- Wire.requestFrom(mcp1_address, 1) compiler warning
- hardware failure
- Changing I2C outputs on-the-fly
- Teensy 3.2 and Multiple SPI Interfaces
- MCP23017 not initializing in Setup
- Which Keyboard.press code should I use?
- teensy 3.5 interrupt using timer ovf
- Negative values on AnalogRead
- Teensy 3.6 SD Card IO
- SPI.transfer() send multiple bytes, array? (teensy 3.2)
- virtual sound driver
- Grounding issue with touchSense project
- Midi Controller using MIDIcontroller library (first project ever, plz help :) )
- i have a question, need help?
- Cannot light WS2812's and may need a simple pointer: Teensy 3.2 + Prop Shield
- Teensyview and using other SPI devices on the same bus
- Questions about Teensy from a beginner
- Pin to port mapping reference for Teensy 3.6?
- Current output of Teensy 3.5?
- Teensy 3.6 as a 16bit 1MSPS DAQ
- Program stops when it encounters FastLED.show()
- IDE with instruction time measuring (simulator mode)
- Use MKL26Z 32 VFT4 in place of the 64 for TeensyLC (until stock is back)
- Writing and reading large struct to and from SD card
- Has the debugging problem on teensy 3.6 been resolved?
- Using teensy 3.6 to sample at 1-us intervals within a for loop
- Where to buy ILI9341 Touch LCD
- ENC28J60 initializing and reading firmware version, but not receiving packets on T3.6
- TeensyTransfer: Communication error / Teensy 3.2 + Prop Shield
- Teensy 3.6 Direct Memory Access port B read problem
- Incorrect analog readings
- A21 A22 pins on Teensy 3.6
- what could cause this behaviour with 4051-muxes?
- Access to ADC0 differential pair on teensy 3.5
- Teensy 3.2 + Audio Adapter: Memory Spikes and Playback Stutters
- Teensy 3.2 - Conflict between FLEXCAN and FASTLED libraries ?
- Teensy midi problem...
- Pulse output on Teensy 3.6
- Teensy loader cli with rawhid device
- Howto use timer capture mode? Teensy 3.5
- After updating to Teensyduino 1.4.2 always this 'gettimeofday' message
- teensy 3.6 died
- Using "amp" from Audio.h
- Generical question about "audio_block_t" for new audio objects
- really noob question on usbMidi/MIDI and Serial Port
- Teensie 3.2 Max Temperature
- FreqMeasureMulti - Teensy 3.5 - Problems
- audio design tool
- Teensy 3.6 & 5vdc sharp sensor
- Volume change on SGTL5000 does only work on startup
- Teensy Specific #define and Their Use?
- Faders jump when I push through 50%
- Teensy 2.0 issue
- Teensy 3.6 Reset Pin
- Read PWM Signal GND-controlled
- Sizes
- Teensy 3.6 does not work. I used for 2 hours and it seems like I fried the board..?
- Tensy 3.X capable Updater for Mac
- Simultaneous MIDI and OSC over USB
- OCTO WS2811 Light Board - Problem with VideoSDcard.ino
- SPI with BMI160
- Teensy Drone Wav Player
- MKL02Z32 distance from MK66FX1MO on custom board
- VID and PID
- Serial Commnication not worknig?
- Teensy 3.5 start time and brief glitch using OctoWS2811 Adapter
- ODD/resolved: New Stereo - program T_3.6 not T_3.1
- exact value of adc reference voltage
- How should I care to havet latest libraries?
- Teensy Bringing Arduino to a Crawl
- How to diagnose input hang on Serial1 of Teensy 3.2
- programming languages
- sound quality difference between teensy audioboard line-output and headphone-output
- Problems with accessing internal registers
- Teensy Audio Library - Strange Pops/Clicks in Output
- Teensy 3.6: Sending blocks of data through USB
- is it possible to ... ?
- Teensy 3.5 -- program running, 3V3 voltage pins have zero voltage
- Interrupt timing
- Advice on low-profile headers to stack Teensy 3.2 + Prop Shield + TeensyView OLED
- Teensy 3.2 + ESP8266 + Zeroconf (mDNS, Bonjour)
- Can a 7805 kill a Teensy?
