View Full Version : Project Guidance
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13
  1. Welcome
  2. USB MIDI on Teensy 3; midi debugging
  3. T3Bot
  4. JTag on Teensy
  5. Teensy 3.0 and interrupts
  6. Teensy Debugging
  7. External power on Teensy 3
  8. How to create variable length output pulses without blocking?
  9. Touch sensing: sliders, rotary, etc
  10. Suggested Development Tools for Mac
  11. Suggested C Development Environment for Teensy 3.0 (Windows or Linux)
  12. Teensyduino 1.10 and Teensy3 "beta7"
  13. MCU for a 3 axis DC Servo that uses quadrature encoders for feedbac?
  14. touch sensor pins not all created equal
  15. Need help with Teensy3 + uSD + WS2801 LED strips SPI problem
  16. Timer Input Capture
  17. Teensy Pilot?
  18. USB Serial data integrity
  19. embedXcode: Teensy 3.0 on Xcode
  20. Real newbie questions
  21. Teensy XBee Shield
  22. How do I use the Parallax Serial LCD with Teensy 3
  23. Teensy 3.0 to Arduino R3 breakout board
  24. Video Compression
  25. T3 BaseBoard - organized modular connection system for the Teensy 3.
  26. Reassigning a pin (SPI SCK)
  27. nordic radio + tlc5940 + t2/t3 = possible?
  28. PWM Frequency (was: TimerOne on Teensy 3)
  29. ChibiOS/RTand FreeRTOS for Teensy 3.0
  30. A couple of questions before I buy my first Teensy.
  31. GY-26 Conmpass
  32. Using Differential ADC atmega32U or at90usb1286 (Teensy or Teensy++) w/Thermocouple
  33. Opto-isolator for the Teensy 3.0
  34. Teensy 3 and c string functions
  35. Firmware loader for Teensy 3
  36. Newbie: Question about the "Teensy Loader"
  37. Mini T3 BaseBoard for the Teensy 3
  38. Teensy 3.0 and audio
  39. Differential ADC and power supply options
  40. Teensy 3.0 - How many USB end points does it have?
  41. USB-MIDI and MIDI interface
  42. Computer-to-computer over USB Keyboard feasibility
  43. Has anybody used a WTV020-SD-16 (sound chip) with the Teensy 3.0?
  44. Wireless USB keyboard on a Teensy?
  45. JTAG debugging on a Teensy2.0
  46. Porting Marlin Reprap
  47. Motion tracking using Teensy 3.0
  48. Teensy loader for Raspberry Pi?
  49. Ethernet for Teensy3
  50. Teensy breakout board / shield style adapter?
  51. IR Blaster difficulty?
  52. Possible to read SD card data on the computer through the teensy 3.0?
  53. Java libraries needed for setting up HID dev
  54. AES Encryption for Teensy 3.0
  55. multi task cooperative scheduler for Teensy2 & 3 similar to java Thread with timer
