- Teensy LED is very dim
- Teensy 3.2 adafruit ILI9341 tips for polling IRQ, not currently functioning
- multiple open files on uSD card
- Using IntervalTimer with multiple timers
- One Midi Device not working with the USBHost_t36 library
- A single Teensy 3.x to show up as MULTIPLE USB serial ports?
- Need Finite State Machine Help and/or Guidance
- Teensy 3.2 now showing up as 'keyboard'
- Can't upload anything to Teensy 3.2
- How to connect the power supply to Teensy 3.6 and Adafruit GSM board
- Teensy 2.0 not working?
- Font character width & concatenating arrays
- USB Host 5V in/out
- if statement question, multiple definitions of a variable
- controlling auto reset in a teensy like the arduino mini pro
- Teensy Loader does not show connected Teensy 3.6 board on Raspberry Pi Zero W
- Compiler error: can't find {library_name}.a file
- 5-pin DIN MIDI IN and RealTimeSystem Clock ticks (24 ppq)
- Teensy 3.6 and memmory
- Understanding PWM Resolution
- ILI9341_t3 and ILI9341_t3DMA fillTriangle bug solution
- How to change code flashing address in Arduino IDE for Teensy 3.6
- Use Teensy as Midi and USB Keyboard controller at the same time
- Is there a limit to the number of global variables used?
- Serial Monitor Crashes
- Audio shield pin 13 PC board jumper trace.
- T3.6 USB Host - New USB Keyboard
- How to write in flash at specific location in teensy 3.6 board.
- Teensy 3.6 can not write to EEPROM memory when running faster than 120 MHz
- Teensy 3.2 FastLED parallel output strange flickering
- Game controller does not appear properly in Windows
- cannot read exteneded CANBus frames in FlexCAN
- Teensy 3.5 "error sending reboot command (HID)"
- multiple square wave generation, but phase adjustable
- Is there a getPixel command for the WS2812Serial Library?
- Having issues with setting filters with the FlexCAN library!
- Teensy-based mouse can't connect to CircuitsAtHome USBhost
- Teensy 3.6's pin 4 has slightly different electrical characteristics?
- T3.6 USB Host MIDI - Theory of operation question
- Tx only needed oSoftserial lib for MIDI on T3.6 -
- Flash memory write/read in teensy 3.6
- Teensy 3.2 serial port pins
- Problem Connecting Teensy to Raspberry Pi with USB
- I2C eprom help
- Actively manipulating a Teensys clock to Control a stepper motor.
- How do I modify IDE board upload procedure to run .bat instead of Teensyduino?
- Why won't the xbee work with my teensy?
- Newbie Question Regarding Pin Assignments
- Early CAN packets not rec'd by IFCT on Teensy 3.2
- Long Upload Time on Teensy 3.6
- Change CPU clock on the fly.
- Audio Adaptor Board with headers soldered on in the EU?
- Power Teensy 3.6 with lipo battery?
- Teensy 3.6 dead - reballing?
- Multiple MIDI Serial Inputs?
- T3.6 SPI1 alternative CS?
- Teensy LC not sleeping with SPI Flash
- Teensy++ 2.0 Not Writing Data to SD File
- Hardware flow control in Teensy 3.6
- How to output same data to all pins octows2811
- 2 Teensy 3.6's burned out
- XRAD: Need help, code not working on T 3.6, works on 3.2
- TeensyLC won't boot unless I reprogram it every time
- Blink Thread example ok on T3.2 but fails to compile for TLC.(Arudino 1.8.8)
- Struct values are returning back to default values
- Loop stops executing if I omit Serial.println
- Problem: Mystery stepper and L298 works, but only when inputs driven like LEDs
- Interference between LEDs (PWM) and DAC (Teensy 3.2)
- SD Card and UTF8 encoding
- Teensy 3.6 trace width between USB socket and VUSB pad
- Teensy overheating/not working
- Tlc59401
- Teensy 2.0 Row and columns
- Why this code does not crash ?
- Can I use the AREF pin for regular analog input?
- SPI pins for two devices with audio shield enabled
- SD library - speed
- Need assistance optimizing H-bridge driver code
- safe shutdown when power loss
- Help flashing a printrboard
- Teensyduino in pen drive portable Arduino IDE
- version `GLIBC_2.15' not found
- Help identifying the dual diode on the teensy
- Audio Lib: Playing SD Wav Files with More Than 2 Channels
- Potentiometer has no value change until quarter turn
- Teensy LC guidence & help req
- Teensy LC & usb joystick pcb?
