View Full Version : Project Guidance
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15
  1. USB MIDI and Audio
  2. Audio shield teensy 3.0 drum machine query
  3. Rotary encoder without interrupts
  4. USB HID delayed keyboard key toggler
  5. teensy 3 powering another teensy 3 + sensor
  6. Trying to write an event listener with Teensyduino 2.0
  7. 7-segement with rgb led strip
  8. How to: USB-to-USB keyboard/mouse filter?
  9. Teensy 3.1 & Glediator LED-Wall Sketch
  10. Usb Powered led strip
  11. Anyone know a good audio DAC breakout board?
  12. Ambilight with Teensy 2.0 / 3.0 / 3.1
  13. HDMI and teensy?
  14. Using dynamic serial number for USB with Teensy 2.0++
  15. Teensy 3.0 + Lipo 3.7V 850mAh is this adequate for my use?
  16. Modifying the Movie2Serial code for the BeagleBone Black
  17. Wife's 50th Birthday Present
  18. LCD Touch screen in addition to MIDI thru USB
  19. Teensy 3.1 DAC audio output
  20. Analog code
  21. Help with audio delay program
  22. Teensy 3.1 + SPI TFT LCD
  23. Trouble with Octows2811 and Adafruit NeoPixels
  24. phase correct PWM
  25. SPI Data in/out naming clarity
  26. Teensy 3.1 audio output advice
  27. Teensy 3.1 Pin info
  28. Sending data to Teensy
  29. How best to parse / format incoming stream of data
  30. Multiple Audio outputs
  31. audio record, processing and play with teensy 3.1
  32. MOSFET regulated thermoelectric cooling circuit -PCB
  33. Custom Joystick with Teensy 2.0 ++
  34. Sourcing LED strips.Where did you get yours?
  35. Pixel sampling in OCTOWS2811
  36. Pov project / Teensy - Beaglebone - ?
  37. MIDI Filter/Processor feasibility
  38. Colour TFT and Touch Screen Support
  39. Oscilloscope and Function Generator Using Teensy 3.1
  40. Astronomical code based Sunrise/Sunset simulator questions
  41. logic levels
  42. Can OctoWS2811 and Audio Adaptor Board work together?
  43. Teensy 3.1 PWM frequency?
  44. Teensy 3.0 / 3.1 - Using the touch inputs
  45. Teensy receiving serial data from PIC16F873 microcontroller - how to unpack?
  46. Audio board: reading an audio file while doing other things ?
  47. teensy 3.1 5V output?
  48. Sub second timing with RTC
  49. Problem with communication between Arduino UNO and Teensy 3.1 via I2C. Help requested
  50. on-chip temperature demo
  51. Teensy as a programmer
  52. Is XBee adaptor necessary?
  53. Teensy-based Ondes Martenot controller
  54. Teensy and USB Host for MIDI communication
  55. Affordable capacitive touch screen that can be powered from USB
  56. Teensy 3.1 - where's the detailed datasheet located?
  57. Audio on the Teensy 3.1
  58. Teensy to serialize Video-communication
  59. USB-MIDI to Digital Pin(HIGH) code
  60. TouchScreen and Teensy 3?
  61. CC3000 with Teensy3.1
  62. Quick Piece of Code Advice - Toggling keyboard commands
  63. VGA output
  64. Replace PCB of generic keyboard including different key layout?
  65. LED Helmet (Deadmau5 replica)
  66. From breadboard to PCB
  67. ac dimming via inMojo AC Dimmer Module Lite
  68. persistent data in flash?
