View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. teensy audio shield compatibility
  2. Teensy 3.5 Ultra Fast Digital Input
  3. Stupid newbie question - Cannot access Teensy
  4. monitoring teensy from the web with Yun
  5. Can't get sound from propshield lc
  6. Teensy 3.5 use SDcard with another SPI-controller
  7. PC crashing with Teensy 3.6
  8. Need help having Teensy 3.6 press on a touch screen.
  9. How to view serial data for debugging purposes.
  10. Encoder Library Help
  11. How to reboot Teensy 3.x without editing Watchdog
  12. ILI9341 TFT Display
  13. 4 Slave Teensy to 1 Master Teensy/EPS8266 using SPI
  14. FFT with Audio Shield and 32x32 RGB Matrix
  15. TFT from Buydisplay with ILI9488 and FT6236 controllers -Wiring
  16. Difference between UART Teensy and USB to UART
  17. Teensy LC, Logic Pro X help
  18. Help with detecting battery level and when USB is connected
  19. Are rawhid_recv() and rawhid_send() thread safe or "thread usable"?
  20. ILI9341 Library doesn't work above 96MHz
  21. Teensy 3.6 suddenly stopped working
  22. MIDI controller by Teensy 3.5 was not worked !
  23. Highest recommended analog input impedance
  24. Ballistics instrumentation
  25. Teensy 3.2 not Communicating with XBee
  26. Tennsy 3.2 doesn't read CAN messages.
  27. LED Strip Display Code Issue: Teensy 3.2 + OctoWS2811
  28. DMA slave mode teensy 3.6
  29. Teensy 3.6 - Looking for a complete list of all FPU accelerated math functions
  30. Need help identifying components on Teensy 3.2 board.
  31. Can you use the analog pins on teensy 2.0 as digital
  32. Tips for precise timing?
  33. Simple Midi CC assignment question.
  34. Wiz850io no handle of multicast and no answer to ARP messages?
  35. Interpolation of amg8834 sensor data
  36. did I fry my mcp23017 or is my hookup wrong
  37. SD Card higher Snooze.hibernate currents.
  38. Teensy++ Windows10 unable to communicate with board.
  39. TimeTeensy3 example -> Time chosen is not permanent
  40. Teensy 3.2 with audio, serial, and ili9341 touchscreen hangup problem
  41. How to add nonstandard baud rate to flexCAN(colink80 version)?
  42. Two joysticks on a Windows computer
  43. Teensy 3.5: How is USB1 accessed?
  44. 1N36B teensy 3.1 non working with USB
  45. Shutdown RTC current
  46. Android Teensyduino app (for programming)
  47. Odd button behavior on pin22 vs 23
  48. OctoWS2811 Pin Restrictions for Teensy 3.2
  49. Any chance of adding SPI.transfer(txBuf, rxBuf, count)?
  50. Hardware Serial Flush
  51. Teensy 3.6 and W5500 Ethernet chip
  52. ILI9341_t3(n) and snooze, power consumption in hibernate
  53. Teensy 3.2 and ChronoDot 2.1
  54. Change Arduino IDE colors
  55. CAN FD on Teensy?
  56. This circuit killed 2 teensy 3.1's , what did I do wrong ?
  57. Working with two Teensy 3.x on same PC
  58. Accurate Square-wave Frequency with elapsedMicros?
  59. Teensy 3.6: determine if board is functioning
  60. Cannot power OneWire sensor from batteries
  61. A way to know when the host polls an USB endpoint?
  62. Teensy 3.x and SMLAL cycles (32×32+64 signed multiply-add)
  63. MIDI CLOCK performance problems with Teensy 3.2
  64. Trying to use Serial5 to my laptop USB port.
  65. Bus speed of Teensy 3.2 at 72 Mhz?
  66. Teensy 3.6 vs Arduino Issues with Adafruit Bluefruit LE SPI Friend
  67. T 3.6 UDP problems
  68. Cortex - read out status register of ALU
  69. Two Teensy's on One Computer et al
  70. mpr121+audioboard+Teensy3.5
