View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Not able to upload sketch to Teensy
  2. APDS-9960 with teensy
  3. Spi port pin assignment problem
  4. Unable to flash using makefile
  5. OneWire with Arduino Zero
  6. Code compiles & works for 2.0 but not LC (or 3.1)
  7. Teensy 3.2 power supply
  8. Teensy 3.2 not responding to interrupt on PIN 13 (LED PIN)
  9. Teensy 3.1 ILI9341_t3 lib questions
  10. 4067 multiplexer read back rotated
  11. Trouble with multiple phantom touches using XPT2046
  12. Teensy 3.1 not working with Arduino Wifi101 shield
  13. ADC on Teensy 3.0 part is maybe jittery?
  14. Custom Teensy 3.1 board (MINI54) bootup issue
  15. How to uninstall teensyduino on mac
  16. Detecting The State Of A USB Port
  17. How should I use Audio Filters teensy 3.1
  18. Driving 4 channels wit the octows2811 lib
  19. Desperate for help-serial driver not recognising old Arduino after Teensy install
  20. Teensy 3.1 Forgetting code after power off/removal from USB
  21. Make 2.4 inch TFT Display SPDF5408 work with Teensy3.2
  22. Failing to send MIDI via TX1 on Teensy 3.2
  23. Largest size 8SOIC flash chip to use?
  24. No Serial Port Name Defined
  25. Need guidance for software SPI with DMA (to drive TLC5947)
  26. usbMIDI.sendSysEx example
  27. Teensy 3.2 MIDI SysEx size over 255 bytes
  28. Teensy 3.1 question about ADC
  29. SPI problems
  30. Potentiometers affecting each others when connected to 74HC4051
  31. Teensy 3.1 Cascade Filtering
  32. CNC with grbl8 g-code-parser
  33. OSC through serial vs USB-midi mode
  34. Help: Teensy 2.0 Switch between two I/O pins
  35. 5V Analog Pressure Sensor on Teensy?
  36. Choosing the correct library for the board
  37. Make Teensy a 2.4 GHz Receiver
  38. Powering Teensy 3.2 from external power and still have usb in with power cable in it?
  39. Problem with libraries and Teensyduino 1.27
  40. HELP: Softmodem (FSK modem) library for Teensy
  41. adafruit 1.5" OLED pinout clarification for TEENSY application
  42. Problem on compiling in arduino ide 1.6.7 & TeensyDuino 1.27
  43. Teensy 3.2 work on 4AA?
  44. SPI hangs with CS low on Teensy 3.2 and WIZ820io example program
  45. Stupid Question - WIZ820/Teensy 3.2 ArtNet
  46. Cortex m4 dsp guidance
  47. Newbie, problems with serial ports.
  48. DISPLAY_ILI9341_TOUCH - Displays goes white and unresponsive after hours of operation
  49. project problem!
  50. Teensy LC, serial port only not recognized by Windows, serial+kbd+ms+joystick is OK ?
  51. Having touble with my Teensy 2.0
  52. DigitalRead on Teensy
  53. Audio teensy gui help
  54. 18.000px Tv ambient 3D room light by teensy
  55. Encoder Wiring Help
  56. Teensy 3.1, Overlapped FFT
  57. Interrups Ports on Teensy 3.1
  58. Change Micro USB Female to USB Male
  59. High speed dual ADC - detect edges?
  60. Locations of Variables
  61. Neopixels causing Teensy-LC to perpetually reboot
  62. Lineout 'pop' when audioShield.enable() is called
  63. force sensing resistor to LED light strip
  64. Unsolder Pushbutton
  65. How do I get Arduino IDE to recognize Teensy as one of its boards?
  66. Serial port behaviour with delay() on Teensy LC
  67. Weird issue USB CDC + PWM
  68. Is it broke
  69. analogRead speed vs CPU speed
  70. Datalogger with S25FL127S SPI Flash Chip
  71. Multiple SPI devices (ADS7843 touch and W5200) lockup
  72. Teensy shut down problem
  73. Is FASTRUN broken in arduino 1.6.7
  74. Reading GPS data on RX1 - is there a timing issue?
  75. qvgatest_touch Purple board does it need pull up resistors?
