- Teensy with BLE and OLED muliple SPI devices - display not working
- Need help with an example (mediabuttons)
- XPlane GNS 430 DataRefs or Commands
- Teensy3.2: WS2801 Led's not preforming corrctly
- Interrupts
- Pixels not updating on LED array D:
- Sparkfun Autodriver L6470 not working completely on Teensy 3.2, and I don't know why?
- Teensy 3.2 OLED LCD Display Help
- FreqCounter for Theremin
- Which USB Hubs Work Well with Teensy?
- openFrameworks serial communicaton
- Teensy ++ 2.0 ( led and diode broken)
- Code suddenly stopped working, tried troubleshooting, any tips?
- GPIO read issue...
- Audio Adaptor stops working after a few seconds
- Potentiometers using MIDI.ControlChange
- Teensy 3.2 Midi Code Problem
- Complete beginner to interrupts, trying to make a counter.
- Teensy compile errors for HDQ Arduino library
- Program Stops Running Intermittently
- Addition of Processor ID to Teensy Cards
- Serial Issue with Teensy
- Over-the-air programming for Teensy
- Teensy 3.1 and Raspberry Pi 2 Serial Problem goes mute
- Teensy correctly blinking but usb not detectable.
- Generating 0.5us long pulse & counting rising edges with 0.5us resolution
- Octows 2811 Adaptor & Teensy 3.2 setp up with 480 WS2801 LED's
- Setting build options in code
- How to clean the Teensy 3.2
- Teensy 3.2 : Error opening serial port 'COMx' (Port busy).
- Teensy 3.0 Flexible led Display
- Algorithm used in PulsePosition library
- IntervalTimer not interrupting loop()
- Build options changed, rebuilding all
- EEPROM issues
- Teensy 3.2 with 12864 Full Graphic Smart Controller
- Teensy Audio and I2C serial converter for LCD screen
- Teensy LC and IntervalTimer - working proprely ?
- Midi In Connection on the Teensy 3.2
- Custom USB wiring
- Problem to insert my code into Teensy 3.2
- serial1.write
- Internal Pullup resistor as a Mosfet gate resistor
- Clocking in Individual Bits
- Serial1.available() seems to fail when first byte is NULL
- Teensy EMC sensibility (electromagnetic immunity)
- ArduCAM with Teensy 3.2
- FreqCount library counter every 2ms
- Analog input impedance and pull-up?
- WS2801 LEDs flicker with 12v LEDs and 5.5v or higher only with 3.1 not older 3.0
- There is an error in the calculation of yaw angle with 9 DOF sensor.
- Teensy LC with touchscreen
- Adafruit WINC1500 WiFi module with a Teensy 3.1?
- Teensy 3.2 Using Interval Timer
- UART Test using example code.
- Having trouble using multiple devices with a FIFO SPI library?
- Noisy output when playing recorded line in signal
- Pin assignment on FreqCount
- Seiral / USB problems
- Teensy-LC Custom USB Settings
- Teensy 3.2 - prop shield - ws2801
- Logic behind Teensy pin outs for Octowall
- Optimizing live screen capture based on movie2serial
- WS2801 random lighting
- Teensy 3.2 + Adafruit nRF8001 (not advertising etc.)
- Teensy 3.2 - SPI Clock over 30 MHz.
- Max DMA Buffer Size ?
- USB through Pogo Pins
- Teensy 3.2 SBUS
- 5v-Serial @ Teensy 3.2 unstable?
- Teensy 2.0 keyboard Troubleshooting
- OSC message error
- Need Help with Timers..
- Problem with i2c_t3/IntervalTimer/RingBuffer and Serial output
- Teensy 3.2 Bluetooth Joystick Help Needed
- Teensy 3.2 with Audio Board and ILI9341 2.8 inch Touch Screen
- NeoPixel RGBW compiler error
- Does Teensy lock the flash memory ?
- teensy as PS/2 barcode reader device
- i burned my dac
- Teensy 3.2 Arduino 1.6.8 Teensyduino 1.28 where are the libraries?
- Enabling a single interrupt (A0) only
- Wiz820io probs, Please check my wiring
- hangs at same point every time when power cycled but not after flash
- Using multiple Teensy3.2 HID on one PC question.