  71. Teensy LC - went dead ? SPI / I2C Programming ?
  72. Voltage droop - Teensy LC
  73. Teensy 3.2 odd results with Slow Baud rates and High CPU Speeds
  74. USBHost_t36 Problem
  75. Teensy 3.5 - ADC, DAC Questions
  76. A dangerous Teensy 3.6 quirk
  77. fastled lib question about apa102
  78. Master.ino.hex unreadable
  79. MK66 VREG_IN Mux
  80. Disable Uart TX to use as GPIO
  81. Bricked Teensy LC with Blinky?
  82. first kicad schematic attempt
  83. Dynamic AudioInputAnalog/AudioAnalyzeFFT1024/AudioConnection instances
  84. IntervalTimer::UpdateInterval(void (*funct)(), uint32_t cycles) addition?
  85. Teensy 3.6 FreqMeasure alternate pins
  86. Pin count discrepancy.
  87. MKL04 Flash lifespan? Can a Teensy be made to last decades?
  88. Teensy Spec table
  89. Teensy LC & datalogger SPI pins?
  90. Teensy 3.2 no longer able to upload code via Arduino IDE
  91. Yet another dumb newbie question
  92. SPI Library use on Teensy 3.5
  93. WAV file or SD card corruption
  94. Implementation of VREF
  95. unnessary serial output SD
  96. noInterrupts() allowing some interrupts - LIS3DH, NRF24L01+, Teensy 3.6
  97. Teensy with MK66FN2M0VMD18
  98. Rohs?
  99. USB HID Set Report. Where to get the Data?
  100. Custom Teensy3.5 Layout
  101. Not able to update firmware on Ergodox keyboard on OpenSuse 42.3 Leap
  102. Teensy 3.2 using Mahony/Madgwick AHRS. Should it be this Slow...
  103. Digital pin difference between Teensy and Arduino?
  104. Teensy 3.6 USB Host and Keyboard LEDs
  105. Possible danger when using low voltage signal wiring from 240vac black box?
  106. MS5611's I2C not detected on Teensy 3.6 but detected on Raspberry Pi !
  107. Deactivating FPU on Teensy 3.6
  108. Teeny loader automatically shuts down after opening, used to work
  109. Teensy 3.5 - DAC questions.
  110. Teens 3.2 - Strange behavior on pin 14?
  111. SerialUSB on Teensy3.2 locking up on overflow?
  112. SD card open second file.
  113. Is this possible? Teensy 3.2 + Audio Shield + Lipo Charger + Lipo Fuel Gauge?
  114. Converting Due specific code to general SPI library
  115. snd-usb-audio: probe of 1-1.5:1.3 failed with error -16 (Teensy 3.2, audio+midi+seria
  116. Can a teensy 3.5 handle 5 encoders and 5 PIDs?
  117. Externalize bootloader
  118. Neopixel Library Missing Arduino Defines for Teensy 3.5
  119. Proper use of Teensy 3.x AGND
  120. Teensy 3.5 serial port (port busy)
  121. E1.31 sACN Ethernet DMX Performance help - 6 Universe Limit improvements?
  122. Publishing Issues
  123. Teensy 3.2 doesn't appear at device manager/arduino IDE
  124. I2c eeprom with Adafruit numeric display
  125. Teensy 3.5 clock configuration
  126. Teensy 3.6 EEPROM read/write cycles
  127. Teensy 3.5 different packages
  128. Teensy 3.6 - programming usb pin
  129. SdFs - a New SD Library for FAT16/FAT32/exFAT
  130. Hesitation in executing sketch code on Teensy 3.6
  131. writeRectNbpp() function display bitmaps with out size in variables
  132. Adafruit_winc155 spi
  133. Custom board based on 3.6
  134. 100kHz noise on power supply when USB is plugged in
  135. Are the boolloadre chips compatible with MKL26Z64VLH4?
  136. FlexCAN with extended ID's
  137. Assistance with Teensy 3.2 and Adafruit Ultimate GPS Data Logger
  138. Battery backed NV RAM
  139. Cannot compile Adafruit_CC3000_Library
  140. decrementing struct with switch case
  141. <FreqCount.h> Can I measure 2 frequencies at the same time? (On 2 pins?) Teensy 3.5
