View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Frequently Asked Questions
  2. 0.5 microsecond resolution Teensy 3.6
  3. Advice on solder-on header choices, Teensy 3.6?
  4. Wrong DAC Output when playing 2 WAV files with Teensy 3.6
  5. I there a "teensy_reader_cli" program?
  6. java.lang.OutOfMemoryError: Java heap space
  7. Teensy 3.6 DAC Output Bug
  8. debugging question - basic check
  9. Teensy 3.2 RTC load capacitance and intermittent failure to tick
  10. Does audio board support mic-in on 3.5mm jack?
  11. L3gd20h data ready(DRDY) pin
  12. Uploading won't reset 3.6
  13. Brief clarification on pwm frequency behavior for slow PWM frequency and PID
  14. serial.print won't print + general debugging issues
  15. Teensy 3.6 USB High Speed status?
  16. WIZ820io adaptor power down
  17. Powering T3.2 or T3.6 from a single LiFePo4 battery
  18. Read Micron N25Q064A Flash Chip using SerialFlash library
  19. Getting input back into the teensy.
  20. FlexCAN Mailbox Provisioning
  21. multitasking- not sure how to use millis()
  22. Teensy 3.2 Sensor Reading Issues
  23. Teensy 3.5 + Audio.h + ICS43432 for Audio Cue?
  24. Use more than one Teensy with RawHID at once?
  25. Boot loader license
  26. Using 14 instead of 13 for SCK in 4 wire SPI
  27. Teensy LC Serial2 9-bit hangs on open
  28. Hardware Serial Buffer Size Library
  29. Clarification on using SPI within interrupts on the teensy 3.X series
  30. Teensy 3.2 Audio Shield and APA102 LED STRIP
  31. New Teensy LC Problem
  32. Ethernet on T3.6 SPI1 with FIFO
  33. Testing teensy 3.2 loop time getting strange result?
  34. Teensy LC gets very hot and can't be reprogrammed
  35. SPI (seemingly) half speed
  36. Teensy 3.2: Has anyone got it to interface with android in any mode?
  37. set teensy 3.1 clock at 2 mega hertz!!!!!
  38. DIfferentiating I2C ports
  39. A handful of newb Teensy 3.2 questions
  40. Teensy LC + CD74HC4051 multiplex Midi problem...
  41. Teensy 3.5 with Adafruit Fether adaptor
  42. SHT21 hangs I2C bus
  43. start/stop interrupts with IntervalTimer
  44. Compile / Link Error with i2c_t3 and Audio
  45. Serial comm isssue.
  46. Best way to drive huge LED Matrix Display
  47. Extracting the joystick library
  48. A question about Teensy 3.6 USB interfaces
  49. Trying to fix broken Teensy 3.6 boards -- is there a component layout guide anywhere?
  50. can't find a pin ! D10 - T3.5
  51. Issues with SPIFlash and Spansion S25FL128L memory
  52. Legitimate Teensy 3.2?
  53. USB Low Speed
  54. Teensy 3.6 died mysteriously x 2
  55. tools for profiling and more
  56. RTOS no longer usable with Teensy?
  57. Teensy 3.5 and X-Plane
  58. Maybe a Linux build problem - redefinition errors
  59. Teensy 3.6 millis() problem &fastled
  60. Teensy LC - command line build not working
  61. Which header file to use to resolve "Keybord.print" and where to find it?
  62. Board-Specific Compilation
  63. GUI tutorial and ideas ?
  64. Serial communication at high baudrates
  65. Teensy push button
  66. Low USB connection latency on Teensy 3.5
  67. new problem with start/stop interrupts with IntervalTimer
  68. Teensy 3.x SPI hardware bugs - trying to get an overview
  69. has any one ever bricked a teensy through programming it.
  70. Teensy 3.2 INPUT_PULLUP. Problems with Pushbutton
  71. combining Teensy Audio and Pedvide's ADC libraries
  72. Which I/O pins on Teensy 3.6 are interrupt-capable?
  73. Json data compression???
  74. teensy 3.6 problem
  75. OctoSK6812+Artnet+ 280ledsSK6812 x4: Blackled from Alex-Arc
  76. Teensy Programming without Windows Drivers
  77. New T3.6 USB serial port problem
  78. USB_Serial for Teensy 3.2 without Arduino
  79. Teensy and Adafruit TCA9548A
  80. New on Teensy, products choice and the logic.
  81. Support for FreeRTOS
  82. Can't load a new program
  83. curious errors porting a project from Arduino to Teensy
  84. 12.5V into a Teensy-LC somewhere?