  56. New version of ChibiOS/RT with coop scheduling example
  57. JTAG with (not of) Teensy
  58. New version of FreeRTOS for Teensy 3.0, Due, and AVR boards
  59. LED Bar Graph sketch conversion to the Teensy 3. Any bit bangers out there?
  60. Teensy 3.0 - Internal voltage regulator, 18650 batteries
  61. Trying to use the PS2X library
  62. Teensy 3.0 Re-program wirelessly
  63. Fan speed controller
  64. USB Host Status?
  65. ADC Guidance
  66. LIN bus monitoring
  67. Margin of Victory camera
  68. Any chance to get 500mA from USB?
  69. LPD 8806 and TEENSY ????
  70. Could a newbie get some sample code?
  71. External Reference voltage maximum? (How to sample 0 - 10V)
  72. How do I get the Adafruit 8-channel bi-dierctional logic level converter to work
  73. Capacitive touch on a handheld device?
  74. Read wii nunchuck on teensy 3.0
  75. WS2811 on Teensy 3.0 using FastSPI_LED library
  76. Teensy 3.0 as a fan controller/serial device/computer light controller!
  77. Big Numbers and how to print them
  78. Teensy3 I2S with DMA
  79. Feasible to drive Adafruit Neopixel LED strip?
  80. Counter issues
  81. Power Supply and other questions for Teensy 3, Motor, LCD, and Ethernet
  82. BIOS Attack with Teensy
  83. Thinking of getting Teensy3 for my project
  84. Emulate Serial protocol with 0.200 us bit width
  85. looking for ideas on generating RGB colors from accelerometer + gyroscope
  86. Using L298 Board to drive a dc motor
  87. 2.8" TFT touchscreen + Teensy 3.0
  88. Serial (RS-232) command interpreter project
  89. Advice needed - MIDI controlled LED bar/ VU meter
  90. Minimal Signal Processing
  91. UART receive interrupt
  92. GY-80 IMU with 3axis Gyro, 3 axis Accel, 3 Axis Compass & Barometer
  93. May be pushing it too far. Using the Teensy as a HDMI, touch to usb converter?
  94. Helping hand for a friend in a band. Anyone? Foot Switch Midi Controller
  95. Looking for ways to upload bitmaps to SD via Teensy 3 and over bluetooth
  96. Using a pin interrupt to activate listening over Serial.
  97. Teensy 3 power supply voltage when running 24/7
  98. Adafruit 1.8'' screen with Teensy 3
  99. Reading/Writing from/to motherboard EEPROM chip... is it possible?
  100. Using an led strip (MOSI, SCK) and an sd card reader - Teensy 3
  101. Remote update for Teens 2.0++
  102. Teensy 3.0 driving 9-DOF accelerometer?
  103. Teensy 3.0 -> Small-Scale Production
  104. Seeking advice/wisdom - new to the teensy world
  105. Noob questions
  106. Teensy 2.0 PWM frequency
  107. What to do with unconnected pins?
  108. external USB connector on Teensy 3?
  109. Teensy 3.0 - driving an SSD1289 with utft
  110. 5V step up converter needed for driving Teensy + WS2811
  111. The Hula Hoop From Hell
  112. small ethernet module + teensy 3
  113. Ethernet Bootloader for Teensy?
  114. Need pointers in converting a program from mbed to teensy 3
  115. Newb type question - Reading voltage coming in.
  116. Storing Wacom USB Data for later
  117. Help with an Arduino Library
  118. Questions about USB CDC and SPI
  119. Dual Teensy Keyboards help....
  120. Does Teensy have a processor ID?
  121. Update program on Teensy using serial. Is this possible?
  122. Multiple virtual MIDI ports over USB with Teensy 2.0? (Or 3.0?)
  123. Maximum Power draw for Teensy++ 2.0
  124. Teensy 2.0 ++ or 3.0
  125. YEI 3-Space Embedded over Bluetooth
  126. Choosing and creating simple checksums
  127. Has anyone used the sparkful LiPO fuel gauge with the Teensy 3.0?
  128. How can I use lpd8806.h and FastSPI_LED.h without interfering?
  129. confused again. Cutting VIN from VUSB - Teensy 3.0
  130. Joystick emulation with mouse
  131. Battery guidance
  132. parts for mouse and joystick
  133. Smallest available power supplies?
  134. ws2811 schematic
  135. Encoder Simulator
  136. Soldering LED strips back together
  137. VT100 multiplexing
  138. MIDI synthesizer with Teensy 3.0
  139. Multi-Voltage ADC Nuttiness.
  140. Help with PWM signal
  141. How to drive a F/A-18D Replica Up-Front Control (UFC) Panel?
  142. LPD8806 code on TEENSY 2.0++
  143. USB Hid, Transferring bigger reports than 64 bytes ?
  144. xinput for joystick
  145. vKeyboard
  146. How to enable/disable Bluetooth module using digital pin
  147. How to break code and variable declarations into manageable chunks
  148. Communication between Teensy2.0++ and Arduino Uno
  149. touchRead values going backwards?
