View Full Version : Project Guidance
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15
  1. Midi polyphonic synth help with code or new approach
  2. Would it be possible to (ab)use I2S to control LED drivers?
  3. Teensy 3.1 and I2c pins 16 & 17
  4. External clock into a timer on T3.2
  5. A few questions before buying the Teensy Audio Adaptor Board/Shield
  6. in field upgrade of code
  7. Teensy as a keyboard
  8. Teensy 2.0 using Potentiometer strip and Joystick for zoom/pan in Photoshop
  9. guidance needed for: basic stereo audio input and output, no processing.
  10. Half of the OctoWS2811 + pin changes
  11. Power load cell high and Teensy for high precission
  12. DIY membrane switches?
  13. Powering Teensy 3.1 off of a 11.1V (3S) LiPo
  14. Teensy 3.2 Libaries Compatibility?
  15. Teensy 3.2 with six 2.2 inch tft displays
  16. Dreaming of racing pedals, potentiometers + optional loadcell
  17. Static Electric Keyboard
  18. Gyrocopter Project Concept
  19. Project help needed
  20. Differential digital signals to singel ended - advice on which part to use
  21. Accurate light pulse measurement, etc device for measuring plant health
  22. Wireless MIDI controller - Aid
  23. can i get this old 7" TFT LCD to work with T3.2 ?
  24. Audio File player
  25. My First PCB Design - Questions
  26. Can the Teensy board do this before I go buy it?
  27. atmel 45DB081D how to read it
  28. General Termination Resistance Question
  29. Feasability of using Teensy 3.1 for a telescope autoguider (processing small images)
  30. Bus + External AVR chips vs. local port expanders + longwires
  31. Teensy for mixed signal MIDI controller
  32. Teensy 3.2 , pins A0 to A9 , ( D13 to D23 ) , 5v compatability
  33. Fried two 2.0's - I think I know why - Sanity Check appreciated
  34. Using an I2S microphone with Audio library and no audio shield... Wiring help
  35. Experiences with encryption on Teensy
  36. Teensy, sensors, actuators & display
  37. Teensy + AT45DB061D or similar
  38. Programming Teensy 3.1 from RPI or Edison
  39. Teensy - octo2811 - Falcon Player 1.6 (Now has generic serial controller option!!!)
  40. LED Matrix Grounding
  41. High Powered LED matrix controller
  42. Teensy 3.1 External 3.3v power
  43. Generate (n*8) MHz clock signal on Teensy 3.1
  44. Advice Needed : Teensy 3.1 / 3.2 Spectrum Analyser with 960 APA102 LED's
  45. More efficient way to make pins low??
  46. Teensy 3.1/3.2 True Analog Out question
  47. Noob Artnet vs. USB question
  48. Tone function question/help
  49. Active frequency modifier
  50. Octows2811 code help.
  51. replacement for usb_configured() on Teensy?
  52. optical disdrometer project feasibility
  53. Teensy 3.2 , pin interupts
  54. Teensy 3.1 or Teensy LC in a product
  55. find the magnitude of A - B
  56. 10`x 6` LED matrix 96x56 Resolution
  57. USB host detection
  58. Teensy as USB HID keyboard
  59. 3.2" SPI ILI9325 TFT Touch Screen Compatible Library
  60. Newbie questions
  61. OpenEffectsProject
  62. Blink inflates when combining Teensy-LC and uTasker serialbootloader
  63. Teensy 3.2 Lightsaber
  64. Teensy 3.2 & Lepton FLIR 80*60
  65. Current Measurement robust against massive overcurrent
  66. Feasibility: Modular LED project
  67. ILI9341_t3 touch screen menu library
  68. Can anyone help me on how to read DSMX - PPM Signals on the teensy?
  69. Teensy 3.2 & OpenCv
  70. Speakers for Teensy 3.1 + Audio Board (v1)
  71. PWM - RC Receiver
  72. Teensy 3.2 and Audio board integration schematic verification help needed
  73. ESD protection for Teensy++ inputs
  74. USB Joystick HID descriptor
  75. Geeting time from a dcf77 module
  76. Help and suggestions on bring life to an old piano
  77. Model citizen SPI device library - HOW?
  78. Static Electric Keyboard
  79. Switching 7.4V 3A LED Driver
  80. Switched LED display
  81. DAC resolution - Audio board - Teensy breakout board
  82. SPI slave to a mega2560
  83. Flextimer - Varying MODULUS value when using output compare toggle
  84. teensy and puredata. Too much bangs
  85. Sourcing JST-PH connectors
  86. native application loading?
