- Every Pin on Circuit Reading High
- Increasing EEPROM space on Teensy
- DMXSimple Issues
- Consistently inconsistent time between loop itterations
- Flash strings and RAM
- teensy 2.0 with network over USB (Parrot Bebop)
- Minimum Tbuf time
- Does u8glib(V1.17) natively support hardware SPI for Teensy3.x?
- Teensy fuse values
- lock bit(s) for MK20DX256VLH7
- Best Way To Read up to 50V DC via ADC on Teensy 3.1 ??
- Are there limits to encoder numbers in Teensy 3.1?
- Unable find Teensy Loader. Is the Teensy Loader application running? error on OS X
- can anybody give me some hardware advice
- Fft256
- Reading from Multiple UARTs
- Teensy-LC w/ SD stackable board please help
- Teensy 3.1 & audioshield record and play through AudioPlayMemory?
- 2 teensy 3.1 boards died while driving L298N controller board
- fastled work?
- teensy_loader_cli: error writing to Teensy: only with LC
- Can't get __disable_irq() to work on Teensy LC
- Issue with ssd1306 128x64 displays on the TEENSY3.0 (using u8glib)
- help getting sketch from Teensy 3.1
- Help running NeoPixel Painter
- Teensy LC USB.SendSysEx handles only 13 Bytes ?
- nRF8001 and Snooze library with Teensy 3.1
- Teensy 3.1 is not running program
- Connecting a Speaker to Teensy 3.1 DAC / A14 ?
- 90s Guitar Synth Keypad Matrix Sending midi notes - Suggestions/Help
- Teensy++ 2.0 regulator smoke
- some issue while using external power source (USB/5V Vin both)
- Teensy 3.1 external power, diode direction
- Teensy Audio Library, suggestion for AudioInputAnalog
- Voltage divider from 5v to 3 volts
- Please help with porting to Teensy LC
- ATMEGA 32U4 and Wiznet 820io
- Mic In on Teensy Audio board
- I2C Lock-up. i2c_t3 questions.
- Teensy LC Capacitance function
- Is there something wrong with pins 19/18 on my teensy 3.1? MPU6050s keep burning out
- capacitive sensor
- Audio: __disable_irq() and update()
- Incomprehensible Software Issue With An NRF24L01 Set-Up
- Slow performance with Arduino Ethernet shield
- ESP8266 at 4.2V (LIPO)
- Teensy 3.1 Optimized Overclock - What does Optimized Mean
- Arduino _keyReport.modifiers
- Teensy 3.1 quit communicating
- Non-responsive Teensy 3.1s
- Is there a way of reconnecting a patchcord in the Audio library?
- sync multiple teensy3.1 each reading a bin-data from a sd-card
- Teensy 3.1 SPI, U8Glib and SDfat
- Teensy did not respond to a USB-based request to automatically reboot.
- Teensyduino not working?
- Eastrising 5" TFT RA8875 with sumotoy lib not responding
- EEPROM.h stopped working between 1.2 and 1.23
- Does serial1Event or serial2Event work in Teensy 3.1?
- Weird example
- Touchscreen on Linux with Mouse.moveTo()
- Creating a 3rd Party Board Variant for the Board Manager for a Teensy Variant
- Program Teensy 2.0 in assembly?
- Teensy 3.1 not recognized by windows
- Teensy 2.0 analog resolution and external reference
- Teensy 2.0 no inputs
- Teensy 3.1 NFC program is not compiling on new Teensyduino 1.22
- Powering teensy for portable projects?
- no leds working after soldering headers to teensy
- Teensy MIDI device name problems
- Program storage space in Teensy LC
- Teensy 3.1 I2C communication (Where are SDA & SCL)
- Moving away from Arduino: Programming Teensy 3.1 in C
- What for is 100 ohm resistor on Color TFT Display?
- Teensy products no longer accessible via ttyACM? port
- BreakOut board
- Looking for a discussion
- Teensy 3.1 and JSON
- Driving a couple of motor channels and a couple of servos. Servo library question.
- Teensy 3.1 read Midi from Ableton/have metronome click
- 74HCT245 to read 5V sensor modules ?
