- teensy 3.1 print to serial not showing on serial monitor
- Teensy 3.1 Octo2811 Power issues
- Pin testing and/or test suite post-soldering?
- Battery voltage measurement / What is AREF Pin? PTD6?
- Teensy LC PWM Pins and timers
- EA DOGS104W LCD Display
- Using TSI for capacitance measurement
- Mac OS X El Capitan Serial port problems - need more info to raise issue with Apple
- CAN rx/tx as regular Serial?
- Teensy++ 2.0 showing up under Win8.1 as a libusb device?
- Problem reading a PWM signal from RC receiver
- OctoWS2811 LEDs intermittently display incorrect colors
- Programming multiple connected Teensys
- What is the Sampling Rate for ADC?
- FTDI - Teensy USB Host shield
- Timer1 troubles when porting code from Arduino UNO to Teensy 3.1.
- Teensy Hardware Serial delay
- DC servos and ferrite rings: on the motor, on the encoder, or both?
- The /dev/cu.usbmodem440323 port name Teensys appear with - how static is it?
- Midi emulated serial in Processing ?
- 12 Bit DAC Example Produces No Output
- teensy_loader_cli on OS X for a teensy3
- Powering confusion / sanity check
- Is there some way to reset MIDI
- 74HC595 and teensy 3.1
- Teensy 3.1 short issue?
- OctoWS2811 displaying 1/4 lines in zig-zag configuration
- CTRL+ALT+L not working in Linux
- pinModeFast() doesn't work in Arduino 1.6.5 (Teensyduino 1.25 beta 2) ?
- ADB with Teensy 2.0, USB Host Shield 2.0 / microbridge
- Serial monitor causes noise?
- synchronize ADC samples with PWM output?
- array from teensy to matlab
- Teensy 3.1: OS X drag issue
- Teensy USB Serial Bug (comunication crashing when sending message)
- Audio Board circular reference filter and AUDIO_BLOCKS
- Encoder Library Qestion
- Teensy++ 2.0 Pin D6 always reads ground
- Teensy Audio Board
- Teensy 3.1 Serial with Adafruit ILI9340 display
- Teensy 3.1 not recognised by Windows 7
- Software to build project layout?
- Problems with adafruit FONA and TeensyLC
- i2c question: will a fast device over-write a slow device's response?
- Help with Large Array
- spi4teensy3 alternate pins + usage with SPI lib
- Teensy2.0 with 0.11v
- wiz820io with teensy 3.1 and wiz820 sd adaptor
- Different current consumption, repower vs reboot.
- Teensy LC pull-up
- Yes, Teensy-3.1 works on mbed
- Are interrupts slow?
- Weak data signal ?
- Serial midi input stopping completely at random moments
- no serial port name defined
- Teensy 3.1 Serial I/O re: rosserial
- TFT 2.4 ILI9341 and Teensy 3.1 - Display not working with optimized teensy library.
- Where do I find the source code on my Mac
- Watchdog Timer missing!
- Is millis() affected by long ISRs (Interrupts) on Teensy?
- 20x4 I2C LCD Fails
- Pin AREF voltage level
- Keyboard is not working
- Understand Prog pin in Teensy3.1
- Teensy 3.1 Blown...
- What is the prefered method to attach leads to use the Rest and Pins 28 - A13
- "Bricked" Teensy 3.2 and recovery
- FreqMeasure Library on the Teensy-LC ?
- Teensey -LC, serial port numbers
- Teensy 3.1 and u8glib why so slow?...
- can't auto upload after changing product name
- Playing BIN file off of SD card w Teensy 3.1 & OctoWS2811 & WIZ820+SD Adaptor
- Micro SD Card performance
- Teensy 3.1 and multiple mpu-6050
- Teensy 3.1 vs. 3.2 pnout locations
- Reconfigure ADC via a DMA transfer to allow multiple Channel Acquisition
- Teensy LC & DS1307: Current Time Weirdness
- Using a pushbutton to allow code to proceed operation
- can anyone flash code to external MK20DX256VLH7 chip using Teensy 3.2/3.1 dev board?
- Teensy 2 MIDI / RawHID / Keyboard
- Playing with the FreqMeasure Library
- Teensy++ 2.0 3.3V question
- Teensy 3.1 as LOW SPEED USB Device?