  85. Teensy octows library and adaptor
  86. short pulses on the MOSI line after every 8 bits
  87. USB 5v on Teensy LC
  88. Analog input problem
  89. error compiling for teensy 3.5
  90. Teensy 3.5 with nRF24L01+, only half of the message is correct?
  91. Avoiding I2C bus lock using MCU-driven I2C Slaves
  92. Spi
  93. question regarding use of multiple teensy simultaneously
  94. MIDI out from DAW
  95. 3 AAA batteries with a "dummy" usb cable
  96. Accidentally wrong CPU speed flashed
  97. SnoozeSleepPWM does not work
  98. Need help with FT800 using Gameduino 2 libraries on Teensy 3.6
  99. #define vs. constant int
  100. Teensy LC/3.1/3.2 controlling a +5VDC 8A load: schematic check
  101. Teensy 3.6 and GNU MCU Eclipse
  102. Teensy + sound card running Color Organ - How to add BLE audio input?
  103. RC Receiver Problem With Teensy 3.2
  104. Teensy 3.6 SPI transaction speed problem
  105. Java out of memory error, please help
  106. How to "attachInterrupt" inside a library?
  107. time but not teensy loader
  108. Teensy++ 2.0 Keyboard Modifiers
  109. Teensy++ 2.0 as ArduinoISP Programer
  110. Ardunio IDE and orange colour of class methods or properties
  111. Teensy + winc1500 - only working when plugged into computer
  112. Teensy LC exact baud rates?
  113. manchester decoding teensy 3.2 with uart
  114. A22 not declared in this scope
  115. time needed for analogRead()
  116. SD-card reading with Teensy3.2 much slowlier than with Arduino2560
  117. Teensy 3.5 + Arduino 1.8.2 + Teensyduino 1.39 (trying to compile neopixel-library)
  118. Very Basic Teensy3.5 query
  119. Teensy 3.2 with IIC 128x64 OLED Module
  120. how to reinstall USB driver?
  121. Uploading hex files via teensy_loader_cli without pressing the reset button
  122. Periodically interrupting PWM signal using DMA
  123. Keyboard Extra keys - both USB Keyboard and T3.6 USB host Keyboard.
  124. How to master/slave Arduino UNO->Teensy 3.6
  125. USB Type B Connector ( External ) for Teensy - HARDWARE
  126. unreliable timing using metro library
  127. Teensy 3.5/3.6 Ethernet
  128. Semihosting and creating files on host computer
  129. SPI and I2C distorted signals Teensy 3.5
  130. Help with some UART raw transmit code
  131. Inrush current limiting techniques and solutions
  132. USB host port on Teensy 3.6
  133. Auto Loader not working. Teensy 3.2 and 3.6.
  134. Trouble with analog ports on Teensy3.6
  135. Need clarification about I2C and the audio shield or other devices as INPUTs
  136. Teensy 3.5/3.6 header pin height
  137. Teensy 2++ program button repair...
  138. problem with octows2811 and (probably not) MIDI
  139. Display only shows white
  140. Teensy 3.2 EEPROM
  141. Starting a project based on Teensy 3.6
  142. T3.6: Tpd3s014
  143. Teensy 3.5 forgets the time of day
  144. Teensy 3.2 + Audio Board + MCP23S27
  145. nRF24L01+ radio with Teensy 3.6
  146. pin assignment of uart
  147. How to kill a Teensy
  148. Conflict with Teensy 3.X and HX711 Libary, I think related to ShiftIn function
  149. Teensy3.2 => Atmega328 (Arduino) via I2C Dropping Transmissions
  150. Activate CAN termination resistor using software
  151. trouble using Serial.parseInt
  152. teensy3.6 dead on arrival?
  153. Teensy 3.6 Digital Pin Current Sink
  154. Teensy 3.2 output 16MHz clock?
  155. which Teensy are compatible with Arduino ?
  156. teensy dead ?!
