View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Can I remove the RJ45 plugs from OctoWS2811
  2. Has anyone used one of these TFT 3.2" 240x320 wTouch Screen / Flash / SD / Font Ic
  3. How does the reset pin work?
  4. enquires regarding Teensy 3.1 with audio shield
  5. Teensy OSC to pure data any luck?
  6. Connecting USB camera to Teensy
  7. Teensy3.1 Power Input and connections
  8. Teensy 2++ low power example works only after the teensy button is pressed
  9. Problems with Teensy3.1 playing SDWAV files Mono and Stereo
  10. Bandwidth of SGTL5000?
  11. MikroElektronika Basic and Teensy boards
  12. IR Remote Decodings
  13. Teensy still usable? Ripped off an SMD part
  14. C preprocessor guru / wizard wanted....
  15. Graphic equlaizer info
  16. MissingSPI.h compile error
  17. Teensy Loader has stopped auto loading but reset works - Normal?
  18. Teensy 1.0 as Joystick
  19. OctoWS2811: section attribute not allowed for 'displayMemory'
  20. SdFat (B.Greiman) and Audiolibrary
  21. Newbie: Difference between Halfkay bootloader and teensy loader
  22. AudioCard startup question
  23. MIDI stream - LinkedList? XML DB? Variable struct with ordering?
  24. 2.8" tft from buydisplay.com
  25. teensy 3.1 with CC3000 gives "no route to host"
  26. RS485 RE/DE Teensy 3.1 pin(s)
  27. Teensy 3.1 internal pullup enabled pinsl
  28. Teensy 3.1 #define STRINGIFY_(a) #a Error
  29. Can't launch Teensy Loader at compile; Mac OS 10.5.8, Teensy 1.2, Arduino 1.0.6
  30. Small Micro-Usb to Usb Adapter for teensy 3.1?
  31. delayed and dropped serial messages while using Neopixel or FastLED on Teensy 3.1
  32. Using INMP441 I2S Microphone
  33. Teensy 3.1 - Converting to 3.3V
  34. Information on using the USB disable for teensyduino
  35. Teensy 3.1 w/ Arduino MIDI Library (4.2) Rx issues
  36. How to debug i2c
  37. Teensy 3.1 - LCD Connection and EFI Attack
  38. Accelerometer Data to be Stored on SD card
  39. Data types on the Teensy 3.1 (32bit vs 16bit)
  40. Conflict/Issue with optimized ILI9341 library and other SPI device
  41. OctoWS2811 - troubleshooting offset diff btwn image on screen and LEDs
  42. Pots reading max before, hitting the max
  43. analogRead from inside library returns low values
  44. try to multiply two uint32_t into a uint64_t seems not to work
  45. teensy ++ 2 unable to upload
  46. Bootloader for Teensy 3.1 that supports Bluetooth
  47. Teensy 3.1 usb change on the flight
  48. MINI54 Clock Speed?
  49. Restore Teensy 3.1 Back to Orginal State
  50. Teensy 3.1 non-arduino build blinks twice faster usb-serial not functional
  51. OLED 1.5" SSD1351 & Teensy 3.1 - Please help
  52. Problems with Serial Driver after Sleep (Windows)
  53. OctoWS2811 - flickering when using more than one Teensy
  54. Delayed auto reboot of T3.1
  55. Can't upload code to Teensy 3.0
  56. Example contribution
  57. digitalWriteFast with AnalogWrite - Compatibility?
  58. Problem using PIND on teensy 3.1
  59. Teensy 3.1 in combination with Digital & Analog Accelerometer
  60. https://www.coolcomponents.co.uk/ - Genuine supplier ?
  61. Teensy 3.1 Phone game-case coding tweaks.
  62. How to call c++ functions on arduino-teensy 3.0?
  63. Soldering to pads on the bottom of Teensy 3.1
  64. SPI-DMA-slave problem.
  65. Using Flash for data storage on Teensy 3.x
  66. 'Serial 1' was not declared in this scope - Yosemite 10.10
  67. Teensy 3.1 + Serial Bluetooth 4.0 BLE Module - iBeacon
  68. Teensy 3.1 - USB-MIDI and serial at the same time ?
  69. Teensy 3.1 recognition problem Windows 8 (not solved by common troubleshooting tips)
  70. Teensy 3.1 - Yosemite (Mac OS X 10.10) compatible?
  71. Teensy 3.1 Communication problems
  72. Problem Creating a CC3000 Web Server
  73. Teensy 3.1, never ending programming loop.
  74. Teensy3.1 serial logging without arduino
  75. Teensy 3.1 Serial Midi Input Woes
  76. recommended pots for T3.1 filter cap on analog pin?