  69. Requesting help - T3.1 MIDI controller schematic
  70. OctoWS2811 Help on Controlling Brightness
  71. Determining slow AI period with FFT in audiomaster ?
  72. Help for a project involving Teensy and Beaglebone
  73. Help Creating a Two Channel Complimentary Waveform Generator
  74. PID controller with Teensy 3.1
  75. acos asin atan2 for teensy 3.1
  76. Measuring a voltage of max 2,8v
  77. AltSoftSerial Project Help
  78. Is possible to reassign digital pins to analog? If not, how do I use the bottom pins?
  79. Teensy a la flash drive
  80. Teensey 3.0/MechWarrior Online Cockpit. Need help on pins.
  81. Custom midi Controller for Traktor 2
  82. Connecting Teensy Wirelessly to Arduino
  83. Teensy 3.1 + Freetronics 128x OLED Display - No Display
  84. Assembly coding for Teensy3.1
  85. Synchronizing data between python client and teensy
  86. How to dispay date and time on gameduino 2
  87. How to avoid noise when writing to the microSD?
  88. WS2811 project
  89. Teensy controlled LEGO train?
  90. Using OctoWS2811 with a single strand of LEDs
  91. Combined Joystick and serial com port.
  92. DIY Flight Stick
  93. External Power Newbie Lesson
  94. Can't compile SD card functionality (Teensy 3.1 / TeensyLoader 1.18 / Arduino 1.0.5 )
  95. Teensy 3.1, possible to mix OctoWS2811 and AudioAnalogInput?
  96. Teensy Quick Reference: Code Examples, Tips and Tricks
  97. [Teensy 3.1] Pinout Diagram - with example code for sensors / devices
  98. high-rez NTSC out on Teensy 3.1
  99. OCTOWS2811: clone signal pins
  100. New project - feasable?
  101. Motor controller with Teensy 3.1
  102. I2C Port Expander Shield - Teensy 3.1 Project guidance
  103. Custom board - MK20 micro not booting
  104. Peizo Microphone => Audio Adaptor/Teensy3.1 =>FTT to LED and Audio out to speaker.
  105. 36 by 32 led matrix
  106. Mosfet to influence resistance
  107. Usb Midi Control : leds / copper foil / pots
  108. OCTOWS2811 Moving Pin4 to Pin17 Possible?
  109. Low Rate Wireless sensors with Teensy3
  110. Looking for lightweight signal and slot classes
  111. Thermistor
  112. Teensy 3.0 battery powered + USB recharging? PCB schematic
  113. Oddities in Timing of SD Card writes
  114. USB-based network?
  115. About the optional 150 uF capacitor on the back side of Teensy 3.x
  116. FreqMeasure - Sampling time
  117. Dj scratching emulation (HID)
  118. Feasibility - OctoWS2811 very large (in both ways) LED display
  119. OctoWS2811 and CAN, simultaneously?
  120. Octows2811 Thesis Project
  121. Feasability and roadmap query
  122. Teensy Audio board and I2C query
  123. Motorized fader with teensy
  124. Teensy 3.1 trouble with Bluetooth and Android
  125. Teensy 3.1 Mouse works great... but not in game?
  126. ADC steps to maximize resolution/accuracy
  127. Advice on Using Cat6 with WS2811/12
  128. Cautionary tale: Idiot error with analog input
  129. Led strip background
  130. Multi Processor Project, best/fastest way to data share?
  131. networking options?
  132. Jumping to bootloader and got stuck...
  133. What is the difference between the 74HCT245 and sparkfun's logic level converter?
  134. Teensy and LED project
  135. Using an ADC + Teensy or a DPM with BCD output + Teensy
  136. polyphonic audio sampler
  137. Teensy flight sim/game/keyboard controller
  138. Scrolling Text Code Ideas
  139. Best / fastest method of communication between teensy 3.1 and Touch Designer?
  140. Problems with teensy 3.1 and WIZ550io
  141. UTFT Library with ILI9341, 2.2 Inch 240*320 SPI TFT LCD Display
  142. RF22 wireless library replaced with "RadioHead" lib. For RFM69,RFM22, Si4432 wireless
  143. Node-red on mac osx - Teensy 3.1 question?
  144. Interactive LED Table
  145. Charge Amplifier
  146. Need wifi for my teensy.
  147. Code for Joystick or Gamepad With Accelerometer?
  148. ADXL193 Accelerometer with Teensy 3.1
  149. Advice for large-scale LED installation
  150. Interfacing Teensy 3.x to TFT_320QVT LCD/Touchscreen/SD reader
  151. Weensy (That's a W not T where W is for Wifi)
  152. Teensy 3: how to know RAM usage
  153. Pre-programmed Mini54 Packaging?
  154. Connecting WS2801 to teensy
  155. Fast CRC library (uses the built-in crc-module in Teensy3)
  156. One Teensy to communicate to Ten Teensy's
  157. Audio Streaming on teensy 3.0/3.1
  158. multiple microphones with audio libraray
  159. Teensy to trig a vintage drum machine via a computer
  160. Help with LED Sign that pulls data from internet...
  161. Any alternative to 4067BE multiplexer?
  162. ws2811 single channel logic level converter ?