  157. Do SPI1 and SPI2 of Teensy 3.6 work?
  158. Serial not picking up data on resets
  159. Joystick Teensy with problems in last update of Widows 10
  160. Teensy 3.6 pinout drawing?
  161. Upload sketch to teensy via serial1 or any input besides the main input.
  162. Simple digital input button on teensy 3.6
  163. Tools>optimize> ??
  164. An easy way to get Serial with HID?
  165. Teensy 3.2 and Serial1 baud rate
  166. How does the Arduino IDE detect on which serial Port the Teensy is attached
  167. Whine Noise
  168. What microphone should I get?
  169. Synchronous ADC read and DMA transfer
  170. How to find out the interrupt number that IntervalTimer is using?
  171. TEENSY 3.6 is suddenly not being detected after working fine for a while
  172. breadboard problem, suggestion for a good one in the EU
  173. Connecting to USB while powered up via lipo troubles...
  174. Struggling generating values for non-linear PWM output
  175. Teensy 3.2 and 1602 llc
  176. Teensy 3.5 Power Supply short
  177. Array of structs ?
  178. 100kHz input signal returns 5V digital output
  179. 2 simultaneous SPI communications on Teensy for a Full-Duplex System
  180. Advice on code design needed
  181. OctoWS2811 and Glediator
  182. Teensy 3.5 use onboard micro SD + second SD card
  183. Is it bad to use breadboarding jumper wires outside of prototyping ?
  184. Set pinMode via const array for pin numbers?
  185. bInterval values for BULK-IN and BULK-OUT Decriptors
  186. OctoWS2811 - Pinout
  187. memset __OPTIMIZE_SIZE__ ?
  188. teensy 3.6 ADC resolution problem
  189. Teensy Pot linearity
  190. Question about serial ports
  191. COM error under Windows 10
  192. OctoWS2811 with WS2815 leds - 12v DC
  193. Connecting Raspberry Pi to Teensy 3.2
  194. Bug with Teensy 3.2, WS2811 LED-Strip and FastLED
  195. USB Keyboard not working (Teensy LC, Ubuntu 16.04)
  196. Powering Teensy LC via IO-Pin?
  197. T 3.5 was working, now no USB
  198. Teensy 3.2 analogRead question
  199. USB direct wire?
  200. Need help setting up AHRS with Teensy LC and MPU9250
  201. Analog Read Teensy 3.5
  202. I2C communication between to teensy boards
  203. Storing images or image data on SD (gaming)
  204. Using RC522 on SPI1, Serial1, and SCK1.
  205. What is the power consumption of the Teensy 3.6?
  206. usb_serial_class and HardwareSerial as class member
  207. XPT2046_Touchscreen & Interrupt
  208. What does the second IC do in the Teensy LC?
  209. FastLed vs Neopixel vs Audio library - CPU overload?
  210. Dual Voltage Teensy LC
  211. TimerOne over 1Mhz
  212. Teensy 3.5 doesn't become programmed
  213. Problem with the Encoder library
  214. Teensyduino Installer can't access Arduino folder when installed from App Store
  215. OctoWS2811 basic test behaving erratically
  216. Teensy 3.2 Vin voltage range
  217. Recording Data to Flash using Prop Shield
  218. Teensy & Prop Shield lagging after being on for a short amount of time
  219. Trouble with i2c_t3.h library
  220. Pololu AltIMU-10 v5 not working (Teensy3.6)
  221. Teensy 3.2 RTC clock crystal
  222. SerialFlash Library - Max Number of Files allowed?
  223. Startup/hard reset problem.
  224. How do the keyboard set_key(n) codes work?
  225. Feeding Voltage into PIN of Unpowered Teensy
  226. Output to Serial from functions in .cpp file
  227. Teensy LC USB pad dimensions/location
  228. button on teensy 3.6
  229. Teensy 3.6 Power Problems
  230. Sierra10.12.6 and Arduino IDE 1.8.4 do not alow for teensy USB port connection
  231. OctoWS2811 Wiring Question
  232. Need help with code for Project Shade Sort(Inventory Management)
  233. Can't analogRead and play audio at the same time without massive interference
  234. Need help debugging Teensy LC and MPU-9250 (via i2c)
  235. Teensy 3.6 give 0.33V digital output
  236. 5V tolerance on pins configured as analog inputs
  237. Teensy 3.2 Potentiometer Arduino Coding (minor problem)
  238. ads8885, ADS132A02, ADS1252 question
  239. TB6612FNG motor driver not working (Teensy3.6)
  240. Using built in filters (Biquad, fir, etc.) to remove noise in dac signal?
  241. More than 8 MCP23017
  242. Serial.print() stops
  243. IntervalTimer and FreqMeasure resource conflict (Teensy 3.2)?
  244. Error when passing elapsedMillis to map function
  245. ST7735 Occasional White Screen with Teensy 3.2
  246. Can't send info to Teensy 3.6 com port from PC
  247. Bounce libray :use of constructor and setup()
  248. Teensy 3.6 audio library and pulseIn read from an RC transmitter
  249. Teensy LC Serial1
  250. Blink LED by direclty port manipulation
