View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. using an i2c library from arduino in teensy 3.6
  2. Teensy 3.2 Serial Communication with RF module Issue
  3. Normally open transistor to control the inhibit of a driver from Teensy 3.5
  4. Difference between software reset and power on/off
  5. Problem with built-in SD card on Teensy 3.6
  6. Having some trouble figuring out a keyboard matrix
  7. damaged Teensy 3.0 question
  8. Joystick not working on Teensy++ 2.0 in Serial+Keyboard+Mouse+Joystick mode
  9. Teensy 3.5 only works with torsion applied to board
  10. question about heap size and stack
  11. Inverting pin signal for bi-color led
  12. OctoWS2811 Adaptor dimensions
  13. PlatformIO on Linux Mint in VMware on a Windows system -> upload not working
  14. Teensy 3.2 overheating / internal short
  15. Fast Port Reading inside interrupt with Teensy 3.6
  16. Serial Plotting Issue with T3.6
  17. Teensy 3.2 SPI pins
  18. Change Teensy HID Capabilities
  19. External Power Teensy 3.2 won't turn on without USB plugged in
  20. USB MIDI Example sketches are missing from my TeensyLC install, Plz help!
  21. ILI9325 with teensy 3.5 please really need help
  22. Teensy 3.2 as FTDI programmer for ESP12E
  23. teensy 3.5 port mapping
  24. unused Teensy not loading sketch have tried all the obvious trouble shoots
  25. USB Serial write timeout after sending 13 bytes to Teensy 3.2
  26. Has anyone tried TeensyLC with FL Studio? FL seems to ignore mine but MidiOx loves it
  27. Is my teensy 3.6 dead?
  28. memcpy
  29. Is it faster to use 32-bit operations on 32-bit processors?
  30. Teensy 3.2 HID - Can I receive info from PC as well as send keyboard commands
  31. Teensy 3.2 3.5 3.6 cache sizes
  32. Teensy 3.6 + Adafruit ATWINC1500 breakout board
  33. Various problems with an LED display I've made
  34. Custom HID hack
  35. Teensy External Reset?
  36. Example for i2c_t3 DMA
  37. lo noise stuff
  38. Using Reset on ILI9341 board
  39. Modifying touch.c
  40. help with atachinterrupt on teensy 3.5
  41. Low Voltage Detect (LVD) & Low Voltage Warning (LVW) on Teensy 3.6
  42. Example for i2c_t3 DMA
  43. Is there a simple E-paper driver for Teensy LC?
  44. Venus GPS integration with Teensy 2.0
  45. ILI9341 init commands
  46. Using Teensy 3.2, OctoWS2811 and SD Card Adaptor together
  47. Newbie struggles to connect Teensy LC to Xplane11
  48. Latching Push Button Woes
  49. switching 3.x between 96MHz/48MHz/24MHz (same F_PLL) on the fly ?
  50. Audio Adaptor Board - Thumbwheel Potentiometer
  51. Read real time data from Teeny 3.6 into MATLAB
  52. Problems trying to download via j-link
  53. Nmae of the CS pin in bare metal programming
  54. Teensy and Audio Shield not working
  55. How do I use nRF24L01 with TFT Touch screen on Teensy 3.6
  56. Powering teensy 3.5 from external power
  57. Teensyarduino won't install
  58. Reading file data from flash mem
  59. gracefully stop/restart USB ?
  60. Using Teensy 3.5 SD Card Port with Existing Code
  61. Keyboard.write() won't write backspace
  62. Teensy 3.2 works in Emulation Station but not Retroarch
  63. Paul, what is the "case code" for the 470ohm resistor in series with the LED on 3.5 ?
  64. SPI clock polarity setup not long enough..
  65. Long SD Filenames for Audio library
  66. Teensy 3.5 FREQMEASUREMULTI timer clock rate?
  67. Teensy 3.2 Keyboard // detect multiple keys pressed simultaneously
  68. help with teensy 3.5 and elec mic
  69. Rewriting DMA source buffer for DAC output
  70. Anti-grain 2D graphics library
  71. Teensy 3.1 smoked?
  72. Could I have bricked my Teensy LC? I don't get it so show up under Windows or Mac OS.
  73. Hard real time in Teensy 3.5
  74. syncing RTC to a PC via USB Serial, accuracy ?
