View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Teensy 3.1 USB and Bootloader without USB Cable
  2. Teensy 3.1 instability
  3. Adafruit MCP 23017 Library and Teensy 3.1 not working
  4. SPI Isolation
  5. Teensy LC & Low Power
  6. Power supply design
  7. Altium Library Teensy 3
  8. USB Host Shield and Teensy 2++
  9. error: 'keyboard' was not declared in this scope
  10. Class D Audio Amp Application (TPA2005D1)
  11. Sometimes sd card does not work
  12. Problem with Teensy clone: loads code in IDE but GPIO unresponsive
  13. Math function not found
  14. Program a Teensy 3.1 with Android?
  15. 2 out of 6 photocells not responding on analog inputs
  16. TimerOne on Teensy LC
  17. Standalone Programmer
  18. Theremin with Delay behaving badly
  19. Teensy2++ (AT90USB1286) bootloader problems
  20. 24 servo control through the Servo library
  21. Determining if compiling for Teensy
  22. Teensy 3.1 + sd card fail!!
  23. Using Serial.println in C code
  24. Teensy technical questions
  25. I2C Slave not responding
  26. linking .a files
  27. Teensy 3.1 to Teensy 3.1 communication speed
  28. Teensy 2.0 with Micro SD Adaptor
  29. can't even get started
  30. Serial ports use 4 pins?
  31. Recording and FFT in a single program
  32. foot print
  33. Visual Micro Issue when compiling
  34. Teensy RTC lag
  35. weird behavior serial from GPS
  36. Teensy operating temperature
  37. Assembler List File for Teensy 3.1
  38. SPI SD card show up as USB disk = possible? (teensy 3.1)
  39. Recording audio to buffer
  40. Teensy 3.1 I2C problem communicating with DRV8830 Motor Driver
  41. Clearing serial buffer for simulink?
  42. Easy VR 2.0 and Teensy 3.1
  43. Teensy 3.1 SPI CS pins
  44. Using 'Smart Control Servos' (Feetech) with Teensy...
  45. Which pin should I use for BlueDuino rev2?
  46. Problem with Audio playback after several hours
  47. Need some input on this strange issue with a 3.1 and x-plane
  48. Little problem
  49. Aurora on SmartMatrix + RF24 Library – Apparently broken :(
  50. Loading Variables from an SD Card at Startup
  51. Newbie Question; What is difference between Optimized Clock and Plain Clock freq?
  52. analogRead basic (but strange) question
  53. Sysex in serial midi and usbMIDI
  54. 2 14x14 led matrix panels howto
  55. how are the pins numbered?
  56. TEENSY 3.1 + Adafruit 10-DOF IMU Breakout - L3GD20H + LSM303 + BMP180
  57. Teensy 3.1 ADXL345 accelerometer freeze/does not work - wire.endTransmission
  58. Nothing heard from Electret mic on Teensy Audio Mic pins
  59. USB CDC driver conflict with Teens vs. Espruino
  60. Teensy 3.1 desoldered SMD component
  61. MPU6050 minimum connections and parts
  62. Trying to use Teensy to follow instructables. I have a 3.1 and it's confusing.
  63. how to port this Clock code to Teensy 3.1
  64. Looking for code to do a software restart with the Teensy LC
  65. unable to access the SD card with WAV sample code
  66. Teensy 3.1 signalr.c:(.text._kill_r+0xe): undefined reference to `_kill' error
  67. i would like to convert some code into some signals
  68. Why diodes in parallel?
  69. Issue when attempting ADC on pins 20,21
  70. Audio library : left and right channel output control?
  71. Audio library play back from NON root directory?
  72. pwm synchronize with external event
  73. problem displaying BMP on ST7735 and T3.1
  74. Newbi RTC without Cristall?
  75. 2.4 TFT with SPFD5408 controller
  76. Hardware triggered DMA data transfer setup problem
  77. Another dead Teensy 3.1
  78. Increase impedance
  79. which motherboard use?