- Interesting behavior by ADC library
- Execution freezes at low level SPI library code when reading files from flash ...
- Bluetooth
- Teensy 3.1 with I2C OLED and SH1106 Controller
- Teensy 3.1 as USB midi interface and USB -> DMX converter
- Upload failing
- Teensy power and potentiometer?
- Teensy 3.1 crashing, memory problem?
- Is this a defective ADC?
- Teensy 3.0 External Power
- Teensy 3.1 + AudioBoard: Problem with noise
- Teensy 3.* battery power
- Teensy LC EEPROM location
- teensey 3.1 how do i program teensey to unlock efi on mac air
- Question for Paul on Teensyduino and X-Plane
- 4-20ma output into teensy 3.2 analog input
- DM3D-SF question
- Updating video with Teesy3.1 + OctoWS2811 + SD card reader
- Help with Integrated Teensy
- recorder example glitches?
- Teensy running pixel invader display image doubled
- Arduino 1.6.5-r5win + Teensyduino 1.25-beta2 + SPI.setMOSI(7) + SPI.setSCK(14)ALTpins
- Noise in audio circuit output when Teensy connected via USB
- Teensy dead and overheating
- Virtual Serial Ports
- Bootloader Erased-Software
- Timeout delay in sendUDP in endPacket when target is not online
- User Name
- Dreaded "Teensy did not respond to a USB-based request to automatically reboot."
- Teensy 3.1 use internal Temp Sensor
- Digital write program
- 2.8" TFT LCD Cap Touch on Teensy 3.2
- Is there a reference for porting Arduino examples to Teensy?
- When do you need the teensy reset button?
- Com port not found, even though it clearly is found
- ILI9341_t3 as wired for audio card no longer functions
- Expanding Teensy3 input pin count?
- Adding horizontal scroll to teensy 3.1
- Rebooting Teensy (LC, 3.0) to bootloader without Teensyduino
- Using OLED Monitor with Teensy 3.1
- Coding problem with builtin rtc
- Code issues, not sure how to procede
- Method to know type of Teensy while running?
- 2.8 ILI9341 restive touch miso not connected ?
- Hardware reset on Teensy LC
- Interference noise on audio output w/ Teensy Audio Adapter board
- powering teensy with 1500ma usb charger possible?
- Teensy + Audio board noise on polyphonic WAV playback
- Game Controller Question....
- Almost fried my teensy?
- Teensy 3.1 not coming out of bootloader when powering up
- no serial data received in Ubuntu 15.04
- Accessing pressed keys of usb_keyboard_class
- Teensy LC interval timer limitations?
- Counting microsecond ticks using the Teensy 3.1. Programmed in C
- Servo has Jerky Movement
- Slow compile... really slow compile...
- Teensy ++ 2.0 I/O Pins
- Teensy 3.1 (or 3.2) - Driving 3 LEDs from a Digital Write Pin?
- SD Bootloader
- WS2811 Driver circuit
- Teensy 3.0 / Missing libraries ?
- DMA on both I2S input data ports?
- Windows code to get virtual serial port number
- Teensy 3.2 requires Teensyduino 1.25 or maybe earlier
- Issue with reading LSM303 over I2C (Adafruit 9DOF)
- dynamic AudioConnection
- Design Problem?
- Audio clicking on sound start/stop
- Question about Teensy 3.1's 3.3V pin
- SWD pullups
- DIRECT_MODE_OUTPUT in OneWire not working?
- RGB strips are red at the ends
- TimeAlarm Library Alarm.write function
- How to avoid Teensy fake Keyboard to disable my touchpad ?
- USB HID on Teensy 3.2
- Encoder help needed for newbie
- Teensy Audio shield headphone output problems
- Need an example for RPM Measure with freqMeasure zero method
- Help needed for creating a simple PWM tone using the Audio library on pin 5
- Problems with Teensy 3.2 and LiPoly Charger (MCP73831) limiting current thru VUSB
- Noob ? Can I really use both sides of my Teensy 3.x at once ?
- Teensy 3.1 and Adafruit ILI9341 - need to always re-flash.