- USB communication with battery power
- Teensy 3.2 EEPROM issues
- Custom Teensy PCB not responding
- Wiring Issues
- Teensy ++ 2.0 keyboard - double hits
- WIZ820io adapter Rev2 changes, reset chip datasheet, using with WIZ850io
- Maximum number of FlightSimIntegers of 10??
- Low power USB
- Teensy 3.2 CLKOUT fail
- Teensy 3.1 "Unable to Reboot" & "Download Error"
- Part for Teensy 3.2 USB pads?
- Teensy 3.1 and Neopixel 8x8 matrix
- Teensy not listed in the serial ports list - programs are uploaded although
- Encder with Teensy LC
- Constant Problems with 124x68 OLED
- Adding colours to the ILI9341_t3 library
- USB Power for teensy3.2
- Teensy 2++ input voltage
- WS2812B strips odd behavior w/ ArtNet
- Teensy LC Increase EEPROM Size
- digitalWriteFast - Teensy 2 and 3.2...
- blink = OK! SDcardtest or Hardware_Test (audio) CRASH!
- Powerboost 1000C + Teensey
- ESP07 -> Teensy pins for ESP programming mode
- Teensy 3.2 problem with Visual Micro "debugging" on UART serial port
- Which Pogo pin to use for Reset on T3.2?
- Teensy 3.1 / adafruit 1.77" tft
- Can't merge I2C and serial streams to USB
- Analog Reference Low issue
- Baffled - Please help - Quad buffer / line driver tri state circuit issue
- Read 3 or 4 ADC without hanging
- Yet another ILI9341 driver problem!
- Calculating ideal PWM frequencies when overclocking (120,144,168 MHz)
- updating time date
- Building BlinkLED
- RA8875 external font use
- accidentally overwritten the bootloader?
- XPT2046 touch IRQ issue
- How to share SPI with the Audio optimized SD library ???
- TMC2100 Stepper Motor Driver
- Multiple CDC on Teensy 3.1/3.2?
- Teensy 3.2 + Adafruit BNO055 IMU + i2c_t3 startup problems
- Serial Rx Only
- Teensy 3.2 File Error & Light not blinking & SMD fell off
- POR and LVD on Teensy
- Confusion about value of Teeensy's 3.1/3.2 internal input pullup resistors
- Teensy UART at high baud rates
- RawHid for 64 Bit Windows
- Getting the yellow Triangle w/ Exclamation point
- Convert Teensy DAC Single Ended Output to Differential Output
- Too many objects?
- Can Teensy be used to capture USB data from a USB cable ?
- drop-in MCU upgrade?
- Peensy missing library help
- OSC message value always 0 after sending with SLIP
- USB RawHID message size (teensy 3.1)
- Bricked Teensy - cannot erase flash?
- Powering Teensy 3.2 and Smartphone
- Trying to get more than 12 commands on teensy LC
- Website bug: bugzlilla link forbidden
- Audio tool generation bug: renaming nodes
- Burned teensy 3.1, can I replace mk20dx256?
- What is with 32768 Hz crystal for the teensy 2.0 ++?
- TimeAlarms Library: how to update the timer?
- TeensyLC Alternate UART0 / Serial1
- SPI max 5 MHZ
- Why is the Reset button sometimes needed but sometimes not?
- max supply voltage to operate teensy 2.0
- Questions regarding the EzPort on MK20 (for Teensy 3.2)
- No console output from Teensy 3.2 using L3GD20H library
- Using "StandardCPlusPlus" library with teensy doesn't compile. Works on arduinos
- SPI Returns Zero with IMU Sensor on Teensy 3.2
- MIDI Data Thinning/Running Status, etc.
- .elf file generated in arduino for MK20DX256VLH7 is not working.
- Midi usb raw input question and possible bug in usb_midi.h
- I need to know, how to: read - write onewire eprom 33+ , 45+
- analogRead not working with rotary pot?
- joy.cpl appearance
- Arduino String: How to identify valid float
- TimerOne Library timer pins on Teensy-LC
- Teensy 3.2 and New Haven LCD
- XPT2046 Touchscreen project questions
- Please help a lugnut...
