View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Ws2812 in series
  2. Noob can't even get out of the gate
  3. Ty3.1 + SD Card Info...
  4. MAX6675 and Teensy3.1
  5. nanosecond precision
  6. Teensy 3.1 running ... CP/M!!!
  7. Teensy 3.1
  8. MINI54 and MK20DX256VLH7 use on other Teensyduino type projects?
  9. Problem with ElecFreaks TFT01-2.2SPI
  10. Easy WiFi Can not Run Examples
  11. Prototype not enumerating com port in IDE
  12. Teensy 3.1, autorun on multiple platforms.
  13. Compile Fail - Just updated IDE
  14. Logic Levels
  15. Can't Access SD Card with Teensy 3.1 and Audio-Shield
  16. Teensy 3.1 / How To Increase Buffer Size For Serial1?
  17. SoftPWM not compiling - Teensy 3.1 & Arduino
  18. Does PJRC ili9341 display work with 3.3v?
  19. Detecting a reset of the USB bus
  20. analog pin smoothing function gives strange results
  21. SI5351 DDS and Teensy 3.1 compile problem
  22. Joystick calibration in windows 7 issues
  23. Overclocking also for Teensy 3.0
  24. RawHID and seremo outside Arduino
  25. SD FAT & GPS / Checksum Errors
  26. Request for Stand-alone drivers
  27. Applying equalizer to boost bass using Audio library?
  28. Do additional 5V harm the Teensy?
  29. Teensy 3.1 A14 to A17 noisy input
  30. Teensy 3.1 Trying To Generate 1MHz PWM Output
  31. Teensy 3.1 disable branch prediction, disable system interrupts
  32. GCC optimization level
  33. User friendly way to modify code with out arduino IDE - Is this possible?
  34. Timer1.attachInterrupt(); "invalid use of a void exspression"
  35. Teensy 3.1 GPIO interrupts
  36. ili9341 code seems to stop access to Serial1 (pin 0,1)
  37. SPI and Digole Display Clock divider problems.
  38. Is there a way to communicate with 125kBaud / 250kBaud serial with Teensy 3.1
  39. Measuring length of WAV file not correct
  40. Teensy 3.1: Discrepancy between pin assignments and schematics (strange connections)
  41. Teensy 3.1 and I2C
  42. ILI9341 Flicker
  43. possible dead Teensy 3.1
  44. Help needed with USB button project please
  45. Possible conflicts between Servo library and SPI library?
  46. Does Teensy have enough internal clocks for Audio Shield + Real Time Clock?
  47. sdFat + Audio Shield
  48. Teensy 3.1 - getting started
  49. Teensy 3.1 and "5V tolerance"
  50. TEENSY 3.1 RX & TX for MIDI Circuit
  51. Teensy to Teensy Serial Communications...
  52. Is there a bug in my assemblercode ?
  53. Using functions itoa, and dtostrf
  54. Can't compile most Audio library examples
  55. Teensy 2: Can I plug 12v into the +5v pin?
  56. Starting out - teensy joystick sample code and HAT switches
  57. Teensy SPI Slave CS
  58. Can RTC oscillator switched off?
  59. Arduino IDE 1.0.5 r2 (windows) serial monitor problem
  60. Teensy 3.1 seems very hot, pulling 140mA, while another one is only 40mA
  61. Ask for new Audio Sampler Advise
  62. X Plane Data Refs
  63. Errors when trying to compile Teensyduino octows2811 code
  64. Teensy 3.1 Pulse sensor port
  65. OSX pop-up when starting Arduino
  66. Using External AREF with ADC
  67. Teensyduino Installer source
  68. PCB & Teensy - Behavior of Teensy with short circuit
  69. Solution to keeping Teensy 3.1 Serial connection open (reconnect) after a reboot
  70. Teensy 3.1, Servos and PWM
  71. Multi-PWM-Output Object for Audio Library?
  72. High Speed Timer - DigitalRead problems
  73. SoftwareSerial in XBEEexample does it have to be translated to Altsoftserial & HWSERI
  74. What means SSAT with right shift?
  75. Is GCC able to generate SSAT ?
  76. How to re-compile core functions, such as HardwareSerial? (Rx buffer overrun?)
  77. Super Easy Teensy 3.1 Question Please! (Newbie)
  78. 10MHz Counter
  79. upload firmware image via Teensy 3.1 host?