- Upload produces error message but still succeeds
- External cv inputs and attenuverters board
- OctoWS2811 scrolling text?
- Rotary Encoder and Interrupts
- Help with fault_isr
- Is inheriting from usb_serial_class a bad idea ?
- Fast changing range or bits of a number (e.g. 0-31 to 0-255)
- i2c communication (400 kHz) between teensy and arduino - delay required
- MTP Responder in real SDfat environment problem
- SD speed on Teensy 3.2
- PS2X Library Teensy 3.6 Convert volatile uint8 to volatile uint32 error
- No longer working after pc reformat
- Heteroskedastic discrepancy between buffers collected and system time
- Teensy 3.6 and DMXSimple HELP!
- How does usbMIDI.read() works?
- Installing Teensyduino on Raspberry Pi
- Tlc5940 library on Teensy 3.2
- Clean Looping Mod for AudioPlaySDWav Using File.seek(int)
- Teensy 3.5 not recognised by Arduino IDE 1.8.9 on Windows 10
- Understanding SPI on Teensy 3.6
- Help. Can we apply 3.3V directly to the +3.3v pins instead of Vin
- Reset status register
- teensy 3.5 + NXPMotionSense
- Yet another SPI Flash question
- Need peak value of 2 microsec voltage spikes occurring every 1.67 seconds. Capacitor?
- Teensy does not start up from cold boot
- Error when skecthing on teensy 3.2 recipe.preproc.macros pattern is missing
- Quad channel input problem
- OctoWS2811 board behaving weird
- Teensy disappeared while programming it, no response from reset button
- Help making a modwheel-type MIDI controller with Teensy LC
- Sequence point compiler error
- Does changing FTM clock affect UART?
- Bare metal 3.2 and LC : jump to bootloader
- Tensyduino compatibility with Arduino Command Line?
- Teensy 3.2 Serial1 different baud rates for sending and receiving
- How to use 3xAA Batteries with Teensy 3.2
- Trouble with Teensy 3.1 and SERIAL_7E1
- How to factory reset teensy 3.2?
- redeclared as different kind of symbol only on Teensy 3.
- String issue..
- Output 0-5v vs 0-3.3v
- Processing Struct variable from a pointer yields different results in LC than in UNO
- XRAD keypad lock: How to store string to int EEPROM teensy 3.2
- red led turn on when connect teensy
- Issue with analogWriteResolutoin
- teensy 3.2 octo adapter, all leds white
- Chaining RawHID Packets
- Need help debugging a rare crash
- PlatformIO project creation problems
- Issue when connecting two teensy 3.6 via serial pins
- unbranded linear actuator communication
- Mac OS nightmare ! Bunch of Teensy devices
- Teensy 3.6: Standard SD or SdFat library?
- Teensy 3.1: usb not found (was working) ... related to pins?
- Teensy 3.6: Can I see the microSD as a pendrive?
- Serial connection question
- Using Interval Timer with Teensy Stepper
- Vbat vs. Vin power teensy
- Adxl343 library not working
- USB0 and USB1... Swapping functionality...
- Reading a 1Mhz -15V to Gnd clock
- While uploading "An error occured" and serial monitor got stuck...or?
- Need help with CAN bus...
- 3.6 SD card issue, freezing before loop starts
- 3.5 EEPROM SIZE increase
- SdFat with Teensy 3.6: error: write MBR - SD error: 23,200002
- Main chip of Teensy 3.2 Overheating
- T3.2 Power Fuse Rating
- Teensy 3.2 Usb Midi Interface for Synthisizer
- How do I use INPUT_PULLUP on pin 13 (LED)?
- Replacement policy
- Potentiometers?
- Midi IN interface for Teensy 3.2 Midi Data Issue
- Motor Driver problem when uploading new sketch
- Puzzler with Snooze and wav player
- Trouble extending Mass Storage Device MTP Disk
- Driver problems Windows 10 vs Windows 7 ?
- I programed a interrupt on pins 3 and 4
- Hitting Watchdog Too Often
- using the envelope object with the pwm output
- analogWriteResolution ?
