View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. What are the color codes on the teensy card?
  2. Teensy 3.2 - programming with Windows / CLI software (no GUI, no Arduino please!)...
  3. adalight WS2812B Different Lengths Strips
  4. Teensy 3.6 ADC resolution
  5. SoftwareSerial problem
  6. Problem getting Active Low Pullup working with multiple push buttons
  7. Multiple light patterns using FastLED
  8. problems using button controls + updating display function
  9. How to install/use Eigen template library
  10. Teensy 3.6: Sketch is not starting depending on power supply....
  11. IntervalTimer vs Elapsed
  12. Teensy 3.2 just randomly died?
  13. Teensy 3.2 : How to connect an external clock
  14. Teensy Audio Questions
  15. Ethernet.begin hangs after power cyle in Nov 29, 2016 release
  16. Interrupt during interrupt
  17. spi ports
  18. new to writing classes and a logic error I don't see
  19. help me for can bus interface using teensy 3.2 and mcp2515 module
  20. USB HID, report ID, and outputs
  21. Do I need the WIZ820io adapter for the Teensy 3.6 or can I connect WIZ850io directly?
  22. Custom Teensy LC with MK02 accepts bootloader but no USB
  23. fast pinMode switching?
  24. Is it possible to upload code to teensy (3.x) using hardware serial
  25. Teensy 3.6 SD Card
  26. ethernet init issues, 3.2 and 3.6
  27. Advice on reducing PWM "jitter"
  28. Remove Teensy
  29. If I want more than 16 channels of MIDI do I need a second teensy?
  30. Best way to ensure I'm sending exact # of bytes over BT serial
  31. ShiftPWM - problem
  32. Teensy 3.6 TPMs...
  33. Teensy 3.6 + Audio Shield huge noise
  34. W5200 lib not installed
  35. Teensy 3.2 power-up problem
  36. OpenTherm protocol
  37. Display Linear Gauge Method
  38. How do I specify a channel for the USBMIDI protocol?
  39. T3.6 & WIZ820io + Bonjour
  40. Teensy 3.6 built in Ethernet?
  41. Identifying the different teensy models
  42. How to use T3.5 with RCT DS3231 using i2c_t3 library
  43. Compile issues on Windows Arduino IDE 1.8.1 (Windows 10), TD: 1.35
  44. What am I doing wrong with modern embedded stuff?
  45. Teensy 3.xx pin definition
  46. Custom Teensy starting up problem
  47. T3.6 with WIZ820io adaptor board
  48. 128x32 OLED display with teensy 3.2
  49. Changing Teensy Driver in Windows 7 to FTDI
  50. fix behavior of keyPad scanning with SX1509 port expander
  51. Teensy 2 keyboard issues
  52. Teensy 3.2 and ILI9341
  53. Simplified way to program .hex file in Teensy without Teensyduino
  54. USBMIDI "note" was not declared in this scope
  55. How to support multiple clients with Ethernet library? (re: Teensy 3.6 + Wiz850io)
  56. Teensy 3.2 behavior function of USB plugged in or not
  57. SPI interrupts and modules on Teensy 3.1
  58. What's wrong with my Script?
  59. TM1638 & pwm compatibility issue
  60. Teensy 3.6 Micro USB power
  61. Teensy++2.0 with X-plane 11 and input Pins?
  62. Connecting Sensors to 3.6
  63. does not name a type
  64. webserver with json
  65. intermittant ethernet operation
  66. How big is the serial input buffer in the teensy LC?
  67. Capacitive resistance on analog pins
  68. WS2811 / OctoWS2811 - Desperate Questions.
  69. Should I use Teensy Ethernet library or Ethernet2 with W5500/Wiz850io?
  70. Reading Vin voltage directly for external alimentation
  71. What's wrong with my Script? (v2)
  72. btmcmahan/Teensy-3.0-SPI-Master---Slave on teensy LC
  73. USB device descriptor request failed Custom Board
  74. How to external power Teensy 3.6 and switch between USB power and external?
  75. New ili9341 and t3.6 issues
  76. Initialise member array using const
  77. Teensy 3.5 Hardware Pin Interrupt
  78. program eeprom 24c02
  79. Teensy 3.2 doesnt get recognized anymore (Windows)
  80. How can I default an output pin to high immediately when power is applied?
  81. Combining struct's - EasyTransfer?
  82. Use of resistors on ws2812 led setup
  83. Flashing firmware+eeprom data to Teensy 2.0
  84. 5v pin on the 3.6
  85. HX8357D and Teensy 3.2 touchscreen not responding
  86. Question about SdFat-Beta
  87. Need help on using SPI library
  88. Strange Button behaviour
  89. analogRead on teensy 3.2
  90. Linux question about udev rules
