- Serial Flash filesystem size
- Teensy 3.2 + Esp8266 + Time
- Which ADC pins are differential on Teensy 3.6?
- Problem compiling ADC code under TD 1.36, worked in TD 1.35
- Question about USB Serial on Teensy 3.x
- FreqMeasureMulti & analogWriteFrequency
- FastLED and HW SPI on T3.2, T3.5, T3.6
- How to debug freeze issues on Teensy 3.5 ?
- Flex Timer for input event capture at full system clock rate
- Teensy 2 Keyboard dead for several days, then alive, now dead again.
- Best way to change SPI speed?
- Debugging BuyDisplay ILI9341 ER-TFT028-4 320x240 touchscreen
- 'priority' of main()?
- Using OctoWS2811 and Adafruit Neopixel in one sketch
- Teensy 3.6 ADC sampling error
- PWM Output on Pin 5 - Teensy 3.5
- Timers on Teensy 3.6
- Create 38 kHz square wave with Teensy LC?
- Teensy LC & String handling?
- how to print a long double ... to 33 decimals
- Teensy 3.1 not more recognised after flashing with cli - unbrickableTeensy bricked???
- Timestamp at packet receive in serial 1 ISR
- Issue with clock on DIY Teensy
- Can't get SPI1 working on Teensy 3.6. What am I missing?
- gcc error: impossible constraint in 'asm' building Audio lib
- How to create ISR routines?
- teensy 3.2 and usb power wall wart
- Detailed operation of a Periodic Interval Timer
- Large file transfers from Teensy to host
- Control voltage outputs
- Teensy 3.1 bricked after flashing custom image
- Keyboard 3.5 fail, help from someone with an earlier teensy please ?
- Teensy 3.2 Maths compatablity with Mega 2560
- Teensy 3.1, RTC problems
- Teensy 3.2 + RTC wake up on specific time
- Can't program Teensy LC after flashing
- Teensy 3.6 GPS rfm69 conflicts
- bug in windows rawhid_send?
- Teensy Loader problems
- DMA multiplexing, teensy 3.6
- simple program/script to reset teensy 2.0 in bootloader mode
- teensy and running of a lipo battery
- Question about binary data sent from Matlab to Teensy 3.2
- UART on Teensy 3.6
- Differences between reboot_Teensyduino and restart_Teensyduino in Teensy core
- Teensy-LC EAGLE Files
- Teensy3.1 + Octows2811 + 12V ws2811 strips RGB swapped
- Programming and charging teensy off one usb port.
- Serial print leading zeroes
- Teensy 3.6 mkl02Z32vfg4(Cortex M0) and upload code
- Teensy-LC and the AREF Pin
- Micro SD card format teensy 3.x
- New to Linux, trouble uploading
- Teensy 3.2 with multiple RFID-RC522 Readers
- Converting old CDJ-800 into traktor midi controller
- Detecting USB serial application state
- Teensy 3.5 and internal pullups etc
- Button problems
- No SD cards work on new Teensy 3.2 + Audio adapter
- Teensy Loader not recognizing Teensy 3.2
- No 64-bit unsigned ints?
- Help with basics for using two SPI buses on Teensy 3.5
- Teensy-LC and Analog Signal Measurement Stability
- What is the proper way to connect 5V Rotary Optical Encoder to Teensy 3.6?
- Low Power Teensy+PCB problem
- Help with RGBW pixel mask for Processing Sketch
- Install Teensyduino on openSUSE
- nanosecond timer (capable of +/- 100 nanosecond resolution)
- Teensy 3.6 ADC_1 stuck when using PDB
- Baking in Teensy 3.6
- help with graphics issues
- Porting Elechouse VoiceRecognitionV3 library
- Teensy 3.2 LED spazzing
- PuggableUSB for Teensy ?
- Using Teensy SdFat library (SdFatSdioEX)
- MacOS Sierra port problem
- Using WS2812 and Servo in the same sketch
- IntervalTimer Example
- SPI.transfer(bytes, count) has byte order issue w/Teensy 3.2 and Teensyduino 1.36
- Teensy loader not detecting teensy 2.0 with any of my mini usb cables
- How to dump i2c eeprom with Teensy 2.0?
- delayMicroseconds broken?