- Blusmirf Gold and teensy 3.0
- bme280 board. Does it need external pullups?
- Not seeing the audio examples in Arduino 1.6.9
- Cpu saturation?
- MK20DX256VLH7 Fuse settings?
- Snooze deepSleep drawing almost 40ma
- Teensy listen to audio shield without controlling it
- Sine Wave Example Requirements
- Help with code for LCD display
- Teensy 2.0 Registers Multiple Times Per Button Press
- NRF24L01+ and Teensy 3.2... Fail
- Cannot get button to work with external interrupt
- Serial.print can fail?
- Using Teensy Loader (GUI) to trigger the board into Bootloader mode
- LC uC Pin 13 aka PTE29 as GPIO Output High / Low
- Intermittent problems compiling
- arm-none-eabi-objcopy crashes on big arrays on MSWin.
- conditional statements not equivalent - why?
- 7 Segment LED troubles
- DMA memset()
- code to implement, teensy 3.2 to glediator to ucs1903 string
- Are Teensy3.2 Pins High Low and Tri State
- Flex timer overflow isr not firing!
- Help Please: Error while setting serial port parameters: 115,200 N 8 1
- Teensy 3.2 + Prop Shield trouble getting audio on flash
- Can't read from serial device?
- Audio shield + prop shield
- Timer1.read()
- ILI9341 readcommand8 not working.
- Teensy 3.2 and mbed-rtos
- Distorted audio when using USB input on Teensy 3.1
- Prop Shield Angular Velocity
- Help with bare metal USB device driver
- DMA: Possible to transfer bytes twice?
- Small MIDI issue for a newbie
- RFM69 + RadioHead issue
- Cannot read from serial port
- Thoughts on feasibility of self-updating from an SD card
- Pogo pins and I2S speed
- Driving LED strips off USB power, and negotiating USB 3.0 power levels
- Interrupts and declarations
- Connecting 2 or more Teensy together
- Teensy LC with ShiftPWM
- Homemade-motor-encoder-works-great-on-Mega-not-so-well-on-Teensy3-1
- Teensy 3.x USB Host?
- Teensy with APA102 for many strips
- newbie needs help on Serial.read ()
- Scanner Discovery Problem
- Migration from MEGA to TEENSY3.2
- highByte and lowByte not compiling
- Arduino 1.6.8 exits when I plug Teensy 3.2 in suspepect java problem
- Need coding help and modding Mixman DM2 DJ Gear.
- Pin 13 and Bounce2 (Teensy 3,2)
- LC Doesn't Repond to Reset Button
- Arduino code will not compile with Teensy 3.2
- Teensy 3.2 Pin A11 ADC function
- set -D compiler option in Arduino IDE?
- Differential ADC Maximum Input Voltage
- Update firmware of Teensy ++2.0 using another microcontroller over UART
- Core_pins.h issues, stuff not declared in this scope
- Audio Workshop Part_3_03_TFT_Display Code Compatibility
- OLED Display for Teensy 3.2 + CANBus + Megasquirt 2/3
- USB Midi overflow
- Custom Teensy 3.2 via probes and bread-board is not getting programmed.
- Need help using Teensy++
- attachInterrupt , digitalPinToInterrupt question
- PS2Keyboard Library with Flexible USB/PS2 Keyboard
- FreqCount/FreqMeasure on Arduino Mega2560
- Arduino crashes in SerialBoardsLister upon startup after teensy install
- Teensy 3.2 with Prop Shield issues with IR
- LLVM and Cortex-M4
- ADC slowest speed configuration (Teensy 3.2)
- USB Serial C Code on Teensy 3.2
- Teensy 3.2 16 bit differential mode only returns 15 bits
- circuit for fbas/cvbs -> adc
- Increasing Serial TX abd RX buffer size to 1024
- 3.2" IPS display, possible with Teensy 3.2? (hx8357b OR ILI9481 chipset)
- Errors with example TimeNTP_ESP8266WiFi
- Paired Emitter Detector Diodes
- Movie2serial: limit on the number of LEDs per teensy?