  75. Why install libraries along with teensy support?
  76. problems with arduino-1.8.5 + teensyduino-1.41 and serial on linux and FastLED
  77. Another vexing problem with FastLED (lastest version): code hangs on show()
  78. WIZ820io inits to ip address 0.0.0.0
  79. Error with loop counter in audio processing project application
  80. How can i use DAC0 for analog input and DAC1 for audio output?
  81. Embed Xcode Teensy3.1 usbMIDI
  82. inflection detection
  83. problem with union in Teensy 3.5
  84. <PID_v1.h> myPID.Compute() function in IntervalTimer on Teensy 3.5
  85. Reading a signal at 40kHz
  86. Disable USB specific interface?
  87. T++ 2.0 on Arduino IDE 1.8.2 'class USB' has no member named 'Init'
  88. Compiler not detecting double constants?
  89. 24bit packed data format
  90. baudrate problem with teensy to teensy byte package communication
  91. How can I see with which parameters gcc is called?
  92. pins_teensy.c:163:56: error: expected identifier before numeric constant
  93. [SOLVED]4051 multiplexer not working correctly with teensy 3.2 but works with arduino
  94. Alarm.delay
  95. GND vs AGND
  96. Teensy 3.X COM port (frequently) disappears after programming
  97. Teensy 3.6 SD card during high energy impact
  98. Question about retrieving a file
  99. Teensy 3.5 3.3V Pin
  100. Disconnecting from I2C bus possible ?
  101. External Power AND sending MIDI data via USB port ?
  102. Teensy 3.6 RTC Performance Below Freezing
  103. Teensy 3.6 - I2S Audio on a Breadboard
  104. When is #define KINETISC needed?
  105. Why Int instead of 3 bytes for RGB?
  106. Problem with GPIOD_PDOR !
  107. Max output volume of AudioPlaySerialflashRaw
  108. New in 8051 and Want to learn more.
  109. Teensy 3.2 with FTDI Friend (adafruit) not receiving transmits
  110. Q for Paul - can I use SGTL5k in my own RX "shield" ?
  111. How to get accurate high resolution potentiometer readings
  112. Audio Adapter Dead...RIP
  113. USB Keyboard on Teensy LC not recognized on boot
  114. Help with Teensy 3.2 Midi controller code.
  115. Graphics Library for generic Dot Matrix Display?
  116. Online tutorials?
  117. Dedicated controller for soft synth that also reflects current settings
  118. ILI9341 using 4-wire SPI - confused by 5th wire? :)
  119. Does using 8 or 16bit variables save up RAM?
  120. Octows2811 with matrix panel
  121. Question: Rgb matrix, serial, gui?
  122. Problems with Single Wire UART
  123. Teensy 3.5 stopped working and gets hot.
  124. Teensy 3.5 with RGB Matrix Panel and Audio Shield
  125. UART with OC on Teensy 3.6
  126. FreqMeasurecapture.h porting to arduino 101
  127. offset with dac on teensy 3.6
  128. Any good way to profile code running with pio on a Teensy 3.2?
  129. Windows Installer Options?
  130. SSD1306,DIGISpark OLED not working with teensy 3.2
  131. How to use additional SPI ports on Teensy 3.5/3.6
  132. I want to use UART/USART with Teensy++ 2.0. But I'm beginner.
  133. some understanding problems with teensy 3.6
  134. (Newbie) Question regarding Interrupt dependency on USB comms (Teensy++2)
  135. Teensy 3.0 read out flash contents
  136. Why does COM Port change with different Teensy?
  137. VUSB Low voltage problem
  138. Teensy Snooze Timer reset after digitalpin detect
  139. How to wire ILTMS lightsaber?
  140. Linux Ubuntu 16.04 not create ttyACM* dev
  141. Teensy 3.6 Breakout Board SPI Design conflict Issue
  142. Probably really basic timing question... Teensy 3.2
  143. QueueArray library max queue size
  144. Arduino Ethernet Sheild (wiznet 5100) with Teenst 3.5
  145. Store time in variable using RTC module DS3231
  146. Debugging a Teensy 3.6 - Funny things happening with the built-in LED
  147. need help with large screen
  148. Config error when trying to use prop shield
  149. how to calculate the time of one ADS1259 in continious mode with a teensy3.2
