View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Teensy 3.5 SDCard access
  2. Concurrent DMA-READ and DMA-WRITE to same RAM area
  3. Arduino builds using Command lines for teensy using PuTTy or the like
  4. Is my program compatible with using idle mode?
  5. Teensy 3.2 eagle cad project file with connection holes
  6. lambdas
  7. switch statement - case using string/char array
  8. Teensy ++ 2.0 (not recognized by windows error 42) After Few Minutes
  9. MCP3204 ADC SPI and Wiz5500 Ethernet SPI not getting along
  10. Access to extra pins in Teensy 3.6 for breadboarding
  11. Using malloc(), realloc(), and free() on teensy 3.2
  12. Teensy 3.5 + HXD8357D 3.5" TFT -- Advice on images
  13. Teensy 3.2 DAC output issue on power cycling
  14. Connecting a Battery to the Teensy-LC
  15. Teensy 2 and Mouse.move()
  16. TEENSY 3.2 ERROR - fatal error: ros/node_handle.h: No such file or directory
  17. Conflict with MFRC522 and ST7735 libraries
  18. Alternate clock speeds in platformio for 3.2/3.5/3.6
  19. Teensy 3.2 SdFat always losing last data set, not saving to SD
  20. Issues while running Movie2Serial on raspberry pi3
  21. Problems with the duration of PITimer1 pulses on Teensy 3.1
  22. Bizarre behaviour teensy misses execution of start of setup?
  23. TeensyduinoInstall.linuxarm won't run on Raspberry
  24. SPI Mag Dropout with multiple 9250 Sensor on Teensy 3.2
  25. Teensy LC can't run LCAnalyzeFFT.h and Adafruit_NeoPixel.h libraries at the same time
  26. A question about pin current.
  27. Disable SPI on Teensy 3.5 SD?
  28. HD monitor
  29. Teensy 3.6 & Variables declaration to store in EEPROM area.
  30. Need to write a struct fast from and to an 24LC512 chip over i2c
  31. Best practice for many-button controller
  32. Midi Out : Doubt on Teensy page
  33. Teensy 2.0 - unable to upload any sketch, is it dead?
  34. Ili9341 power and restock available
  35. Aynone used buydisplay ra8875 with flash ??
  36. Bricking multiple Flash Storage chips ?!?!
  37. use *non standard* modifier keys
  38. Analogue to digital within the Teensy
  39. USB COM based interrupt
  40. Teensy 2.0
  41. Correct usage of ethernet.init(SS_PIN)
  42. Teensy 3.5: Pin 15 only works when I press on the CPU
  43. Connecting the PIXY camera to a Teensy 3.5
  44. Ultra noob seeking some MIDI coding help.
  45. Has anyone tried using JTAG on the Teensy 3.6?
  46. Teensy 3.2 Not properly working when using trimpots with an external non-alimentation
  47. Can transmit CAN bus information, however I can not receive the information
  48. Eh...Is my Teensy 3.2 Dead?
  49. Teensy + HAL libraries
  50. A simple SerialFlash datalogger
  51. Touch Screen Display. No display
  52. edit serial2parallel for apa102
  53. Why are PINBemulation and PINCemulation in avr_emulation.h reading the same ports?
  54. 2++ as ISP; new problem
  55. Direct address of samples on flash chip
  56. Software ADC on Teensy 3.1
  57. Teensy 3.2 dying when playing WAV files in the SD-CARD
  58. XPT2046_Touchscreen library - Configurable SPI pins?
  59. Weird int-to-float cast bug ?
  60. Line in voltage of Teensy
  61. Where to find Teensy library source sketches on Mac? IE Wire.h
  62. Looking for help on USB keyboard project
  63. Blocking AM2321 Library with Arduino 1.8.2 / Teensyduino 1.36
  64. ILI9341_t3DMA not working this time around
  65. choosing a serial port on the Teensy 3.6?
  66. WatchdogTimer
  67. Detecting 120VAC with Teensy
  68. Ultrasound transmitting
  69. TFT capacitive touch teensy 3.6
  70. Teensy 2.0 ++ attachInterrupt issue
  71. Modify freqMeasure library for higher frequencies
  72. Teensy 3.2 -- extending number of capacitive sensors using an analog mux?
  73. Serial over USB fails if not connected
  74. Fastest method of communicating with SSD1322 display?
  75. Mysterious Partially Bricked Teensy 3.6s
  76. Teensy 3.2 + LC - Osh Park edition not showing up on OS X
  77. Possible to toggle low power mode and normal power mode?
  78. Teensy Shift Register issue AGAIN
  79. Only Read Some of the Folders on SD Card
  80. double precision maths queries ...
