View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. what voltage for a teensy 2.0
  2. Is size of int type correct?
  3. how to use i2c_t3 and u8g2
  4. Teensy 3-6 DACS issue
  5. Is Pin 15/CS0/Touch an Irregular Analog Pin?
  6. Question about manipulating bits
  7. Teensy 3.1 usbMIDI not working with Akai MAX49 keyboard
  8. OpenBCI enslaving Teensy 3.6 for signal processing ?
  9. Teensy 3.2 Joystick and serial interface compatibility
  10. 3.6 D+ and D- pins
  11. asking for kind help and support
  12. Adafruit SSD1306 multiple instances issue?
  13. Teensy 3.5 USB issue
  14. Teensy 3.2 + Piezo Sensors + WIZ850io Ethernet = A Bad Time?
  15. ADC readSynchronizedContinuous additional channel
  16. function return code is limited to one byte?
  17. T3.2 Serial + Audio, [no_device] issue
  18. AnalogRead floating problem
  19. Teensy 3.6 prop shield major yaw drift
  20. TeensyStep issue - Driver not working
  21. Teensy 3.6 SPI library - garbled output on SparkFun LCDs
  22. Voltage reference for Teensy 3.2
  23. Teensy LC Half Alive
  24. ST7735_t3 and Adafruit 0.96" 160x80 Color TFT Display?
  25. TeensyStep - How to switch from 1 speed to another
  26. Inconsistent serial between Teensy 3.2 and PySerial
  27. Teensy 3.2: Drops/corruptions while receiving data via usb_serial under load
  28. DMA & DAC ring buffer examples
  29. Teensy 3.1 - SPI - Multiple SPI Devices - OLED SSD1306 + NRF24L01 Transceiver
  30. Use Teensy3.2+TB6612 driver board to control dc motor with encoder on ROS
  31. Teensy 3.5 no port
  32. Teensy Bootloader with MK64FX512VLQ12
  33. Rotary Encoder to USB Joystick
  34. Teensy 3.2 and laser rangefinder -- problem with interrupt
  35. When to cut the 3.3V to 5V connection?
  36. Error compiling/Multiple libraries for SD.h Issues
  37. Audio recording 6 Bluetooth streaming
  38. Wire.setSDA() and Wire.setSCL() and/or i2c_t3.h
  39. Compile error with Arduino 1.8.8 release
  40. Running on 5V Power..
  41. ULN2803A Darlington Array and maybe a TIP120 to switch/control PC case fans
  42. Incrementing int produces bizarre behavior
  43. Sample Based Synth Using SD card and Polyphony??
  44. Step up 3v3 to 5v to runws2812 leds using ws2812serial library on teensy 3.6
  45. Need Faster Interrupt Handling!! >>>
  46. Teensy 3.6 to Arduino MEGA Adapter Board
  47. Why the delay in touchRead()?
  48. Teensy 3.2 running out of RAM?
  49. Cannot program teensy 3.6
  50. Teensyduino ide installation issue
  51. MPU 6050 + TF mini Lidar problem
  52. Interrupt on Serial (USB) receive
  53. DC offset on ADC readings on Teensy 3.2
  54. Using FreqCount and FreqMeasure together in one Arduino program
  55. Teensy 1.0 (sob story :))
  56. My Teensy caught fire
  57. Specification issues (I²S)
  58. Cannot communicate with teensy 3.6
  59. making a measure class
  60. Self-print code for documentation ?
  61. Two Joystick HIDs at the Same Time (Teensy ++ 2.0)
  62. Questions about Interrupts and loop()
  63. touchRead and Snooze library
  64. Potentiometer Q. Teensy 3.2 and existing electronics
  65. Uploading encrypted firmware support
  66. Fast Data Logging over USB
  67. Problem converting Adafruit IMU Library to use i2c_t3
  68. Socket for Teensy Bootloader
  69. Port FreqCount library to SAMD21 architectures
  70. hooking audio board and teensy 3.5
  71. Teensy DMX / RDM
  72. Teensy 3.2 Holds I2C Bus Low
  73. Teensy 3.2 ADC Input Range?
  74. USBHost_t36 Mouse.ino example "baud rate" question
  75. About Teensy 3.2 and 1.44" TFT display
  76. Teensy LC/3.2 Transmit Enable and drawing sheet
  77. st7735 multiple displays and chip select
  78. Teensy 3.2 with OctoWS2811 adapter long distance help
  79. RTC Not running while sleeping
  80. Query Teensy 3.6 CRC on transmitted USB data
  81. PJRC ( and SparkFun ) show T_3.5 with 192 KB RAM
  82. Disconnect Pin in Software
  83. Connecting Teensy 3.3V out to Analog Reference?
