- Problems with Encoder-Lib and PEC16-4020F Encoder
- Can't seem to debounce buttons...
- Noise with ESP8266
- usbMIDI Controller Digital Pin 0 Problem
- Teensy v3.2 + octoWS2811 + WS2812b flickering
- line-in connections
- teensy_loader_cli on 3.5 & 3.6
- usb_configured on teensy 3.2
- Serial Flash rewrite question
- Teensy ++ 2.0 Self flash
- Reboot Teensy 3.2 programmatically
- Teensy 3.2 audio library pin configuration defaults without STGL5000
- Change Joystick USB Name
- Color 320x240 TFT Touchscreen, ILI9341 Controller Chip - not working
- Teensy gamepad no longer working
- SainSmart Teensy 2.0
- Issue with Teensy 3.6 noteFrequency + sound output
- Portmanipulation for Teensy 3.6
- How can I generate an assembler listing when compiling Teensy LP.
- Teensy 3.0 midi schematic
- Teensy 3.6 Recognized By Arduino IDE 1.3.12
- Artnet Wiz820 Adapter - Right Light Solid, Left light Blinking - Not on Network
- Interferences of USB-serial on ISR?
- teensy losing flash
- Teensy 3.2 Power Question
- 3.2, Does this microcontroller support Dual/Quad SPI interface?
- Teensy 3.6 Slow boot time
- How to download software for Arduino?
- Serial port and interrupts issue with Teensy LC
- Parsing problem with strtok - teensy 3.2
- Teensy Transfer Sketch Compile Error!
- Using SdFat to acces Teensy 3.6 SD internal card (& with audio board)
- Problem when using 3v3 powering option - Teensy++2.0
- Teensyduino Upload error
- name.c rewrites other Teensy MIDI device name strings???
- digitalwritefast v digital write on teensy 3.2 , 3.6
- NEWB Help If/Else Statement
- Maximum 5v supply current on prop shield
- Questions about adding 23LC1024 RAM to the audio adapter
- Distorted sinewave when powering from another Teensy
- limit on encoder?
- Shorting 5V to Ground
- analogReadAveraging Question.
- Teensy 3.6 PWM refresh rate?
- RF433mHz module VirtalWire how to send float data properly?
- Is the Teensy LC's MKL02 the same as the Teensy 3.2's?
- Teensy 2++ soldering usb contacts
- Tone function - Teensyduino
- SD Card Power Budget
- Will 5V Tolerantdigital pins drive a LCD Display?
- Is there a [more complete] language reference for the Teesy?
- Help with Storing incoming serial2 data in buffer at 115200 baud with teensy 3.2's
- Strange Compiler Behavior - Code okay for Arduino but fails for Teensy 3.2
- Teensy MIDI out issues
- Teensy LC....is there a way to use both SPI buses?
- Mount Teensy both as HID and SD-Storage?
- What FTDI cables are suitable?
- Teensy 3.5 FIFO Serial Ports
- Teensy 3.5 not detected or can't start
- Teensy 2.0 can be flashed on Windows 10, but can't on Ubuntu.
- pins 28-30 completely unoperative problem
- Flex timer problem
- Help Needed: Audio Input LineIn not working
- where is serial1 defined for teensy 3.2?
- Teensy 3.6 16 bit write - where is PTD10 / B3 ?
- ISR Change - how to use
- Can teensy use Audio library and Firmata library at the same time?
- Audio, Question about Teensy 3.6 with Audio Shield
- Data sheet for the TFT Touchscreen?
- should i compulsory to use octows2811 adapter to build, giant led wall?
- Arduino-Makefile with Teensy 3.6: unrecognized command line option '-mfloat-abi'
- Blinky LED Teensy 3.6 using KDS
- Limitation of DMA_MAX_CHANNELS to 16?
- Lowest Teensy 3.6 power consumption using snooze library?
- Crash when using analogRead on Teensy 3.6
- analogRead potentiometer jitter help
- Is there any trick to maximize touch sensor inputs?
- I'm trying to do a RAWHID test program for TeensyLC
- Center aligned PWM speed not what was expected Teensy 3.2
- Error: Code 10 in device manager after installing
- WIZ820io & Micro SD Card Adaptor and Serial Ports
- Bringing up Teensy "Clone" - help re: USB
- Teensyduino compatibility
- Teensy flash corruption (low voltage issue)?