  80. No port selection in arduino IDE
  81. problem with interferences and E18-D80NK
  82. no activity on pin 2 when running octoWS2811 w/ Teensy 3.1
  83. Teensy 2.0 BSDL files for Proteus
  84. Old linux OS and Teensy 3.1
  85. SPI works only in the Setup()
  86. Teensy2 occasionally hanging (Mac OS X)
  87. Out of RAM when I shouldn't be on custom Teensy 3.1
  88. Can not verify/upload code to Teensy 3.1 on Mac OS 10.6.8
  89. UTFT SD file selection with on-the-fly buttons
  90. Accessing the backside pins?
  91. Baffling problem with Teensy 2.0 usb_keyboard_debug sample code
  92. Using I/O registers with USB Serial on Teensy 2.0++ (Teensyduino)
  93. Using SPI for video overlay with Teensy 3.1 -- glitches
  94. SPI Transactions Implementation
  95. Audio Shield + TFT Shield?
  96. Teensy3.0/3.1 Audio Library Perform FFT on analoginput pin without Audio Shield
  97. Teensy, USB and Extended Configuration Descriptor
  98. Teensy 3.1 with MicroSD card adapter and RFM69HW on SPI bus
  99. Float versus Double on Teensy 3.1
  100. Teensy to Teensy communication trough MIDI
  101. Welding the TRISTATE in DUAL NAND
  102. Using Serial3; Nothing display in serial console
  103. Pause Audio on the Teensy 3.1 Audio shield
  104. power issues
  105. Teensy3 and 3.1: SPI SCK on Pin13 -> May the LED pose a problem at high speed?
  106. Teensy analog input not functioning properly
  107. Setting an output pin to GND/disconnect rather than GND/5V
  108. How to use idle mode on teensy 2 ?
  109. Teensy 3.1 possible connections
  110. ChibiOS and Teensy 3(.1) without Arduino IDE
  111. Teensy Internal file system
  112. Source code available? New version?
  113. Compiler problem with shift operator
  114. new to micro-controllers, please help!
  115. potentiometer at its full potential!
  116. Planning T3+++ or T4 - values available out there in the wild ...
  117. ILI9341 colour display debugging
  118. Problems with Custom Board - Target not answering
  119. Arduino Library to Teensy 3.1 changes
  120. Teensy as a USB network device?
  121. #error unknown CPU
  122. Teensy 3.1 ADC lag issues. taking 10-20ms to detect immediate changes in voltage.
  123. digitalRead(16) always returning 0 when using SPI?
  124. Teensy 3.1 USB packet size
  125. Audio signal with DC offset, how to use the lower half?
  126. Video experimenter shield
  127. Problem with MIDI, Teensy 3.1, Arduino 1.0.6, Mac OS X 10.9.5 - No receive of note on
  128. Teensy3.1 USB to FT232R communications
  129. Solved: Teensy 3.1 with Ableton Live
  130. help using ADC.h with Arduino 1.0.6 and Teensyduino v1.20
  131. Most Accurate Way to Return at a Time
  132. Pin13 as input?
  133. Teensyduino Keyboard/Mouse/Joystick Windows 7 Not Installing
  134. Mouse.moveTo not working in linux?
  135. plugging in two teensy 2.0 boards into the same computer
  136. Audio-Lib: processor-usage with additional swi
  137. Teensy 3.1 vs FT2606 Capacitance Touch Driver (2.8" TFT)
  138. Teensy 3.1 with Wiznet WIZ820io crashes
  139. Windows 7 Keyboard/Mouse/Joystick cannot install
  140. OctoWS2811 Adaptor with NeoPixel Lib?
  141. native c/c++ compilier
  142. Teensy++ 2.0 project with a 16x2 LCD display
  143. What mic would you recommend?
  144. Teensy 3.1 Abs voltage max? Somehow mine is surviving 6.76V
  145. bit shifting and pinout for teensy 3.1
  146. SmartMatrixSD card forces Teensy 3.1 loader to require press of Reset Button ?
  147. Trouble getting serial port working
  148. ldrex, strex, gcc atomic operations
  149. The power of the Mini54 & alternative bootloader code?
  150. OctoWS2811 Library - Using LED's of multiple lengths?
  151. Teensy3.1 Audio Synth Waveforms and WAV files
  152. AudioPlayQueue getBuffer(): How to get audio into and out of the queue objects?
  153. Strange issue with interrupts
  154. TFT character display from Teensy
  155. Teensy 3.1 bootloop?
  156. Teensy 3.1 and ADC + FIR Filtering
  157. RAW HID + USB HID Keyboard simulateonously with at90usb162
  158. Teensy 3.1 I2C Adafruit sensors and BLE
  159. SPI configuration Teensy 3.1
  160. Playing audio files from Teensy on-board memory
  161. Encoder library with Pololu A-Star Micro
  162. ILI9341 Parallel without using direct GPIO manipulation
  163. Teensy 3.x Crystal
  164. USB keyboard library problem
  165. Teensy 2.0++ 3.3v problem
  166. MIDI running status on Teensy
  167. Problems with my audio loop and sound output quality
  168. Teensy 3.1 with Arduino GSM Shield
  169. Distributing 'print' over multiple printable objects
  170. Problem with 'bool'
  171. Accurately reading a 50k pot
  172. Serial Monitor not doing anything!
  173. Teensy -> Production
  174. Very hot teensy
  175. Weird behaviour from digitalReadFast?
  176. problems with Teensy3.1 rules.d and linuxMint
  177. 3400+ LED display - Wiring question..
