View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Problem with getting two Teensys 3.6 recognized as USB MIDI Controllers
  2. FreqMeasureMulti and pinMode
  3. Teensy 3.2 Breakout Board with CAN transceiver Design Question
  4. Possible mismatch in Fcn params - teensy/td_midi.html vs sample code
  5. Question about mutex in rawhhid_recv
  6. Latest Windows 10 update issue
  7. Encoder Help
  8. Unable to Assign Teensy 3.2 to ttyACM* port on Linux
  9. Reset due to (motor-) EMI?
  10. Encoder Library : Error compiling for board Arduino/Genuino Mega or Mega 2560
  11. did I brick my teensy3? usb connects, then disconnects almost right away
  12. Teensy prop shield amp. Need troubleshooting assistance
  13. Teensy 3+ Port Pin Register Help (New User)
  14. MPU-9250 SPI in BASIC
  15. Improving Character LCD Refresh Rate
  16. Multi-master I2C using Teensy3.2 + ATtiny85
  17. Audio and ESC don't work together
  18. MIDI IN on Teensy?
  19. not sure how to use DAC ( not PWM ) T3.6
  20. Teensy 3.2 and PFC8523
  21. Lockup after WIZ820io to WIZ850io
  22. Fastled issue on Teensy 3.6
  23. Teensy 3.2 with Grove Infrared Temp Sensor
  24. Custom Teensy 3.2 with empty processor works?
  25. A question about master timing of the audio connection matrix
  26. How to uninstall teensyduino on Linux arm on Raspberry Pi3
  27. Program pin on Teensy 3.5 need pullup resistor ?
  28. I2C Clock rate question on Teensy 3.5 and 3.6
  29. Power over ethernet (PoE) for Teensy?
  30. DMAchannel.h won't compile in newer version of Arduino
  31. Teensy 3.2: USB HID simple example updates?
  32. Teensy 3.6 Need to support a mems mic on i2cInput
  33. Noob questions; (X) vs. (y) for optimizing speed/efficiency of program.
  34. my circuit acts mad
  35. Teensy 3.6 I2S Slave Mode Question
  36. Method of 'polling' audio objects?
  37. missing pin-highs
  38. Two seperate programs in a Teensy 3.6
  39. Teensy 3.5 I2C issues
  40. PWM tone heard on ground plane of connected audio device
  41. ISP, FOR Teensy
  42. Using Teensy 3.2 on I2c Wire1 (pins 29/30) with SSD1306 Library
  43. Push to release and lock SD card
  44. ST7789 support for Adafruit 1.54" 240x240 Wide Angle TFT LCD Display with MicroSD
  45. Consumer Status LEDs via USB
  46. Digital Pin State being always high after powerup
  47. other way to access teensy timers?
  48. Noise and grounding issues with piezo analog input with Teensy 3.2
  49. Getting started with Teensy 3.6 USB Host
  50. Read signals
  51. Teensy 3.2 UART0 Receive Lockup after first Write in RS485 circuit
  52. Teensy 3.6 rtc question
  53. double type?
