- Using a POT as a controller (with the internal voltage source)
- Audio board + 74HC595 with Teensy 3.2
- USb / Serial Teensy 3.2 While ( !Serial ) does not work for me.
- Teensy 3.2 Failed To Access SD Card
- teensyduino midi sync
- VUSB and AGND are shorted. Teensy Heating up and not working
- Issues with Teensy and Longevity
- Teensy upload and the arduino eclipse plugin
- Cannot upload my program on my Teensy3.2 board.
- Everything goes wrong trying to work without the Arduino IDE.
- Code with alot of text has me confused
- Teensy 3.1 and ENC28J60
- Teensy 3.2 @3.3V (ext regulator): integrated RTC freezes everything
- AudioProcessorUsageMax() confusion, confessions of a noob.
- help needed with Teensy triggering relay chain circuit
- Upload with the Bootloader/Programmer without button access (Teensy 3.X)
- Samsung USB Cable and Teensy
- Maximum GPIO toggling, (Teensy 3.2)
- unsupported avr errors with teensy ++ 2.0
- How to use const class objects in PROGMEM?
- Problems with simple analog read circuit
- PDB for single shot applications
- T3.1 pin 13 led
- FastLED.show() causes Servo to jump and jitter
- DC Motor interfering with another pin interrupt??
- USB Raw HID versus Serial...
- My Teensy keeps locking up
- Problem with FastLED and 16 way parallel output
- Link problems in Arduino Eclipse with Teensy 3.1
- Christmas tree with several teensy Octows2811 and SD card
- Will Paul's SPIFlash library work with these?
- Teensy touchRead() problems, right usage!?
- What connector is this?
- Teensy 3.2 only responds to reset button if USB is connected to serial terminal
- WIZ820io & Micro SD Card Adaptor 101 - sanity check?
- 3 power supplies with Teensy 3.1 help
- Dastardly DMA
- Run function only one after compile
- Are Teensy 2.0 pins 5V tolerant?
- Refining touchRead on an LC - and Connecting to mac USB keyboard
- Loading a HEX file to a Teensy via RasPi terminal
- Can't communicate with Teensy 3.2 through Teensyduino
- Problem with ENC28J60 and Ethercard. Not connecting
- Teensy LC Bootloader LED not blinking
- USB MIDI read to turn on LED's
- Best Practice Transmitting large Dataset to PC over USB Serial
- MK20's resonable unclear datasheet
- Question about TimeAlarms library
- Teensy 3.2 USB Keyboard use byte code not key name
- Need help getting ADS1298 to work with teensy 3 SPI
- Interrupt Jitter
- RawHID and serial at the same time
- Battery Powered 3.6v : Teensy 3.2 + Teensy Shield + Xbee Shield ?
- TEENSY 3.1 + ESP8266 -----> "Busy inet..."
- Question on UCAP pin of Teensy2++
- Polyphonic Audio Sampler Memory
- DMAChannel::triggerAtHardwareEvent digital pin source?
- I2C lockups: is it possible to adapt WSWire (alternative Wire library, has timeouts)?
- Post Deployment of Teensy 3.2 based data log - How to make changes in some variables?
- infrared recievers using multiple
- Random number generator interface error.
- Direct Access to FTM/PWM control
- Inconsistency between value from ADC and voltage measured on voltmeter
- USB bus isolation for Teensy
- Teensy 3.2 millis() going 2.5x faster than actual time?
- ISSUE: APA102, FastLED and Teensy 3.2... flicker on strips with more than 60 LED's.
- Teensy did not respond to a USB-based request
- Teensy and the Chronodot / Time Library
- Wiring look over
- teensy3.1 with wiznet 5500
- New PJRC TFT ILI9341 Sanity Check
- Interchange Teensy T_LC and T_3.1/3.2 with VBat powered pin
- Matrix keypad compile error
- Audio Library waveform frequency control
- audio out gives a 344hz noise and freezes my teensy after about 2-3 minutes
- Conflict with LiquidCrystal_i2c with Audio library
- ILI9341 and XPT2046 for Teensy Touchscreen 320x240 display
- CANTEST demo unable to run with Arduino 1.6.6
- Teensy 3.2 - Neopixel question...
