  161. General guidance for audio project needed !
  162. Arm and Engage relays with 1 button
  163. Using Teensy Libraries without Arduino/Maximum USB performance
  164. Performing hardware reset
  165. teensy 3.5 help reqired
  166. Video data to a teensy 3.1 driving 256 7-segement displays
  167. TI PCM3168A Audio Control Object
  168. Simple guide to coding for OSC control via serial (from Teensy)?
  169. Audio Library and LED components question
  170. Audio Reactive LED Project: Part 2 Questions
  171. Can "OctoWS2811 LED Library" be used to drive RGBW Leds?
  172. Teensy LC: power converter question
  173. MIDI controller with pots, pushbuttons and LED
  174. Teensy for long term job
  175. Create a custom board with MK20DX256VLH7 but not recognize via USB
  176. Many SSD1306 OLEDs plus encoders and RGB LEDs
  177. OTA/ Remote programming of your Teensy Step by step tutorial (Win10 & Pi0W)
  178. Using Lantronix XPort with teensy
  179. Teensy Shield Template
  180. Eurorack teensy experimenter protoshield
  181. SD, SPI and Interrupts
  182. 9-bit UART with non-standard baud on a teensy 3.5?
  183. Hi I am new here - looking for a shield
  184. [Teensy 3.2] Converting binary array to ascii for Hardware Serial Transmission?
  185. Teensy 3.6 LED Pin
  186. Quadrotor Flight Controller controlled from laptop
  187. How to set T3.6 clock speed higher than 240?
  188. Can this fry my Teensy 3.2?
  189. Alternate arm boards that use teensy processor
  190. Success With FreqCount Above 10MHZ on Teensy 3.2
  191. Cable tester using touchRead() pins for other functions
  192. 32x12 Switch + LED Matrix : IC/Library Recs Appreciated
  193. Teensy 3.2 Analog / Digital Pins with Encoder
  194. Midi to PWM to control Solenoids
  195. Teesnsy Processor - who else uses it ?
  196. Getting Started - Again
  197. Amp build enquiry
  198. Can Teensys communicate with each other easily ?
  199. Issues with analogWriteResolution() and analogWriteFrequency() Teensy 3.6
  200. MIDI pot chatter / noise
  201. Quad I2S using 1 audio board, switching between synth/mic
  202. MPU9250 1khz sample to sd card teensy 3.6
  203. Hardware synchronization for different sensors with different output rates
  204. Is it possible to connect a 2 axis hall sensor from an old joystick to the teensy?
  205. 60x32 WS2812B Matrix advice.
  206. Using Teensy as a receiver and transmitter for keystrokes
  207. I2c pullup
  208. Best way to sleep for long periods
  209. 3 Phase Motor Driver and Fast Port Manipulation
  210. FlexCAN_T4 - FlexCAN for Teensy 4
  211. Protecting the inputs
  212. Audio Looping investigations
  213. Duplicating Arduino example code to work for 5 piezo mics
  214. Audio over IP/Ethernet
  215. High Speed counting using interrupts
  216. 16bit PWM output on Teensy 2.0
  217. teensy 3.2 nextion
  218. Connecting an external USB breakout board.
  219. Teensy/Arduino library documentation
  220. Alternativ PCB connectors...somehow
  221. OctoWS2811 VideoDisplay of screen buffer
  222. A question for smart people - Vibration sensor closes transistor for a period of time
  223. Emmc
  224. .jpg decoder code?
  225. Teensy 3.6 Eagle files?
  226. large volumes of serial data ?
  227. Commercial project with teensy system
  228. any idea about force computer to connect to internet !! ( isolated on lan )
  229. Controlling Vollong 5W White High Power LED
  230. Midi Controller - Teensy ++2.0 or Teensy 3.2?
  231. Duty cycle measurement via Teensy 3.6
