View Full Version : Technical Support & Questions
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. C Syntax to Change Multiple Bits
  2. pushbutton tactile switches that don't pop out of breadboard
  3. Serial.write Teensyduino question.
  4. Newbie confused about Teensyduino, Teensyloader and halfKay
  5. USB Device Issues
  6. Teensy 3.0: which variable-declaration for registers?
  7. Teensy 3 Ambilight project
  8. Has anyone ever gotten USB MIDI working with Android?
  9. teensy 3.0, teensyduino and u8glib
  10. USB midi : sysex callback name ?
  11. Bluescreen of death
  12. Gettibng weird results with code for a button that simulates mouse click or f5 ">>>>"
  13. Is Teensy 3.0 RoHS compliant?
  14. A bunch of dead Teensy 3's
  15. OctoWS2811 w/VideoDisplay able to run on less than 8 strips properly?
  16. teensy 3.0 USB Serial speed at 7,5K Bytes/sec
  17. STL and Exception handling on Teensy 2.0?
  18. Arduino 1.0.5 + Teensy 3 + I2C = not working
  19. ttyACM0?
  20. Teensy 2.0 pin 11 analog input?
  21. Tensyrduino & librarues location
  22. Wakeup PC from sleep
  23. NavFrequencyEncoder not picking up in Xplane
  24. Emulating a USB HID Device
  25. Unclear/dangerous I2C tutorial info?
  26. Raw HID memory leak?
  27. issue with teensy++ 2.0
  28. How to execute code in SRAM (Teensy 3)
  29. _reboot_Teensyduino() vs. _restart_Teensyduino()