  54. Trying to us C++ list's but getting errors
  55. tft glitches
  56. Problem installing teensyduino on Ubuntu 18.04.1 LTS
  57. Teensy 3.5 UART IRQ_PRIORITY
  58. LCD 4.3inch touch SSD1963 and Arduino Uno
  59. Problems with a stepper motor and Teensy 3.2
  60. Teensy 3.2 + Audio Board. Problem reading from SD card
  61. Help Needed: Trying to convert from Processing Script (JAVA) to C++
  62. Upload sketch mac vs windows
  63. Help needed with third par applications
  64. FTM timer problems
  65. Windows GET_DESCRIPTOR won't accept > 255 bytes?
  66. Teensy 3.2 custom board advices
  67. Fastest way to calculate I2S FRACT & DIVIDE values?
  68. Send Data From PC to Teensy 2.0 HID Keyboard
  69. Teensy 2.0 and 3.2 responding differently to Python serial communication
  70. [Help] Read magnetic encoder
  71. Serial Monitor start and then freeze on "Hello_world" program
  72. Teensy 3.2 ADC channel number and ideal input impedance
  73. Teensy 3.5/3.6 TeensySdioDemo Failed Error
  74. Output_pwm (Audio Library) technical question
  75. FrequencyTimer2 reset counter value
  76. Problem using ADC library
  77. Trouble getting "playFlashRaw" to work on 3.2 and Prop Shield
  78. analog input for T3.6
  79. OCTOWS2811 and WIZ820IO/SD CARD USE
  80. USB Port Connection
  81. Compiler Library Resolution
  82. Multiple compares on one intervaltimer?
  83. using arduino-builder -prefs="compiler.cpp.extra_flags=-DMY_FLAG=1"
  84. WS2811 LEDs don’t work with 5V power supply
  85. Serial Problem
  86. Weird Driver/Port Problem
  87. Teensy LC dead after blink upload.
  88. Sending 0xd byte, but receving 0xa
  89. Unclear on how to use DDRx and PORTx (teensy 3.2)
  90. Cannot compile empty teensy35 project using arduino-builder
  91. Arrangement issue
  92. Problems compiling
  93. Troubleshooting Audio Adapter
  94. Basic question about analog read voltage
  95. MIDI with SoftSerial on Teensy++ 2.0
  96. Teensy 3.1 - How to connect an SPI 2.42" OLED display 128x64 - SSD1309 from DIY more
  97. Scorching hot Propshield
  98. attachInterrupt CHANGE - how to check if the change was a HIGH or LOW
  99. W850io endPacket() failure
  100. Seemingly bricked Teensy-LC with Rust
  101. USB host always at 500 hz ?
  102. im having trouble with analog input
  103. GND vs AGND Different question
  104. Multiple Teensy not recognized anymore
  105. RF noise causing spurious interrupts
  106. USB Descriptor String Descriptor Issue
  107. Issues with serial initialisation with teensy 3.6
  108. Not able to read CANbus data with Teensy 3.2 uController using the Flexcan library
  109. Mac can't handle amount of serial data that windows can
  110. Teensy 3.6: how to port "Arducam Mini Module 2mp" to Teensy?
  111. Weird digitalWrite issue
  112. Teensy 3.6 @ 24 MHz: can Serial3 (no FIFO) keep up at 57600?
  113. Teensy 3.1 - Which MOSFET instead of Relais ?
  114. Teensy 3.1 - analogRead 0.1 uF capacitor but what kind?
  115. Can't write to P-Flash?
  116. Sequential control packets without ZLP between?
  117. "Normal" values for AudioFilterStateVariable
  118. Teensy 2 ++
  119. Wiz850IO + 3.6, Ethernet Adapter Not Recognized
  120. Teensy 3.2 Setting Output Pin to High Impedance (or blank)
  121. Translate code from Teensy LC to Teensy 3.2?
  122. global questions on potentiometers
  123. What conditions must be met for the teensy loader to work?
  124. Setup as 16 bits but I2S is giving me 24 bits.
  125. Teensy 3.5: could withstand 6.4V Vin?
  126. TEENSY 3.5 use in a project?
  127. Microcontroller ATmega644P (RX and TX)
  128. any potential errors when powering teensy without computer?
  129. Grab compiled binary from Teensy 3.6
  130. 9x Analog inputs on Teensy 3.6
  131. How to get Teensy 3.2 to trigger a 'ground' without a transistor
  132. Unplug before launch !
  133. Teensy 3.5 - WS2812b
  134. Teensy 3.6 256MHz
  135. Embarrassing Keypad Library/Code Question
  136. Teensy 3.5 Serial Woes
  137. Gaussian Distributed Random Numbers
  138. Extended Pin Numbering
  139. Teensy works for some time then stops
  140. Uploading sketch, what happens to pins
  141. 3.3 Voltage
  142. New Teensy 3.2 Won't Show Up as COM Port
  143. USB Serial
  144. Are there any plans/schedule to update GCC toolchain?
  145. LIN bus
  146. Neopixels all flash on until loop() starts
  147. Trouble incrementing an array... attempting to make tapped patterns.
  148. Did I just fry my teensy 3.6?
  149. Accidentally flashed Teensy LC with Teensy 2.0 hex
  150. Macro keys with blink
  151. Teensy 3.2 Ethernet WIZ820io problem
  152. PropShield LC + Teensy LC + WS2812b -- Only works while touching the MOSI pin
  153. Teensy 3.2 Serail Ports
  154. Teensy 3.6 ~1MHz sampling & DMA to extract data?
  155. Possible open pin onTeensy 3.6
  156. Teensy 3.5 No power on Vin pins when plugged into USB... But works
  157. DIY Step down Buck converter for PCB 9V to 3V adjustable
  158. wiznet w5500 Receive all Multicast traffic?
  159. T32 and MeanWell LDD and Darlington circuit: grounding questions
  160. Incoming MIDI messages are shorted to output
  161. [?] New Haven 128128ASC3 wiring and SPI library
  162. TEENSY 3.5 SPI Bus SPEED?
  163. Fragmented UDP datagrams
  164. Decode 10MhZ serial input
  165. Teensy 3.2 serial input
  166. Program hangs depending on code length
  167. non blocking tasks
  168. Piezo resistive fabric with INPUT_PULLUP and analogRead.
  169. Cant access AMA0 serial ports - linux/Raspberry pi
  170. teenzy xBee Adapter
  171. teensy 3.2 touchRead() range ?
