- Servo fails over Serial3
- Prop Shield LM48310 Alternatives
- Teensy 3.2 and esp8266 OSC communication
- White screen with ILI9341 & SD data logger
- Measuring Duty Cycle using Teensy 3.2
- Upload sketch form commandline
- Connect teensy 3.2 to HC-05 bluetooth module
- OSCTime
- WCHAR_T definition
- Need to do lots of "things" while playing back audio through prop shield. Possible?
- Characters on USB Serial on Reboot (Mac OS X)
- Use Can Bus Port as Serial Port ?
- OctoWS2811 Adaptor, Teensy 3.2 and FastLED
- CANbus Teensy3.2 : Cyclic Redundancy Check
- Modbus RTU
- FFT with Audio library - compiling error (SDFile problem)
- Change Core MIDI Name
- Teensy ++ 2.0 Serial Output to LPD8806 from Glediator
- teensy code wont compile with SD library included
- Elechouse CC1101 Library issue
- Issue: Teensy 3.3 randomly boots into bootload while no USB is connected
- teensy loader
- Teensy 3.2 internal RTC
- teensy 3.2 analog voltage measurements, I'm off by 10% and I don't understand why
- Changing sample playback rate on internal DAC
- webserver application, client.print doesn't work if there is a call
- Detecting LED status on boot
- LCD with Teensy ?
- Use MCLK Pin otherwise
- using GPIO onTeensy 3.0 with OctoWS2811
- dead teensy 3.1
- Serial.write inside #ifdef inside setup() function doesn't work with Teensy LC
- Want to use Adafruit_MCP23017 library with i2c_t3 instead of Wire.
- Using libary in class
- Audio Sequencer: IntervalTimer + ILI9341 + AudioPlaySdWav
- Adding delays to serial Midi messages
- Measuring pulse width, interrupts
- Custom Teensy LC with MKL20 and MKL26Z128VFT4 (128kb flash)
- Teensy audio board clock lines
- Intermittent Error compiling for boardTeensy 3.2 / 3.1.
- using A6 and A7
- Teensy 3.2 Locked up. Unable to load new program
- Teensy LC interrupt
- What am I doing wrong? LPD8806 parallel output.
- Problem to use float to char convertion.
- Program Teensy 3.2 from within my own (windows) program
- Maximum frequency when using FreqCount
- Teensy 3.2 Through-hole damaged due to bad soldering
- teensy 3.2 pin mux control
- power down EEPROM (flash) save
- Teensy 3.2 crashes while playing music
- Teensy 3.2 did not work with 3.3V coin cell?
- Suggestions for sockets to use for new Teensy 3.5/6?
- Motor Controller software hanging
- Connecting Teensy 3.2 to Prop shield for LED strip(APA102)
- Example for write and read a TXT File by SerialFlash
- Several Teensy 3.2 + I2C communication + Octows2811 = flashing neopixels
- Arduino Serial Plotter Stopped Working
- 5200 board and wiz net
- Odd issue with MIDI Controller and Windows
- Teensy Audio Board input voltage requirements.
- Teensy 3.2 Pinout Issues
- PJRC update to reflect 3.5/3.6 Info
- Planned support for Teensy LC and 3.2?
- RESET-Pin as Output ?
- where is I2S0_RXD1 on T3.6?
- Teensy 3.2 crashes when playing audio from Prop Shield flash and running FastLED
- Teensy 3.2 + OctoWS2811 : Proper Wiring
- Teensy 3.2 and ethernet
- Teensy library vs arduino
- Installing Teensy - nothing is visible in Arduino?
- Using ethernet on Teensy 3.5/3.6
- Flash firmware to multiple connected Teensy 3
- FreqMeasureMulti library reliability in the 1kHz - 2kHz range?
- EraseEverything sketch how much it can take?
- Question to the experts: Position of WLAN + Long Range RFM9xW on PCB
- 5v to 3.3v analog translation
- Unable To Compile Teensyduino Included FastLED Library Against 3.1/3.2
- I2C Pull-Up resistor Question - Using both a 3.3v and 5v (Not the standard question!)