  80. Udp.ParsePacket() always returning 0 - ArtnetRecieveCallback Example
  81. Disabling Outputs
  82. Basic Teensy 3.1 questions
  83. IS bounce 2 compatible with teensy 3.1?
  84. Audio System Design Tool import?
  85. Trouble with Teency LC as USB Keyboard
  86. Question!
  87. High current USB negotiation during enumeration
  88. Bounce - can you change parameter on the fly ?
  89. Custom Teensy - Sudden death after working!
  90. Teensy 3.1 powering other devices
  91. Trouble with Libraries and the School Network
  92. Program 9 teensy 3.1 in parallel
  93. Rotary encoder "noise"
  94. Setting rotary encoders to zero in functions
  95. Teensy 3.1 USB Serial not communicating
  96. OctoWS2811 Library and Adaptor MAX/MSP Serial communication
  97. Noisy, unintelligible SPI signals using T3SPI
  98. SPI Transactions issues when switching modes with SPISettings
  99. Teensy 3.1 and RN-41 Bluetooth Issue
  100. Reading MS5535C using Teensy 3.1 problem
  101. Read wrong data from I2C with Teensy 3.1
  102. Printing a wave amplitude to the code.
  103. Timer Interrupt on Teensy 3.1 for 5 MHz Signal
  104. Noises while recording audio with Teensy 3.1
  105. UART Serial not working?
  106. #defines & USB-HID - how to vary the RAWHID_USAGE value so I can identify Teensys?
  107. I just fried another Teensy, need an idea to stop
  108. 0-5v analog on 3.1
  109. Teensy LC with DS18B20 example code error
  110. How does one control the brightness of an OLED display (SSD1309) ?
  111. Teensy 3.1 Artnet Troubles
  112. Optimising MIDI transmission
  113. mbed doesn't work on my Teensy, but works on others...
  114. Multiple I2C ports on Teensy 3.1?
  115. Sanity Check; analog input pullups
  116. RPM measuring with hall sensor and teensy 3.1 for a gas helicopter
  117. Teensy 3.1 confusion
  118. Sanity Check: custom teensy pcb design (circuitmaker)
  119. Teensy LC Documentation
  120. Selecting a Teensy development environment for Linux
  121. Alternative SSpin when using ethernet and SPI library together?
  122. running arduino from Linux command line: "Picked up JAVA_TOOL_OPTIONS:"
  123. converting double from 8 bytes from a gps sensor
  124. Extending USB to external connector
  125. Major Micro SD Weirdness w/ Teensy3.0
  126. Ubuntu problem installing Teensy add on
  127. Teensy2 Not Working w/ Some MIDI Interfaces
  128. Another Mini54 Issue
  129. where to put libraries not in Arduino or Teensyduino install?