  81. MotionCal sensor calibration tool - doubt
  82. OSC out from ESP8266 and serial print from ESP8266 through Teensy to ArduinoIDE
  83. Using AVR with ESP boards
  84. MIDI CC’s sending at wrong times Teensy
  85. 'Over the Air' firmware updates, changes for flashing Teensy 3.5 & 3.6
  86. Linux sees nothing from teensy 3.1 serial port
  87. Updating SPIN to work with ESP.
  88. MIDI Library on UDP
  89. To connect power socket
  90. Power problem, usb vs external
  91. OCTOWS2811 and DOTSTAR problems
  92. Xbee error with Teensy 3.2
  93. Just a few technical questions on Teensy 3.2
  94. ArtNet on Teensy 3.2
  95. Snooze does not wake up on Serial1 (pin0)
  96. Problems with ILI9341 on Teensy 3.1
  97. Interrupt registers on Teensy3.6
  98. Problems using Xcode with embedXcode
  99. Prop Shield
  100. How interface 74ls245 with 74ls373
  101. teensy 3.6 rawhid not working in Windows 10
  102. How can I get analog inputs A15-A17 working on a Teensy 3.2 (pins 25-27)
  103. Teensyduino 1.36 failing with Arduino 1.6.5 r5
  104. Can I turn off bootloader of teensy 3.2?
  105. noInterrupts() seem not locked serialEvent interrupt.
  106. errors with micros() function on Teensy 3.1
  107. Mechanics: stacking
  108. Teensy 3.6 and MFRC522 on SPI2
  109. Power Teensy 3.3V
  110. SPI on T3.2, CS selection
  111. Syncing multiple Teensy's to drive large LED installations
  112. Help with SLIP encoding/decoding
  113. GCC "switch" - When does GCC create a jumptable ?
  114. Arducam 5MP-Mini Board with Teensy36
  115. Requesting Algorithm genuis to examine this and point me in a direction.
  116. Question On Spi Transactions
  117. Teensy with mini USB host shield (chineese)
  118. Crypto-acceleration unit
  119. Absolute newb looking for help making teensy 3.2 act as keyboard
  120. Teensy 3.5 timer precision
  121. Terminate an active Audio Object?
  122. Midi file to control LEDs using teensy
  123. Teensy 3.6 and I2C display
  124. Teensy 3.2 LED Strip only one LED lights
  125. Teensy 3.5 Analog input problems...
  126. Setting RTC
  127. fingerprint Scanner-TTL (GT-511C3) message issue
  128. PROBLEM w/ Multiple analogreads on teensy 3.5
  129. Teensy usb issue
  130. Teensy 3.6 SD card detect
  131. Upload program with external 5v connected
  132. migrating project from teensyduino v1.35 to v1.36, ADC no longer works
  133. No audio from Teensy 3.5 and audio board to Mac
  134. Can't get bounce object to update (boneheaded oversight?)
  135. Using the prop shields unneeded pins for alternative uses
  136. Teensy 3.6 Stop working, think the voltage regulator is gone
  137. teensy 3.2 external power and Usb connectivity question
  138. Teensy 3.2 + Adafruit NXP Precision 9DoF Breakout + Teensy Fusion Library?
  139. What does this error mean? section .progmem.data overlaps .data
  140. help needed with replacing switch with circuit
  141. What are people using for WiFi?
  142. 5 SPI devices (with DC) on Teensy 3.2, is it possible?
