- Strange behaviour on potentiometers
- Analog Ground & How to protect Input pins T3.6
- Voltage Range and General Information for touchRead() Teensy 3.2
- Raspberry Pi connection with teensy audio board
- Teensyduino F() behavior
- Get NVIC IRQ # from Pin #
- Timer Interrupts on Teensy
- WS2812Serial question about pin usage
- PIT and DMA
- check ALL if the elements in an array meets a condition
- Teensy 3.6 suddenly half-dead ?
- Teensy 3.6 crystal accuracy?
- Compiling RawHid code in visual Studio?
- Multiple Slaves on SPI
- Teensy 3.6 and RTC date and time not ok when power lost.
- Teensy 3.2 PORTE and DDRE not recognized when setting i/o registers
- Teensy 3.6 - maybe dead after a few weeks of ignoring it
- Problem with AudioQueue on Teensy 3.5 and audio shield (SGTL5000)
- ADC Resolution for single PINs
- Watchdog timer and serial.print
- question on USB routing
- Encoder Library Turn Interrupt on and off
- DigitalWriteFast() to multiple pins simultaneously
- ARDUINO-TEENSY v4.4 by Burgessworld Custom Electronics
- Which transistor to use?
- Inconsistent time between measurements
- Serial (USB) transmission time inconsistency
- AudioEffectDigitalCombine does not name a type
- analogWrite only works on PWM slots (Teensy 2.0)
- Did I brick my Teensy 3.2?
- Serial splits string?
- Prop Shield on Maple Mini
- How to set up sample rate 250Hz in teensy 3.6
- OctoWS2811 with Jinx
- USBHost_t36 library: keyboard modifier keys
- setScrollArea() documentation help
- Teensy 3.2 + external battery = LED on. Umm...?
- Technical Question Regarding digitalWrite()
- Is this teensy3.2 ref schematic correct ?
- Teensy 3.5 with MIKROE-506 (WM8731)
- Strange analogReading struggle with fader
- UartEvent for Teensy 3.5
- T3.5 w/ Lidar Lite V3 - Nothing but Nacks!
- Teensy3.2 DIY but not working
- Is it possible to connect two Teensys via I2S?
- OctoSK6812 errors
- Teensy++2.0 Wiz811MJREV1.0 Teensyduino 1.40 vs 1.41 Arduino 1.85
- Teensy 3.5 sd logging HELP!
- LFO/VCO with Map & Constrain
- Debouncing IC inputs / outputs
- Teensy 3.2 PWM Frequency & Duty Cycle changes / shifts / varies / drifts / drops out
- Problem about Teensy 2.0 no inputs
- Teensy 3.5 - OWM outputs 5V
- Teensy 3.6 on own PCB
- Audio effect memory
- Two startSingleRead() in parallel in Teensy 3.6?
- Teensy Tutorials dont work on teensy 3.2 board
- Tale of my 1st Teensy 3.2 (questions which's answers helps the maidens)
- Teensy 3.2 / Adafruit ST7735 / spitftbitmap Example - Image is off the screen?
- Cv voltage from modular to control teensy oscillator
- SD I/O rate question (Teensy 3.6)
- Can someone give me a ideal?
- Teensy 3.6 - Dynamic CPU clock switching
- Problem Programming Blank MK20DX256 with MKL04
- Teensy 3.6 Underside Pins
- Can you help me with rerouting audio lib patch cords at runtime?
- Gaming keyboard with Teensy 2.0
- Preperatory Questions regarding FSEC / Security Configuration
- Teensy MIDI, iOS and the Camera Connection Kit
- Teensy 3.2 + Prop Shield only updates LED's when I touch the MOSI Pin?
- How to send SysEx MIDI messages?
- Reading multiple pins in single if statement (teensy 2.0)
- Teensy EEPROM location -- is it static regardless of program data?
- Xubuntu USB Serial Problems
- Teensy 3.2 code debugging question
- I am looking for some help with a very sensitive quadratic encoder wheel.
- Error compiling for board Teensy 3.6.