  91. Custom Teensy Loader issue
  92. Help with EMIC2.h
  93. Serial Port FIFOs?
  94. Teensy 3.5 synchronized/latched DAC output?
  95. Is there an RGB color table/class or something to help with color selection
  96. Where to get Bootloader chips in Europe ??
  97. Teensy loader HEX file too large
  98. Serial monitor works, but can't get Realterm to work
  99. Command line teensy loader bug on Mac
  100. Teensy 3.5 and Encoder Library
  101. Current limits for teensy 3.5 pins, enough to drive a LED?
  102. I think my new Teensy 3.2 is broken
  103. Teensy 3.2 with Adafruit ZFM-20 (Fingerprint)
  104. How to Access Back-side Teensy Pins?
  105. Smoked T3.6, which part(s) most likely damaged?
  106. teensey 2.0 won't enter program mode
  107. Measuring Duty Cycle of Mx2125 Accelerometer Output using Interrupts
  108. How to preload custom data into EEPROM on T3.x?
  109. 10v was appled to a 3.6. Any chance I can repair it?
  110. Teensy LC not detected by Win10 or Mac OS 10.11
  111. ILI9341_t3 with a DC pin problem.
  112. Teensy 3.6 and RA8875 Fonts
  113. Possible to copy hex from one Teensy to another?
  114. Teensy 3.6 Datalogger
  115. Teensy 3.X Hardware Serial Elapsed Time Problem
  116. Writing objects/class instances to SD built In card T3.6
  117. Pwm on teensy 3.1
  118. Teensy 3.2 ILI9341 Touch and SD wiring (ILI9341_t examples)
  119. amp meter "fixing" led strip power supply overload....
  120. Serial Monitor not working
  121. Reset audio board codec SGTL5000 in realtime processing
  122. Trigger DMA with Signal at Input Pin
  123. A digital read freezes my program
  124. Prop Shield I2C
  125. touchRead - slow reading when not grounded
  126. Teensyduino install causes time library routines not to compile correctly
  127. analogWrite delay? Teensy 3.2
  128. Esp8266 - led ws2811
  129. AltSoftSerial question
  130. Teensy LC bricked.
  131. WS2812B v2.1 release from manufacturer not working
  132. Communication impossible in I2C tennsy3.6
  133. Trellis and Multiple I2C ports
  134. Strange problem wiring encoders and LCD
  135. Teensey 3.2 and MIDI Test card
  136. FastLED Library and Hardware SPI
  137. How to solve compile problems of Arduino libraires
  138. PC Java ByteBuffer to Teensyduino union {float} via UART issue
  139. Perplexing Power Issue
  140. Strange Hardware Serial (Serial4) Issue?
  141. ADC Questions using Teensy 3.5 for midi potentiometers use.
  142. WIZ850io & Teensy 3.2 loose ping after a while
  143. Beginners Questions Again regarding Debounce and Vu-Meter
  144. Problem Tennsy 3.6 and U8GLIB and 1.3" OLED
  145. Powering Teensy 3.6 with 3.3V?
  146. Teensy 3.1 pulling 140mA with blink sketch
  147. Looking for a good 7" 800x480 TFT for an RA8875...
  148. Forcing the Arduino IDE to use the right libraries?
  149. OctoWS2811 - Are other Teensy pins usable for LED strip control?
  150. Teensy 3.2 Serial1 and Serial3
  151. VideoDisplay: How are pixels set?
  152. Teensy 3.5, low fps with 2400 ws2812b's
  153. Servo and Audio not playing well together
  154. Teensy LC will not program
  155. Teensy 2.0 USB pads
  156. Teensy 3.6 and external power: recap
  157. How to print german Umlaute (, , ) to a tft screen
  158. Need help with SD card & OLED screen not working together.
  159. Teensy 3.2 + SparkFun AVR Oscilloscope Clock Help
  160. Strange USB Serial 15ms maximum latency on Win7
  161. Teensy 3.6 CANBUS filter and mask
  162. Teensy 3.6 USB1 and VREGIN
  163. Complier errors on Adafruit program
  164. Sniff on Sanyo CCB bus
  165. How to debug ARM assambly
  166. which is the right teensy to use
  167. Help migrating MPU-6050 Wire to i2c_t3
  168. Teensy2.0 recognized by mac as USB plugged but not in Teensy software
  169. Teensy Loader not found on ODROID (Ubuntu)
  170. RA8875 Library Color Issue
  171. Problem with Teensy 3.2 Class Compliant MIDI +RawHID Device
  172. Teensy 2.0 ++ USB Mass Storage variable mounting time
  173. X Plane 10 Writing DataRefs Question
  174. Compiler warnings making me nuts
  175. removing pull-up resistor on GY-521 board w/MPU-6050
  176. Duplicate SPI2 port pinouts on Teensy 3.5/3.6?
  177. Teensy LC 3.3v Pins
  178. Adding ground to teensy from ili9341 turns teensy3.6 off while adding power
  179. ns delay library?