- Pin assignment reference Teensy 3.5
- Question about string formatting and printing from a structure
- Interferences concerning interrupts on Teensy 3.1
- Teensy as Mass Storage and file access logger
- [i2Cdevlib/MPU6050] Is the library correctly installed?
- Datalogger Serial Communication - break detection work unstable - isr wrong
- Problem in Receving and Manual ACK in nRF24L01+
- Compilation error
- Certain sampling rate Teensy ADC
- Teensy3.2 and 20Cx4L LCD with I2C backpack
- Connecting a Teensy with RPi
- SerialFlash file position confusion
- TFT Display issue ILI9341
- Timing, OC and Otimiser?
- Programming Teensy 3.5 from a precompiled file using the Linux console?
- PWMServo prevents motor from working
- Teensy 3.2 sleep, CAN bus wakeup
- Compile error
- SD Card on SPI1 - T3.5
- [ERROR] Compilation Error for TeensyLC board
- Can't List All Directories on SD Card
- Teensy to XBee Adaptor Kit alternative
- playFlashRaw and FastLED incompatible?
- Teensy misreading the I/O pin inputs
- UART: coping with hosts not honoring start bit timings
- command line loader utility (no button press)
- Debouncing trouble of switches connected to four MCP23017s
- 16K W5500 Buffer & EthernetClient
- using ILI9431 without the blinking
- Encoder Library not as efficient as XOR method
- No com port when using hex files?
- ILI 9341 Parallel Library
- How to make an array of AudioPlaySerialflashRaw
- Rotary Encoder Debugging on SAMD11
- LED Colorfade pause not working (Interrupt) on Teensy LC
- T3tris help
- TTS (Text-to-Speech) Library Port?
- 6dof IMU problem on teensy 3.6 probably related to i2c
- Error setting serial port parameters
- 8-bit TFT wiring or simultaneously over SPI with Ethernet?
- Simple explanation of DMA?
- Encoder.h - trying to reset encoders to 0 from keyboard
- TimeTeensy3 - Serial functions..
- analogRead and analogWrite in one loop Teensy 3.6
- Teensydouno 1.36 installation problem
- Check and/or reset i2c pins
- Can't use BUILTIN_SDCARD on Teensy 3.5
- Teensy 3.2 OS overheads?
- Function conversion and compiler refuses to see functions but does
- Teensy 3.6 - RawHID: receive timeout when serial monitor is closed
- Teensy 3.2 drawing a lot of current / overheating
- Can i use my Teensy 2 to control 2 analog thumb-sticks.
- How to stream pixel data to Addressable LEDs over Teensy USB Serial?
- DMAChannel Confusion
- Teensy 3.6 good timestamp practices
- How to implement software flow control using easytransfer
- AudioConnection patchCord with delay breaks program
- Minimum recommended pull up resistor value for I2C with a Teensy 3.2?
- Optimizing Teensy 3.2 Startup
- interupts interfering with serial?
- Boot on Power-Up Problem with three T3.6s.
- Teensy Not Starting Without USB Monitor
- Teensyduino 1.36 not uploading to Teensy 3.6
- Serial Output Buffer Size
- GPIO OpenDrain with pull-up
- Hang up - USB Serial monitor
- Mystery with Teensy 3.6 and ILI9341_t3
- Audio Shield volume controller ground problem
- Custom Teensy Board
- pinMode disabled USB Serial - Teensy 3.6
- How to update Teensyduino...
- Is it posebale to us a analog pin for a button.
- 'simple delay' test using my laptop fails, but it works fine with someone else's - ??
- Simulating ili9341_t3: request help with drawChar()
- Teensy LC Keyboard & Midi
- Teensy 3.5 w. LORA SX1278 chips and Radio Head library not working reliably
- Integer Storage
- How to Reset/Restart Teensy 3.5 using sotware
- Teensy 3.5 Octo2811 lib - second LED bug
- Problem with OctoWS2811 adaptor and / or library and/ or my understanding
- where is the Rx Tx on teensy 3.5?
- How to clear an external interrupt's status flag in Teensyduino for Teensy 3.2
- Stepper motor sensing and reproducing
- sending Pitch bend doens't work
- faulty voltage regulation on t3.6
- Teensy 3.2 bootloader connections
- Teensy tracked sine wave gliassando.
