View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Using SparkFun's RFM69HCW and Bi-Directional Logic Level Converter with Teensy 3.2
  2. change sample rate in Recorder.ino?
  3. Inconsistent clock line with multiple SPI devices
  4. Mains noise problem and reduced sensitivity
  5. Saving Data/SD Card Problems
  6. Maximum sizie of WS2811 displayMemory
  7. Do I need libusb-1.0-dev as well as libusb-dev?
  8. Teensy 3.2 / SPI Flash Memory Erase Issue
  9. Teensy drivers
  10. teensy to matrix board with 400 ucs1903 ledstring output destroyed teensy ???
  11. What is -DOS_$(OS) in the rawhid_test makefile?
  12. What to Do with Reset Pin on MKL26 when Removed From Teensy-LC board
  13. Serial.println() and serial capture
  14. Compiling error
  15. Defining USB Keyboard Codepage
  16. Sending string data over Serial1 to trigger usb.MIDIsendNote
  17. Simple Serial Question..
  18. How to tell my Teensy is dead?
  19. FreqCounter or FreqMeasure libraries with nano, pro mini, or attiny85?
  20. ILI9341 & XTP2046 Touch problems
  21. shiftPWM compiling error problem(teensy 3.2)
  22. Weird GPS problem
  23. Teensy 3.2 + Seeed Studio CAN-Bus Shield - Showing RX on CAN Shield but no data
  24. FLEXCAN problem on teensy 3.2
  25. Adafruit RFM69HCW Breakout Not Functioning with Teensy 3.2 and RFM69 Libraries
  26. Best way to convert GPS coordinates to decimal in my project.
  27. Creating a varriable wien bridge oscillator
  28. no matching function for call to 'RPLidar::begin(usb_serial_class&)'