  163. Signal smoothing or simplification
  164. Oscilloscope advice
  165. CTCSS / DPL rapid tone detection. Method for accomplishing this?
  166. Q on altering boards.txt
  167. Trouble with Teensy 2.0 Joystick
  168. Teensy 3.1 & Programmable WS2812B RGB LED POV Staff - Newbie Questions
  169. Out of pins, shift registers sucků TO THE TEENSY++ 2.0!!!
  170. Register Addressing
  171. Multiple Teensy 3.1 + I2C + Octo2812B
  172. T3 hangs with SD & interrupts
  173. New project: digital mesh network walkie talkies
  174. Laptop keyboard to USB
  175. Is 3,840 led's too much for 1 teensy 3.1 using the OctoWS2811 library?
  176. Teensy + I2C + USB with 1000 Hz transfer loop
  177. new member
  178. Teensy Joystick connection numbering
  179. I quite don't understand grounding - Ws2801 led strip connected to ATX PSU
  180. C++ Question (Warning: pointers inside ;-)
  181. Error using OctoWS2812b for only 4 pins for Video display
  182. Project : LCD + Teensy + SDIO + RF breakboard module
  183. Teensy 3.1 based custom design?
  184. Analog signal issues with migration from Arduino UNO to Teesny 3.1. Help requested.
  185. Teensy 3.1 & Audio board as a soundcard for a RC Tank?
  186. Changes for driving WS2812b with teensy using only 4 pins
  187. Capacitive sliders
  188. Frequency Driven Oscillator -- Using True Audio Output?
  189. Adapter board RFM69W radio for Teensy 3- Also diagnostic software...
  190. Capturing 8 bit data on 10 mhz square wave
  191. Need more memory
  192. Teensy 3.1 : Questions regarding Analog Pins and a few other general questions
  193. Problem compiling with the Teensy 3.1
  194. teensy 3.1, Radar proximity/speed sensor readout
  195. Teensy3.1 & GLCD
  196. Teensy 3.1 uploading and USB interaction
  197. Teensy + kodenshi opto switch
  198. 14-bit MIDI over USB?
  199. Teensy 2 PCB Intergration
  200. Bluetooth Breakout PCB Design problem
  201. LCD purchase advice needed
  202. Teensy 3.1 with multiple loops
  203. Project Guidance: advice for >2.8" lcd with some library support & teensy 3.1?
  204. Using Octows2811 for RBBA (Amber) LED'S
  205. Mcp23017 and Tlc5940 pin conflict
  206. Wake from sleep mode using keypad interrupt
  207. 9- and 10-DoF LSM9DS0 shield for Teensy 3.1
  208. I'm testing capacitive sensors and need some advice
  209. A few doubts about PCB layout and first project
  210. Teensy 3.1 digital input voltage limit?
  211. Another 3.3V power supply + USB thread
  212. Porting Interrupts
  213. Keyboard inputs
  214. A cubic array of LEDs; to Octo or not; and other Q's wrt architecture and programming
  215. Connecting teensy 2.0 with Sparkfun's USB Host Shield
  216. OctoWS2811 Adaptor + Audio Adaptor Board
  217. Would it be possible to Pixel Map the Video to the OctoWS2811 library via OSC ?
  218. Offloading data from a SD data logger?
  219. Modular keyboard idea
  220. Wrt using teensy31, octows2811 with switches, dials etc
  221. Fastest DAC speed possible for Teensy 3.1 using Arduino?
  222. pixel strips for POV with 30-40 leds?
  223. Help with Teensy2 Layered Keyboard Firmware, Esp the Scanning and Press Sending Parts
  224. Need help for i2s use (pin assignment issue)
  225. Planning Video to Teensy+ push buttons
  226. motorized faders via midi usb
  227. 32x32 RGB LED Cube Technical Questions
  228. NeoPixel Project Help
  229. Converting a library from arduino. SDM-IO (some timer issue)
  230. A Teensy 3.1, an Xbee, and NTP to sync the RTC
  231. Power considerations for connect two Teensy boards via SPI?
  232. Teensy or Arduino?
  233. Serial+joystick+keyboard+mouse Teensy 3.1 W7
  234. AltSoftSerial interference with Duemilanove PWM?
  235. Neural Network Example - ArduinoANN
  236. A little guidance with global interrupts.
  237. Guidance on detecting external pulses, digital input voltages and comparators
  238. Trouble by programming (attachinterrupt inside lib and defines)
  239. Using a different MCU with the Teensyduino stuff
  240. quick question: Teensyduino/OctoWS2811 and Cat 6; What's the max recomended length
  241. teensy and arduino pro mini i2c
  242. TeensyDuino - support with any Teensy or only Teensy 2.x?
  243. sample rates + Audio range waveforms from Teensy 3.1 DAC
  244. Large portable led display project, and a question about power / cable connectors!
  245. RFM69 tranceiver with Wiznet 820io Ethernet and Teensy 3.1
  246. Creating USB Descripter, parsing offsets for bytes?
  247. Question re: Effective Number of Bits vs. the resolution of an ADC
  248. USB Keyboard (and mouse?) switch
  249. Are there examples for using Teensy 3.1 as a USB Host?
  250. USB MIDI - how does serial monitor in PrintIncoming work?