- How to boost pin voltage to cope with voltahe drop due to wire length?
- Teensy 2.0 doesn't work(Program mode)not install firmware
- Shortened pins on Teensy LC
- Teensyduino 1.36 Will Not Install on Arduino 1.8.2 IDE
- Teensy 3.2 Input impedance
- Teensy 3.2 + Audio Adapter + nRF240l Audio hitching, cracks, freezes
- Drawing bitmaps into arrays for displaying multiple bitmaps CORRECTLY
- Undefined reference to `twi_writeTo'
- Legacy Libraries
- Windows upgrade on 6-15 causes Arduino 1.82 and TD 1.36 to not upload
- Teensy 3.6 sd card
- VS2017/Visual Micro - How to config for auto upload without Teensy reset?
- changing include order?
- Teensy 3.6 fried in vehicle?
- remote program button?
- Why no ground poly on the signal planes?
- sdfat LowLatencyLogger and SDIO
- Preventing Speaker Pop When Switching on Teensy 3.2 with Audio Adaptor
- 2 8x8 Led matrix with MAX7219 and Teensy 3.2
- Bluetooth Module UUID
- Running Teensy 2.0 on external 5V power
- Custom Atmel M7 using MKL02/04 Chip
- Damaged audio output when attempting headphone detection?
- Change CPU Speed in the program?
- T3.6 not programming, but working
- Alternative PWM Frequencies
- Compiling issues for Teensy 3.2 & 3.6 with latest Arduino 1.8.3 & Teensyduino 1.37
- Can not get PropShield to Play MP3's with MP3Player
- T3.6 Real Time Clock
- Pull Down Resistor problems
- Using frame buffering to solidify tft displayed objects
- Removing files from the core library
- teensy loader commands in Arduino IDE
- Error Compiling for T3.5/PropShield/FastLED
- Using adafruit 1.44" graphics library on teensy 3.2
- Piezo speaker doesn't beep on battery power
- Using ADC enableCompareRange
- teensy loader problem
- Adjust the BIAS_VOLT and ADC_VOL
- Teensy 3.2 - FreqCount lib + SD card?
- Yet another Teensy Loader RPI3 Question thread....
- analogReadAveraging not behaving as I would expect
- LUFA Mouse - Scroll wheel?
- ADC interrupt not being called
- Teensy 3.6 with 2 LCD 9341 not working on ILI9341_t3 library
- Issues with Teensy 3.2 I2C
- Programming without bootloarder
- Uploader vs TyTools using VS2017 CE & Visual Micro for two Teensy 3.5's?
- Teensy and Stepper Control
- Programming the teensy 3.6 chip whilst in circuit
- Teensy 2, dead after flashing?
- Is there any sd card detect pin for Teensy 3.6 builtin SD Card
- Can someone explain this circuit to me?
- Teensy 3.6 DIY Reference Board schematic
- ports and busses in teensyduino
- Teens 3.2 (and later) - Sinking 5v 2ma for Serial Output
- Teensy 3.2 wont compile with SSD1306 program
- Borrowing a mk20dx256vlh7 from Teensy 3.2 for custom board
- Changing resolution of ADC
- Teensy 2.0 Detect NUMLOCK Status
- Built-in Ethernet (Teensy 3.6)
- Timer0 and Timer2 unable to change frequency in CTC mode
- Teensy 3.6 and WIZ820io low performance/slow transfer speed
- elapsedMicros strangeness?
- IntervalTimer - data consistency...
- Unable to compile under windoze
- New Teensy 3.2 not able to program.
- Generic Board design with protection in/outs
- SPI interface with microwave synthesizer
- Prop Shield - large drift
- USBHost_t36: Midi send?
- Issue with Dallas Temperature / One Wire library example
- **crosspost from github.com/adafruit/ILI9340** can't drive two displays simultanously
- ILI9341 display
- Android Things and a Teensy
- Fast streaming USB data through Teensy DAC
- ILI9341 display libraries
- Battery and charger add on for 3.2
- Accelerating Arduino Ethernet Speed
- WS2811 5V strip lights up for an instant, then nothing
- Teensy 3.2 and Wiz820io not communicating