  172. changing I2C address on Sparkfun 7 segment display, COM-11441
  173. Teensy shield for pololu style drivers
  174. Dual ILI9341_t3 management
  175. Having trouble multiplying out my code for MIDI controlled LED lights
  176. Encoder library velocity sense and debounce
  177. Teensy 3.5: using 2 SHT31 sensors simultaneously
  178. USB to XT keyboard using USB Host Shield and Teensy
  179. Compile Problem with ALL ino-files: In constructor constexpr Stream::Stream()
  180. Teensy 3.6: using analogWrite() on second DAC while other is triggered by DMA
  181. Burned out Teensy 3.6?
  182. MTP Troubles
  183. Teensy boot problem
  184. Custom Teensy LC Bootloader not programming MCU
  185. Generating Core Library for Single Board
  186. Error while setting serial port parameters: 115,200 N 8 1
  187. PlatformIO reboot issue when multiple boards connected using teensy-cli.
  188. Reading UART registers causes my program to hang - why?
  189. MCUExpresso with Debugger Configuration?
  190. Help with delayMicroseconds() and UART init, inside an IRQ_UART0_STATUS function
  191. Loopback PWM
  192. I²C on Teensy++ 2.0
  193. SPI DAC for Audio Library
  194. I2C Oled display and Audio Adaptor with Teensy 3.6
  195. Teensy 3.2 + QRE1113 interrupts
  196. Multiple Teensy Architecture Questions
  197. Teensy LC + IR receiver
  198. Teensy 3.6, AREF, 470Ohm and VREFH
  199. Problem to program a custom board (MK66FN2M0)
  200. Tech Specs: Bandwidth?
  201. Question about IntervalTimer::beginCycles and "ISR safety"
  202. help with keypad
  203. Teensy 3.6 and display board
  204. Teensy 3.2 NVIC_ENABLE_IRQ not setting transmit interrupts
  205. ILI9341_t font structure format
  206. flashing several teensy 3.5 - something not updating?
  207. Teensys Intermittently Stop Responding?
  208. W5200 UDP not working??? Teensy 3.2
  209. Midi Footswitches not working
  210. Problem recognizing some MIDI devices on Teensy 3.6 with USBHost_t36
  211. Teensy LC
  212. Changing analogWriteFrequency Breaks nrf24l01+ Wireless
  213. Teensy 3.2 VUSB trace, where to cut?
  214. DMA - Masked writes?
  215. Teensy 3.6: speed of DigitalReadFast?
  216. Miniaturization MKL02/04 Out of the PCB
  217. SoftwareSerial broken for Teensy LC
  218. I ran out of dynamic memory. I've free'd up enough but how can I know.
  219. Teensy 3.6 best approach for external SD card full size?
  220. VID and PID of an FTDI that is connected to a Teensy 3.6 via USB
  221. Serial.printf Bug ?
  222. USB serial data loss
  223. counting pulses problems
  224. Issue Ramping PWM signal for blower
  225. Teensy 3.2 randomly stops when working with NeoPixel to much?!
  226. Dimensions for Teensy 3.5?
  227. Teensy 3.1 analog out to inverting opamp pin
  228. Seeking ideas on using state in callbacks
  229. "SPI Repeater" for long APA102 strands?
  230. Teensy 3.6 not starting on power-on, only when serial monitor is connected
  231. 74hct245 - W2812B
  232. after upgrading to Arduino IDE 1.8.7 and Teensy loader 1.44 no teensy boards detected
  233. Silly question time: push button
  234. Teensy 3.5 Hardware Serial
  235. Capacitive touch position sensing?
  236. ILI9341_t3 swap() conflict
  237. Files files files.. SD card questions.
  238. Interesting: Writing to UART_C2 before serial-init locks up
  239. Modulating frequency with an envelope?
  240. Freeze after 4 to 6 weeks.
  241. Compile error for SDI-12
  242. seeed OLED library
  243. Bootloader not recognised in virtual Ubuntu
  244. DAC Noise on Teensy 3.6
  245. USB connecter dettached from my Teensy 3.2
  246. Teensy 3.5 i2c 5V
  247. Compile Error Trying to Use getopt()
  248. Teensy 3.2 Showing up as Keyboard/Mouse/Joystick
  249. Teensy 3.2 Snooze sleep_all_wakeups problems?
  250. Debugging with the serial port, issues..