  180. Do-It-Yourself board - PTA1 to usb
  181. EasyTransfer over Software Serial
  182. Simple DMA questions... DMAMEM?
  183. Low Noise Clock Generation
  184. Teensy 3.2 acquisition of data in a time interval
  185. I2C Seemingly not working
  186. Midi - one specific note not transmitted with USB-Midi / no hardware issue
  187. Teensy 3.1 analog help
  188. PJRC Ethernet Library + wiz850io
  189. TFT and sad card reader module same SPI lines?
  190. Fastled using LED_TYPE of OCTOWS2811 and teensy 3.6
  191. Find "core pin" based on pin name in datasheet?
  192. 2 node CAN bus with SN65HVD230 tranceiver.
  193. I2C question on Teensy 3.6
  194. usbMIDI sysex Callback function
  195. Strange behavior with multiplexers
  196. Wiz850io on Teensy LC?
  197. Erasing EEPROM when loading code
  198. Teensy 2.0 as a 4mhz Crystal for TI SN76489 sound chip?
  199. XPlane 11 and GPS datarefs
  200. Teensy 3.2 Not Creating Serial Port (I think my code is causing a seg-fault)
  201. Accidentally Desoldered some SMT components on a Teensy 3.2
  202. [Teensy 3.2] Serial interface seems to be hanging
  203. If statement help
  204. Problem uploading sketch for the first time
  205. Teensy 3.6 5V PWM Signals
  206. Teensy 3.6 Peripherals Help
  207. Teensy starting and stopping Serial Connection
  208. Teensy 3.2 PWM
  209. Teensy 3.2 & Audio Module issue
  210. Teensy 3.1 SPI Flash
  211. Custom Teensy3.2
  212. Timer 1 cycle problems
  213. Teensy 3.1 Temperature from CPU
  214. g++/gcc flag diffrences between PlatformIO and the default Makefile
  215. Help -- Teensy Port No Longer Found by IDE or Windows Device Manger!
  216. OctoWS2811 Pixel Controller Slow with large matrix
  217. Teensy with Max Msp
  218. I2C hanging with SDA and SCL both high, ARB_LOST & TIMEOUT forever status
  219. Stylus/Pen Digitizer Emulator - with pressure sensitivity?
  220. Problem with new Dell 8900 pc
  221. Ext Interrupt to sample playback latency
  222. Faster way to copy then getting and setting? getPixel(num) to setPixel(num, color)
  223. Basic question regarding pins A21, A22 on Teensy 3.6 and Teensyduino
  224. CNY70 Reflective Optical Sensor for Teensy 3.2
  225. ILI9341 Screen Dump to SD Card on Teensy 3.6
  226. ADC issues with Teensy 3.6
  227. [QUESTION][HELP]Teensy Loader not recognize Teensy Board.
  228. Teensy Blink Led 1000 Hertz Stroboscope
  229. Do touch pins trigger some sort of pause?
  230. Is my Teensy 3.5 dead?
  231. Crystal PCB design for custom Teensy
  232. SD card size
  233. Organ band file unable to compile
  234. Issues with Serial1/2/3 on teensy 3.2
  235. Speed of, or knowing when rotary encoder is still
  236. Time lib on T3.6 using internal RTC falsely(?) reports time is set
  237. Record time on SD Card
  238. Record a .wav file
  239. 3.6 using Midi_basic_IO sketch, not blinking LED. Sanity Check.
  240. SerialFlash loading image to bitmap?
  241. Do I need to hold Teensy 3.6 in Reset during powerup?
  242. Flicker in rainbow with audiolib and analog input
  243. Teensy 3.2 with USB and external power
  244. WavFilePlayerUSB
  245. Unable to use catalex MicroSD card adapter with teensy 3.2.
  246. GPIO pins on Teensy 3.1
  247. How to upload to Teensy 3.2 with FTDI serial cable?
  248. touchread problems with pin 1, 18, 19
  249. Accuracy of Teensy 3.2 clock sans RTC and underclocked
  250. SerialFlash, eraseAll eraseBlock and remove
