View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50
  1. Teensy 4.0 USB serial problem - hangs after some amount of data
  2. Using register A for digital I/O on Teensy++
  3. multiplexer with teensy 3.6 - 5V or 3,3V ?
  4. Doc update request to cover Teensy4.0 for Pulsed Output: PWM & Tone
  5. Use SD library in C
  6. Teensy USB-Midi single client?
  7. Question on TeensyDuino libraries
  8. Vehicle Cabin Audio - Audio update painfully slow!
  9. Uploading Teensy files to PC
  10. teensys 3.5 - serial2 problem
  11. Teensy 3.x library for tick timer?
  12. scripted instalation and update
  13. speed up SD card transfer
  14. Using usb as serial port and for uploading code
  15. Teensy 4 IntervalTimer Max Speed
  16. Teensy 4 PDM Audio Input
  17. SD read speed in raw 512 byte mode on Teensy 3.6 and 4.0
  18. Teensy 4.0 compatible microSD connector?
  19. Possible Teensy 4 schematic typo
  20. Raft of Teensy 4 pin\port parallel read questions
  21. Teensy 4.0 USB Mode only shows serial
  22. Teensy 4.0: need an example of using USB host
  23. direct pin access
  24. TimeTeensy3 Question - "processSyncMessage" - WOSSAT?
  25. Teensy 4 round pads, where do they go?
  26. I2C and audio library
  27. Canbus with Teensy 3.2/4.0
  28. Teensy 4.0 power draw at lower clock speeds
  29. Teensy 3.2 MicroUSB plug fell out
  30. Where to d/l "IntervalTimer" lib?
  31. Teensy 4.0 vs. MIMXRT1062DVL6A Datasheet: Number of CAN Buses
  32. Teensy 4.0 DMA over GPIO
  33. Could RC Servos and PPM Library replace steppers???
  34. mk20dx256vlh7 Equivalent of a Programming Manual?
  35. How to run Flight Sim Controls and send serial data to an application?
  36. Teensy 4.0 Read value of pins right from register
  37. Sending MIDI CC value based on last received value with midi read
  38. Can I read the battery backup voltage (VBat) internally?
  39. Teensy 3.2 not starting in very particular circumstances
  40. Teensy 4 as SPI Slave
  41. WS2812Serial Question
  42. Teensy 3.2/4.0 inrush current?
  43. Issue with temperature sensor DHT22 and Teensy 4.0
  44. T3.5 Serial Halting Problem
  45. Teensy 4.0 Serial USB baud rate
  46. Timer GPT question
  47. T4 RTC wake-up
  48. adc->startSynchronizedSingleRead(pinLicht,ADC_INTERN AL _SOURCE::TEMP_SENSOR); -> Erro
  49. TeensyStep - changing target while running
  50. Teensy 4 Interval Timer
  51. Using map() with Midi controller pots
  52. FastLED Library Failing to build
  53. disable monitor in tycmd (platformio)