  150. Couple questions about LED driver IC TL4242
  151. Problem with Teensy 3.6 and 7" TFT Touchscreen
  152. Compiler Error Arduino IDE Teensy 3.5 WIN7
  153. Assigning a float kills my program
  154. Teensy 3.2 refuses to run on external power
  155. Problems with Interrupt on digital pin 0,1 and 13
  156. WS2812 library in Arduino library manager?
  157. Port Open fails with T3.5, works with T3.2
  158. Teensy keyboard not working in WinPE
  159. send_receive one byte via SPI
  160. Flickering when using 74HCT245
  161. Teensy 3.2 doesn't seem to load program if USB cable isn't connected.
  162. Please help explain this code to an amateur
  163. SD.h isn't work on Teensy 3.5
  164. Question about Ethernet library and MAX_SOCKET_NUM
  165. LEDs flicker when switches are pressed
  166. Teensy 3.2 and Solid State Relay
  167. Programming multiple Teensys from same computer.
  168. I2C Restart with i2c_t3?
  169. library reference problems with Teensy 3.2 project
  170. Teensy 3.6 USB Audio : Listed as two audio devices on OS X.
  171. Teensy 3.6 PWM documentation?
  172. Teensy 3.2 custom schematic
  173. Device names
  174. 3.6 - Needing to press the program button to program the teensy :(
  175. Are there Teensy 3.2 and 64-bit compatibility issues?
  176. Setting the rtc DS1302 time with the time of the pc at the compilation
  177. Teensy LC MKL26Z64
  178. FTDI 231Xq and teensy 3.6 host question
  179. OctoWS2811 Timing Glitch
  180. wiz52io SPI speed and buffer increase compile error
  181. low memory, floating point - sprintf
  182. Info about AudioPlaySdRaw
  183. 1602 lcd with I2c board and Teensy 3.2
  184. teensy 2++ teensyduino USB interrupt latency
  185. Teensy++ 2.0 lock bootloader?
  186. Teensy Audio Tutorials
  187. teensy-3.2, mcp23017 with encoders & interrupt..
  188. ClearPath - Teknic servos
  189. Serial communication issue between Teensy and Raspberry Pi
  190. IntervalTimer causes I2C from Wire library to fail
  191. audio shield mic input
  192. Mux encoders?
  193. Weired torque senor reading
  194. New program won't be uploaded on T3.5
  195. Teensy Refuses to Program
  196. <PID_v1.h> myPID.Compute() function in IntervalTimer on Teensy 3.5
  197. Teensy 3.6 with HX8357 tft and ILI9341_t3 library
  198. two functions calls in the same intervalTimer
  199. Best way to do complex calculation ?
  200. Connecting grounds
  201. SPI chip that works find on a Uno but will not work with teensy 3.6
  202. Bluefruit SPI with audio board
  203. Can't upload arduino sketch on Odroid
  204. FastLED v3.1.8 not working in parallel with teensy 3.6
  205. [OctoWS2811 lib] dynamic strip length
  206. OLED-Problem
  207. malloc fails on Teensy LC
  208. Errors with any Teensy project in Visual Studio
  209. USBHost_t36 Midi InputFunctions example is not working for me... Hardware issue?
  210. Teensy 3.2 and OctoWS2811 movie2serial not working
  211. fast pow function
  212. Teensy Math Error Parsing NMEA data
  213. DAC latency
  214. Old version of Teensyduino (1.21)
  215. Teensy 3.6 - analogWriteFrequency on pin 16 and 17
  216. Custom board using MKL04 - yield problems
  217. Teensy 3.2 Buttons
  218. Trying to get the Color 320x240 TFT Touchscreen, ILI9341 to work
  219. using libraries for fast builds
  220. Debug suggestions for a .hex that isn't booting up?
  221. Teensy 3.2 ADC opamp buffering
  222. Too much breadboards?
  223. Support for ATmega128 by the TimerOne library
  224. Trouble using std::string
  225. Is there a reference for Teensy routines that aren't part of Arduino?
  226. LED on 13 with Teensy LC barely lights up at all with one of my switches but...
  227. AGND Assistance
  228. teensy 3.1
  229. Teensy 3.5 forgets the time of day
  230. Ultra Slow Teensy uC Clock Speed
  231. Lightsaber project, can I power it like this?
  232. pinMode latches ADC into low impedance state on Teensy 3.2
  233. stupid question about mounting potentiometers
  234. What's the best equipment for a big LED display?
  235. Teensy ADC fried?
  236. Teensy Audio Library Incomplete
  237. Help getting Canbus data from teensy 3.2 and SN65HVD230 transciever!
  238. Documentation for the Threading Library
  239. Have I fried my board?
  240. PWM value for 100% ON
  241. Linux and Teensyduino
  242. 3.3 Volts on Teensy 3.2 pin when calculating resistor for LED, right?
  243. How can I determine the version of Teensyduino I'm running?
  244. Serial.println() apparently doesn't print the first time thru loop().
  245. Modifying the Adafruit TCS34725 to use i2c_t3
  246. Hardware Dimming 2.8" color TFT from PJRC
  247. DAC output on Teensy 3.5 and 3.6
  248. Using Protocentral ADS1220 with Teensy
  249. Unsuccessful at writing to Adafruit TFT ST7735 with Teensy 3.2
  250. SPI Problem? - Sharing SD Card and TFT Display