- fatal error: Keyboard.h: No such file or directory
- Using NDEF library with Teensyduino; avr-g++ hangs
- Decoupling Capacitor Placement in PCB Design with an Integrated Teensy
- Teensy LC and HC-SR04s
- Interference from motor on analog input pin?
- Can Audio library be extended to 32 bit?
- Teensy 3.1 fails to connect to usb
- Teensy 3.1 and Audio board
- 9pin audio to 2 3.5 female jack adapter
- Teensy 3.1 "USB-based request", program mode problem
- Sending I2C message from ISR
- How many analog sources at once can I read with a Teensy 3.1?
- Teensy 3.1 Analog pin/ADC impedance.
- class stream support?
- Problem with Teensy++2.0
- new teensy 3.1 not recognised by windows
- Teensy 3.1 sleep and interrupts
- Teensy 3.1 and microSD breakout problem
- USB GET_REPORT support
- Sanity check; Using SPI pins for something else.
- Teensy 3.1 fried, not sure what happened
- Interrupts not always served on Teensy 3.1
- Teensy Audio board and Hydrophones
- Fresh Teensy 3.1 not retaining code when power cycled.
- DMA with OLED and DAC
- teensy
- mouse only sort of working
- PCB Design: Analog parts necessary?
- Change lower limit on ADC range?
- teensy 3.1
- AltsoftSerial and Xbee S1 Problem Teensy 3.1
- Teensy 3.1 Serial shuffle
- New to Teensy and looking for some guidance with compiling errors. Graphicstest???
- Teensy 3 detect unplug USB cable
- Teensy 2++ Problem formatting Disk internal + keyboard
- undead teensy
- MCGIRCLK Clock
- Installation of Teensyduino, Version 1.23
- Multi-TT USB hubs - multiple Teensy units - Xplane Simulator
- Using string.h
- Quectel AT commands and http
- More compiler debug output?
- #include <library>, library in bold and/or colored or black?
- Midi and Serial
- [Teensy 3.1] PWM noise on Photodiode
- Teensy3.1 for Vehicle Telemetry
- Audio board - RECORDER Example - modification
- Compiling for Teensy LC and Linux
- Upload Hex file from Teensy 3.1
- Compile errors using interrupts on Teensy 3.1
- USB serial (CDC) + mouse (HID) using C + makefile for teensy 2.0 (linux or mac)
- interrupt.h file is empty
- MC34063 SMD Inductor Selection
- Problem: Cannot read USB Serial from Teensy 3.1 on Debian machine
- Teensy3.1 8 pot 74HC4051 multiplexer with MIDI
- Talking between 2 teensy 3.1
- Question re: LC pin voltages
- Can I use microseconds in the Tone function with Teensy 3.1?
- Trying to install Teensyduino on Arduino 1.0.6 built from source for Linux
- Update documentation on the web site
- 8266 AND tEENSY 3.1
- Is SPI different on Nano and Teensy 3.1?
- Building A 25-Key Midi Pedalboard
- Teensy 2++ - Drivers
- Teensy 2++ Only keyboard ?
- Audio Board fails to output proper audio after time
- how to send continues data for arduino i2c protocol
- Teensy 3.x Reference
- Reset Teensy to "As New" condition?
- Open Drain Enable on pin 1
- DMAChannel code works in Teens 3.0 but not in LC
- Compile Errors with Arduino 1.6.3 `
- [Error] Compile error using Many-Axis joystick lib and test file
- Can a Teensy re-flash itself from an SD card?
- Setting up an Emulated Serial monitor like Arduino's included Serial Monitor
- (PS2 Protocol) PS2 mouse movement packet bad/odd data, multiple mice
- A curious story - Teensy 3.1 stops after 1-2 sec. with external power supply
- Audio shield MIC input, need help here
- USING SEVERAL MDI/USB audio peripherals : TEENSY 3.1 takes all the bandwidth
- Dead Teensy 3.1
- USB-Serial DSR and RI control?
- analogreadresolution
- Adalight project +350 Led (WS2811IC ) + Teensy 3.1 and OctoWS2811
- USB Connector
- External Pin Interrupt not working
- howto compile for teensy-lc with avr-gcc
- dead teensy 2++?
