- Teensy 3.6 UDP broadcast
- How to use long file names on Teensy/Arduino SD Card Reader
- Teensy 3.2 power supply issue
- Small bug in EthernetClient write
- too low values from analogRead II
- Servo with audio shield attached
- Teensy 3.2 RTC Battery from Vin?
- Unstable analog values from multiplexing
- I2C_t3 library, changing frequency
- Teensy 3.2, a button, and 2 WS2812 strips on separate pins.
- seeking code tutor. $$.
- Problem with Snooze library - USB Program mode
- Potentiometer Stablization algo, any/all feedback welcome
- External Crystal on Teensy LC with MCUXpresso IDE
- Float/hi-z A21 and A22 input after analogWrite on T3.6
- Beginner w/ simple questions for connecting Octows2811 to WS2812B Strip
- Buttons, Switch, and TS inputs not working with Teensy 3.6
- Teensy 2.0 i2c communication with QMK
- MIDI SendSysEx on USB host
- Teensy LC SD Card SCK mapping broken
- Teensy 3.6 - FlexCAN - Listen and respond
- USB not recognizing Teensy 3.5
- Teensy LC printf float options
- Teensy 3.2 - Wrong (?) readings from mcp23017/i2c
- Unable to upload a sketch on teensy 3.5
- Cannot install teensyduino on Ubuntu since unable to find my Arduino /lib/version.txt
- Teensy 3.2 Connections to the underside?
- TRS Input, Teensy 3.6, Yamaha FC7 expression pedal
- USB Host MIDI controller name
- Teensy 3.2 -- Corrupted serial port values when run above 48MHz?
- Using a 4x4 touch sensor keyboard [TTP229-BSF] as an I2C module with Teensy 3.6
- Detecting about-to-be-programmed
- need help understanding pointers and returning an array of bytes
- Using Teensy USB audio input object
- Possible connection issue between MKL02 and MKL26 on Teensy LC
- send int-var with Serial1.write()
- Teensy 3.2 - latch-up when not connected to USB
- Teensy 3.2/LC and FastLED unexpected behaviour
- Teensy Audio USB type
- Maximum capacitance on 3.3V rail / maximum rise time for Teensy 3.2
- SD-Card not working on Teensy 3.5 with LiPo Battery
- long file names and play audio from SD card
- Unexpectedy behavior due to optimization?
- Teensy 3.6 + OctoWS2811 - Unable to power on system with RJ44 connected
- Keypad library more than 10 rows
- Problem displaying RFM95 data (Teensy 3.2)
- Using registers with Teensy 36
- Inner working of filter_biquad
- Teensy 3.2 difficulty uploading using Teensyduino
- Can't get Teensy 3.2 to work reliably as a midi cc controller.
- [Pixel mapping] 16 DMA, how to use them ?
- Teensy3.2 + ILI9341 display not working
- Use Mosfet as switch and control it by teensy
- Serial Monitor Only Works for ~10secs on Linux
- Teensy 3.6 Multiple AudioPlaySdWav players
- RAM and CPU usage
- Problems with AudioSynthWaveform at higher frequencies
- WS2812Serial and Serial1 Conflict
- PJRC Prop shield (+ Teensy 3.5): how to get reliable heading values?
- Serial monitor Rx interrupt
- Generating a precise note out of tones with the Audio Shield
- Bitshift problem - Endian issue?
- Trying to install mcp4278 library to Arduino IDE v.1.8.8?
- Arinc 429 data reciver
- Program failing when initializing a class no compile time errors
- CAN Issues with FlexCAN, Teensy 3.2, and Teensy 3.5
- Microcontroller swap
- RCSwitch library
- Teensy LC, selecting keyboard only presents a joystick to linux
- Adafruit Fona, SMS receive, Teensy 3.2
- How do you check if Teensy 2.0 INT6 (pin 24) works?
- Calculate Tempo from external MIDI Clock pulses.
- LIDARLite library and i2c_t3
- SPI Clock Speed
- Analog Ground and Multiplexers / separating ground planes on PCB
- WIZ850's DOA from Mouser? No Link Lihgts
- analogRead from MIDI controller overwhelming synthesizer with messages
- Teensy 3.2 with Adafruit Featherwing Adapter - Battery voltage reading too low
- Teensy 3.6 and DHT11 sensor not working together. Clockspeed?
- Change SPI Port for RH_RF69 library
- PC to USB SERIAL interface
- Teensy LC Internal Resistors
- Teensy 2.0 chips (Atmega 32U4) available in VQFN package?
