View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50
  1. rapidly storing ADC data
  2. Stuck trying to get NeoPixelBus library working on Teensy 3.2
  3. Teensy 4.0 - Bare minimum initialization and memory layout question
  4. Teensy 4.0 - On Program/Reboot Teensy loses power & disconnects! (Beginner)
  5. WS2812Serial question - conflict between FastLED and Adafruit NeoPixel libraries?
  6. Windows 10 is being super flakey about USB type Keyboard / Mouse / Joystick
  7. Teensy Chip Sets
  8. Teensy 3.2 and 3.6 CAN BUS
  9. Are resistors needed with rotary encoders?
  10. Unable to get Rotary Encoder to work with my Teensy 3.5
  11. Teensy 4.0 Bootloader Chip Question
  12. Teensy 3.5 Coding Problem
  13. Eurorack voltages to/from Teensy
  14. Teensy 3.1/3.2 KINETISK_UART2.... S1, D & C2
  15. Extern micro SD card on T4
  16. Do the ILI9341 and SD libraries play nice together on the T4?
  17. Teensy 4.0 usb-c breakout
  18. How do I code a keyboard when keys are in rows and columns wired from pin to pin?
  19. Need Wire.endTransmissionNonblocking();
  20. Concerns about connection between 3V3 ports between two Teensys
  21. Analog MEMS mic connected to Audio Shield only picks up noise.
  22. Using 3V3 pin on T4
  23. Need Help, Teensy 3.2 Snooze library. Can't wake from sleep with pushbutton.
  24. Teensy 4.0 USB Host hardware connection Q's
  25. Implementing I2C Slave on T3.2
  26. Custom Teensy 3.6 Problems
  27. FXOS8700CQ(Accelerometer and Magnetometer) and FXAS21002C(Gyroscope) Axis Mapping
  28. code for fast ADC reading on a T3.6?
  29. ADC intern reference voltage on teensy 4
  30. Wiring 5" TFT to Teensy 3.6
  31. analogRead() vs Frequency on T4
  32. Teensy USB delay
  33. USB Host polling rate issues
  34. Curious about serial1.c uart0_status_isr() and a teensy 3.6
  35. Temboo library error Unknown type name 'bool'
  36. Part number for Micro USB Header on the Teensy3.2
  37. PT8211 Audio Kit for T4
  38. Multiple SPI interface on Teensy 3.6 ?
  39. Yaw Values are not getting stable
  40. Teensy3.5 SPI RX using DMA
  41. Teensy 4.0 CPU Speed Option Not Working Properly !
  42. Teensy 3.5 pins
  43. MahonyIMU buid error :- 'class mahony' has no member named 'begin'
  44. config error FXOS8700
  45. c++17
  46. Flexible Array in Arduino ?
  47. How to repllicate a barber pole type effect on string on WS8211 pixels OctoWS2811
  48. avr missing in teensyduino 1.48
  49. qvgatest_touch purple board USB power?
  50. Timer Interrupt in QMK with Teensy2.0++
  51. 3D graphics
  52. Newbie alert ! ;-) Trying to use WS2811 Library - BasicTest - Lights don't come on
  53. Why does IntervalTimer restrict cycles to >= 36?
  54. using interrupts with encoder library
  55. Realtime display of a captured data using Arduiono / Teensy 3.6
  56. Some trouble with SD reading
  57. Teensy 3.6 and Propshield : Yaw value unstable
  58. Teensy 4.0 Serial Monitor Issues
  59. T3.5/6 I2c pin re-assignment query
  60. Min output cycle time for Teensy 3.2 & 3.5
  61. How to read bytes transmissions of various lengths ?
  62. SD card read time
  63. Keyboard commands behave weirdly when put in a specific part of the code
  64. test mic without an output?
  65. Multiple SPI reads not returning data
  66. Tennsy4.0 Port manipulation
  67. Teensy 3.2 died -- 4.0 and MIDI? -- Overnight delivery?
  68. Teensy 4.0 will receive USB power but won't connect to a computer as a USB device
  69. Weird behavior between Serial3 and SD Card Slot on Teensy 3.6
  70. Library question
  71. Volume with PAM8302 and Teensy 3.5 is incredibly quiet. Wiring confusion.
  72. Serial timeout / hangs - MIDI related problem
  73. Teensy LC I2C communication issues
  74. PlatformIO, how to compile for Teensy 4.0 with beta core
  75. Using Different Connector with USB Serial
  76. Trying to make small , simple debounce code to handle 2 buttons.
  77. TeensyLC Fried by 5V Tx/Rx from Serial communication with UNO??
  78. Teensy 3.6 Joystick USB_desc.c
  79. Teensy 3.2 freezing while printing to Serial
  80. Trying to light a single Neopixel
  81. static discharge confusing 1602 display, precautions?
  82. Teensy 3.2 Schematic Questions
  83. [Teensy 3.6] How to read data sent by a HidD SetFeature request.