- Teensy 3.2 serial port not recognized.
- IMU (MPU6050) behaving Strangely on Teensy only
- FAT16 or FAT32 SD Micro Formatting for audio playback on Teensy Audio adapter?
- breadboard joystick to move mouse help
- Teensy 3.2 self-triggered programming problem and fix
- DAC Help!!!
- In need of help -- Teensy 3.2
- Teensy-LC and Capacitive Sensor
- USB Micro-AB Pin 4
- Connecting Teensy Audio Adapter to Teensy 3.2
- Teensy 3.1 won't boot unless connected to host computer over USB
- Teensy Audio Board + I2C
- How to run Teensy with 9V battery?
- F_CPU, F_BUS & i2c_t3
- Learning about DMA and interrupts
- X-plane Datarefs for audio controls
- CapacitiveSensor - very slow readings/reaction
- Library sourcing
- Teensy 3.1 USB keyboard
- Trying to run Eclipse getting /arduino/memcpy-armv7m.S.o: No such file or directory
- Xplane flap gauge and Teensy 2++
- Device is not recognized by win8.1 PC.
- Teensy++ 2.0 as keyboard (redefinition of usb_keyboard_class)
- None booting custom teensy board :(
- Audio Board SD card
- Teensy LC recognition issue
- Power rail sharing between multiple Teensy 3.2s
- Linux no longer talking to Teensy 3.1
- Capture image from HD 700TVL 3.6mm Objektiv SONY CCD Effio-E CCTV Camera?
- Wire Library rxBuffer overflow
- Can ping Teensy and Wiz920IO, but webserver demo times out.
- teensy 3.1 random line breaks in serial data output
- SPI between two Teensy LC
- Eigen library
- Fadecandy & Teensy 3.2
- Teensy3Clock.get() returns error
- Probleme ISR() with Teensy 3.2
- problem with double precision floating point constants
- Development environment for OS X 10.6.4 (Snow Leopard)
- AM Demodulation - Complex Magnitude
- Writing a class that can accept hardware serial and usb serial.
- SD library; declaring different file names using "if" statment
- LCD5110_Basic Compile Errors on Teensy
- Teensy 3.2 RTC time sync frustration.
- Teensy + AT45DB061D or similar
- Teensy USB Board, Version 2.0 Keyboard key F13 - F14 - F15
- Help for connecting Vixen with Teensy 3.2
- Power supply question
- I2C_T3 and Wire Not working on Teensy 3.0 anymore?
- Teensy Audio Board not playing some WAV file
- Serial Port Read with Matlab on Linux
- How to upload without pushing the button on Teensy 3.1
- LedDisplay HCMS-2902 Issue
- Teensy 3.2: 3.3V regulated power source (bypassing onboard reg)?
- status of uint64_t on Teensy 3.2
- Self-Programming: Program tenth of teensies over a can-bootloader
- RFID question (MiFare Classic)
- Newbie: "get started with Arduino IDE" guide?
- multitasking - david anderson
- Teensyduino compiler crash !
- Using Slider to move mouse but mouse pointer shakes
- SD card: which library?
- Teensy 3.2/Wiz820IO, can I force TX buffers to flush?
- Modifying WavFilePlayer Sketch to start and stop audio clips with pushbuttons?
- float and double
- Converting Teensy 2.0 to 3.3V?
- tsl2561 arduino Lib crashing teensy
- DS1307RTC.h library not compatible with OneWire.h?
- Broke off small resistor on teensy 3.1 - can it be saved? (pic)
- USB Hosting Teensy 3.2
- SD Library fails to connect
- Custom board problem, loads but program won't run.
- SIMD instructions with Teensy
- Analog Conversion Complete Interrupt?
- Automatic boot doesn't happen
- UbuntuGnome 15.10 - Teensy 3.1/3.2 programming issue
- SD Card Problems
- AltSoftSerial and Servo libraries fails to compile
- Quick Question about Paul Stoffregen's ILI9341_t3 library and wiring
- odd Audio Library mixer.gain behaviour.
- Arduino keystrokes via push-buttons, how to debounce, when to use matrix?
- Teensy functionality controlled by DIP switches
- Integrated Teensy 3.2 reset line issue