  87. OctoWS2811 - red is green!
  88. Ultimate GPS -> Teesny3.1 -> wifi broadcast
  89. chip won't power on unless I wait since last power-on
  90. ILI9341 TFT how to save power with no touch for 30 seconds?
  91. Serial Help: Hardware or Code my Problem?
  92. Accessing stored data on Teensy as Joystick
  93. Teensey 2.0 joystick matrix
  94. ILI9341 display SD Card as datalogger??
  95. Whats the best equipment for this project?
  96. LPD8806 and teensy 2.0
  97. Detect flashlight on/off
  98. Displaying outgoing usbMIDI info onboard
  99. Teensy 3.1 - SPI - Master Tx - Slave Rx
  100. Teensy 3.2 , USB B connector
  101. Teensey 2 timers
  102. Sending 8 clock outputs at different variable speeds ?
  103. USB to UART alternatives
  104. Minimum question
  105. Options for Mounting Teensy 3.2 to PCB
  106. Using Android as the USB console
  107. Big red button usb for photo booth
  108. OctoWS2811 Teensy LED matrix project
  109. external USB?
  110. Wii nunchuk/Classic controller
  111. OSCuino & Wiz820io beginner.
  112. .ino file to .cpp file
  113. DMX512 Transmit and Receive?
  114. Android controller power consumption question
  115. Couple of Quick Hardware Questions
  116. Kind of Force Sensor Array
  117. Weird noise audio shield
  118. Wiring best practice -photos please
  119. Correct wiring for W5500 on Teensy 3.1?
  120. Drum Module Help
  121. Kallax Video Wall
  122. Teensy 3.2 as a WiFi webserver
  123. Teensy 2.0 - custom USB types?
  124. Why my pov is so ugly?
  125. Teensy 2.0 button input
  126. Custom joystick problems and help needed
  127. PWM and RGB question
  128. Teensy LC Ambient light - newbie questions
  129. Custom Teensy power on
  130. audio, servos, leds and sequencing
  131. Possible to show video on cheap RGB Matrix Display
  132. Prop halo Assault Rifle with shot counter and various sound effects.
  133. Teensy 3.2 as USB Host (for USB-MIDI keyboard input/ctrl)
  134. Teensy 3.1 + Bluefruit LE SPI friend
  135. Need help programming 16 switch digital arcade stick
  136. Teensy 3 + Storage + NFC/RFID
  137. Connecting a microphone.
  138. custom Teensy 3.2 with processor upgrade
  139. Teensy 3 + Audio Board + SPI Flash?
  140. Joystick Libraries
  141. SD Card direct connection
  142. AccelStepper Question
  143. Oscilloscope Help - what to use/buy
  144. Reading rate of clock input
  145. Teensy Software Defined Radio Receiver
  146. OctoWs2811 to 4 x Ws2812b strips / beginner LED programing on different strips
  147. Code for joystick. help needed
  148. Simplest possible way to read load cell on teensy
  149. Audio Adaptor Board benefits?
  150. How to synchronize a gaggle of RS485 clients....
  151. Teensy ++2 and 3.2 with audio as master slave
  152. ISR 'bug' in stirplate design.
  153. Routing USB data traces on custom teensy board
  154. APDS-9960 with teensy
  155. Output time data to LED matrix
  156. Reflected IR Proximity Switch
  157. Any touch screens available without pins pre-installed?
  158. Custom teensy for POV, stage: schematics
  159. Farming Simulator Controller
  160. Using multiple analog inputs with an ADC
  161. WIZ820io & Micro SD Card Adaptor connections
  162. teensy 3.2, OctoWs2811, Ws2812b strips doesn't twinkle
  163. any cost reduction ideas?
  164. Teensyboy not working... 3.2 problem?
  165. help! pt100 + teensy 3.2 + ?
  166. Visualize frequency responses with the serial plotter of the Arduino IDE
  167. Flight sim Controls - Elevator/Aileron/Rudder Trim and other various controls
  168. Question re: crystals...
  169. What to do with Telephony codecs? S44232 IC
  170. 3.2++ x - ?