  150. xbee pro series 1 on teensy 3
  151. NES Four Score to USB
  152. CAR Systems control with TEENSY (ROOPOD)
  153. File transfer messaging
  154. How to make a simple button for Dummy's??HELP
  155. Writing to Mini54 from teensy 3?
  156. Long Integer to ASCII Numbers Conversion
  157. RS485 half duplex for Dynamixel AX12
  158. Ardunio Serial Installer versus Windows Driver Installer for C Serial
  159. huge midi controller, I2c expansion question
  160. Teensy++ 2.0 low power wake up on external interrupt
  161. Teensy 3 Upgrade
  162. Button State controlling other functions of buttons
  163. PixelController >> Teensy 2 << WS2811
  164. Teensy 3.0 with LED array
  165. Wanted ... very easy to use RTOS + Pwr. Management + Teensyduino code compatible.
  166. Control AC Mains voltages
  167. syphon to octows2811 (via movie2serial)
  168. Running the code the first time teensy is connected to a new computer
  169. Simple USB joystick
  170. Importing Arduino Code?
  171. Speeding up ADC to <5us per conversion
  172. DIY capacitive keypad
  173. Precise low-speed brushless DC motor control
  174. Teensy 3.0 Clock Pins and setup
  175. Teensy3 - fast multichannel adc
  176. Problem with movie2serial example octows2811 library
  177. Zombie Detector
  178. K-line (iso 9141) interface using mc33290d
  179. Remote programming of Teensy 2.0 via XBee. Best method?
  180. Using a 4051 to read buttonstates
  181. WS2811. Roller coaster fuse effect needs high travel speed of led pixels. 8ft/s
  182. Teensy 3.0 + WS2801
  183. Threading in Teensy3
  184. Flash Memory in Teensy 3.0
  185. Adding Midi to a 32 note Pedalboard via Teensy?
  186. Teensy 3.0 LiPo Battery Connector
  187. Can Teensy do this? Ps2, USB , HID
  188. Industrial Pressure Transmitter Wiring
  189. Can I use the RawHID example in a Teensy 2.0++ arduino sketch?
  190. Teensy 3 Temperature Calculation
  191. Touch-based Row/Column Matrix
  192. MIDIJammer - Sonome MIDI Keyboard Controller
  193. Analog Thumb Joysticks Teensy
  194. Teensy Game Controller
  195. Can we run multiple SPI devices on a Teensy++ 2.0?
  196. Teensy 3.0 attaching micro SD adapter
  197. Teensy 3 CRC
  198. Teensy2 simple usb_disk code sample (teensyduino or not)
  199. Teensy 3.0 Backup battery
  200. Teensy2/XBee
  201. OctoWS2811 and scrolling text
  202. Advice on Teensy audio input voltage
  203. Using teensy to interpret guitar pickup signal as smooth data curve
  204. Teensy 2.0++, using UART and USB simultaneously
  205. Teensy 3.0 FreqCounter
  206. Teensy 3.0 OctoWS2811 with Raspberry Pi or Beaglebone or ?!?
  207. Pressure reading device guidance
  208. SDI-12 - anyone worked with Teensy3 and SDI-12 sensors?
  209. teensy 3 external power
  210. OctoWS2811: Grouping pixel modules to create 'super pixels'
  211. Bluetooth transceiver suggestions?
  212. digital I/O hypothetical
  213. SPI TLC5940 AND SD Card at same time.
  214. (n00b) Switch ports on KVM
  215. Teensy 3.0 DSP libraries?
  216. quadratic encoder - force feedback?
  217. Transistor recommendation
  218. WS2811 v12
  219. Delayed switch circuit
  220. Buying resistive strips
  221. OctoWS2811 POV
  222. Building a virtual gaming system
  223. OctoWS2811 Processing Problem
  224. IR/alternate pin musings
  225. Teensy 3.0, Problem with ST7565R display
  226. AC motor speed control with Teensy
  227. Playstation 2 HubDrive construct.
  228. Teensy2.0 and two quad encoders?
  229. Hal-effect velocimeter probe and teensy ++ 2.0
  230. Push button with led , midi-usb
  231. Project brief feedback - volumetric music visualizer
  232. first small scale test of our 160x80 [Video] wall
  233. Auto-Text Entry - skip a line from reading a file?
  234. breakout/shield for prototyping/testing: feedback please?
  235. 28BYJ-48 stepper motor works
  236. Controlling multiple Teensy3s from one PC
  237. Wireless (remote) programming of Teensy 3.0?
  238. fixed point math library
  239. Variable Length Array
  240. Teensy++ 2.0 with SD adaptor and WIZ812 adaptor together
  241. Trying to use WT5001M02-28P
  242. Cable recommendation for WS2811 LEDs?
  243. USB Serial and Interrupt Latency
  244. More efficient going from 3.3V to 5V or going from 6.6V to 5v?
  245. Speeding up raw HID communication
  246. Right way to step a stepper
  247. OctoWs2811 Video with software other than proccessing
  248. 3D pov display Full Design
  249. MIDI HID combo
  250. MakerFaire BeagleBone to Teensy protocol