  130. What to due when compiled Hex file is to large
  131. Teensy 3.1 serial stops responding after a minute
  132. Sanity Check / Power Source Troubleshooting
  133. teensy 3.1 with adafruit ultimate gps
  134. Problem getting FFT to work (though it worked earlier this week)
  135. Teensy 3.1 Button problems
  136. 433mhz rf receiver and rgb led remote
  137. TFT LCD displaying BMP as fast as possible (ILI9341_t3)
  138. Crystal questions :)
  139. Teensy 3.1 DMX WS2811 Control
  140. Compile error when byte variable declared in a ".h" file
  141. SDFat with multiple SPI devices (Shared SPI Bus)
  142. Teensy LC startup time
  143. OneWire device( DS18B20) reported present by reset but is actually abscent
  144. Teensy 3.1 dead?
  145. Changing delay to a function that slows clock speed for power savings
  146. FFTs with CMSIS
  147. Teensy LC and infrared receive
  148. BMC encoder/decoder for teensy 3.1
  149. Teensy 3.1 dead with Lipo and USB power
  150. teensy 3.1 SD/SPI clock rates 'n such
  151. No library found for processing.video
  152. WIZ820io with CS on pin 8
  153. Teensy 3.1 with Kinetis Design Studio
  154. Use of 1000uf capacitor on LED strip power line....yes/no?
  155. Teensy software
  156. Teensy LC serial buffer resize
  157. Read a file out of Flash?
  158. Quick Question about External Power For Teensy++ 2.0
  159. Libraries specific for Teensy 3.1
  160. Teensy LC with ILI9341 TFT Library Error
  161. SFH618A-2 opto-coupler
  162. Teensy 3.1 No Serial Port.
  163. Using Swift (OS X) to communicate with Teensys - any experience here?
  164. Execution Speed of the Teensy 3.1
  165. Arduino Mega vs Teensy3.1
  166. Arduino 1.65 + Teensyduino 1.24 device has become unstable
  167. Teensy 3.1 max baud rate
  168. Using the Teensy 3.1 as a keyboard
  169. Windows 10 with Arduino IDE: no serial port name defined + port name corrupt
  170. Teensyduino USB Mouse Only profile
  171. Teensy LC settings pins in assembly
  172. Will changing VID/PID on Teensy 2++ break serial driver?
  173. Timing of the Audio library
  174. slow power supply rise time leads to Teensy 3.1 hanging
  175. Loading array into Flash from SD Card
  176. Teensy 3.1 and ESP266 UART communication issue
  177. Uninstall windows driver
  178. Teensy 3.1 + micro SD program die
  179. TimerOne Leonardo and Teensy 3.1 library location issues
  180. Mouse Press and release
  181. Help picking an IDE to develop code.
  182. FastLED code compiles & works for 2.0 but not 3.0?
  183. PWM Trouble at Low Frequency driving a 3 phase blower
  184. Teensy 3.1 Windows 8.1 does not see it
  185. Teensy LC resets due to EMI?
  186. Teensy 3.1 and 5V TTL Serial?
  187. (FreqMeasure.available() timeout semaphore
  188. SPDIF (not Toslink) Output
  189. Working Sketch not compiling on new computer - Arduino /Teensy 3.1
  190. Issues with Teensy 3.1 and OLED
  191. MA55xx library incompatible with AdafruitST5537 library??
  192. Driving WS8212B from a Teensy 3.3V pin
  193. Teensy 2.0 Case/Housing?
  194. Arduino 1.6.5 IDE with the teensy extension is not finding a library
  195. Strange octoWS2811 Behavior (flickring and limited strip length)
  196. Teensy-LC & Fastled
  197. Where is source code for Teensy serial driver installer?
  198. Help with Timer Interrupt
  199. Teensy Gateway Source
  200. latest Arduino-IRremote broken?
  201. Question about on-board pushbutton Teensy3.0
  202. MIDI input on Teensy 2 problem
  203. Sending data quickly between two Teensy 3.1's
  204. Ultimarc Spinnner Spintrak with Teensy ++ 2.0 example
  205. Long delay before teensy loader uploads.
  206. pin 32 problem with custom teensy 3.1
  207. Issue with Winbond W25Q80BV
  208. HID Communication on Arduino Leonardo to Windows 10
  209. Teensy 3.1 and ST7735 TFT screen not powering on
  210. _builtin_bswap64 problem.
  211. Teensy LC + I2C SSD1306 Oled + Xbee
  212. LSM9DS0: Gyros do updated on initial power up
  213. Teensy 3.1 My 2 year bottle neck and the fix.
  214. Problem compiling using Eclipse
  215. Is "low memory" really a problem?
  216. Nokia 5110 Display not working with teensy 3.1
  217. Teensy 3.1 SDcard adapter not working.
  218. Software reset from Python
  219. Using Stino with Teensyduino
  220. Touching usb cable to USB connector housing produces strange effect
  221. AudioAnalyzeFFT1024.available() returns false
  222. eagle part for microSD
  223. Help with Hardware Interrupts
  224. Powering via LiPo
  225. Teensy 3.1 Under Windows 10 comReadError (8020)
  226. BNO055 Gyro Update Rate
  227. Teensy 3.0 Teensyduino not downloading to Arduino
  228. Teensyduino Install Error
  229. How to override built-in libraries reliably
  230. How much current do internal pull-up resistors draw on Teensy 3.1?
  231. Would shorting a pin to ground burn the Teensy?
  232. 12 synchronized pulses
  233. Teensyduino Installer won't recognize folder where Arduino is located
  234. Teensy 3.1 encoder using interrupts not working with x-plane
  235. Teensy 3.1 Joystick Trouble
  236. Debug Techniques Needed
  237. Teensy 3.1 with Davis 6410
  238. Arduino/Teensyduino String object
  239. Teensyduino Install Problems
  240. Only sometimes working for a second (TEENSY 3.1)
  241. Audio library: co-existence of a waveform synthesis object and an FFT object
  242. Trying to understand Teensy 3.0 PWM motor behavior.
  243. Teensy 3.0 not uploading code
  244. teensyduino refusing to install against arduino 1.6.5-r5
  245. Teensy 3.1 taking too much RAM compare to Mega 2560
  246. Teensy 3.1 Upload issues under Windows 10
  247. Teensy-LC + WS2812 = dropped serial bytes
  248. Octows2811 SD card and BLE
  249. Teensy LC Snooze and I2C problem
  250. compilation error in avr_functions.h