  77. Reduce current consumption of Teensy 3.1
  78. Newbie to bit level coding '_delay_ms' was not declared in this scope
  79. LED Noise
  80. Can there be negative control values in MIDI?
  81. FIR filter coefficients
  82. More PWM teensy 3.1
  83. Library question
  84. Can access digital inputs on Teensy 3.1 pins (A10 and A11)?
  85. IntervalTimer is not precise
  86. Is there a 1-Wire Device Limitation on MicroLan with OneWire library?
  87. Teensy Loader will no longer run
  88. STGL5000 and filters
  89. Teensy 3.1 and Parallax PIR 555-28027
  90. Drawing current from 3.3V?
  91. Custom build Teensy 3.1 PCB not responding
  92. New Teensy-LC
  93. Ethernet transmitt buffer
  94. Make error when attempting build of rawhid_test.exe using source code from pjrc.com
  95. Using wdt.h
  96. How to achieve fastest USB transmission FROM teensy3.1 TO computer
  97. Audio adaptor boad + ST7735 (Using hardware SPI)
  98. Disable boot loader pushbutton
  99. ADC Negative voltage spike
  100. Large LED matrix glitching on a few strands
  101. Using the LED pin for USB input
  102. Using Teensy 3.1 with 24 Bit I2S Audio Codec
  103. Teensy ports and reference stuff
  104. Question about ws2812b and voltage drop
  105. Teensy bootloader compatibility
  106. Reset Button on Teensy 2.0
  107. SPIFIFO / chip select / compatibility issues
  108. variable I2S master clock (and sampling) frequency
  109. USB 1.1 native device / RS232 max speed
  110. Counterfeit, need confirmation please.
  111. Teensy 3.1 freeze troubleshooting
  112. RX/change interrupts pins on Teensy 3.1, 3.0 and new TeensyLC
  113. (Un)dead Teensy 3.1
  114. Midi controller problem with Ableton
  115. Teensy PWM impulses
  116. display only works when in IDE - Teensy 3.1 with SSD1306 I2C,
  117. SSL client / server
  118. Teensy 3.1 pin 1-9
  119. Teensy 3.1 disable pin 13 LED? to use as INPUT_PULLUP
  120. SPI Questions *default speed and quicker chip select
  121. Processing optical linear encoder signals
  122. Teensy 3.1 - PROGMEM or const for a lookup table
  123. rxtxSerial.dll
  124. Teensy 2.0 Counting Pulse Lengths
  125. Teensyduino (1.20) damgaing "Arduino.app" (1.0.6)
  126. DIN MIDI from Teensy 3.1 works with computer but not with old hardware keyboard
  127. Detecting "touch" on pots / rotary encoders
  128. smoking t3.1
  129. Teensy 3.1 UART set to 7-E-2 Mode?
  130. cannot get CC3000 to work with T3.1 in server mode. UNO works fine
  131. Accessing Comparator Hangs Serial on Teensy 3.1
  132. Writing a Wrapper around a Library
  133. Question on mapping a non rectangular ledShape with Octows2811 / control about 8000
  134. Moving code from Pro Trinket to Teensy 3.1
  135. Which Teensy 3.0 Processor?
  136. Teensyduino ST7735 library problem
  137. HID USB Keyboard Receive on T3
  138. Teensy 3.1 audio Volume not working in custom PCB
  139. Problems powering motor with teensy 3.1
  140. Serial.paresInt not working as expected with Teensy 3.1
  141. Adafruit Atmega32u4 BB+ support?
  142. Teensy 3.1 Reprogramming Pin State
  143. X-Plane + Teensy 3.1 + Real Parts = This
  144. 5 volt Power supply
  145. Audio Library Wrapper
  146. teensy serial port installer
  147. DAC Output Voltage Range
  148. Can you identify Teensy 3.1 or LC from software ?
  149. PIN wiring overlap for Color Display and WIZ820io & Micro SD Card Adaptor to Teensy 3
  150. Strings array
  151. Float in sscanf on Teensy 3.1
  152. Audio Filter
  153. Teensy 3.1 back side pins
  154. Audio Timestamp
  155. Access USB pins on any Teensy?
  156. Teensy 2.0 has 21 digital I/O pins?
  157. I2C with Arduino Pro Mini
  158. Have Teensy 2.0++ and RAMPS 1.4 How do I wire them together?
  159. Max PWM frequency for Teensy 3.1
  160. Using MCP23017 Library and Interrupts
  161. Teensy 3.1 Voice Encryption
  162. Ra8875 7" lcd
  163. testing if a string is numeric
  164. Purchased a board - New to Arduino - over my head with install
  165. Teensy 3.1 Physical Width
  166. millis() and micros() timer on teensy 3.1, changing PWM frequency