  142. Teensy 3.6 dual USB device
  143. Teensy 3.6 FPU and 'fuses'
  144. Available Digital Output Pins
  145. Sd: Use_teensy3_optimized_code
  146. DMA priority confusion
  147. Use Teensy 3.6 USB for serial.
  148. Fastled and SSD1306
  149. Help me get started with Teensy LC and LEDs
  150. Simple toggle switch
  151. Teensy 3.2 RTC crystal replacement
  152. OctoWS2811 output pins available for other uses
  153. Teensy 3.5 input power regulator (LDO)
  154. LED Matrix TLC5940 optimization
  155. /dev/acm0 not found
  156. Teensy 3.5/3.6 SD card free space
  157. Constant MIDI Messages Sent...
  158. Two sensors can't work at the same time on Teensy 3.6
  159. Teensy 3.2 with Wiz820IO cannot receive multicast messages
  160. Teensy 3.6 and Adafruit_RA8875
  161. Help for Teensy 3.2 + F-RAM 4mbit 3 byte addressing
  162. SD + ILI9341 conflict
  163. Teensy 3.6 library for Proteus
  164. COM port error
  165. teensyduino -> USB Type: Keyboard + serial
  166. vertical scrolling with ili9341_t3 or ili9341_t3n
  167. Teensy 3.6 ADC/DMA Question
  168. Using multiple spi hardware controllers on teensy
  169. teensy 3.6 and pin A11 A10 AREF
  170. Teensy 3.x and Dragino Lora Bee Question/Problem
  171. Teensy++ 2.0 3v3
  172. adding functions to library ili9341_t3 or ili9341_t3n
  173. Teensy High Low threshold
  174. Teensy 3.2, ADXL345, and SPI comms
  175. Fried my Teensy, help me understand how please
  176. Audio Line In with FFT
  177. Freqmesaure and MKRFOX1200 arduino.
  178. OctoSK6812+Artnet+ 280ledsSK6812 x4: Only first 3 universes ok, next are lagging
  179. Issue between Teensy and STM32duino
  180. Solar cell + supercap to power a Teensy LC
  181. How to use the FPU in teensy 3.6?
  182. Teensy (LC) and nrf24 do not work
  183. Change I2C bus for TCS34725
  184. Teensy 3.2 not showing up on serial port already tried troubleshooting
  185. USB MIDI stops working after a few seconds
  186. DMAChannel help for reading camera data bus
  187. unsuccessful in communicating with new 3.2 via Arduino and Teensy
  188. Multiple Teensies connected to Linux computer - only first 17 detected
  189. Does Teensy3.6 support this current?
  190. SerialUSB in Teensy-3.5/3.6 not worked with microPython
  191. Changing the PIN_SPI_SS from 10 to 15
  192. Teensy LC not recognized
  193. Good mapping for JTAG TMS pin on Teensy 3.6
  194. Teensy 3.2 Flash over serial
  195. How do you use processing to set RTC on a teensy 3.2 ?
  196. Recording Stereo Audio to SD Card
  197. I2C on Teensy 3.6 doesn't work (i2c_t3 examples too)
  198. LED Ring with 595 shift register - pinout/bit order?
  199. Issue with SPI.h, teensy 3.6 arduino
  200. Teensy 3.6 and (Arduino) library "Wire"
  201. Full byte/word read and writes? 3.2
  202. Help! Having troubles verifying in Arduino software - Error Compiling for Board
  203. Can't upload to Teensy LC on Raspberry Pi
  204. Attaching interrupt to CAN on teensy 3.6
  205. Pool Teensy at 1kHz via USB
  206. Default serial port of Teensy 3.6
  207. Copying/Duplicating Program on Teensy ++2.0
  208. Teensy++2.0 Keyboard
  209. teensy quit unexpectedly
  210. Serial port number via USB
  211. Print descendents, scope issue, comsManager
  212. I want to control large LCD or touch LCD(10~16 inch).
  213. IP Broadcasting backwards with Teensy 3.2 and ENC28J60 Ethernet Module
  214. LSM9DS1, Madwick and Teensy 3.6
  215. elapsedMicros: how to disable almost all interrupts?
  216. Which of the two "hidraw" devices is my RawHID?
  217. Selecting Alternative Functions of a Pin
  218. SPI-SPIsettings clock polarity change(CPOL) happens late with AD9833
  219. Teensy 3.6 at high baud rate
  220. Good way to debug DHCP library in Visual Micro?
  221. begginer question - serial monitor not responding
  222. Seeking explanation of "5V tolerant" re Teensy 3.2
  223. Using FreqMeasure to detect audio sine tones frequencies from audio source
  224. Project viability
  225. 2D array does not get allocated?
  226. WinAVR install destroys PATH env var?!?
  227. Teensy 3.2 Octows2811 fastled flickering problem
  228. Code works on Arduino but not on Teensy
  229. Equivalent to AVR ports?
  230. beginner question - need clarification/links for further readings
  231. Question about the XenGi's KiCAD library
  232. Teensy 3.x External memory bus feature usability or substitute?
  233. Teensy LC "true 12 bit digital to analog converter" -- how to?
  234. Strange behaviour of SD library
  235. ILI9341 Blink TFT teensy3.2 help
  236. How much time does it take to execute a digitalWrite instruction on Teensy 3.2?
  237. How to Best to Pass WireX to a Library
  238. Keil usage with teensy 3.6
  239. trying to port some assembly.
  240. Custom Teensy 3.2 power issue when USB is not used
  241. Help!
  242. problem using digitalreadfast
  243. Need Help with Teensy 3.6. Serial COM port disappears after uploading code
  244. Setting a variable to 0 requires two writes?
  245. Where can I find the source code to the "blink_fast_Teensy2" program?
  246. Teensy 3.6 bare USB code
  247. 400 Hz ESC PWM
  248. Teensy LC and MIDI library: MIDI_CREATE_DEFAULT_INSTANCE() not needed?
  249. Cortex code with Teensy
  250. question about IntervalTimer
