- Teensy write key by key, UTF-8
- digital output goes high on power up
- WS2812Serial, BasicTest not working
- Teensy 3.6 internal clock fast at 2 Mhz
- Teensy conflict problem?
- Using two Oled with the same address on a teensy 3.5
- Win10 USB Serial yellow triangle
- MIDI wont work on teensy, works on arduino?
- Simultaneously start multiple timers
- Teensy 3.5 irregular output from PID control loop in 5800ms intervals
- Inadequate number of slave selects in SPI_PUSHR_PCS macro
- USB not detected
- Is there a list of timers (and other peripherals used)?
- println stops after 6 iterations
- Audio Block Allocation Question
- USB Host Status of control transfers
- ICS-52000 24bit TDM and Teensy audio
- double literals need to be marked as long double?
- Teensy 3.2 + ENC28J60 Strange behavior
- Help with multiple SPI buses and SD card reading
- Teensy 3.2 and 74HC595 Problems
- "Continuous mode"
- Teensy 3.5 - Using different voltage references for ADC and DAC
- trying to upgrade teensyduino
- I2C pains with Sensirion Pressure Sensor SDP810
- teensy 2.0 usb keyboard
- Teensy 3.5: Programming Problem
- Teensy 2.0 as joystick not working
- Xbee Teensy 3.2 Adaptor old style
- digitalRead() the Teensy's 3.3V logic? (digitalRead not working)
- Short simple menu? (gaming)
- Teensy 3.5 and SPI2
- (question) Uploading and running ARM machine code?
- Newbie SD card questions
- Need help using Teensy++
- Wiz850IO and PHYCFGR register
- Teensy 3.6, Flexcan lib, dual canbus
- Teensy LC and Prop Shield with APA102
- Some I2C observations on T3.2 vs T.36 with Wire.h and i2c_t3.h
- Encoder Library / Menu Advice
- port manipulation - What am I doing wrong?
- Teensy Power from source other than USB
- Using 1gb eeproms with two chip select pins
- How long the comparator mux settling time, tweensy 3.2?
- Writing recorded audio to SD card - prominent sound artefacts hearable
- Any way to remap GPIOs?
- USB Device Not Supported - on iPad
- Teensy 3.6 5V and 3.3V workaround
- Teensy 3.6 instruction reference
- CmdMessenger + PyCmdMessenger on teensy
- Teensy 3.6, audio adapter and apa102: sound reactive LEDs
- Trying to customise <TimeLib.h>
- Question about Teensy
- Problem FreqCount Lib No read after 12MHz
- Wierd and frustrating ?bugs?
- Teensy3Time.ino updates wrong time ...
- Teensy Audio Workshop Connection A1 SD card problem
- OctoWS2811.show() return takes too long
- Teensy 3.5 serial port malfunctioning
- Encoder library, how to change direction (CCW CW)
- 5V on analog input teensy 3.2
- Cannot flash/upload code to Teensy 2.00
- HID serial emulation (SEREMU)
- Running Teensy LC on external 3.3V
- Using Pins 18 & 19 while using the audio library (without the audio board)?
- Strangeness with Tone
- Raspberry Pi B+ Marlin Firmware Teensyduino QU-BD 2UP Printer, Firmware Flash issue
- Wiring to board
- Teensy 3.6 overclocked to 216-240MHz and audio adapter board -> LRCLK jitter
- Teensy 3.2 + WIZ812MJ
- 1.723V on GPIO and muxing pins
- Gui bug with teensy 2.0 based mouse.
- T35 issue with floats/int32s conversion - maybe?
- Issue with i2c_t3 interfering with wire declaration
- Accessing PROGMEM correctly with Structs
- Teensy 3.2, internal pulldown and pullup resistors
- Does AudioMemory() support more than 192 blocks?
- Encoder feedback inaccurate, how to change encoder direction
- 3.5 Boot Lockup
- Teensy 3.6 and Max7219
- Teensy 3.6 crystal
- BCLK Generation (I2S)
- Upload firmware via CANbus
- How to use the audio adapter thumbwheel potentiometer?
- return value of usb_serial_write()
- Teensy LC - MPU6050 I2C. How to pullup +3.3V?