  167. teensy duino makes arduino-1.0.5 tools menu really slow
  168. teensyduino 1.20 on win8 x64 does not work using arduino 1.5.x or 1.6.0
  169. Teensy 3.1 Analog Read Isses
  170. Keyboard error compile issue
  171. Wierd characters from Serial[1,2,3]
  172. SPI clock regularity with spi4teensy3
  173. OctoWS2811 and delays
  174. Max current through VUSB to PCB
  175. How to achieve better infrared transmitter performance?
  176. Teensy 3.1 app not recognizing pushbutton
  177. Q on SPI DMA speeds for read/write mass storage
  178. Arduino 1.6.0 compiler does not output error messages
  179. Problem with teensyduino finding Arduino
  180. wav2sketch 16 bit help
  181. Audio "examples\Analysis\FFT\FFT.ino" Compile failure: ide 1.6 Beta6
  182. Is there some way I can have my PC app control my Teensy 2.0++?
  183. Using Sketch RAM as Larger EEPROM
  184. AltSoftSerial - inverted RX?
  185. Im sure youve heard this beforev -My code doesnt work
  186. connection problem pixelcontroller - teensy2 - ws2801
  187. Teensy 3.1 Parts List
  188. More MINI54 Trouble
  189. Is it possible to fry in a teensy an AVR code compiled elsewhere?
  190. Migrating Arduino Mega 2560 based project to Teensy 3.1
  191. Using 4 channel dac chip with audio library
  192. Tying 2 Tennsy 3.1 voltage out's together
  193. PWMServo examples compile failure
  194. Using Teensy Audio within another Library
  195. Delay() accuracy
  196. Optimized ILI9341 Library Problem
  197. 1024 point FFT, 30% more efficient (experimental)
  198. teensy 3.1 dip switch input pins always reading LOW
  199. Custom Teensy 3.1 PCB troubleshooting
  200. SDI12 Library for Teensy 3.x & Teensy LC
  201. transparent background for BMP file
  202. Teensy 3.1 runs for a few minutes, then constantly resets
  203. PROGMEM warning: dereferencing type-punned pointer will break strict-aliasing rules
  204. Understanding how to use audio's FIR function
  205. Teensy 3.1 & Xbee Wifi Library
  206. How to make a MIDI controller?
  207. powering atmega32u4 with battery and usb
  208. Three Teensy 3.1 died completely after sketch upload
  209. Teensy as DSP?
  210. Teensy 3.1 Midi problems.
  211. how to open SD card files by index instead of name to reduce latency?
  212. USB Serial Compile Errors
  213. Sound on my Teensy 3.x Carrier boards...
  214. Teensy 3.1 + Arduino Android Keyboard fails
  215. Code to Run Permanently
  216. Teensy++ 2.0 USB - PS/2 pin assignment
  217. Custom Teensy 2.0 Board USB connection Fail
  218. Trouble getting Interrupts to trigger
  219. FLOPS not scaling to F_CPU
  220. INPUT_PULLUP is not pulling up (Teensy 2++)
  221. Tone Function For Variometer
  222. DAC output pops on startup
  223. Problems with telemetry to APM 2.6
  224. AGND vs GND ?
  225. teensy 3.1 octows2811 with a 16x90 ws2811 matrix
  226. Teensy 2.0 - power consumption
  227. Teensy HEX output?
  228. Teensy Android Connection
  229. W5100 shield and Teensy 3.1
  230. Teensy++ 2.0 with ATMEL JTAGICE MKII?
  231. ILI9241_t3 support for Teensy LC?
  232. Disable UART RX Teensy 3.x
  233. gcc -flto
  234. Teensy 2.0 appears unresponsive; tried posted troubleshooting steps
  235. variable size when porting from Aruino project
  236. Using digital pins for InterTeensy signaling
  237. Flashing custom code over serial...?
  238. 120 LEDs problem
  239. Teensy 3.1 and 2 power supply
  240. IRLremote (not IRremote) Compatibility
  241. Protecting WS2812b
  242. Optocoupler to drive 40khz ultrasonic transducer directly
  243. Remote reboot without download?
  244. I cant get Teensduino to work with arduino-1.6.0-windows.exe on windows7 64Bit Pro ve
  245. Compiler optimization flag passing-IDE to Visual Studio 2013 Community (freeware)
  246. Field uploading code to the Teensy without arduino/Teensyduino
  247. Driving ws2812b strips via teensy 3.1 - TPM2serial - pixelcontroller
  248. What's the point of the CS pin?
  249. Teensy Network
  250. Portable way to use library only for Teensy, not Arduino