  84. Noise but no Movement with 3+ Steppers & TeensyStep
  85. I2C Serial Communication between two Teensy 3.2
  86. Storing & Reading Large Arrays on Micro SD Card?
  87. Slow upload speed?
  88. Could Teensy 2.0 board overheat?
  89. Useful Up-to-Date Tutorials for Beginners...do they exist?
  90. midi transport messages with Teensy LC
  91. Board at usb:10003/0/0/8/4 is not available
  92. Teensy 3.2 Pinball Controller not detected in Android
  93. Teensey LC wont compile PinSim
  94. Encoder library using pins 2 and 4
  95. Want to overcock the SPI bus with 120Mhz CPU speed.
  96. Teensyduino Install Problem
  97. Clarifying Crystal Design Guidelines
  98. Teensy 3.2, can A14 be used as a digital input?
  99. Teensy 3.5 and multiple AS5048A Rotary Encoders wont work
  100. a little FreqCount bug and two questions
  101. Teensy 3.6 CMT primary prescaler and FrequencyTimer2 library
  102. Setting pinMode using GPIO on Teensy 3.6?
  103. About 1.54" TFT 240x240 pixel with ST7789 and 22 pin connector
  104. Problem using alternative i2c lines with accelerometer
  105. i2c_t3.h and audio.h
  106. marlin 2.0 teensy hal with i2c gpio expander
  107. I call it "where's the FAQ"
  108. USB Host Shield 2.0 Mini on Teensy 3.1 gives OSC did not start
  109. Timer problem
  110. Serial link problem
  111. Teensy LC Game Controller Works In Windows, Not In Games
  112. Teensy3.2 ADC Pin Assignement
  113. ADS115 multiplexing not recording correct pins.
  114. Switch component for Jumper Pins
  115. Issue with Teensy USB features - handing USB communication when reading data
  116. Teensyduino Install - Has it Worked?
  117. I2C_T3.h library starting up High speed mode
  118. Circuitry ok to measure my PSU's voltage using the integrated Teensy 3.5 ADC?
  119. Digital Input - BAT54S
  120. Inreasing USB-Serial-Buffer Teensy 3.2
  121. Teensy 3.6 pins 24 and above
  122. i2c_t3 basic example returns FAIL
  123. Running first sketch with Teensy 3.2
  124. Cannot reprogram after waking from Snooze.hibernate or Snooze.deepSleep
  125. Teensy 3.6 + wiz820io NTP example problem
  126. Defining Encoder() pins at runtime
  127. Teensy and ArtNet Multicast Issue
  128. Timing for running two DMA channels sequentially
  129. Faceplanting When Using the Hardware Serial Ports - Teensy 3.2
  130. Question regarding Serial.end() - teensyduino
  131. Audio and ILI9341_t3 library conflict
  132. Maximum transfer rate between computer and teensy 3.6
  133. Correction values for HSB colour wheel to spend same time on each colour
  134. Adafruit_VS1053_Library
  135. TEENSY LC Failing to Compile- "False" File Location Error
  136. Using SD List Files Code
  137. Teensy 3.2 DAC output voltage issues
  138. "Found Teensy Loader version 1.40, but the minimum required is 1.42."
  139. weird behaviour with the LiPo battery charger add-on
  140. Teensy Command Line Loader Help - Willing to Pay
  141. Using Bitwise and in If statements...
  142. Teensy 3.5 pulls down I2C lines when off
  143. Encapsulating USB host midi in a class
  144. Is there a way to send a signal to "All" MIDI notes?
  145. How to access usbMIDI.PitchBend as a variable for a Function
  146. Dimensioned drawing for Teensy 3.6
  147. "ADC1 error: Wrong pin error." using both ADCs (T3.6) in continuous differential mode
  148. Noob question about bit and byte
  149. Using an Object for Interrupt (and other) Call Backs
  150. errors compiling since wave example.
  151. Reboot out of control in hardfault handler
  152. Adding leds into my code (not changing the keyboard part) makes keyboard undeclared?
  153. Daisy chain USB hub
  154. Multi 5-direction switch-based joystick with 1 Teensy, Possible?
  155. ILI9341 TFT LCD Tutorial
  156. Sketch doesn't work on Teensy but works on Arduino
  157. teensy3.6 Can't load blink -- teensyduino 1.42 arduino 1.8.8 archlinux latest