  171. Audio Library; Timing of Commands
  172. Need some guidance/advice on building an RC transmitter firmware.
  173. Teensy 3.x as multi-touch
  174. Attach Class-D via I2S
  175. Analog to Digital Conversion?
  176. Connect Teensy to Windows CE via USB serial
  177. Hex to Binary to SPI
  178. All things - Low Power
  179. Large led display - noob questions.
  180. Best Practice soldering for Teeny 3.X plus Audio Shield and Breadboard
  181. Mounting of ILI9341 TFT to complete project??
  182. FreqMeasure Wiring
  183. Would it be possible to set Board, USB type, etc within sketch?
  184. monitoring the status of another system
  185. Teensy LC DAC
  186. Hid: Feature report
  187. Boost/buck regulator with or without Teensy 3.2 linear regulator
  188. A place to upload & cut custom designed plastic project boxes?
  189. Resistors for OE and DIR on 74HC245, plus a couple other noob questions
  190. My own bootloader
  191. MCU for a 3 axis DC Servo that uses quadrature encoders for feedbac?
  192. Two teensy 3.1 with CANBUS
  193. True simultaneous dual ADC sampling on Teensy 3.1/3.2 and some DAC work (semi-noob)
  194. Can I use the reuse bootloader's pins for UART0?
  195. Teensy 3 pins available when using OctoWS2811 Adapter
  196. SSD1306 questions
  197. Teensy 3.1/3.2: PWM Input (digital interrupts)
  198. Fandecandy with RGB-123 fandecandy-breakout-board > 8 x Ws2812b strips of 64 LED each
  199. Organ to midi conversion
  200. Two-wheeled balancing robot
  201. Network audio with audio adaptor ?
  202. Connecting 10+ teensys to read 140+ sensors
  203. Teensy USB Host/Slave?
  204. DIY Teensy reference board
  205. Wireless Voice Communication System with NLMS Based Acoustic Echo Cancelation
  206. Using second ADC_1 to cancel noise in ADC_0 measurements
  207. Opto Isolated Mosfet Driver Board
  208. Midi foot controller with Banks (code)
  209. Glediator/Jinx with Teensy 3.2 and WS2812b
  210. Teensy 3.2 and Nextion 7" Display
  211. Send mouse event data over the internet to a Raspberry Pi controlled TEENSY.
  212. teensy wifi artnet lights
  213. Teensy 3.2 Stepper Driver Passthrough
  214. Reading battery data from SMBus/i2c
  215. Teensy++ 2.0 Arcade Button Midi Controller - How many buttons?
  216. Using individual push buttons to control individual LEDs on a ws2811 strip
  217. Can't get fonts to work with tft screen
  218. Question on Teensy USB Design
  219. Quick and easy wireless Teensy controller
  220. Teensy 3.1 analog sticks to generate keyboard input
  221. S25FL127S SPI Flash Datalogger
  222. Custom 2.0 Board Not Recognized as USB Device
  223. USB Midi Type send Keyboard Commands
  224. Teensy 3.1 Mouse horizontal scroll
  225. Frequency detector in audible sound freq range. Teensy vs Arduino
  226. Messages between two Teensy 3.1 over XBee: should I go MIDI or not?
  227. Darkness/Light Detection
  228. connecting a battery to Teensy 3.1
  229. One Thumb Keyboard
  230. Surface Mount Component Sizes?
  231. I need help with Teensy 2++ and LED driver programing
  232. Increase "bcdDevice" Revision Number
  233. DMA-based stepper library ?
  234. Teensy with LED driver - switching between modes
  235. Teensy++ 2.0 Midi Controller - Issues with triggering notes in Ableton
  236. Z-Wave
  237. Gameport Yoke & Pedals USB Conversion
  238. Connecting multiple things at once
  239. Teensy to read SDR radio dongle? Is this possible?
  240. Proper way to load a power supply
  241. USB Joystick Rumble/Force Feedback on Teensy 3.1
  242. Ultrasonic Range Finder Project
  243. Switch between two USB sources without direct access to teensy; best way to...?
  244. Midi Foot controller project help
  245. System / VBAT register files
  246. DAW Control Surface, MIDI, HUI, Logic Pro & Teensy.. sugegstions needed.
  247. Read analog inputs in a matrix with multiplexer 4051
  248. I2C nightmare (Teensy 3 + MCP23017 + SSD1306 + tca9548)
  249. Automate old milling machine
  250. OneWire & DS2401 IC as addressable daisy chained input