  29. Teensy3.2 Teensy Loader - Arduino settings
  30. I2C Code with SSCDANT030PG2A3 and the Teensy 3.2
  31. Which communication protocol to use?
  32. Teensy LC internal EEPROM issue
  33. Decoupling caps, PCB layout?
  34. No Serial Port name defined
  35. C++ how to call one constructor from another, happy to pay for some consulting time
  36. DAC protection to reverse voltage
  37. RadioHead with SPI transactions - success with RFM69HCW and ILI9341 based TFT
  38. Teensy LC DAC on during hibernate
  39. Ethernet Library Questions
  40. Teensy_reboot.exe stacking, 100% CPU
  41. Teensy 3.2 SD card problem
  42. Burning .hex file of teensy3.2 in blank mk20dx256.
  43. Setting flash security byte
  44. Touchread sawtooth noise visible on separate (analogRead) pins
  45. teensy 3.2 and old sd card adaptor
  46. Knocked an SMD component off a T3.1, can I still use it?
  47. PROP_LC Hot Amp Chip
  48. Question re: setTime(t)
  49. Connecting LED strips to ground
  50. Teensy Audio Shield Capacitor's are not polarized? Right?
  51. How to connect tennsy 3.2 + maxbotic i2c sonar??
  52. newbee help
  53. USB not recognised in custom teensy
  54. How do backup flash and eeprom contents from a teensy
  55. How to send a binary file for a customer to update a Teensy 3.2 system?
  56. Trying to read i2s directly from SGTL5000
  57. Subclass HardwareSerial and serialEvent to access Serial1, Serial2 on Teensy 3.2
  58. Do UARTs and HardwareSerial use interrupts or not?
  59. Receive data from serial on pins 0/1
  60. Sending simple "console" commands through serial Tx
  61. Can't get audio signal from mic on Audio Board (w/ Teensy 3.2)
  62. SOLVED - "Dead Spots" in Analog Read values - arbitrary-base values with Serial.print
  63. ADC - is many analog signals measure in time possible?
  64. Teensy 3.2 fails after an hour of data taking
  65. VS Error from macro AudioMemory(num) in AudioStream.h
  66. Battery powered Teensy
  67. I need some pointers on finding documentation, Teensy3Clock
  68. Error Compling for board Teensy 3.2/3.1
  69. Teensyduino 1.29 installer failure
  70. How to keep .WAV file in teensy 3.2.
  71. Cortex-M0+ Documentation
  72. USB noise in ADC readings?
  73. Problems w/ Teensy 3.1/3.2 and Adafruit SD Breakout
  74. Error from EEPROM library while compiling
  75. Maximum baud of AltSoftwareSerial with other serial communication hardware present
  76. Measure CPU time of Audio library output object's ISR
  77. Load RAW image from SPI Flash to ILI9341 TFT (Teensy 3.2)
  78. Using a Seeed Grove TH02 Temp/humidity sensor on teensy 3.2
  79. Teensyduino not installing example code on Windows 10
  80. Teensy 3.x C-compiler
  81. Problem with OctoWS2811 Library (Leds basically just white)
  82. Teensy Internal Reference Voltage Question
  83. LED Hoop Repair with APA102-C LED strip HELP PLEASE!
  84. Overlay support on arm-none-eabi-gcc toolchain
  85. Seem to have bricked two Teensy 3.2's in rapid succession
  86. Compile problem - include directories
  87. Employing Extended Kalman Filter for battery SOC meter
  88. Keyboard special keys volume
  89. Advice on UART and SPI pin connections for a shield for Teensy3.2 that i am designing
  90. MIDI library + Capacitive sensor Library Problems
  91. Updating Arduino IDE
  92. WIZ820io on different pins?
  93. Serial Teensy 3.2 and Processing = Error, disabling serialEvent()
  94. 2.2 TFT SPI Does Not Display
  95. Teensy3.2 Serial Ports talk
  96. Compile Problem - Ethernet and SPI
  97. Any advice re: Windows 7 and Serial not working?
  98. Typewriter: Using сard reader and usb host shield at the same time on Teensy 2.0
  99. APA102 sticking in SPI mode using FastLED.h
  100. Teensy 3.2 bottom pads: Is there some connector for that?
  101. Flash memory jump instructions
  102. ZoneAlarm Error in Teensy 3.2.
  103. Teensy 3.1 + FastLED with USB and external power
  104. Export for ILI9341_t3 with GIMP
  105. USB pad locations on Teensy 3.2
  106. std::map error: undefined reference to std::_Rb_tree_decrement
  107. could somebody tell me why this isnt working for me please?
  108. USB serial flow control Teensy LC
  109. Teensy Low Voltage Operation?
  110. How to dump serial port output to a memory card for later analysis
  111. Teensy 3.2 flashed program does not run without USB cable
  112. Teensy3.2 I2S Data Format
  113. External power: one or both ground pins?
  114. Strange problem with linking causing Undefined reference to Serial
  115. 16 bit diff mode maximum voltage
  116. ILI9341 graphicstest compiles but removes serial com port from Windows 10
  117. TeensyDuino 1.29 gives EEPROM warning. I suggest the fix...
  118. Connecting 2 or more Teensy together with RS485
  119. USB serial control for 3rd party device
  120. Teensy 2.0 USB Keyboard+Mouse in C?
  121. wiz820 v1 vs v2 adaptor board issues
  122. Help With RFM69HCW Radio
  123. is String obejct a good way to build up string from multiple pieces?
  124. Teensy w/ OctoWS2811 to BBB
  125. Teensy-LC stopped working, no longer detected on pc
  126. A Revisit to RDM on Teensy 3.2
  127. mk20dx256 external interrupts in teensyduino
  128. leaner (than 16 KBytes) printf?
  129. FastLED freezing with prop shield
  130. Daily Alarms setup
  131. Teensy 3.2 won't work with external power?
  132. Bricked Teensy 3.1
  133. Modifying the pins that FreqMeasure library uses
  134. Control LEDs over Artnet -> Teensy 3.2 & OctoWS2811 & WIZ820io & WS2812 LED Strips
  135. Audio library blocking other code in the loop section?
  136. ili9341 LCD display getting off after 10 minutes
  137. Teensy 3.2 Interrupt
  138. DMASPI library needs some (probably breaking) changes to really support multiple SPIs
  139. Audio adapter input all -1
  140. Problem sending Byte Array with BLE
  141. Teeensy-LC MKL26Z64VLH4 Support
  142. fps gt-511c3 library for teensy
  143. Hardware SPI1 on Teensy-LC
  144. Can't get Part 1 02 of Audio tutorial to work
  145. Bought some 18b20 temp sensors on ebay. Are they fake? or am I doing something wrong?
  146. RADIOHEAD - Questions about versions, beginTransaction, multiple buss
  147. Unable to access file system on sd card.
  148. OctoWs2811 Adaptor Voltage problem
  149. Converting a Yamaha keyboard assembly with a Teensy to a MIDI controller
  150. AS5048A rotary magnetic encoder.
  151. neopixel compass not working with prop shield
  152. Code update without Arduino IDE and no button
  153. Teensy hangs up after few manipulations with LEDs
  154. Stoping a Midi Trigger with Interrupt
  155. troubleshooting a midi + keyboard combo
  156. union + struct not working (but works on arduino mega)