- Teensy 3.6 ADC data sheet / setting a static sampling rate
- Teensy 2 : internal LED issue with pin PD6
- Teensy Loader Linux soft reboot not working for brand new teensy. (Works on windows)
- Teensy3X as serial communication device uart/ftdi
- Teensy 3.6, Single wire and WS2811
- Teensie 3.6 SPI communication not getting SCK signal as an output
- I2c scanner doesn't find audio board
- Arduino 1.8.5 New Teensy 3.2 not showing up on port list anymore
- Teensy 3.2 external power 9Volt problem
- Download ERROR (post str r0, [r1])
- how to prevent data loss when sending large file over usb serial
- teensy2 ADC weired berhaviour
- MIDI Teensy 3.2 Issue[s]
- Teensy 3.6 with usb host shield
- Teensy not being recognized as MIDI device (showing up as generic usb audio)
- COM-Port problem
- Teensy 3.5 - How to write data to DAC pins easily?
- Complementary PWM with the Teensy-LC
- Vl53l0x
- Usb host (computer)to usb host(teensy)
- Teensy programing mode
- Teensy 3.5 + Exemple 'AnalogControlChange' Problems
- teensy 3.5 and I2C MODULE FOR LCD 20X4
- Count ADC multiplexing delay
- Interrupts and float operations
- USB Descriptor packet fun!
- Command line teensyduino install?
- Teensy 3.6 SPI problem with Teensyduino 1.40 but not 1.35
- Dedicated controller for soft synth that also reflects current settings
- How to program the teensy without pushing the button
- Teensy Loader, Command Line, Version 2.1 - no upload anymore
- Interrupt Module?
- available() always returns zero after receiving 10 bytes on hardware serial ports
- movie2serial issue ( a library used by this sketch)
- Instantiating AudioPlaySdWav from a library.
- BlackLed problems with ws2812
- AudioLibrary Github workflow
- Teensy3.6 joystick host?
- TeensyLC, arduino 1.8.5 joystick problem in Win7
- switching button controls from one function to another
- Teensy 3.5 OctoWS2811 WS2812B Pixel Tree
- Teensy 3.2 flickering using fastLED library for some xmas lights projects
- The strange SD card behavior
- test code for piezo
- SPI PCSIS Pin Order
- usb midi name
- Updating Bounce Objects After Wakeup from Snooze
- Using Teensy 3.2 with Audio Adapter Board and Prop Shield
- float variable to pwm
- Teensy loader cli on fresh noobs raspbian install on raspberry pi
- Anyone else seeing Serial problems with 3.5 recently?
- Midi Controller (1 potentiometer + 1 capacity sensor)
- Teensy 3.2 octows2811
- PlaySdWav(string)
- Correct -mmcu for Teensy 3.5
- micros() and delay() - novice question
- Teensy 3.2 programming through Atollic TrueStudio?
- Serial USB communication weird boxes
- Support for SLEEP_MODE_IDLE on Teensy 3
- Using 2 DMA Channels for 2 DACs on Teensy 3.6
- Can I use teensy as a simple analogue to digital converter when connected to a PC USB
- Cycles to LDVAL in PIT explanation (IntervalTimer)
- Best practices for not frying a non-5v-tolerant Teensy
- Cold start problem
- T3.5 Interval Timer example-OK in Arduino IDE,compiles but doesnt work in VM
- problem using MIDI library and serial monitor at the same time
- Problem communicating with Teensy 3.2
- Teensy LC - EEPROM reader
- SDI Serial and AltSoftSerial
- USB HID Reportid
- Cubesat Teensy, software uploading
- M4 pin to Teensy 3.2 pin mapping?
- Stepper Driver Voltage
- PSA: How to retrieve the status of "lock" LEDS in a USB Keyboard project. [Teensy2.0]
- Data logging
- Reset Teensy 3.2 from another Arduino
- digitalWriteFast() unexpected behavior
- Questions about W5500 and Wiz850io
- Arduino tem file directory not found
- TOF mini Lidar
- Dump NAND Flash
- how to pick ports for analogRead () on T3.2
- matrix of pins to increase inputs
- Teensy pin 13 use and the audio board.