  84. Having a weird issue with two LEDs and some light sensors on a Teensy LC
  85. Inverting midi range with analog read expression pedal
  86. Teensy 4.0 external USB-B connector: board D+ D- pads not connected to microUSB ?
  87. Code generated for Teensy40
  88. Teensy 3.6 cant take enable of L6234 high
  89. can't get attachInterrupt to work on Teensy 4.0
  90. Beginner - I don't understand the pin assignments
  91. Teensy 4.0 vs CNMAT OSC error
  92. Teensy 3.6 + ILI9488
  93. How does "Get Board Info" work?
  94. Which serial port to choose in the Arduino IDE?
  95. Using TMC2130 Stepper Driver Stallguard feature for sensorlesshoming with Teensy 4.0
  96. Non-Blocking WS2812 library still has significant delay
  97. Teensy 4.0 memory allocation
  98. FreqMeasure Library, reading optical rotary encoder for pulse width.
  99. cannot get CopyfromSD working
  100. Pins label
  101. Powering T3.5 with external or USB with muxer
  102. Teensy 4.0 - falling edge interrupt keeps triggering when there is no falling edge
  103. sprintf is not running correctly on my 3.6, Thanks.
  104. T40 with CPU Max >33%=> noise and stuttering
  105. OLED display 128x64 ADA-938 SPI on Teensy4.0 does not work
  106. Prop shield Heading Drift
  107. FreqMeasure.read() What would the reading be at 600 Hz?
  108. Error compiling for board Teensy 4.0 BUT NOT Teensy 3.6
  109. Teensy 4.0 pull-up?
  110. FASTRUN feature on Teensy 4.0
  111. Teensyduino 1.48 corrupting Arduino 1.8.10 under OSX 10.14.6
  112. Teensy 4.0 Can't program when using external power supply
  113. Teensy 3.0 background interrupts / interrupt priority
  114. USB for T4.0
  115. Vusb and the 500ma fuse
  116. Teensy 3.6 DAC basics
  117. Getting heap_size at runtime
  118. teensy
  119. Compiling for Teensy4 with Makefile
  120. Teensy 3.6 Interrupts
  121. Freezing using Serial during a UART ISR on a Teensy LC
  122. Teensy 4.0 Pixel Pipeline Documentation / Code Samples?
  123. IMU.readSensor Is Causing Code To Freeze - MPU9250
  124. Dynamic Clock Speed of Teensy 4.0
  125. After connecting a teensy to a board, I'm unable to program it
  126. FastLED and IntevalTimer not compatible on Teensy 4?
  127. Random Numbers : Teensy 4.0 and Entropy Library
  128. Connecting wireless a TeensyLC with WIN10 computer
  129. Teensy 3.5 & XBee Pro 900HP Communication Issues
  130. Teensy 3.2 bitband?
  131. .Can no longer program on Ubuntu 18.04.3 LTS
  132. Interrupt routine change of state too fast.
  133. Teensy 3.5 and WIZ850 Multicast
  134. Teensy 3.6 PDB register access access causes program to crash
  135. kiCad Footprints
  136. Teensy 4.0 I2C comms with Adafruit MCP4725 DAC board
  137. Teensy 4 Easytransfer won't send chars .
  138. T3.5 Quad I2S Microphones to RecordQueues not working
  139. Multiple problems with Teensy 4.0
  140. How to use keystrokes in serial-mode
  141. Clock speed for PDB: Tested on Teensy 3.2 and 3.5
  142. How to improve frequency sampling in Teensy 3.5 for saving data with SD card?
  143. Precision of arithmetic in C (Teensy 4.0 double vs. float)
  144. T 3.2 windows 7 driver ?
  145. Can the Teensy 3.2 or 4.0 use larger flash Winbond chips? (W25N01GVZEIG TR)
  146. One of six Teensy 4.0s failed
  147. I2C error 4 for Wire.endTransmission(true)
  148. SPI conflict: MAX31855 and microSD card on Teensy 3.2
  149. Having problems getting started with Teensy 4.0 and Arduino IDE...
  150. Timing of nop-delayloops on Teensy4.0
  151. Teensy 4.0: SD card problems/errors
  152. Teensy Type Reporting in BCD_DEVICE
  153. Qt and teensy 3.x
  154. Does FreqMeasure ou FreqMeasureMult library work with Teensy 4.x?
  155. Teensy 3.2 stuck in bootloader
  156. Issue using PWM output on Teensy 4
  157. Teensy 4.0 & ILI9341_t3n
  158. Reading from and writing to the GPTx_SR register takes incredibly long
  159. Weird program restart, and then Serial doesn't output until button or power cycle
  160. Issue accessing class properly in AudioSynthWaveform array
  161. RTC & time library for Teensy 4.0
  162. LiquidCrystal lib
  163. Reproducible Freeze: WS2812Serial freezes teensy 4 when printing serial
  164. SMBus with i2c_t3?
  165. Teensy 4.0 TimerOne Issues
  166. Relay buzzing under load, Don't know why
  167. MCP23017 and Teensy 3.6 button sketch not working