  143. Teensy 3.6 add timestamps to DMA transfers
  144. Dimensions to the USB D+ and D- pads on the underside of the Teensy 3.6?
  145. Help with FFT of raw data.
  146. Interrupt for powerloss and save Data into EEPROM
  147. videoSDcard with teensy 3.6
  148. Detecting Stale RTC time
  149. Digital Pin always high
  150. compile errors going from mega2650 to teensy 3.5
  151. reversing bitwise operations
  152. Teensy3.2 + audio board + purple board + PJRC ILI9341 color display
  153. teensy 3.2 with 5v flex sensors
  154. How to count time when interrupts are disabled?
  155. Teensy 3.6 micros() rate depends on digital output state??
  156. Conflict between RTC and SD on SPI
  157. can't play wav file on my audio adapter
  158. Teensy 3.5 crystal accuracy
  159. Fastled and Teensy audio library. Flickering leds when audio library used?
  160. Audio board + teensy 3.2 keeps getting fried!
  161. Multitouch? (capacitive touch panels)
  162. No support for Teensy++ 1.0 on Arduino 1.6.12 on my Mac
  163. Seamless Looping
  164. Teensy 3.5 -- program without USB?
  165. 9bit SPI Interface (3-wire), teensy 3.2
  166. Problem with sampling
  167. Very Simple thing - me
  168. Serial communication after upload / Neopixels
  169. Quick question about the sd card cs 10k pull up on teensy audio board.
  170. Keyboard Send Any Unicode Character?
  171. Long sketch code question
  172. Optimization Fast/Faster/Fastest with/without LTO?
  173. Auto Reboot not working
  174. OctoWS2811 Unexpected Colors (7 bits per channel )
  175. Dead pin teensy 3.6
  176. Teensy 3.5 SPI DMA?
  177. Help me understand where I'm wrong with this Midi DIN out
  178. Converting int16_t to float teensy 3.2
  179. Hardware SPI and AD5668
  180. Problem installing Teensyduino 1.36
  181. IntervalTimer vs. TimerOne interrupts
  182. Sustitute for PC900V
  183. Potentially Counterfeit Teensy 2.0?
  184. Teensy 3.1 + RAW HID
  185. usbMIDI Note On with velocity=0
  186. Hardward serial question
  187. Running more than 1 LED per pin
  188. Constantly changing serial port number?
  189. Sensing with Teensy 3.2
  190. WIZ820io with Arduino 1.8.2/Teensyduino 1.3.6 doesn't work.
  191. Teensy LC and parallel relay
  192. Help with Connecting Lipo Battery and Charger to Teensy 3.2
  193. Teensy 3.6 & WIZNET_SD_ADAPTOR ethernet setup
  194. Teensyduino 1.26 for Audio Tutorial
  195. Teensy 3.6 + Audio Card + ILI9341 display - display not working
  196. How to use timers in ctc mode for variable frequency generation, teensy 3.2
  197. SD card slot on teensy 3.6
  198. Xplane move aircraft
  199. WS2811 First LED failure
  200. Teensy 3.2 PS2Keyboard compiled error
  201. Teensy-LC Serial read problems
  202. I2C LCD Display - sketch not compiling - HELP!
  203. Teensy Installer X86 32-bit Linux 1.36 not working here
  204. Why is my EasyTransfer test working with 16 ints but not 17 and above?
  205. Serial port not found for new Teensy 3.2
  206. SPI in 1.36 changes... where?
  207. Output Multiple Copies of the Same Signal
  208. Teensy 3.5 HID not found
  209. Teensy LC battery
  210. teensy 3.6 serial TX buffer size
  211. PPM output using pulseposition library on teensy 3.6
  212. Transitioning to bare metal board, still using Teensyduino IDE
  213. WIZ850 (w5500) support on arduino IDE 1.8.2 and 1.36
  214. Measuring USB bus timing for clock synch
  215. RS232/Serial communication: Do I need DSR/DTR and CTS/RTS?
  216. possible hardware problem???
  217. Teensy t3.2 and t3.6 not recognized
  218. Sync Issues Teensy => Huzzah
  219. Sigh... No port available on OSX for teensy...
  220. MFRC522 random error
  221. Calculate time for ultrasonic sensor without millis() Teensy 3.1
  222. USB INT not firing.. my ignorance, my fault, I need help.
  223. Advice on teensy 3.6 rs485 and dynamixel - totally stuck
  224. stricmp() missing or moved in Arduino 1.8.2?
  225. Strange blink - USB behavior on Win10
  226. Ethernet library socket issues
  227. How to do I troubleshoot the touch part of the 2.8 ILI9341?
  228. Teensy-LC and Sharp Memory LCD Library
  229. teensy 3.6 bricked?
  230. wiring sensors teensy 3.6
  231. Teensy 3.1 bricked
  232. compiling for Teensy fails but for Arduino is ok
  233. AnalogWrite Bug or Feature?
  234. Issue with mouse functions in linux
  235. noInterrupts() not working?
  236. how to use NVIC_SET_PRIORITY, teensy 3.6
  237. Using SD with t3.6 and other t3x MCU's micro GUI
  238. CANopen
  239. Teensy++2.0 at 3.3V breaks USB?
  240. Float Arrays get corrupted on Teensy 3.6
  241. PCB audio section layout best practices.
  242. Teensy 3.2 gets "stuck" and won't mount COM port
  243. i2c Adafruit I2C + Teensy 3.6 issue
  244. Change between 2 PWM frequencies - Teensy LC
  245. OLD TeensyDuino V1.18
  246. Teensy 3.2 and Maxon motor encoder (+5V power supply)
  247. Powering Teensy/Huzzah with breadboard power supply
  248. Question about Teensy3.1 with Makefile (no Arduino IDE)
  249. Teensy-LC Sleep_CPU() and Hardware Interrupt to Wake-up
  250. MotionCal Tool Format