  178. Float 32 format
  179. edfed's stuff
  180. Teensy3.1 Play SDcard WAVs play problems
  181. A couple of questions re variables on the Teensy3
  182. Passing a String value to audio PlayRAW - convert to char array inline
  183. Really confused about setup() and loop()
  184. Some kind of Flashadapter for the MK20
  185. Silly Question re: a higher-reolution mills() function
  186. Teensy 3.1 port pins vs schematic reference designators
  187. Add Interrupt pins to Teensy 2.0
  188. Q: Audioshield + ILI9341
  189. AltSoftSerial on Teensy 2.0
  190. Simple and configurable HEX uploader like XLoader or AX Loader needed
  191. q: RAW_HID + teensy_gateway + Putty (windows) + Receive on T.
  192. How do I find out what the current IRQ level is?
  193. Underclocking teensy 3.1
  194. "Disk(SD Card)+Keyboard" with "Teensy 3.1" with Teensyduino+Arduino
  195. SerialMonitor takes very long to find serial port
  196. Audio High pitch buzzing
  197. Trigger pin state change between 2 TS3.1 generic question
  198. Teensy 3.1 Serial.print(F(" "));
  199. usb_serial_write question
  200. Is it possible to use the UART of the Teensy 2.0 at 2Mbps?
  201. Using envelope to control filter frequency
  202. SPIFIFO kills SRAM chip (23LC1024)
  203. Teensy 2.0 stopped working (no blink on connect)
  204. T3.1 w/ TD 1.2: I2C failure after power loss, requiring re-upload to fix
  205. Teensy I/O pin state during startup
  206. How to configure EEPROM for custom Teensy 3.1 PCB ?
  207. Problem with Teensy 3.1
  208. Teensy 3.1 + Neopixel ring: Light show only works the first time after uploading!
  209. DMA multi-buffer data transfer ?
  210. Need hel pwith a bootloader
  211. Teensy 2.0++ not reading analog in from potentiometer.
  212. Teensy with Labview
  213. teensy 3.1 and audio shield strange wav player problem
  214. Help with Teensy 2.0 head tracking
  215. Teensy 2.0++ not outputting 5v.
  216. Teensy 3.1 Pin Assignments in C
  217. Feeding i2c bus with Vin (5v USB) on Teensy 3.1
  218. Perhaps a silly question: analogWriteResolution and Teensy 3.1 DAC/PWM
  219. Teensy 3.1 'plug-in' PCB questions.
  220. Teensy++ 2.0 and Adafruits 1.5" 128x128 OLED Display
  221. zero handling in FreqMeasure ?
  222. Priorities - Audio Library plus PS/2Keyboard
  223. Two notification from windows for 1 HID insertion and issue with multiple HID devices
  224. Teensy 3.1 ADC Audio library question
  225. Using analog input for audio library filter
  226. WAV playback sounds distorted
  227. Teensy 3.x / SPI communication with "Wifly Shield" by "Sparkfun"
  228. Asymmetrical Duty Cycle When Bit-Banging Squarewave
  229. Teensy 3.1 MIDI sendNoteOn not received
  230. Teensy 3.1 non-blocking idle
  231. MINI54 Bringup
  232. ILI9341 8bit (not SPI) + Teensy 3.1
  233. Teensy 3.1 - ILI9341 connection problem SPI
  234. Programming MIDI Banks on Teensy
  235. Teensy 3.1 and FastLED 3.0.3 Compatibility
  236. SPIFIO issues
  237. ILI9341_t3 Library Fonts
  238. Minimal distance between T3.1 and audio board?
  239. Teensy 2 not recognized under Debian
  240. SPIFIFO & Transactions ?
  241. 1.5" LCDs for Smartwatch
  242. GPIO interrupts on teensy 3.1
  243. Having trouble with IR Receiver and a simple IR remote :(
  244. Note to Paul
  245. @Paul: Raw Stereo
  246. Correct bluetooth COM port not available for Simulink (Teensy 3.0)
  247. 96 kHz sampling with F_CPU=144 MHz
  248. Panel led with audio animations
  249. Computer shutdown using Teensy
  250. Audio shield sampler 2 channel playback/recording problem