- Teensy 3.6 extra Ethernet Pins? (TIMR)
- 12 Bit ADC in Teensy LC
- Compile Error Low Resources
- Migrating SD Card project from regular Arduino to Teensy
- flickering Apa102, low Mhz and USB.
- Can't install Windows Serial Installer in windows 7
- Teensyduino Pi tames WAN mouse: Beavis nears the finish line!
- any working Low Power library for Teensy 3.2 and Teensy LC?
- Teensy Audio clipping distortion on summing sine wave with low gain
- analogReadAveraging Mystery?
- Using DMA with OLED Library
- Flashing Teensy LC bootloader onto Flysky i6?
- Any special procedure to read/write SD1 cards on the Teensy 3.5 and 3.6?
- What is the difference between pin A4 and A3 (A5 and A2)?
- Error compiling for board Teensy 2.0
- Teensy 3.2 + Adafruit 10-DOF IMU
- Teensy-LC list of items to avoid?
- Upgrading Microgranny to 2.5
- Oled and Amoled Display
- Are SPI signals CS0 and CS1 meaningful?
- Is there and alignment directive to align data on a 16-byte boundary?
- Best Practice for five device SPI on Teensy 3.6
- Ultra slow upload.
- Need some help with simple working test app for WS2812 LED on Teensy LC
- Teensy LC and the 20mA pins
- How to connect LCD 18 pin ADM1602K1-FS RGB teensy 3.2
- Teensy 3.5 SD isue
- auto upload - is it possible to always upload code and not use reset button?
- Arduino ver 1.7.11
- Teensy 3.2 Interrupt doesn't work. HELP
- FreqMeasure stops reporting values after a few seconds
- LED as a light sensor
- Teensy Keyboard
- P-channel mosfet switch
- ESP-01 + Teensy
- Snooze Issues on Teensy 3.2
- Very basic problem with push-button
- Structs, RF24 and 32bit vs 8bit headaches
- CAN logger and SD card speed.
- Comparator on 3.5
- Bluefruit SPI Friend not working when change SPI config
- Dead Custom Teensy - Help me find why?
- Progress on a new exFAT SD library.
- Moving to MK22 from Kinetis
- Teensy 3.6 OctoWS2811 Spectrum Analyzer
- Change keyboard layout in code rather than in command line
- Multiple AnalogRead Pins Measuring the Same Wire
- Teensy 3.2 with WIZ820io and OSC
- Teensy 3.6 DAC performance
- 8bit port scan and send has weird behaviour?
- Teensy 3.2 OctoWS2811 SK6812 RGBW Adalight Help Needed
- Teensy 3.2 with Arduino Ethernet Shield W5100 (clone)
- Teensy LC - DAC faulty voltage
- SSD 1306 – SPI Clock Speed
- teensy 3.6 using A18,A19 as I2C along with audio shield
- simple class problem
- how do I adjust touchRead current on Teensy 3.6?
- Power restart on Teensy 3.6
- associative and multidimensional arrays
- Teensy 3.5 RTC Not Working
- Advice needed on capturing mouse x,y values
- wierd behaviour with pushbutton
- Running Hot with External Power
- SD Card Breckout Errors
- Teensy 3.2 w/ Prop Shield - Pressure Sensor causing sketch to run very slow...
- Processing : capture screen.
- Can't find interrupt pin for MPU5050 tutorial.
- highlighting "trigger"
- SPI clock not uniform?
- Difference between other audio board
- Teensy 3.6 and LiquidCrystalFast library
- can i remove the bootloader once the controller is programmed?(Teensy 3.2).
- try to understand multiple file sketches
- Unable to program Teensy 3.5
- Teensy 3.6 builtin SD card - SdFatSdio SD.card()->writeStart() blocks GPS signal
- pinMode (PIN, OUTPUT_OPENDRAIN)
- USB communication without Arduino IDE
- New to Teensy. How many digital pins?