  30. Teensy 3 can power a 5 volt load?
  31. Webserver demo runs with Teensy++2 but not with 2 - server is at 255.255.255.255
  32. ARM EEPROM on Teensy 3
  33. teensy++2 power questions
  34. DS1307RTC and ATTiny85
  35. teensyduino and Multi-Inno MI0283QT-9A display/touchscreen
  36. Teensy 3 stops communicating or is not recognized by Windows after a few weeks
  37. connecting pin 33 to ground prevents teensy3 from booting
  38. Android uploader?
  39. RSA encryption
  40. Teensy 3 USB Midi - is it working?
  41. Help with custom hardware for OctoWS2811
  42. Get state of dip switch with less then 8 cables.
  43. Using CDC ACM with Windows 8?
  44. Want to build a MIDI Controller, is this possible?
  45. I2C Communication
  46. Problem with Serial.write / waits for 70ms then goes on error 3 times
  47. Teensy 3.0: 3.3V pins, maximal Current
  48. Mapping Teensy with usbMidi in Traktor/Ableton
  49. Two questions regarding K20 processor
  50. Strangeness re: Mini54
  51. whats the kbd shortcut to see compilation errors in detail
  52. u8glib now has an ARM variant
  53. RS485 signal transmission - LED panels
  54. Fastest way to erase Teensy 3 flash memory?
  55. I need help with setting up teensy3, usb keyboard
  56. usbMIDI routing problem
  57. Encoder library on the Teensy3
  58. Encoder De-Bouncing
  59. I keep burning Teensys. Tips?
  60. Teensy 3 is not recognized by Windows after bootup until unplugged/plugged in again?
  61. Teensy 3.0 and TLC5940
  62. Teensy 3.0 timer interrupt problems
  63. overpowered teensy2++
  64. Combining interrupts, DMA and SPI on teensy 3
  65. New Teensies do not show same info / work with drivers the same
  66. ADC Maximum Sampling Rate
  67. Teensy 2 ++ Midi out problem.
  68. Teensy 3: SPI hangs at speeds other than 24 MHz
  69. Arduino 1.0.5 behavior problem
  70. just got not working teensy
  71. Teensy 3 + teensyduino tutorial #2 problems !
  72. VideoDisplay and Led Layout
  73. FastSPI_LED2 Teensy 3 and const array access
  74. NeoPixel Strip & Teensy 3.0 Issues
  75. Teensy 3.0 speed and how to connect many leds, buttons and potis?
  76. Teensy help and questions
  77. Hello World Teensy 3.0 without Teensyduino
  78. Stepper count ~4x greater than expected on Teensy 3.0
  79. weird serial port hang, windows only
  80. Teensy 3 programing without using USB port
  81. Teensy 3.0 crashes
  82. Hopefully simple coding solution
  83. Teensy 3.0 boards dying on me!
  84. Teensy 3.0 and Adafruit TFT Library Compile Errors
  85. Teensy 2.0 and 3.0 Specifications
  86. Question about MAME Hooker and Teensy 2.0
  87. Strange MIDI CC messages stuck Triple-axis Accelerometer+Magnetometer (Compass) Board
  88. Question about Teensy ++ 2.0
  89. kurtosis of an analog signal
  90. Teensyduino code on non-Teensy? (eg. Arduino Uno)
  91. Teensy 3.0 multiple SPI device issue, this is out of my league help!
  92. Adding RawHID to Teensy 3.0's USB Serial HID
  93. Remote USB Display feasibility????
  94. Automate software testing on Teensy?
  95. new and delete operators in Teensy 3.0
  96. What is the maximum current a digital output pin can pass through itself?
  97. Teensy 2.0 not properly identified as keyboard in OSX
  98. Teensy++2.0 reflashing only the data portion of your program
  99. Serial port not recognised
  100. Teensy 2 Keyboard question
  101. Teensy 3 Running out of RAM?
  102. Serial speed sending from Raspberry Pi to Teensy 3.0
  103. MIDI issues
  104. Teensy3 serial write speed
  105. Teensy 3.0 chip speed
  106. Spi macros question
  107. Teensy 3.0, Teensyduino -> Object allocation and deallocation: new and delete?
  108. Moving beyond Arduino IDE to a Makefile
  109. Digital pins seem to respond to human touch.
  110. Teensy 3.0 Uart in SPI mode?
  111. Teensy 3.0 - VREGIN max voltage / PWM output frequency?
  112. Is there a way to slow down the I2C datarate on a Teensy 3.0?
  113. Teensy 3.0 and sdfatlib communication problem
  114. MCP1825 3.3V Regulator and Teensy++2.0 and 5volts
  115. Portable Power Supply
  116. node-serialport
  117. ZeroConf/Bonjour Library
  118. First Serial.print not seen on USB
  119. AGND and GND Issue
  120. wire.endTransmission() hangs if it can't connect with I2C slave device?
  121. Using the PDB on Teensy 3
  122. Plugged teensy 2.0 into USB while powered by 5v, can't upload new program
  123. OLED SSD1306 128x64 fonts
  124. SPI communication with IMU ADIS16480
  125. Teensy++ 2.0 gets garbage whenever I cat /dev/ttyACM0
  126. Dead Teensy 3.0 after install of RTC components.
  127. Any particulars I have to follow when using a Mini54 for the first time?
  128. interfacing with ads1115 using I2C
  129. help in understanding the ws2811 led
  130. How to enable CLKO on Teensy++ 2.0
  131. Encoder not responding
  132. Teensy 2.0 + USB functions
  133. First pixel in WS2812b strip extremely hot (enough to fail)
  134. Connecting Teensy 3.0 with Sparkfun Bluetooth modem
  135. Troubles in reading 2x 4067 Multiplexers
  136. Arduino library errors on Teensy
  137. separating VIN from VUSB for the OctoWS2811 library
  138. delayMicrosceconds limitations using teensyduino?
  139. OctoWS2811 POV reading BMP from SD card
  140. Teensy 3.0 and I2C
  141. Teensy 3: Structure packing has an effect on the generated asm where it "shouldn't"
  142. Question about piezo and analog in
  143. pre programmed teensy 2 ++ chip?
  144. Teensy 3.0 TFT LCD compiling errors
  145. teensy 3 and interrupt error
  146. Teensy2 power consumption
  147. pins_arduino.h sample code - usage
  148. Cross Compiling libsndfile for Teensy3.0
  149. Teensy3 and SSD1306 SPI help!
  150. Still trying to get flicker to go away.. do I have to buy an oscope?
  151. Teensy 3 and Adafruit CC3000 breakout
  152. octows2811 basictest color issue
  153. Speed of digitalRead and digitalWrite with Teensy3.0
  154. Capacitive TouchRead() Range/Sensitivity?
  155. Serial_install not working
  156. Controlling SGTL5000 (TWR-AUDIO-SGTL) using Teensy++ 2.0
  157. teensyduino on fedora on arm, no solution?