- Teensy3.6 with TinyGPS, Interrupts
- RTC battery for T3.2
- Teensy3 linking (Makefile)
- keypad library: how to differentiate between momentary switch and toggle switch
- Teensy 3.5 RX4-TX4 RX5-TX5 RX6-TX6 pins inverted
- Time setSyncProvider in library
- Calibrating touch screen display
- Pin bank mapping on Teensy 3.5/3.6?
- Clash with ethernet and TFT_ILI9163C libraries
- How do you use the Joystick class to setup a HID joystick?
- Weird HWserial1 behaviour compared to Mega2560
- collect2.exe: error: ld returned 5 exit status
- 9bit Serial on Teensy2/Teensy2++
- SSD1306 Library crashing Teensy 2.0
- FYI: Using the Teensy 3.6’s USB1 (USBHS, High Speed) port in device mode
- Getting Kinetis SDK examples to work on the Teensy
- Porting TVout lib on Teensy 3.2
- Teensy 3.2 Pin output voltage <1V, Broken?
- Dragonframe stop motion software with Teensy and Stepper Motors
- shift registers aren't working on teensy
- Teensy 3.6 Upload Problems
- Teensy 3.2 not powering up from my custom breakout board
- Eclipse cannot resolve symbol Serial
- SD card initialization failed
- Teensy 3.2 + Octows2811 random trashed data
- Teensy 3.6 Random Number Generator
- [Teensy 3.2] Help! Can't get basic Teensyduino servo example working?
- No COM port
- Teensy Quad Assembly/Testing
- Issue powering Teensy 3.6
- Teensy 3.6 Fastest Generated Waveform
- T3.6 Simple AnalogRead While loop with Serial Debug generates corrupt debug
- Teensy 3.6 + Octo LED Performance
- Teensy LC strange power -- HELP!
- New to Teensy.. no upload LED flicker?
- Corrupted data structure after file open?
- Help with Teensy 3.2 and a 3-way switch to read on a single analog pin
- How to stop continuous FlightSim updates. Tennsy++2
- FreqMeasure frequencies off by 2X
- Snooze digital.pinMode problem
- Teensy 3.5 and bounce2 - different behaviour on USB power bank vs PC!
- Teensy 3.6 with $xx NXP LPC-Link3 debug probe & $0 MCUXpresso IDE with GCC, GDB etc.
- Teensy LC with own board
- Teensy 3.5 Can + FreqMesure Problem
- Teensy 3.1 on Linux
- Multiplexing bits in Pin Control Register
- using uint64_t and mucking with bits...
- Rotary Encoder for 3.3V (Teensy 3.6)
- Library Conflict
- Teensy 3.6: USB host female cable in EU?
- SBUS library - not reading analog pin
- Is there a way to calibrate analog inputs?
- Teensy version for HID?
- Teensy LC: Detect if a usb connection has been established
- Teensy++2.0 Modifier Keys help
- Union containing struct -> union constructor gets auto-deleted
- weird digital input behavior with weak weak pull-down
- How to add Teensy board to VS Code with Arduino plugin?
- How do I provide 5v from Teensy 3.2?
- Visual Micro and rtc_localtime symbol
- Teensy 3.2 not recognized by Windows 10.
- Teensy Pitch Detection: How to go faster than 70ms?
- unwanted solder bridge, Serial3 to ground
- Teensy3.1 Occasionally unresponsive
- Analog input size on Teensy 3.2...
- Teensy3.6 clock frequency
- Problem with three buttons
- Uploading from Sleober to Teensy
- Teensy LC stopped working.
- Compile errors with core_cmFunc.h
- Changing MISO pin using SPIFIFO
- NeoGPS, speed to pwm output Teensy 3.2.
- controlling gecko servo driver
- Teensy SPI question
- Changing the PWM frequency on Teensy 3.6
- I made a dumb mistake building a voltage divider board - will it hurt?
- Teensie RTOS (Real time operational system)
- Teensy 3.6 controlling Kangaroo x2 motor controller
- SSD1322 and teensy 3.5/3.6 connections
- USB Serial communication problem