- Running Audio and Neopixels at the same time with Prop Sheild
- HW problem: Teensy 3.6 stopped working, gets hot
- Multiple tone() outputs
- 23LC1024 packaging
- interrupt question
- OctoWS2011 + Teensy3.5 Stop flicker
- Teensy 2.0 USB MIDI + MOUSE
- Is it possible to set the lower limit of the ADC?
- Error compiling for board Teensy 3.2 / 3.1.
- I can't use i2c_t3 in a sketch - Conflict with wire.h?
- Pin change interrupts with Teensy 3.6
- W25Q128FV SPI Memory Chip Discontinued, Should This 'Direct Replacement' Work Fine?
- Fritzing part for Audio Shield and Octo?
- Teensy 3.2 Joystick compatibility issues
- Erratic readings with ADC
- RTC only counts when I touch the device
- Audio issue with Teensy 3.2 and Teensy audio board as supplied by Sparkfun, WAV issue
- Need help for set up 2 psp sticks on teensy LC
- midi controller for ableton help writing code
- Teensy 3.6 Bricked? Any way to do a system reset?
- DMA-based SPI on T3.2
- Prop Shield Blown amplifier??
- hi everybody
- udev rules for multiple teensies
- radio module RFM23BP "need help to receive the messages"
- Is teensyduino serial monitor somehow special? Problems with other terminal programs.
- Teensy 3.2 hack project
- Descriptor error 43
- Ethernet library server.available() problem
- which is the best and affordable industrial uSD card?
- More info on compile errors?
- Teensy Audio Board -- possibly fried my SGTL5000?
- Teensy 3.2 complie error
- Noob question - teensy 3.5 Midicontroller
- Using Wire2 (SDA2/SCL2) to run a 4 Line X 20 display
- Teensy 3.6 code not running on 5 Volt external power
- ADC_ISR not turning back on after burst
- Want to output data on GPIO in parallel, what is the delay between each pin?
- Need for help
- Multiple Teensy 3.2 boards connected to one USB 2.0 port via a USB 2.0 Hub
- Teensy 3.2 for changing Bios Settings
- teensy 1st setup problem.
- I have a few questions
- C++ Structure Intializing Help
- Request for code review. pretty basic... i think
- What's wrong with overclocking?
- Arduino libraries for teensey 3.2
- Help me use the TPM/FTM on a Teensy LC
- New Teensy 3.2 won't connect to IDE
- Pozyx library issue
- Teensy with Encoders and MCP23017
- TyCommander can upload on MacOS but not Windows
- issue with Flexcan & FreqMeasureMulti
- Latency on piezo + teensy (drums)
- Teensy 3.2
- digitalRead oszillates: GND-problem?
- FreqMeasure and Teensy 3.5
- Using SD and Wiz850io with specific CS pins
- Simultaenous DAC and 2 channels of ADC
- Joystick HID with FFB (Feedback - vibration)
- Can't upload to previously working Teensy 3.6
- Some help for an unresponsive custom Teensy board
- Trouble with Serial between 2 Teensy's
- Custom Teensy 3.2 Board: Board Not Recognized by PC
- Availability of Teensy 3.5 in the future
- Teensy 3.6 getting hot
- Simple example, DMA with two ADC inputs
- Troubleshooting my fried Teensy 3.2
- A little bit OT: where to get information about DSP math?
- Multiple midi devices
- ADC adc_pdb xample does not compile
- Prop Shield Accelerometer Sensitivity
- ADC synchronized read calls, are they really synchronized?
- ADC adc_pdb example, pdb_isr() does not run
- Is there a pin-conflict between USB-host and Serial1 on Teensy-3.6?
- Can I use chips from this source to accomplish my task or do they need to be purchase
- Teensy 3.2 power rails and max mA output.
- teensy 3.2 with unresponsive usb jack
- Burnt my first OctoWS2811 adapter, What Went Wrong?
- How to speed up some operations (for pitch funcionality)
- SPI and RFDI Reader
- Teensy Compile Problem in function main
- Gameduino and FlexCAN library issue
- Teensy 3.2 + PropShield + WS2811 LED Issue
- Glitches in audio when writing to TFT
- Keypad Library with pulldown resisters?