- FreqMeasure troubles
- Ethernet Shield Teensy 3.6
- Serial communication to Arduino boards not working
- MKL26Z64VFM4 and custom Teensy LC
- Couldn't Load - and solved - switch USB ports
- Slow PC to Teensy 3.6 USB Speed
- Unstable touchRead
- USB midi shutdown / init
- SPI clock jitter (Teensy 3.6)
- Teensy 3.6 SD interference
- Teensy3.5 and SSD1351 128x128 OLED
- VideoDisplay does not work on LED screen 60x36/3 controlled by OctoWS2811 and Teensy
- Teensy LC
- Transfer Files From PC to SD card with Teensy 3.2
- Teensy 2.0 disconnects from USB-port
- RFM69 from board to board through serial
- Midi - 8X8 diode matrix vs 16:1 MUX
- Unable to find Teensy Loader and similar errors, especially on Linux
- FreqMeasure and teensy 3.6
- FreqMeasure response
- Need to change SPI clock rate for RF24 radio modules w/ TMRh20 library
- Teensy 3.2 - pjrc color touchscreen help
- UTFT issues and update
- Programming pic with teensy ++ 2.0?
- Audio Board Problems
- Teensy 3.2: 16x2 LCD works but 20x4 not even find i2c adress
- would this display work with teensy 3.2 ?
- UTFT - Teensy 3.2 - PJRC color tft
- Teensy Midi | Pitch Bend Range
- Disassembly / Other IDEs
- byte definition in teensy3.2's print.h stops my compilation
- TFT - println and then clear the message
- Teensy 3.2: Slow Serial1 throughput from ESP8266 when using FastLED
- SPI observation - Something doesn't seem to be working as expected
- Teensyduino USB issue
- Bulk Transfer for Teensy 3.6
- I2S audio output and problems w/ I2C IMU
- Analog midi input and wire.h
- Code that works on 3.2 not working on LC
- Teensy 3.6 program loader and I/O glitches
- Teensy 3.2 and RFM96W LoRa Radio issue
- Teensy 3.6 to Android HID bidirectional communication guidance - code Samples?
- analogWrite wont give me a continuous 3.3V , it chops down at 488Hz
- Teensy 2.0 convert mini B to USB male
- Defining pin numbers in sketch
- Multiple Devices Over I2C
- Help understanding Midi-OX
- Encoder-"Resolution" ??
- No teensey 3.6 pinout available?
- Teensy 3.6 under Netbeans - Help
- Need help ASAP. Code freezes before reaching setup()
- HardwareSerial::flush causing freeze inside interrupts
- Scrambled PWM from Servo Function on Teensy 3.5
- no communication Teensy LC and Teensy 3.2
- Teensy 3.5: programming through USB header?
- ResponsiveAnalogRead Library
- serial monitor woes
- Teensy 3.5 compile error
- Pushbuttons as Trumpet Valves
- BeagleBone connect with Teensy 3.2
- Teensy 2.0++ internal pull-down? ambitious midi controller
- RawHID descriptor longer than 256 byte?
- raspberry pi 3 and 1.6.13/TD1.32 errors
- command for shutdown teensy
- Identify MAC address on WIZ820_SD_Adapter
- push button causing noise on potentiometer reading
- Kali linux teensy issue
- Teensy LC with fastLED and AP102 - not working
- Map Function ?
- Teensy 3.6 ADC documentation
- Petitfatfs iniatlization errors in TX RX functions loop_until_byte_is_set(spsr,spif)
- teenysduino 1.32 arduino 1.6.13 error compiling for board Teensy 3.2
- FastLED with Audio library causing lockups or flicker
- Unable to communicate with Teensy 3.2 on Windows 10
- Electronics question..How can I shift a 13.6 to 6.8V to 3.3v logic levels of high/low
- LPTMR on the Teensy 3.1/3.2/3.5/3.6
- Teensy 3.2 overheating?
- sending media key using teensy 2.0
- Strange pin mapping (port E3 used)
- Teensy 3.5 & 3.2 USB Serial Won't Enumerate Under Windows 7
- Strange interrupt behaviour when using SPI on Teensy 3.1
- Prop shield and WiFi101, how to manage multiple SPI slaves
- Teensy 3.6 Serial Not working
- Teensy 2.0 reset button broken
- Teensy 3.1 Reset without the Reset Button
- Teensy 3.2 Error compile blink example
- Teensy 3.2 ADC & AREF ?
- Issue with Teensy 3.2 + OctoWS2811 + 2812B LED's