- Teensy 3.6 with HX8357 and Audio Shield - Alt SPI pins
- How can I change the clock speed of the I2S interface?
- Teensy 2.0++ as Keyboard HID not recognized by C64 mini
- Connecting the Adafruit micro SD breakout board to Teensy 3.6
- Teensy 3.2 AREF(EXTERNAL) and analogRead()
- Teensy Theramin using VL53L1X Time Of Flight Sensor (Library issue)
- list_ports.comports() lists Teensy port as 'USB Serial Device (COM3)'
- Teensy cannot send (but can receive) USB serial commands
- Problem with falling edge interrupt delaying 1-2 microseconds inconsistently
- Heat generated by an Teensy 3.6 ?
- Teensy 3.6: Which CAN0 pins to use?
- What is delivered with the Audio board?
- Correct resistors to convert 5V signal into 3.3V?
- Teensy++ 2.0 in Arduino, can't control PORTF
- Hobbs meter project, a few questions
- Teensy 3,6: VREG_OUT to VDD (?) and choosing the clock frequency via the IDE
- Simple WavFilePlayer not working
- Teensy 3.5... GPS in... 1.5" OLED out... No Display
- Arduino UNO and Teensy 3.2: same code but different behaviours for fixed-point math
- TFT LCD Support for Pop-Up / Sliding Windows
- Photon Counter
- overheating / dead 3.2 ?
- Received my audio shield today and want some test to done...but...
- fastLED Teensy 3.2 WS2813 Strip- No Joy
- run teensy3.2 with labview using command line.
- Troubles with RS485 between 2 teensy
- Help on connecting an I2C MPRLS pressure sensor from Adafruit
- Teensy 3.6 will not run without USB
- Teensuino strang behaviour
- Idea for FTM Application - Is a Race Condition Possible?
- In search of a cute little potentiometer in germany... :)
- Teensy3.6 serial communication.. issue ?
- Kinda "terminal" for the Teensy 3.6 ?
- Teensy Complete Lockup
- Serial or Seremu
- Octoboard and Teensy 3.2 and Fast LED
- Parsing and comparing strings on Teensy 3.2: different behaviour from gcc?
- Differentiate reset source
- Problem with X-Plane v11.4.r1 upgrade - Teensy board no longer working
- Help with joystick
- Python script not reading from serial unless teensy is rebooted
- AUDIO board internal Mic failure...?
- How to wire and GND everything correctly to get accurate ADC readings in my project?
- Serial monitor erratic separation issue
- Teensy 3.5 temperature range
- Teensy 2.0 midi
- Testing S/P DIF with AudioPlaySerialflashRaw
- FlexCAN can only send globally defined CAN_message_t
- Teensy v3.6: is it safe to use 230400 baud?
- 16bit gamma correction on Teensy not working as expected
- Need help: InternalTemperature lib and bad analogRead value...
- DIY teensy 3.5
- Troubles Processing MIDI
- instruction timing for Teensy36
- Full-Size USB host shield with Teensy 3.5 gives some weird errors
- More Joystick questions
- Ws2812b + 74hct245 random failure
- Hardware serial debugging in USB stack (Teensy 3.2)
- T3.2 output 5v ?
- Map function teensy
- Counting backwards from 100 to 0 stops at 55
- Arduino + FREERTOS Problem
- Newly received Teensy 3.5 no longer support USB type - Flight Sim + Joystick
- DS3231: Do I lost the internal Flux Compensator or....WHAT?
- serial monitor stops working T 3.2
- Interval Timers running different frequencies - Teensy 3.2
- Snooze_TinyGPSPlus_Teensy 3.2 - problem reading gps on wake
- SPI - shared pins problem
- Enable pin
- How to find out which Serial is used
- Teensy serial debugging, am I doing this wrong?
- tennsy 3.6 and usb
- Teensy 3.6 - GND or AGND
- Programming issues after cutting VIN <> VUSB
- Teensy library routines lock up with data loggin application
- Teensy Joystick axes not detected on Windows 10 only
- Teensy 3.2 with command line.
- Wire library BUFFER_LENGTH - is there a good way to change it?
- Teensy 3.6 CPU in Thumb or ARM mode?
- Generating clock signal for an 8 bits 6502 CPU
- FreqCount on multiple pins ? T3.2