- ILI9341 8-bit Parallel TFT LCD
- Teensy 3.2 EEPROM Write Question
- No GND = sound, GND = No Sound on Audio Adaptor
- Can't program Teensy 3.1
- Audio Adapter SGTL5000 Group Delay
- analogeRead confusion
- Slow Teensy write speeds from Windows compared to OSX
- Serial write speed slowdown across multi-TT hub ports
- teensy 3.2 i2c
- Teensy loader not recognizing Teensy 3.2
- Teensy 3.5 initially worked, but now not recognized by Win 10. COM port strangeness?
- T_3.6 acting oddly: Program Button doing a reset, no bootloader reprogram
- Problem with FFT and SPI communication
- Windows wont recognize Teensy 2.0 ++ @v3.3
- Can't program 3.6 on Ubuntu
- Teensy++ 2.0 not working anymore in Windows 10
- microSD slot on teensy 3.6
- Rotate axes on Prop Shield Motion Sensors
- Prop Shield AGND + Audio
- Teensy audio board + i2c oled
- Audio adapter, direct analogWrite()?
- USB Keyboard code/example not working
- Teensy 3.2 not responding to PROGRAM pin - where is that trace supposed to go?
- Teensy 3.5 DMASPI: Differences between T3.5 and T3.6?
- Bluetooth HC-06 interference with DAC of Teensy 3.2
- Teensy.exe "problem"
- OctoWS2811 - movie2serial - two Teensy 3.1/3.2 - Framerate drops if 2nd Teensy is on
- Problem reading file from Flash SPI using serialFlash library
- Teensy 3.2 ADC with Continuous Read
- Can I use the Teensy to emulate a USB mass storage device to the host?
- Can I use the Teensy to emulate a SD memory card (to deliver a virtual block device)
- Analog/Digital pin conflict in joystick loop?
- possible to wire two octows2811 boards to a teensy 3.6?
- Mixing codes
- SD card with the 3.5/3.6 boards
- Add Second USB-Serial ?
- Please review my Eagle sch+brd files - first time user
- Simply USB Joystick (Very Simple)
- Teensy 3.6
- Measure LiPo battery voltage in Teensy 3.2
- Teensy 3.1 as Disk, can be possible?
- Oled_ssd1306 library stuck pixel
- Custom board with MK02 and MK20 not responding
- Please help: Extremely slow USB transfer
- PSP Joysticks with Teensy 2.0
- Why is my Blink program taking 11,748 bytes of flash memory?
- eeprom_read_* functions: address parameter of different sizes ??? (byte/word/dword)
- TJCTM24028-SPI screen+touch+sd?
- Teensy++ PA, PB, PC, PE, PF digital IO
- TX MIDI out on Teensy 2.0
- Teensy 3.6 ST7735 Example does not Compile
- Differentiate between Teensies based on USB information
- Prop Shield Compatible with Teensy 3.6?
- Analog Read Resistance
- Teensy 2.0 does not accept new sketches.
- Need help using TimeOne
- Midi 4.2 no activity on serial port
- MKL26Z64VLH4 64 pin LQFP IC with teensy LC
- MK20DX32VLF5 50 MHZ controller on Teensy 3
- Unable to upload sketches
- ADS1115 lib with SCL1/SDA1 on teensy 3.1 issues
- i2c_t3 communication Failure with basic_slave and basic_master sketch
- Trying to get SPI1 working on Teensy-LC
- Audio/led noise / distortion
- AccelStepper bundled with TeensyDuino considered harmful
- ST7735 Fonts
- Code test for teensy compilation + problem for delay
- Simulink Embedded Coder TARGET
- Teensy 3.6 debug support
- touchRead and CapacitiveSensor.h - are they the same?
- Serial on T3.2 FREEZE
- Teensy 3.6 Power supply
- Resistors education please- with prop shield and with normal Teensy 3.2
- Teensy 3.2 on board D to A
- Battery measurement using Voltage Divider on Teensy 3.2
- Encoder Resolution
- the Teensy 3.2 working voltage
- Code Help, Arduino to Teensy 3.2
- TeensyDuino Installation and Wire.cpp
- Audio Adaptor Board record from usb
- Advice and suggestins for porting WiFi drivers(CC3100)and a NES Emulator to Teensy3.2
- Teensy 3.2 + FastLed + LPD8806
- Help Needed - Proper way to read Teensy 3.6 MAC Address
- I2C Communication of three Arduinos
- Teensy 3.6 schematics?