  158. Basic RS-232 Question Teensy 3.0
  159. Eclipse and Teensy 3
  160. Executing an if statement only once?
  161. Teensy 3.0 not recognized
  162. Double-check my Teensy 3 current valuies
  163. Teensy 3 w/ large-ish array freezing
  164. Eclipse and Teensyduino 1.17 Release Candidate #2
  165. Soldering WS2811 strip
  166. Teensy 3.0 & si4707 breakout board - hangs on Wire.endTransmission()
  167. MIDI USB teensy and potiometer-- Jittery CC values
  168. 27' imac running Lion had firmware lock out screen how to bypass without firmware pas
  169. SPI4teensy3 simple output to shift register example anyone?
  170. Problem with DMA interrupt
  171. Serial driver in Windows 2000
  172. output open drain
  173. MMA7361 Accelerometer & Teensy 3
  174. 10Dof IMU Teensy I2c
  175. Teensy 3 and Adafruit 3.0 server
  176. Teensy 3 Analog Read
  177. octows2811 movie2serial problem
  178. Read RC Reciever with Teensy 3
  179. Serial Latency T2
  180. Teensy 3 - Http server using cc3000 and sd reader on std spi pins
  181. Teensy 3.0 and PIT interrupts
  182. Updated Teensy 3.1 and Teensy 3.0 Eagle libraries
  183. 1.17 mac.os.x installer issue
  184. Teensy 3.1 port->pin mapping
  185. Microsoft Sidewinder Gameport Joystick project by using Teensy 3.0
  186. Teensy 3.0, Adafruit's SSD1306 128x32 OLED, and Pin Designations
  187. Serial Monitor with Teensy3, Win7 Pro, stops after a few minutes
  188. Problem with "multitasking". Only works for the first 32 seconds [Arduino IDE]
  189. Measuring crystal frequency (Eurorack frequency/tuning module)
  190. Newbie findings re:WS281X signal quality(wire length, resistors, and grounds. Oh my!)
  191. Teensy not recognized by Arduino
  192. Teensy3 and SPI - too fast for my code...
  193. multiple psu on single teensy 3
  194. Bounce library not working for me
  195. adafruit NeoPixel library will not compile with teensy 3.1
  196. spi4teensy3 and teensy 3.1 bug
  197. Mouse.move not working when Serial+Keybd... chosen [Teensy2.0, Win 8, Arduino 1.0.5]
  198. Weird Results with OctoWS2811 on Teensy 3.1
  199. Teensy2.0,LCD,and Thermocouple via SPI
  200. Teensy 2.0 LED controller
  201. Setting PORTF on Teensy 2.0 is asynchronous?
  202. Question about Teensy 3.0's power consumption
  203. Using the VIN pin to ~supply~ power when powered by USB (instead of VUSB). Bad idea?
  204. More Teensy3.1 Makefile Questions
  205. Source for USB initialization for Mk20dx128
  206. RTC & elapsedMillis
  207. Teensy 3.0 & Teensyduino: Undefined reference to 'setup' during "Verify"
  208. Powering a Teensy 3.1 on a breadboard
  209. Artnet to OctoWS2811?
  210. OctoWS2811 leds.show() and IntervalTimer issue.
  211. OctoWS2811 for TLC5940
  212. PC capture of Analog read data
  213. Slow sinewave code
  214. ARM asm?
  215. Teensy 3.1 Simultaneous ADC sampling?
  216. Teensy ++ 2.0
  217. IAR Workbench?
  218. X-Plane Plugin, teensie++ 2.0, Ubuntu 64bit
  219. 1st time USB connect with teensy 3.1
  220. Serial port on Teensy 2.0 locks up after Tlc.update() ????
  221. Problem with ADC on Teensy 3.0
  222. LSM303DLM magnetometer returns weird values
  223. Did I kill my Teensy?
  224. Teensy 3.1 / Win 8 Halfkay bootloader problem.
  225. how can i made 16*128 led dot matrix display using atmega 16.
  226. How to make objects accessible from inside classes?
  227. What is the best way to connect to the bottom digital pins on T3.0?
  228. teensy 3.1 + OctoWS2811 + Adafruit NeoPixel strip == burned out led's?
  229. fprintf with Teensy3.1 hangs
  230. Teensy 3.0/3.1 unresponsive and overheating?
  231. Win8 support
  232. What is the default voltage range on the DAC for the Teensy 3.1?
  233. Will pressing the reset/program button by itself erase the chip?
  234. Teensy 2.0 Micro SD card software needed
  235. H Pyle's I2S library settings help!
  236. Teensy 2 - hot!
  237. Teensy 3.x - Large Sketch/Hex Files?
  238. RS485 Blues… i.e. lots of questions...
  239. Teensy 3.1 - Code for Soft Reset?
  240. How to connect an external Clock source??
  241. Arm math speed?
  242. IntervalTimer and C++
  243. sd-adaptor for teensy 3.*
  244. Two Teensy 2 MIDI Devices with different PORT Names
  245. Midi design reference
  246. KeyCode to character function?
  247. Starting out with Teensy3.1, which tools to install
  248. movie2serial issue for Processing2.1
  249. compiler problem
  250. Power from both USB and external