  76. ADC reading oddity
  77. Teensy ++2 and X-plane dataref problem
  78. FreqMeasureMulti compilier fault
  79. Trouble using different CS and DC pins on Teensy 3.2 with ILI9341 touchscreen
  80. Web server page size limit
  81. Teensy 2.0 joystick x axis inverted
  82. Bearing Calculation and Ring Buffer
  83. Serial2 Alternate pins 26 and 31
  84. What is "proper" page formatting rules for making large mult-page programs?
  85. SerialFlash compilation error
  86. Yet another Lipo supply/charger question
  87. WIZ820io connects only with 10M
  88. Serial port splitting ?
  89. Serial and Serial2 to receive and send same data?
  90. teensy audio board i2c question
  91. Do i need RTC for PPM library?
  92. Which pins to connect 18 pots?
  93. itoa, utoa, and otehr errors performing makefile Teensly-LC build
  94. Some (simple) questions on the PPM library
  95. Sample Code for USB Host with Teensy 3.2?
  96. Synchronizing ADC object and Audio library
  97. How to send PPMOutput to serial?
  98. Make ILI9341 dispaly brighter by changing resistor value??
  99. Trouble mixing Line-In with SD Wav
  100. "Next" button doesn not enable in "teensyduino.exe"
  101. WS2801 pixel wall + Teensy 3.0 + Glediator/Jinx
  102. Problems running CapacitiveSensor example on ESP-12...
  103. What can cause the port to disappear from the Arduino IDE listing?
  104. Questions regarding USB serial interface
  105. Program variable storage for sine table
  106. Teensy LC pcb thickness
  107. Boot loader chip recognize STOP/VLPS low power modes Teensy 3.x/LC
  108. Teensy and gyro L3G4200D compatibility (gy-85) :
  109. Multiple teensy on i2c, multiple pull-ups?
  110. PS/2 Library --> USB Library
  111. Command line Teensy 3.2 Loader, for Windows?
  112. Sparkfun Analog/Digital MUX Breakout - CD74HC4067 - Electrical signal instability
  113. teensy 3.2 + software serial
  114. Teensy 3.2 USB-Keyboard on Non-Windows/OsX/Linux
  115. Problem compiling Duffs Hibernate Example
  116. Is there a list of what you can do in setup()?
  117. really weird upload problem with Teensy 3.1
  118. RS485 faster than Modbus
  119. Teensy 3.2 Reading Megasquirt CAN Bus
  120. How to speed up analogRead?
  121. I2S Quad speed problem
  122. 1.3" i2C OLED trouble with Adafruit SSD1306 library
  123. Loader for Teensy 3.2
  124. SPI Library Issue w/ ILI9341 TFT & PN532 NFC Module on Teensy 3.2
  125. Mac OS X El Capitan - No Serial Port - Solution inside
  126. 5V Output from T3.2
  127. Sniff I2C
  128. Teensy API? Specifically for Joystick
  129. SSD1351 SD Card access?
  130. Wiring question for Teensy 3.2 and DRV8825 stepper driver
  131. Simulator for Teensy/ ARM
  132. Teensy 3.1 open drain voltage tolerance?
  133. Sumotoy RA8875 load image from SD card (sdFat); RA8875 crashes
  134. WIZ820io stuck with DHCP IP Address of 0.0.0.0, MISO always low
  135. Micro USB Port, as well as wires
  136. Connectivity Issue: Teensy 2.0 MIDI Drum Triggers (Piezo) - Pure Data - MobMuPlat
  137. Audio Adapter Board without Teensy
  138. Need help converting SoftI2CMaster library in order to use teensy with sensor
  139. i2c multiple bmp280 question
  140. Example program "HelloSerialMonitor" does not work
  141. Troubleshooting ili9341 SPI interface
  142. Address of flash option byte, used during MK20DX256VLH7 boot.
  143. Does program pin work on teensy 3.2?
  144. Multiple MPR121
  145. ILI9341 Display Issue
  146. 6N138 as replacement for PC900
  147. Teensy 3.1 RawHID interface crashing on OSX
  148. Question re: RTS/CTS flow control
  149. SSD1306 harware SPI on Teensy 3.1
  150. Teensy 3.2 component places
  151. OTA Updates using the ESP8266 and Teensy 3.2
  152. Octo2811 question
  153. Teensy 3.2 at 1.8V (not 3.3V)
  154. HID device to COM-Port
  155. If...Else problem with repeating touch, ILI9341 TFT
  156. How to use "Joystick.useManualSend(true)" and "Joystick.send_now()"
  157. Part number for Button on Teensy LC
  158. not communicating
  159. Serial problem
  160. Using only TX from Serial Port
  161. HelloKeypad Example Does Not Compile
  162. Analog Channels A14-A20 not assigned to ADC
  163. Teensy 3.1/3.2 Serial ports = What is the maximum baud rate?
  164. Multiple Teensies Error - Device Cannot Start
  165. Teensy 3.2 not detected under Vista