- Implementing SAE J2716 - SENT Protocol
- usbMIDI thru off
- disabling UART break detection in T3.x
- using an external reference clock - implications for bootloader and flashing ....
- NXP SensorFusion/NXPMotionSense using a MPU-9250
- Issues with connecting ILI9341 TFT Touchscreen to Teensy 3.6
- Cannot Initialize SD Card (Teensy 3.2 + SparkFun Level Shifting microSD Breakout)
- How to external power supply Teensy 3.6?
- hex Upload description (own uploader)
- 3 Teensy's with OctoWS2811 not working on Raspberry PI
- Assigned IRQ interrupt to digital pin
- frequency counting with teensy 3.6, randomly huge frequency values
- FFT Sample Rate Modification Help
- I2C communication on Teensy 3.2
- Ethernet Library v2.0 - how to get retrieve DhcpServerIP
- Systick ISR
- pretty mind blowing issue with accelstepper and teensy 3.5
- NXP Motion Sensing Library
- Strange problem with simple counter variable (and solution, but still confusing)
- Can not compile on Windows 10
- T_3.6 - SD-Card sometimes works, sometimes not
- analogWriteFrequency issue
- Problems with Teensy 3.6 on USB mode Serial/Keyboard/Mouse/Joystick
- Reverse reading of audio files (from flash memory chip)
- Send UDP to Teenny 3.5 from Max Msp
- Having Trouble Displaying Data from RoboPeak Lidar
- Does the Teensy Prop Shield use pin 10? Conflicting instructions...
- Keypad: Library can't use both 'src' and 'utility' folders error
- Teensy 3.6 Mac serial problem
- Getting Stuck on a simple LED Array Shift! What have I done???
- Power through Midi Out
- Undefined Compiler Errors - help can't figure out why
- Accessing timer registers Teensy 3
- Issue with USB MIDI failing over time when using usbMIDI.sendRealTime
- Two Teensy LC with I2C
- Ht16k33 to drive rgb led
- Issue w/ Teensyduino 1.42 install
- Gigabyte keyboard does not work on Teensy 3.6 host port
- OctoWS2811 with artnet support only 510 leds?
- teensy 3.5/6 ethernet
- Teensyduino installation without Administrative right
- Reprogram Teensy 3.6 with ESP8266
- Compile-time conditional for Teensy series
- lps22hb pressure sensor
- Teensy power feed issue - boot issue
- powering question
- Serial characters mysteriously missing
- Problems with 74HC4051 8-channel Multiplexer w/ Teensy 3.6
- cannot set Teensy RTC time
- Are 3D models available for Teensies?
- Switching noise related to sampling frequency
- Printf revisited?
- only 1 strip of 8 work
- SD.open(myString.c_str()) once worked but suddenly stopped working
- Audio Adaptor Board low power or shutdown, how?
- Which Controller for large LED project
- Triggering the DAC with the ADC COnversion COmplete (COCO) Flag
- IntervalTimer and Interrupts
- error sending reboot command to /dev/hidraw4
- LTO Compile Error
- USB Host Shield with Teensy 3.2
- Serial issues
- Help with Neopixel and Teensy 3.6
- Analog OP, A14
- OctoWS2811 error
- Difficulty in Reading a Push Button
- Some custom 3.2 boards not accepting code
- midiClock / BPM
- what do they do in this video?
- Teensy 3.6 Serial Communication Issue
- using fifo or simple fifo
- Teensy 2.0 not recognized by Teensy Loader on any system - Help
- new Teensy 3.6 user
- usb_serial_getchar()
- Accuracy, Consistency of micros() function
- working with platformiu
- Reading softpots with Arduino works but not with Teensy
- USBHost_t36 library keyboard "ALT" KeyDown
- Teensy 3.2 serial MIDI, losing SysEx bytes on input
- what's the most efficient way to sample continuously from 4 analog pins on teensy 3.6
- Read controls while sound is playing
- Basic coding question on Classes
- Dead Teensy LC?
- Using digital pins for external intterrupts
- OctoWS2811 Full Strand Flickering White?