  157. Force Teensy to reboot and load program via USB
  158. Audio adapter and RTC
  159. Serial.print() sometimes does not work
  160. New Prop Shield dead to i2c
  161. Teensy 3.2 SDFat library SCK assignment from Pin 13 LED to Pin 14
  162. General questions about Teensy 3.2
  163. Compile problem
  164. How many Pixel can Teensy 3.2 Drive ?
  165. Compilng C code and for the teensy
  166. Speed up "Preparing boards"
  167. Is serialflash library compatible with 8-bit AVRs?
  168. PCA9685 Boards - ideal Wire settings for Teensy LC?
  169. SPI Chip Select
  170. SerialFlash CopyFromSerial instructions
  171. What programming language does Teensy use?
  172. Teensy 3.0 capactive touch noise induced by computer
  173. Teensy-LC with ST7735
  174. Complete newbie
  175. Bluefruit le friend uart and teensy lc
  176. APA102, FastLED, Teensyduino 1.29, Teensy 3.2 - Hanging after random number of shows
  177. Dynamic sized global array
  178. USB teensy does not wake up OS X computer
  179. Teensy support with Arduino 1.7.10?
  180. ShiftOut or SPI at 3 MHz
  181. LSM9DS0 + Teensy + Madgwick Filter Redux: Inverted Mag Z and slow response?
  182. keyboard teensy LC, how i generate key "<" and ">" with config key azerty ?
  183. FreqMeasureMulti usage.
  184. Quadrature Counters on T3.5 / T3.6
  185. Adding Teensey Board to Arduino 1.6.10
  186. Controlling the Power Supplied to Touchscreen's LED Pin
  187. Teensy LC max SPI Speed
  188. MK20 PTA3 Debug
  189. Teensy 3.6 microSD pins?
  190. Use Teensy 3.1 as Slave first, then Master second
  191. Teensy 3.2 reboot issues
  192. SMPTE, biphase mark encoding and FLEX timer
  193. [ws2811 led strip] where to attach DI/GND/+5V to the strip?
  194. OTA updates for confused beginner.
  195. Maximum serial port speed on Teensy 3.2?
  196. no communication com port (usb) available in glediator (rtxt and jar file)
  197. Teensy 3.6 MPU puzzle?
  198. Teensy pin out trimmed down
  199. elapsedMillis ?
  200. Problems w Movie2Serial
  201. Wiz820io connection fail
  202. teensy_loader_cli on OSX: "Error opening HID Manager"
  203. Reassinging SPI pins in Due
  204. numlock and capslock LED
  205. Teensy 3.2 gamebuino game sytem with color lcd + button inputs
  206. OctoWS2811 causes garbage on Serial1?
  207. ethernet server won't start
  208. Problem with 23LC1024 RAM memory
  209. Teensy LC ADC input protection - which input impedance is acceptable?
  210. Help needed ! Is there some conflict between HW SPI and ADC sampling on Teensy 3.2 ?
  211. Counterfeit, need confirmation please !
  212. sprintf() definition location within Teensyduino.
  213. TeensyDuino and avr-libc-2.0.0?
  214. No serial window repsonse from ESP-01 using teensy 3.2
  215. Soft Start Circuit, review and critique requested
  216. Help with compile error.
  217. SDHC Interrupt Priority and Card Detect?
  218. SPI for Teensy 3.6 On-board microSD?
  219. Stray Capacitance at Vin?
  220. Teensy 3.1 DMX Receiver with MAX485
  221. Teensy 3.1 to Arduino Mega data transfer - EasyTransfer
  222. Drivers installed but no port in arduino IDE
  223. Run a Sketch only once
  224. Teensy Loader -- Error writing to Teensy LC
  225. OCTOWS2811 drawingMemory size
  226. Crystal of Teensy 3.2
  227. Teensy 3.6 SD busy yield()?
  228. Help using OLED SSD1306 I2C on SCL1 and SDA1
  229. IntervalTimer for very short intervals?
  230. Try SdFat forTeensy 3.5/3.6
  231. Clock source for Audio board
  232. Struggling with 1.5.x + version of SdFat on Teensy
  233. Prop Shield hole and pad positions
  234. Teensy 3.6 pinout, uppercase and lowercase?
  235. Teensy input pins best practice.
  236. Teensy creating two joystick input devices in a Rpi
  237. Teensy, IMU & Madgick Algorithm [kind of a strange bug]
  238. Build Issue Teensy 3.2: __AVR__ defined?
  239. DS3234 clock SRAM question
  240. Changing Product ID
  241. Teensy 3.2 Interrups to Blink LED's at Different Rates
  242. Is Teensy 3.2++ compatible with RS422?
  243. OctoWS2811 Adaptor: documentation clarification
  244. Avoid EEPROM reset when flashing
  245. Teensy++ 2.0 - LPD8806 Getting the proper pin assignment
  246. AudioConnection line of code breaks LED strip
  247. EEPROM writing on T_3.6 in HSRUN mode
  248. Custom Teensy3.2 not getting flashed even with specific bootloader.
  249. question: TFT vs LCD Teensy3.2, Paul Stoffregen Library
  250. Minimum I2C speed for Teensy3.2 with Teensyduino?