  54. Teensy and gigabit ethernet
  55. MIDI stompbox + expedal (spdt switches - help with code)
  56. Out of memory errors with latest PlatformIO
  57. Wire library incorrectly reading last 2 bytes in page
  58. OOM Errors with ample memory on Teensy LC
  59. Limit MIDI to just two ports?
  60. SBUS input
  61. How to find a TD version in an Arduino version...
  62. touchRead value bouncing all over the place
  63. direct timer register access
  64. VideoSDCard Teensy 3.2 +octows2811 flickering + format questions
  65. Teensy 4, signed/encypted boot images
  66. Recommended transistor and base resistor for LED
  67. Direct register access using address
  68. ESP8266 ESP12E Nodemcu Lua Lolin v3 and Teensy 3.2
  69. Teensy 3.6 LED dims with solenoid operation
  70. Port of UTFT to Teensy 4.0 available ?
  71. Code just slightly too slow to wirelessly stream audio via Nrf24L01+?
  72. Need to use pins for both address writes and data reads from parallel memory on T4
  73. Using multiple I2C busses without i2c_t3? (Teensy 4.0)
  74. qc of boards with teensy bootloader - bring RTC clock to a digital output
  75. Teensy 4 upload problem
  76. Will the PulsePosition Library work with Teensy 4.0?
  77. Teensie 3.2 EMI??
  78. Teensy 4.0 and Dynamixel
  79. Teensy 3.2 OctoW2811 WIZ820+SD problem with movie2sdcard
  80. Hooking up an ST7789 display with no CS pin
  81. Hitting some kind of limit on the Teensy 4.0
  82. Touch Panel not working using XPT2046_Touchscreen.h library
  83. Teensy 4.0 - where is USB Type: *+*+Joystick?
  84. Teensy 4.0 SPI pins
  85. Direct read of ADC and transmit to DAC on Audio board
  86. Teensy 3 startup procedure
  87. Teensy 3.6 Ethernet with other fast SPI
  88. Teensy 3.6 with WaveShare CAN not working
  89. No SD CARD on Teensy 3.6
  90. Teensyduino environment won't find the USB/Serial port...
  91. FreqMeasureMulti not working with Teensy 4.0
  92. "error compiling for board Teensy LC" when trying to use ILI9341 example sketches
  93. error compiling
  94. Teensy 3.5 Suddenly Stopped Working
  95. 4.0 CAN Communication
  96. Velostat changes resistance only on press wirh my finger?
  97. I2C works on Teensy 4.0, but not on same chip's EVB. SCL differs.
  98. Teensy 4.0 RTC - setting RTC time works, but current time returns after power cycle
  99. Array of HardwareSerial objects
  100. Port Pin Edge Detection
  101. Sending data between two Teensy 3.2s
  102. Tutorial help - 'waveform1' was not declared in this scope
  103. testing for math overflow
  104. Transfer an arduino project to teensy
  105. TimerOne and TimerThree setup pin 0 to output high on Teensy 3.6
  106. ADC in free running on Teensy 3.6
  107. Teensy 4 On/Off pin
  108. Cant get Teensy out of "unknown usb device descriptor failed state" Windows 10
  109. Need help to convert .elf file into .hex
  110. Implementing "Mode Switching" to use multiple CCs for same switch
  111. Teensy 4.0 and single-wire serial
  112. Teensy 3.2 SPI DMA Transfer (DmaSpi example) SPI1 error
  113. How to use moren than 2 interval timers at the same time on Teensy4
  114. Teensy 4.0 problem with DMA to/from OCRAM interacting with Audio library
  115. Driving EL Wire
  116. porting midi controller code over from an Arduino Due. Need some help
  117. Edge Detection on a signal using Teensy 4.0
  118. Teensy 2.0 & Teensy LC keyboard acting up after about 40 seconds connected to Mac
  119. Serial Flash erase and write speed
  120. Teensy 2.0 Two keystrokes if button is pressed
  121. T4 rtc setting with time change
  122. RA8875 Library with Teensy 4.0
  123. How should I debug audio exceptions
  124. OctoWS2811 and LED signal flow direction to Glediator or Jinx
  125. Teensy 4.0 Analog Voltage Reference
  126. Teensy 3.5 Stuck after Serial for sometime
  127. LC: multiple interrupts on one pin
  128. reliability and current draw from 3.6 @240mhz?
  129. Aref pin on Teensy 3.6.
  130. Sparkfun BNO080 - Teensy 3.6 >> 4.0
  131. HELP!!! Teensy & Arduino Conflict on a Mac
  132. Teensy 3.2 Code Doesn't Reliably Run on Teensy LC
  133. Teensy 4.0 Epoch time if RTC not Set
  134. Teensy 3.2 + Octows2811 adaptor - Processing error: InvocationTargetException
  135. Maximum delay for Teensy 4.0
  136. how can I use AudioEffectEnvelope::isActive ??
  137. Multiplexer to retain the value sent to channels
  138. Teensy 3.2 T3 timng different from Mega
  139. Teensy 3.5 not recognized
  140. TFT ST7789 - convert SPI9 to DMA transfer (Teensy 3.6)
  141. T4.0 Re-assigning pins to get more analogue inputs
  142. T3.5 IntervalTimer stopping main loop?
  143. Can teensy 2.0++ use 3v voltage?
  144. Teensy LC: Wrong action on Port D pins
  145. micros() within Interrupt possible?
  146. TFT 1.54" Teensy 3.6 Bitamp from SD card wrong colour
  147. Question about Arduino Keyboard library and USB sleeping
  148. Teensy 3.2, OctoWS2811, and large Serial.readBytes hang
  149. SPI communication Teensy+NOR Flash Memory
  150. Teensy 4 and propshield CalibrateSensors hangs after a few seconds wigging
  151. Available Teensy 4.0 pins when Audio shield D attached
  152. Jetson Nano Teensyduino 1.48 install fails
  153. Teensy 4.0 12mbps to use HID
  154. Teensy 3.5 vs 3.6
  155. Error when trying run teensyduino on linux
  156. Wire distance between Teensy 3.5 and ILI9341 display
  157. I2C trouble interfacing the Sensirion SDP810 differential pressure sensor
  158. Teensy 4.0 UART RX to DMA
  159. Help Receiving MIDI clock for tempo LED
  160. Issue moving sketch from Uno R3 to Teensy 3.2 - Modular synth clock, SM Tik-Tak
  161. 8 Channel ADC Sampling - Sonar Imaging
  162. Teensy 4.0 Compile Problem not seen with Teensy 3.2
  163. Reading multiple GPIO pins on the Teensy 4.0 "atomically"
  164. Does the Teensy 3.2 have a ratiometric ADC?
  165. SPI Pin questions
  166. My Teensy Is Stuck Pressing Keys, and Now I Can't Upload New Code
  167. Teensy 4.0 which pins for which ADC
  168. Teensy 4.0 hardware timers for PWM and pins
  169. Is it possible to toggle a gpio @300MHz in a teensy 4 @600MHz ?
  170. RawHID speed issue
  171. Teensy 4 and #define ENC_PORT PINC
  172. Controlling two or more Midi-Devices with one teensy?
  173. Calculating fuel consumption averages from can bus data
  174. Teensy 3.6 CAN BUS 5V
  175. Teensy 2.0 pushbutton not working on different computer
  176. Teensy 4.0 has no PORTC and PORTD definitions?
  177. uart2_status_isr interrupt problem
  178. Can't get Teensy LC to receive DMX
  179. Modifier Keys "Sticking" with Keyboard Code
  180. increment operator bug with globals?