- Short analog ground to ground
- I'm working with Teensy 3.2.
- How to control PWM phase?
- USB combination with Serial1
- TeensyLC examples>WS2812Serial>FastLED_Cylon won't compile for me.
- Needing two clicks to see one fire on encoder
- Uploading to teensy with platformio gives error teensy_reboot not found (Raspberry Pi
- Teensy upload problem
- Two-way rocker switch for both power and two inputs? (Doesn't work as expected)
- WS2812Serial Wont Work on Pins other than 1
- Upload .bin to Teensy 3.5/6 on my Linux Debian
- USB keyboard input in Teensy
- TFT Touch Screen not displaying
- Audio to MIDI
- T3.6 MIDI USB Host - querying "midi1.product"
- Verifying that Teensy 3.6 is actually dead
- Serial1 communication between Teensy 3.6 and Raspberry Pi 3B
- I2C - wire.h issue
- Fastest method to obtain digital data
- splitting strings and converting them to veriables
- Debug problems using VisualMicro
- Teensy boards "Seeing" COM Ports
- Output Teensy 3.6 16MHz xtal clock
- Multiple I2C communication, wire1 and wire2 files
- Largest SD card that will work?
- Program slower with 3.2 clock in overdrive than with non-overdrive clock
- undefined reference to `_sbrk'
- map() warning re arguments
- Editing Audio Library
- Encoder.h() Write() function
- Issue with PulsePosition and RC input
- Granular Code RAM Overflowed by X bytes.
- Convert MP3 to midi
- XPT2046_Touchscreen wont allow bitmaps to be read from the SD card
- Encoders and MIDI output - jittery alternating values
- Mouse.MoveTo() on second monitor
- 3.6 SD Card
- rosserial bluetooth teensy problem
- Encoder through 74HC4051
- MCP23017 Wire.requestFrom(mcp1_address, 1) argument list warning
- C/C++ IDE for Teensy-LC Without Pins PRODUCT ID: 2419?
- 3.6 board power clarification
- Temperature and Humidity (again)
- Associative Arrays
- MCP23017 using encoder
- Question about midi data smooth on Pots with Teensy 3.2 with Midi Elements Libery
- Driving 256 servos
- Random freezes when outputting data over USB
- converting String to const char *
- Teensy Printing Constant Data to Serial Print
- String-Comparsion sometimes works and sometimes not
- Passing file names to audio play memory play() function
- Programino IDE -- Teensy configuration
- Teensy 2.0 and a change in crystal frequency
- Reset and program pins
- CS on Teensy 3.2...more than 1?
- is it ok to wire it that way?
- Multiple Teensy LC Game Controllers at a time on Windows
- Strange Serial1 issue
- GLCD (JHD12864E) with Teensy 3.6.
- Teensy LC timers
- processor usage
- Mouse.MoveTo()
- timerthree duty cycle wont go past 50%
- Question about the pilot flame circuit (December 2017 article)
- Custom Teensy Board Help
- What is the electrical state of a GPIO in an unpowered Teensy ?
- TFT Touch Screen
- too low values from analogRead()
- Slow/ Fast blink LEDs no longer working, teensy will not upload properly.
- Problems Using Duff Snooze and Sleeping/Hibernating Teensy
- LSM9DS0_MS5637 Sketch by onehorse
- Inaccurate PWM Signal Frequency and Timing
- Lockups with FastLED & TeensyThreads
- Rotary Encoder and counter variable - Encoder.h library
- Newb needs some help
- Faked / Cloned Teensy 2.0++ Verification?
- Joystick using key matrix
- Will using one serial interface for sending and one for receiving make any difference
- Serial Problems
- Teensy 3.6 - changing Serial buffer size
- Problem in the board, custom Teensy 3.6
- New onewire compile error
- attachInterrupt line prevents sketch from uploading
- Bad serial RX data when writing to SD card
- Problems with compiling a sketch, need help
- conflicting declaration 'i2c_t3 Wire'