  168. Teensy 3.2 Compiled With 2Mhz
  169. How to read the output from a preprogramed teensy??
  170. SPI0 and SPI1/2
  171. Do any of the audio library synths work with teensy LC
  172. octoWS inside a class won't work
  173. Link data from one struct to the other
  174. "Multiple libraries were found" after fresh install of Arduino
  175. Teensyduino 1.49 installer crashing
  176. Teensy 3.5 & BMP280
  177. Will Teensy 4.0 work with MSC Bascom software?
  178. OctoWS vs WS2812Serial vs FastLED
  179. Trying to connect multiple thermocouplle boards to one teensy 3.6
  180. Voltage drop on output pin to 3.217 V
  181. CAN issue with FlexCAN on Teensy 3.5
  182. Teensy 3.1/3.2 USB MIDI: huge latency on receiver side
  183. Teensy++ 2.0 and servo() and pwm and timer1 and timer3 and tone() error problem
  184. Faster way to do if() compares in ISR?
  185. Teensy 4.0 compiler needs 30 minutes for 40000 statements
  186. Time delay betwene pin_mode() changes necessary?
  187. T4: Software reset?
  188. Teensy 4.0 DMA SPI Speed issues
  189. change control board
  190. Where can I find the .json file for Arduino pluggable discovery feature?
  191. Mysterious interrupts on Teensy 4.0
  192. Teensy 4.0 accuracy of 24MHz clock
  193. Weird behavior of SerialMonitor
  194. Using FlexPWM on Teensy 4.0 for Interleaved PWM Signals with deadtime in between...
  195. teensy 4.0 and pn532.
  196. Encoder library with cheap encoders.
  197. Teensy 4.0 not compiling Teensy 3.2 code
  198. Teensy 3.6 requires 3 reprogram events to work properly
  199. T4 Low Power or sleep modes - again, sort of...
  200. I2C units used with TENSY 4.0
  201. Teensy 3.2 with BLE HM-10 using serial RX as an interrupt
  202. Change baud rate: end(); begin(); also needs clear()
  203. Teensy LC - Is it possible to save to permanent Memory?
  204. OctoWS2811 Issues
  205. Quad USB Output
  206. Audio Shield w Teensy 3.6 only produced a click on init
  207. problems with set_arm_clock() on Teensy 4.0
  208. Wavetable artifacts, noise
  209. IntervalTimer on Teensy 4.0 versus 3.6
  210. Updating the IDE and Teensy support
  211. Teensy 4.0 -> OPEN-SMART 3.0 TFT Parallel IF Driver IC: R61509V
  212. Teensy 4.0 w/ Audio Shield and SSD1306 SPI
  213. version check for teensyduino and teensy.cores
  214. Can Keil uVision5 program Teensy 4.0?
  215. How to find implementation details on Teensy 4.0 Libraries?
  216. Problem with USB serial on Teensy 3.6
  217. Cannot compile a simple example with "attachInterrupt" if optimizations are disabled
  218. Concern about Teensy's regulator current draw
  219. Multiplexer Produces strange values with a teensy project
  220. SPI Slave Mode on Teensy 4?
  221. I want to know the mounted parts to repair Teensy
  222. installing Teensyduino in Linux [solved]
  223. FlexIO in Teensy 4.0
  224. printf error at 24 MHz with teensy4.0
  225. Using a teensy3.2 to program a silabs quadcopter esc through BLheli interface
  226. Gaming mice make Wireless
  227. Maximum interrupt speed on Teensy 4
  228. FFC 8 pin, HFW8R-1STE1LF (teensy 4 bottom SD connector) obsolete.
  229. Porting LXTeensy3DMX_Library to Teensy 4.0
  230. strange issue with "'Keyboard' was not declared in this scope" error.
  231. Teensy Audio Not Working on OSX 10.15
  232. Teensy 3.6 SPI0/SPI1 Not Working with Similar Code
  233. Motion Sensor Calibration Tool Parameter Understanding
  234. Board not detected by computer after first upload
  235. using micros() for execution time measurment, can it get "out of order executed"
  236. Hadrware speech recognition
  237. FreqMeasure refuses to compile
  238. teensy and sublime text 3 help
  239. now I start a teensy project, help to get started and recursive
  240. Teensy 3.6 only loading the sketch when connected to a computer with arduino studio
  241. Teensy 4.0 no longer found
  242. Unable to wake Teensy LC using Snooze
  243. Simple Audio example does not compile / Teensy4.0 / Arduino
  244. Pin extensions needed, arduino to teensy
  245. T4 3.3V rail short to GND
  246. Teensy 4.0 Main Clock Speed...
  247. Blynk Support for Teensy 4.0
  248. USB Type: Keyboards vs. Serial? What does it do?
  249. Solved: ADCs on Teensy 4.0 are way too fast?!
  250. Can you explain the runtime of this simple Teensy4 loop?