  181. Emulate two serial ports through the USB connection (Teensy 3.2)
  182. Teensy 4.0, Serial3, attachCts, wrong pin # in HardwareSerial3.cpp?
  183. Troubleshooting trying to get MIDI out to work..
  184. String toDouble not working on Teensy?
  185. Teensy 4.0 USB host current limit chip
  186. Schematics and Board review before PCB
  187. Oddball Serial Receive Problem
  188. AnalogReadRes() Unexpected Behaviour
  189. Teensy LC stops when Ableton playback is engaged
  190. Nextion library for Teensy?
  191. Disable/reduce wear leveling on Teensy 4
  192. Nanosecond Resolution Interrupts on Teensy 4.0
  193. MIDI Message Toggle in Code
  194. This is embarrassing, but I can't do division ?!?!
  195. Not recieving data from RPLidar a1m8 to my Teensy 3.6
  196. Non-Blocking WS2812 LED Library and Teensy 4.0
  197. Software Serial (USB) parity bit
  198. Looking to use SPI master + DMA + Interrupts
  199. teensy 3.2 and I2C EEPROM
  200. No Flight Sim Controls under Tools>USB Type running Teensy 4.0 Teensyduino 1.48
  201. USBHost_t36 Buffer parameter handling
  202. Problem with controling a Line6 Helix with usbmid with my teensy
  203. Teensy 4.0 I2S library compatibility issue
  204. Can my Teensy 3.5 come back to life?
  205. Teensy 4.0 and I2S DAC
  206. Is Teensy Blocking during Serial communication?
  207. Cutting VIN to VUSB trace - or not
  208. Voltage regulator on Teensy 3.5 and VESC simultaneously failed
  209. Which board ?
  210. extend Queue object for Teensy 4.0 to more blocks
  211. Teensy 4.0: Can I use Serial Pins 0 and 1?
  212. Teensy3.2, IMU and servo control problems
  213. Teensy 4: pin on/off, which functions and how should we connect it?
  214. board_build.f_cpu = 72000000L
  215. Teensy 4.0 seems broken after triggering MOSFET
  216. Visual Studio 2017+Visual Micro+Teensyduino+Teensy 4.0 warns: "EMIT not typename"
  217. Porting Mega code to T3_2 and softReset
  218. Using IntervalTimer in Subclass: programming issue
  219. Using Teensy 3.5 Built-in SD card reader for data acquisition
  220. The control keys do not work with Keyboard.h
  221. Teensy 3.1 crashes on trivial code
  222. Teensy 3.6 Jumps in Voltage Acquisition ADC
  223. Teensy 3.2 Air core gauge. 3pin
  224. Teensy Usb Keyboard does not work in BIOS
  225. Teensy 4.0 Adafruit_SSD1306 and Adafruit_GFX crashes at boot
  226. attachInterruptVector() with Teensy 4.0
  227. Anyone else seeing MacBook Air hard crash when using a Teensy 4?
  228. T4 Data in Flash
  229. Problem with pot center value
  230. flip flop out put is quiet slow
  231. Teensy 3.2 USB MIDI Controller Coding Assistance *Willing to Pay*
  232. Teensy 3.5 behaving badly
  233. Teensy Joystick + Serial conflicting
  234. Teensy 3.5 and bluetooth problem
  235. Having the darndest time modifying the joystick library
  236. Coding Assistance Needed with Teensy 3.5
  237. Teensy 3.2 DAC power mode
  238. Bootloader Chip for DIY Teensy4.0
  239. Solved: Eight axis joystick HID descriptor for Teensy LC
  240. Changes in USB keyboard support on Teensy 2.0
  241. Reliably reloading the calibration data of IMU BNO055
  242. Having an issue using SPI on Teensy 2.0
  243. How to calibrate accelerometer, magnetometer and gyroscope?
  244. Question about UART FIFO containing one byte and when RDRF gets set (one char behind)
  245. Teensy 3.2 Enable Analog Reference
  246. Fastest accurate sampling rate on teensy 3.2
  247. ADC schematic T4
  248. teensy audio library and examples are missing
  249. Interface an external RAM with Teensy 4.0
  250. Compatibility of AES Encryption using CryptoAccel library on Teensy 3.6 with PC