  158. installed teensy, arduino IDE now gets java errors
  159. MIDI serial (DIN) to usbMIDI issues: got weird MIDI messages
  160. High noise spikes when connecting Teensy 3.2
  161. Interactive settings from windows gui to arduino/teensy.
  162. RA8875 not found !
  163. Pushbutton Not Working?
  164. Octows2811 For Dummies - Understanding PWM / DMA driven waveforms
  165. Teensy 2.0 and DRV8835 motor controller board
  166. Scheduling Installation / Boot-up Sequence for 10x Steppers in Storefront
  167. Teensy 3.6 EEPROM issue
  168. I2C Examples not working on Teensy 3.6
  169. Teensy Loader faulty CPU utilization
  170. rotary encoder does not decrement
  171. hid_listen waiting for device on Windows 10
  172. Help with setting a bit-band-aliased bit on Teensy 3.5
  173. USB + External Power on 3.2
  174. Watchdog on Teensy LC
  175. Teensy 2.0 Serial Reset Behavior?
  176. Teensy 3.2 + Audio Adaptor crashes with loud buzz
  177. Teensy 3.6 - FlexCAN - Listen and respond
  178. Measure short pulses with Teensy 3.2
  179. LiquidCrystal library with Teensy 3.6?
  180. digitalFastWrite not working on Teensy 3.2
  181. Teensy LC - Trigger DMA with timer
  182. 1602A LCD display brightness
  183. Accuracy of Teensy 3.5
  184. Can I power a second Teensy LC from another Teensy LC that powers 30 LEDs?
  185. Setting elapsedmillis within interrupt?
  186. Direct port manipulation on Teensy 3.6
  187. i2c_t3 - requestFrom unexpected behaviour
  188. Get X/Y Axis with custom gamepad and Teensy 3.2
  189. trouble reading Analog pins A14 and above
  190. Find Teensy USB Vendor and Product ID
  191. Issues with Arduino connecting to Teensy Loader
  192. LInux install problems
  193. Dual CANbus 3.6 send to CAN1
  194. Teensy + Adafruit FONA Problem - timedRead() is private in Stream.h
  195. teensy_ports documentation or source
  196. E1.31 sACN Ethernet DMX - MegaPixel One W5500 TX socket problems
  197. Write File from pc to flash
  198. TEENSY 3.6 / ADAFRUIT 3.5" TFT touch controller issue
  199. Teensy 3.5 adding snooze function to my existing project doesn't compile
  200. Increasing Joystick resolution
  201. Color 320x240 TFT Touchscreen, for the Audio Tutorial
  202. Teensy LC USB Keyboard custom layout
  203. Reading a usb graphics tablet with teensy 3.6
  204. USB Track Width / Parallelism
  205. FastLED, WS2812b and UART Interrupts
  206. Reset pin or not? Wiz820io
  207. Compile error
  208. Teensy 3.6 Modbus TCP
  209. motorized fader controller teensy 3.6 issue
  210. Teensy 3.6 - USB MIDI INPUT - Random CRASHS
  211. WS2812B Flickering with WS2812Serial Library
  212. APA102 Temporal Dithering without Master Brightness?
  213. Teensy 3.5 - Simultaneous Pitch Detection and Stepper Motor Control
  214. Teensy 2.0 B2 pin misfiring on a computer restart
  215. trouble trying to write to, and read from, eeprom to store strings from serial
  216. Detect low voltage (VIN) and save data to eeprom
  217. Problems with 3 or more Teensys on USB-Hub
  218. Problem with multiple slave SPI
  219. UART/Serial Flow Control Documentation
  220. Using i2c_t3 DMA mode to read data from MPU9250 with interruption failed
  221. running AUDIO LIBRARY problem using EXTERNAL POWER
  222. Teensy as USB Audio I2S interface for DAC implementation
  223. Forgot to cut VIN <--> VUSB on a Teensy 3.5/3.6
  224. expected initializer before...
  225. Possible WS2812 Library conflict with USBMidi?
  226. code help - random list between bounds.
  227. Is there a library for the BD663474 SPI TFT driver chip
  228. Teensy 3.2 won't send MIDI over USB
  229. Teensy 2.0++ keyboard sleep and wake PC
  230. Chorus/Flanger
  231. Hardware reset / restart on Teensy RC
  232. Teensy 3.6 get's hot and does not work anymore
  233. Conflict between Lib i2c_t3 and Adafruit_GFX.g / Adafruit_SSD1306.h
  234. Can teensy 3.5 board take 5V analog input?
  235. Teensy 3.2 - I2C and PWM issues with Lidar Lite V3
  236. Syntax Question
  237. shiftPWM - Alternate MOSI / SCK pins
  238. Servo.h + Altserial Doesnt work together
  239. object reference (I'm probably doing it wrong)
  240. Receiving double digit numbers from Pure Data to Arduino over OSC
  241. CopyFromSerial: rawfile-uploader.py not transfer correctly files
  242. Performance of unaligned reads from program memory
  243. Teesnsyduino 1.45 vs SD library
  244. Problems with CMP and PITimers
  245. still struggling with c++ syntax :)
  246. Question Timer3 use it as a countdown
  247. Teensyduino 3.5 sending correct keys to computer, but incorrect keys to VM
  248. Low power uses too much power...
  249. Teensy 3.6 SdFat access file creation date and time
  250. "is implicitly deleted because the default definition would be ill-formed:"