- Teensy 3.2 TSI Interrupt
- T3.5 - testing results without using Serial.print on the spot
- Switching SPI modes
- 14-bit mark parity bit UART communication error
- Did I fry my Teensy?
- Ultrasonic Sensor HC-SR04, Teensy 3.6 and NewPing library ?
- Issues getting an SK6812 RGBW LED Stripe to work with Teensy 3.2
- Teensy 3.6 - Apparent Interrupt Delay
- What happens when you don't close a SD card file?
- Octows2811 Offset and hex translations
- Teensy 3.2 Reset button working, blink/serial monitor not working.
- Teensy 3.6 + Xbee Issue
- External speaker attached to line-out only works when headphones are plugged in
- OSC digital audio workstation controller (Reaper)
- Teensy 3.2 + RTC question. keep time when off?
- Encoeder Teensy 2.0++ on Pin 6
- use a for boucle to call several library functions
- Comms port dropping after uploading
- address for Port F on Teensy 2
- Custom Loader
- OctoWS2811 Adaptor - Changing pin order
- LiquidMenu library not working with teensy
- Can't turn off pull-up resistors on 3.2?
- Are Arduino mega compatible TFT LCD screen compatible with Teensy 3.6
- Raw HID/Non HID?
- Teensy board failure
- T_3.6 Strange conflict between sd card reader and uarts.
- VL6180x sensor and i2c scanner
- Powering teensy LC
- t3.2 & Octows2811 over heating
- Horizontal scroll with Arduino Mouse library, Teensy LC, and Linux?
- [ADSP-SC584 via ICE-1000 ] problem of loading .ldr file to W25Q128JV flash
- Teensy 3.5 problem with incromenting a number
- Tinn Neural Network
- Problems w/ Tone.h and MusicWithoutDelay.h Compiling
- Serial connection working after reprogramming, but not after restart
- Modify analogWriteFrequency function
- Print out library files in C to the arduino serial monitor
- Is my MK20DX256 fried?
- Question about an example from the "Using USB Serial Communication" help page
- Adafruit Alphanumeric Display - Phantom powering
- Simultaneous RFID Reader Serial Communication to Teensy 3.2
- Rdm
- How to set up a structured control system over serial port?
- FFT analysis of AC motor
- Opto-isolator with MCP-23017
- Where can we download previous versions of Teensyduino? ie 1.23
- 31.25 kHz clock source for analogWriteFrequency
- Cooking a Teensy 2.0
- Best serial practice
- Custom Teensy Write Once Memory "Burn" Direction needed
- Teensy 3.6 custom, Problem Board implementation
- Help connecting OLED displays
- Reference for using SD Card on Teensy 3.5
- connecting nrf8001 adafruit ble to teensylc
- Teensyduino not finding Arduino
- For a pin, what does "not 5V tolerant" really mean?
- Teensy 3.5 - MIDI only works when USB plugged in
- Audio Board Eagle Board Schematic & Board Layout
- Teensy 3.6 on custom PCB does not always run program when not powered from USB
- Teensy 2.0 no longer works on most computers
- Teensy 3.2 Serial Port Error From One Line of Code?
- TeensyLC + Propshield motion (data keeps changing)
- Support for higher sample-rate ADCs and DACs
- Teensy 3.6 Speed of analogRead
- Audio project not running unless I upload the code everytime
- fft ifft ?
- openGLCD DrawString refuses to print variable
- SVD files?
- How do I write sketch code to display UART Register contents on the debug console?
- Serial communication problem: Magic numbers?
- Bluetooth HM-13 Teensy 3.6 and AT-Mode
- Why is there a 1.8V regulator on the Audio Shield?
- Teensy 3.2 not running sketches when connected to Vin only
- Secondary serial port
- High frequency square wave output
- Hey guys, any ideas about a whole LED strip not lighting up? OCTOWS2811
- Teensy 3.2 Update program - where to begin?
- anything like PulsePosition input but 2-channel relative timing?
- Teensy 3.2 Compatibility with Unity3D
- Teensy USB to midi + expression pedal
- Glediator/Jinx! SD file restart/loop question