- Still have Timer questions about the 3.6 Teensy
- Teensy 3 Mouse on Android doesn't work if Serial mode is enabled
- DeadOn RTC - DS3234 Breakout-v11 SRAM fix
- Audio FSK for use with a Ham radio
- SPI flash works on T-3.2 but not T-LC
- Teensyduino for basic MIDI MAPPING in Ableton
- Mix sound from mic with SDcard playing on teensy?
- Several questions about the Teensy 3.5 & 3.6 boards
- Teensyduino Media Keys
- Cannot communicate between two Teensy 3.2 via UART
- WS2811 large project help
- How To Load Multiple Sketches
- DMXReceiver and FastLED
- How to run Teensyduino installer for Raspberry Pi
- Teensy 3.2 seem to be malfunctioning
- Teensy LC - pinMode code explanation
- Servo library not working
- Teensy 3.6 - Modify teensy_loader_cli.c
- Install Teensyduino under Ubuntu 16.04
- how do protect data when handling multiple interrupts that access the same data
- Servo Sweep Example Not working
- How to detect a broken Prop shield?
- Support for Arduino 1.6.12
- Teensy LC with Kinetis Design Studio - hex file not working
- Array of hex to char string
- Teensy 2.0, USB MIDI and SysEx
- Spansion S25FL164K issue
- Error compiling example (1.30 & 1.6.11)
- TEENSY LC PWM outputs don't all work
- EMI shield
- 3.6 + vs1053
- Teensy 3.6 timers & frequency
- HelloWorld CAN bus with 2 Teensy3.1-s using FlexCAN
- Use Sublime Text as an Arduino IDE replacement.
- Teensy 3.6 "PassThroughStereo" issue
- Power supply pulling during SD card writes
- Teensy LC with RFM69HCW Breakout
- re-use global variable space for character arrays
- Connect 100+ steppers to Teensy
- Linker failing build blink for Teensy 3.6
- How to use APA102 LEDs and an SPI Oled with a Prop Shield and hardware SPI
- Change Image on LCD
- getting started wiz820io
- overclock
- What mpr121 library works with teensy 3.2?
- Need help debugging Teensy LC as HID
- BasicTest on Teensy 3.2
- Teensy 3.2: change the pwm frequency, IntervalTimer
- Sending data using RawHID
- Teensy 3.5: FPU limited to 8-bit precision and ADC speeds?
- Bluetooth and Joystick with teensy
- Teensy 3.2: usage of Midi-USB and Midi DIN together
- Teensy 3.6 - Schematic / Detailed Information?
- SPI Mode Confusion
- ISR Timer Question
- Can't install Teensy loader on Mac - what location?
- Can't get SPI to work on Teensy 3.2
- Functor Callbacks will not Compile for Teensy 3
- Linker script error: .text overlaps .data
- int Array over Serial treated as unsigned int
- ethernet initialization
- Unable To Read Voltage Change Across Variable Resistor (Not Potentiometer)
- F_CPU settings for 3.5/3.6?
- Rough idea of date when DE on 3.5/3.6 will be functional?
- pgmspace errors teensy 3.2 powered diy gaming
- Teensy 3.6 not working
- Using Teensy Prop Shield to adjust LED brightness
- How does Teensy-Reboot.exe communicate ?
- Audio WM8731 T3.6: I2S breaks I2C?
- 64bit and IEEE754 representation and math
- MAP Command Questions
- 3.2, what is the fastest possible digital pin read method?
- faster FPU operations
- Compiling Teesy 3.5 and Adafruit_TFTLCD
- uSDFS on Teensy 3.6
- blink_fast.hex file for Teensy 3.5
- Created 8 pixel high bold font for Adafruit GFX lib (useful on a 128 x 64 display)
- atmega timers conversion to teensy 3.2 for 16-bit gaming library
- wiz820io server not initializing to fixed IP
- Possible uSDFS problem.
- Adafruit ST7735 errors with 3.6
- Another PulsePosition Library Question.
- Reading the 3.6 legend card
- SPI CS0 pins as inputs on Teensy 3.5/3.6
- On the 3.5/3.6 Kickstarter page, why are the ADCs 13-bit when they are 16-bit
- Teenys 3.6 Code not working