- Teensy (3.1) compile just hangs
- USB microphone
- Non-Serial USB Teensy 2
- libpng12.so.0 not found
- Apparent grounding problem with a thermocouple amplifier, when USB is not connected
- Arduino keeps asking for firewall approval after Teensyduino addon
- Teensy 3.1 / CD74HC mux
- Teensy 3.1 and 3DR Radio Telemetry
- ffmpeg for teensy 3.1
- Teensy 3.1 analogRead problem.
- relative interrupt priorities (Timer0 vs UART) - Teensy3.1
- Button Controller with Encoder support
- USB speed selection
- Trouble with (Native) Blink
- Trouble porting Adafruit nRF51 to Teensy 3.1
- Teensy 3.1 ground isolation issues
- Teensyduino Installer
- Teensy 3.1 stops responding, RESET stuck low
- midi to usb interfase
- Teensy + 3DR Telemetry Communication
- Trouble installing teensyduino on Mac 10.6.8
- Teensy 3.1 and Sparkfun 7-Segment Display UART
- Teensyduino - Arduino 1.6.4 - Win7 - compiler hang
- acceleromer CJMCU 105 ADXL345 suddenly sending jittery data
- Playing two RAW files at once from SD card
- DIY Midi Foot Controler for AxeFX (Guitar Effects Porcessor)
- microSD Adaptor - MISO Line Input
- can use teensy command line loader automatic mode?
- SSD1306 + Teensy MicroSD adapter SPI issues
- Teensy 3.1 with Adafruit TouchScreen (Nintendo DSL digitizer)
- Difficulty reading Serial Data over xBee
- Really fast SPI - maybe try assembly?
- NEWS: I added a touch screen HID device to Teensyduino 1.23 (works also on Linux)
- Library for 128 by 64 OLED I2C Display
- Issue compiling for 3.1, works fine for teensy 3.0
- USB host shield plus ILI934 display : spi4teensy3.h vs SPI.h
- Is my Teensy 3.1 faulty?
- ADMUX/ADCSRA not declared in this scope
- Teensy 3.1 Didn't recognized
- parallel processing on a t3.1?
- Wiring Moga Controller to Teensy
- Teensyduino Freezes up in ubuntu 14.04
- What current limit out Vin pin
- Output pin override switch
- Cant get LCD display to work
- Serial1.peek
- MidiTimeCode MTC over USB
- Audio adapter and library noob frustration
- Serial Numbers, MAC, and device name on MacOSX
- USB serial driver returns slightly different style output for Mac and Windows
- Program 'locks up' when running from memory
- Audio Library Play Latency
- wiz820io max speed ?
- Problem with ILI9341 Screen
- Noisy output from Teensy3.1 - we need a one shot FFT function, please.
- Using psp joystick with teensy
- Direct port access not matching schematic?
- Multiple channel Acquisition on teensy 3.1
- Timers for Infrared Library on Teensy 3.1
- USBMidi Can I Do This?
- c++ question for ADC library
- Audio library: change pins for PWM output
- Joystick with Teensy 2.0 12 buttons, 10 analog inputs: have questions, need advice
- jumper for Teensy 3.1
- Limit for recording using Teensy audio board
- Code Compiles on UNO, Not on 3.1
- Can't compile with DueFlashStorage library
- Eclipse Luna-SR2, Arduino 1.6.5r2, Teensyduino 1v24
- SerialFlash w/ Winbond 25Q80BV
- Can any one say what are the two black chips in the teensy board mentione in belw img
- AudioSheild Memory Question
- Difficulty getting my Teensy connected to my network.
- Basic Exercise - Push Button and turn on the LED!
- Teensy 3.1 & Visual Micro/Visual Studio: COM port issues
- Teensy LC as DMX Receiver
- I2c wire emulation-changing the I2C bus speed
- Killed another Teensy. Power supply requirements with external AREF?
- MINI54 on production boards / usb compatibility questions
- Teensy LC and OctoWS library
- Arduino Compiler gets stuck halfway through?
- Teensy Playing Audio file rejects Pulsein
- Teensy LC vs. Teensy 2.0 Floating Point
- Power and grounding