- ethernet enc28j60 problem
- teensy android drivers
- XPT2046 Touchscreen Can't get just one sensor reading or a complete sensor reading
- Why is my interrupt not working on ADXL345 accelerometer?
- Has anyone gotten the MPU-9250 to work with SPI?
- Keyboard.press and usb_keyboard_press providing different results
- Compiling Adafruit Bluefruit library for Arduino on Teensy 2.0
- Generating digital waveforms via DMA and PIT
- Direct Port Manipulation Problems Teensy 3.1
- Port manipulation and Arduino code conversion to Teensy_LC
- Do I have to include unneeded libraries in the sketch?
- I need of some assistance Teensy 3.1 (handheld gaming system)
- Audio Lib & OctoWS2811 Lib & Hardware?
- USB Write Speed
- Unresponsive Teensy3.2
- MKL26Z128VLH4 from skretch
- Pin to avoid having power during boot?
- Teensy 3.1 and si4432 (RF22) not working
- dsp load over 170% while playing a single wave file?
- Anyone else having issues with micro usb jacks easily coming off?
- ITG 3701 code error while compiling on Arduino Mega
- Complex Numbers
- DMA question
- USB keyboard emulation hangs
- Trouble since El Capitan upgrade
- Audio Library recommended circuit for adc
- Teensy 2.0 clone I2C & USB conflict
- resetting without pressing the (unaccessible) PROGRAM MODE BUTTON
- Audio Shield and flash chip
- Disabling pins on Teensy LC
- Changing SCK pin number in Ethernet library
- Using Mouse.move() -- how can I use my second monitor?
- OctoWS2811 and CAN bus
- Decimation & Interpolation with arm_fir_decimate / interpolate
- question on spi transactions
- PWM output question on Teensy 3.2 Boards?
- Unable to write onto SD card
- Using Teensy 3.1 on new computer - not working
- Teensy and WIZ820io SPI problem
- SPI issue between FFT and Digipot
- ifdef / preprocessor issues?
- How to read Teensy 2.0 Datasheet?
- Minimum pulse width for interrupts
- IRLib compiles and works with Teensy 3.0/3.1 but not LC
- Question about hex files, IC compatabilities and programming
- gcc optimization help needed
- fine frequency control of PWM
- USB Connectivity on custom Board
- Increasing the buffer for usbMIDI?
- Occasional problems creating a new file with SerialFlash/Teensy 3.1/Audioshield
- ATMEGA32U4 QFN Bottom Ground Pad Question
- Teensy 3.1 not working with different IDE and Teensyduino versions
- Fedora 23 cant communicate with Teensy 3.2
- Multiple memory buffers for one DMA channel.
- Pulling data from usbMIDI SysEx Array
- Teensy 3.2 Serial Communication on Pin 5 and Pin 21
- Modify the hardware of Teensy, make it smaller
- Use Teensy as Wireless USB Receiver
- Color 320x240 TFT Libraries Question
- 2x32, Rather Than 8x8, Keypad Matrix?
- Impossible get data from teensy
- Compiling with the 3.1 enviroment with the 3.2 board
- SMBus?
- EEPROM confusion
- Analog input protection
- Save Files on Teensy
- help with analog input circuit
- How'd I fry my Teensy?
- Using I2C on a Teensy LC
- help optimize the code
- Problems loading movies
- Teensy LC with nrf24l01 Issue
- New Teensy 2.0 on Fedora 22 unable to enumerate
- Color Touchscreen and LC
- Audio library on Teensy LC
- USB keyboard issues
- Real Time Clock not running on Teensy
- Android controller power consumption question
- Movies in an array?
- stabilize analog input
- Fedora 22 can't process Installer.
- Teensy 3.2 and XBee
- OctoWs2811 to 4 x Ws2812b strips / beginner LED programing on different strips
- Continuous ADC+DMA in low power modes (Snooze) and/or different CPU frequencies
- inline assembly usat is slower than simple if statements to saturate, why?
- Did i kill teensy 3.2 ?
- Windows 7 (64bit) standlone teensy loader stalls during upload sometimes?
- problem with Teensy3.1 loosing correct time.
- Teensy 3.2, Read Test (DS1307RTC) broken
- Teensy-LC, 'DMAMUX_SOURCE_ADC1' was not declared
- Teensy LC Mouse.click() not working
- Possible to have an Encoder object as a private member of another class?