  166. Sample .ino for usb_serial
  167. Rotary Encoder Types
  168. Problem with serial interface on windows
  169. Question about the analog read?
  170. Keyboard getting slower by time
  171. ILI9340 multiple displays strange behavior
  172. Teensy Touch pins for 4-wire touch screen?
  173. using a Teensy 3.1 for analog Sticks to generate keyboard input
  174. How do I get the teensy LC to show up as a COM port on Windows?
  175. movie2serial: copying a portion of the frame before passing to image2data
  176. Using Adafruit GFX and RGB LED libraries together
  177. 4051 multiplexer selects same analog in on two different channels
  178. AT25SF041 Flash memory for Teensy 3.2 with SerialFlash
  179. ILI9341 Touchscreen X and Y touch values swapping places Intermittently
  180. USB Ethernet?
  181. Teensy 2.0 not working on Windows 10
  182. Purpose of MKL02Z32VFG4
  183. Teensy 3.2 + WIZ820io CAN-bus logger
  184. Two topological layouts for working with li-po hard limit - which is appropriate?
  185. Does FreqMeasureMulti work with Teensy 3.0
  186. Teensy 3.2 Schematic
  187. Best way to read PWM input?
  188. Problem copying file to serial flash
  189. ili9341- Display turns white
  190. rtp-MIDI / Apple-MIDI question…
  191. Does Teensyduino have something like HID listen?
  192. Unable to download Teensyduino.exe
  193. Two Displays, two Librarys?
  194. WM8731 issues
  195. dogLcd lib without delayMicroseconds() ?
  196. Teensy MPU6050 Library Conflicts
  197. Teensy 3.2 RTC Accuracy?
  198. How does TouchRead do its measurment?
  199. Can I use the RX and TX pins to program and communicate with the Teensy?
  200. IRremote and Audio Adapter Board
  201. Remap Tx1 pin on Teensy 3.2
  202. method to capture serial data from /dev/ttyACM0 or /dev/rfcomm0 in linux?
  203. How do I know when Serial1 has finished sending?
  204. conflict with IntervalTimer and display library
  205. using IntervalTimer with SPI.usingInterrupt()
  206. Sidewinder 3DPro -- teensydujino.exe can't see 3DPro32u4.hex
  207. Using External Power for Teensy
  208. CardInfo Sketch error on Teensy 3.2
  209. Electric Fast Transient issue when USB connected
  210. Teensy 2.0 joystick not working properly with windows
  211. How do I find the FTDI version on Windows 10?
  212. PulsePosition for arduino (pro mini)?
  213. ableton live bpm read and display on teensy (clocking)
  214. ADC library Apparent Pin Restriction
  215. Using Audio library into other library???
  216. Reset behavior - OK on Windows, not on Linux
  217. Teensy 3.2 won't run on power cycle
  218. Teensy 3.1 / Save Power / Disable ADC
  219. Teensy 2.0 Arduino Leonardo Only Receives 1 Byte of Many
  220. Is there a diode that fits on the USB power jumper pads?
  221. NewPingEventTimer problem
  222. Teensy3.2 pin input prootection
  223. Teensy 2.0: device descriptor read/64, error -32
  224. where to find ILI9341_t3 library reference?
  225. Deactivate Pushbutton on T3.2
  226. Teensy LC + Wiz820io + Websocket
  227. how to copy data thats already on teensy 3.2
  228. Play SdWav with Audio Library and read other file from SD
  229. OctoWS 2811
  230. movie2serial: image2data changes running very slowly
  231. Teensy 3.2 is not recognized at all
  232. IntervalTimer.h bug
  233. Programming the own function?
  234. TeensyLC + Snooze + hibernate VLLSx : has anyone succeeded to use pin wakeup ?
  235. Teensy crashes - while SPI transfer to DWM1000
  236. Where is the file 49-teensy.rules?
  237. LED's flickering when white.
  238. Arduino IDE with Teensy plugin on Linux, can't see Teensy in the port-selection
  239. Closing Serial Monitor Window stalls Teensy 3.1
  240. Missing data when size increase
  241. Can analog input pins be set to digital pins using pinMode or other means?
  242. What are the difference between libraries: Arduino Wire, Teensy Wire and I2C_t3?
  243. Teensy 3.1 + Processing Serial Speed
  244. Teensy 3 and ADC : is there a way to sample in "normal stop mode" ?
  245. Teensy 3.2 MIDI OUT Connection + MIDI Through
  246. Serial transmission status registers
  247. Teensy 3.2 + Pesky SPIFlash memory + Adafruit BNO055
  248. freeze: Teensy 3.2 + multiple ATTiny85 I2C
  249. Memory usage is much higher when building for teensy
  250. USB CDC flow control for "data loss" detection