- Teensy++2 problem with servo() and tone()
- A question about the teensy Audio Library Biquad filter header file source file
- mkdir error on Teensy 3.6 onboard SD card using SdFat TwoCards
- mpu6050, reading time of data
- Teensy 3.6 + Audio adapter + sumotoy's SSD1331 library
- Teensy 3.6 SPI to TTS-click board Help to speed-up code for near to real-time acces
- Teensy 3.6 on-board Sd Card logging error: createContinuous failed
- 3D Point movement from MPU9250 or any 9 DOF sensor
- I bought a Teensy today and can't get it working
- External SD card connection on teensy 3.5
- Time library - strange behaviour
- Controlling insane numbers of (virtual) RGB(W)-leds with Teensy and NeoPixel library
- How do you send a MIDI control change message using the USB Host Shield library?
- Teensy 3.5 spi and Adafruit HX83573.5" TFT display
- Teensy 3.2, Prop Shield LC, DotStar 60/m strip (2m)
- Teensy 3.6 and OctoWS2811 Adaptor board
- Teensy 3.5 and temperature sensor adafruit mcp9808
- Second Teensy 3.5 Project Failure - please help for heartfelt wish
- Issue with keyboard interfaces in 3rd party USB Host ports
- Which Teensy for 64 joystick button inputs?
- CDC vs Emu Serial port
- Teensy 3.6 capabilities for my project
- Teensy 3.6 Sine -> DAC cannot change frequency
- i2c Teensy Master Reader w/Audio Shield?
- New adafruit GFX 1.4.x libs doesn't work for me
- Teensy 3.6 ADC Speed and multiple analog signals
- EEPROMex not saving past byte 151
- Signal Problem Joystick axis with Loadcell and HX711
- Teensy 3.6 takes 300ms to start up
- Teensy 3.2, ILI9341_t3, D/C question
- Info adc
- Is it possible to prevent accidental flashing over USB on Teensy 3.2?
- Roll mt own Serial3 function in sketch for one way TX communication to a Serial LCD
- Necessity of Level Shifter for Teensy 3.2 I2C Functionality
- Teensy3.6 Serial comm. error
- Teensy3.5 and temperature sensors on i2c (GY21)
- General unsage of the DACs on Teensy 3.5
- Bounce2 double read
- Differential ADC Values Off
- Teensy++ with OLED SSD1351 sd card
- I am trying to mix multiple audio files from an SD card to a PWM pin(sound quality)
- Programming the ATtiny1614 via a Teensy3.2, can I?
- Ps2keyboard sirious problem
- Emulate three USB devices with one Teensy device
- Garbled Data from I2C EEPROM using i2c_t3 with Teensy LC
- Controlling two solenoids
- Problem with LC and RPi
- Difficulty reading registers of DRV8308EVM using SPI with Teensy 3.6 as a master
- conflict in 2 mux16 code
- I2C Slave will not send data to master when requested
- Cannot get Arduino IDE to talk to Teensy 3.6 (Linux)
- Half of WS2811 LEDs not working?
- Setting steps with external button
- Modifying my source code for Teensy
- Find Frequency from a guitar HELP!
- Which Boards Support FTM vs TPM?
- Is it possible to bitshift using ARM native bitshift operators?
- teensy and TCA9548A pullup resistors
- USB Type FlightSim Controls (in PlatformIO)
- Teensy 3.6 and APA 102 LED strips HELP!
- Discontinued ILI9341 Touch Display?
- 14,5 V voltage divider
- teensy3.6 3.3V amper
- USBHost_t36 callbacks for device connected / disconnected etc?
- what makes AGND "analog" ?
- OctoWS2811 and PWM?
- movie2serial port to Python
- Quick Ground Question regarding the Teensy LC
- Kinetis KE1xF
- Trying to Use SD Optimization from Teensy Audio Lib
- Possible to disable 3.3v output pin on Teensy 3.2?
- Help with SPI and Adafruit TLC59711 RGB LED board with Teensy Audio
- Initializing Struct Reference
- playSDWav.isPlaying() and playSDWav.play(file) are blocking loop
- Adc problem
- Help me with 3.3 to 5V Logic level up shifter for TTL LCD serial signals.
- Easy Reset from Software?