- Connecting SPI Device on Teensy
- 8 LED Neopixel Strip on Alternative -- Non-17 -- Teensy LC Pin; Can It Be Done?
- Teensy 3.1 not work with battery (work ok with usb)
- FFT and PEAK detection resolution?
- synth GATE input into Teensy 3.1 circuit
- Teensy 3.2 SPI Problem or my lousy code?
- Teensy 3.2 Teensyduino Tutorial #3
- Teensy++ 2.0 and WIZ820io
- Teensy 2++ shuts down ATX PSU
- Display operating temperature range
- EagleCAD board (.brd) file for Teensy 3.2
- 64 pin MCU upgrade to 80 pin
- Trouble with SD breakout, multiple sensors and Teensy 3.2
- Silly question re using Oscillators
- Relative order of pin changes on port
- Signal Filtering with Teensy
- Teensy 3.2 + ILI9341 = No display.
- How to read data from an USB faderbox
- Teensy 3.1 / Only some GPIO pins and I2C used / How to enable low power at 48MHz?
- Teensy++ and Audio Board?
- Adding more ADC's to Teensy
- Wiegand Library and Example Sketch Work on Uno but not Teensy 3.1 - HALP!
- Data flow and timing with Audio library
- Teensy 3.1 bricked
- Reading a counter and storing in Excel
- New Bulk Order of 10 x Teensy 3.2 - none of them recognised by OSX or Win8
- Teensy joystick problems and help needed
- Teensy 3.1 Problem with CANbus
- Heap functions not weak for AVR teensy boards
- ILI9341 touchscreen constant pressure reporting with no touch
- Teensy Midi Disconnect and Reconnect Problems on Windows
- Teensy very slow I/O write
- Cap touch screen compiler error, need help.
- ADC input with DC offset? Did I break it or am I missing something...
- Random touch screen (3.5" question).
- Hellokeypad sketch compile errors
- Teensy 3.2 SMD Chip Identification Question
- Setting up Teensy sketch folder vs Ardunio sketch folder
- Serial2.available
- SPI using DMA Can a Teensy be a Master and a Slave
- How to check (at runtime) how many digital pins the hardware has?
- Using PWM pin to clock out pulses
- 2.0 / 3.2 pinout compatibility
- Is it possible to reconfigure joystick + button code to use pins out of order?
- Ultrasonic sensors
- Teensy 3.2 can not install arduino files.
- Teensy LC, HW Serial port 2 problem (transmitting data to a Parallax serial LCD)
- 9v power supply to 3.2
- Custom Teensy not uploading firmware
- impossible constraint in 'asm'
- Can Teensy 3.x receive MIDI on pin 7 or 9? Or is it really only Serial1?
- A hopefully simple question about the Tlc5940
- interrupt vectors on Teensy 3.2
- DIY graphic / pixel Poi displayed from SD card (mortonkoph's code)
- Snooze.deepSleep changes pin configuration for Teensy LC?
- Teensy 3.2 3D Model
- bricked teensy 3.2... any way to fix it?
- Changing Port Definitions on Custom Teensy-based Board
- ws2812b led with Teensy3.1 from RASPBERRY PI 2
- External Data bus D0-d7
- Multiple GPIO pin activity monitored in a common interrupt handler example?
- Supported speeds for SPI on Teensy3.2?
- softPWM question
- PWM with phase shifted pulse?
- PN532 with Teensy 3.1/3.2 SPI Issue
- No 'Example>Audio>Tutorial' menu item in Arduino 1.6.5
- MKL04 Pin Ordering
- Teensy 3.x RTC Seconds Interrupt
- Help Compiling "Blinky"
- NRF24L01 sniffer on Teensy
- Encoder library with Arduino Zero?
- What do the shaded descriptions on the reference cards mean?
- Teensy 3.1 Not recognized in device manager, but power is getting to board
- SPI freezes, crashes and lags. fix anyone?
- PulsePosition and Servo in/out on Teensy 3.x
- On Teensy 3.x, should touchRead use AGND or GND?
- 4-wire SPI
- There are 8 modifier keys
- Simple SerialFlash sketch example