- Cant get any meaningful analog readings (novice user)
- How to? Conversion from external RTC1307 to built-in ETC Teensy3.5
- ARTNET Teensy3.2 without success
- Teensy3.6 CANFD - How to communicate via CAN2.0B interface?
- Teensy LC Port registers pinout
- Problem with digitalRead for simple buttons
- Can I use two I2S mems mics (Adafruit SPH0645) with Teensy 3.2 with audio shield
- Key mapping
- NoteFrequency HELP!!! Live input
- SD-card writing making program slow ? Why
- ILI9341 touch - SD Slot
- Suggestion for update to the SD card driver
- APA102/SK9822 LED Strips in Parallel?
- Arduino IDE boot loop. Anyone ever see this?
- PID sample rate
- ILI9341 + Touch - debouncing problem
- TPIC6B596N + Teensy 3.2
- Teensy 3.5 wont send full 2 bytes over I2C to master device
- Newbie: What is meant by "not 5 volt tolerant"
- Using a Raspberry Pi Zero W to program a Teensy 3.1/3.2
- Teensy 3.6 Wire library question
- Generated Code of teensy3.6
- Teensy not working
- Touch screen not displaying labels as expected
- Magnetic North with BNO055 and Teensy 3.5
- Disable Prog Button
- Teensy 3.2 lockup issue
- Understanding pin assignments Teensy 3.6
- Teensy 3.6 ADC - Continuous read giving unexpected results
- I2S audio clipping
- Can't run project.
- integrating multiple teensy's with a printed circuit , weird synchronization occurs
- push buttons with 100 ohm resistance and teensy
- Random function in expression gives wrong values
- Teensy 3.5 died silently
- Adc info
- MIDI All Notes off code takes 2 sec to run can this be fixed?
- USB Serial Sensitive to NULL? Can't be.
- FONA GSM module and utf-16 encoding
- Need basic help using TCA9548A Multiplexer and teensy 3.6
- Can't connect to Teesny anymore
- Mouse.scroll() a variable less than 1? Or how to get more resoloution..
- Teensy 3.6 crystal accuracy and how to improve it
- attachInterrupt() corrupting Serial buffer requiring Serial restart
- Teensy 3.6 host port for PC connection instead of microUSB (but not for programming)
- Teensy 3.5 - Ports A & E 'not declared in scope'
- Teensy 3.6: Max. current for 3.3V pins?
- Getting WS2811 to run with Teensy 3.6
- Cannot get 2.9" epaper to work with Teensy
- Left and Right Channels not in Sync ?
- Teensy 3.2/3.1 connection with FT800-EVE-microe
- LiquidCrystal reset behaviour
- Ubuntu stops receiving USB Serial shortly after start (Teensy 3.2)
- UBS pass-through with USBHost_t36?
- How to connect a button to a Teensy 3.2?
- how to write if() condition from 4 control change midi values ?
- Reading serial data from TeensyDuino not working on Ubuntu 16.04
- RTC hour displays wrong time.
- Serial Monitor behaving oddly
- Help with latency updating Ws2812 Leds with midi noteOn
- I2C issues in slave mode, sometime stay in I2C_SLAVE_RX state
- Transfer files from External SDcard to internal SDcard
- freqmeasuremulti library
- Teensy 3.2/3.5 pin compatibility
- Audio shield headphone out connected to amplified line-in
- Teensy 3.2 EEPROM
- 2 i2c buss timing issue
- How can I control the clock speed of Teensy 3.2?
- Interfacing AD5933 with teensy3.2, I2C issue
- Secondary Ports - T3.5
- bno055 problem code
- Serial port access from library
- Teensy 3.5: EEPROM and Encoder/Interrupt Interactions?
- int to unsigned long
- Array null termination
- how to maintain a static USB serial port in ubuntu
- LS191 Binary Counter Oscillating between two values instead of counting
- ADC ISR stops executing after receiving a CAN frame through ISR
- Canbus Mask and filters
- CS42448 Codec with SD Card Audio
- Teensy 3.2 I2C Read/write to EEPROM
- I nicked off a small chip off my Teensy 2.0... what did it do?
- Creating Raw Files for AudioPlaySdRaw Object
- Blink without delay
- Teensy 3.2 USB input pins?
- Did I just destroy my Teensy? => not found, no led
- How to use hardware serial and Snooze simultaneously?
- TFT Flickering using ILI9341_t3DMA
- Using Bounce library with multiplexer
- Is it safe to connect a 5V I2C LCD module to a 3.3v Teensy 3.6 ?
