View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50
  1. Teensy 4 ADC pins
  2. Serial Print Not Working After Snooze deepSleep
  3. Help with VUSB and VIN
  4. Sqlite on Teensy 4.0
  5. Flash firmware via UART?
  6. Need help for my ILI9341 project, need font char byte for byte
  7. Teensy 4.0 USB Host Issues
  8. Encoder and interrupts
  9. Is "split" a valid command for a string?
  10. Teensy 4.0 GPIO Output Current Limit?
  11. Interesting loop timing on Teensy 4.0
  12. "error sending reboot command (HID)"
  13. Change interrupt priority Teensy 4.0
  14. Problem using Teensy 4.0 with 2.42" Oled and u8g2 or Adafruit Library
  15. How to convert SPI DAC into -+5V
  16. teensy4 no response
  17. TeensyStep - Fallen at the first hurdle!
  18. Looking for Teensyduino installer for Arduino 1.6.9
  19. teensy 2.0++ set low usb speed ¿Impossible?
  20. iConnectivity USB host - TeensyMidi issue
  21. testing data- and instruction-cache on the Teensy 4.0
  22. Teensy 4.0 no support for keyboard_leds
  23. Snooze.h not working with Arduino 1.8.11 and Teensyduino 1.50
  24. Linker problem with Teensy makefile
  25. BH1750 Light Sensor and Teensy 3.2 compatible?
  26. w550 + Teensy LC Max speed
  27. Pushbutton Gets State-Stuck Only With Computer USB
  28. Using Wire1 for multiple I2C on Teensy 3.2?
  29. Teensy 4 not supported by ADC examples
  30. Teensy++ 2.0 jump to bootloader not working
  31. HID Keyboard Device has no Power Management Option
  32. Is this how you do port manipulation?
  33. Disable instruction cache on Teensy 4.0
  34. Trouble with an Opto-Coupler...
  35. I2C questions Teensy 4.0
  36. DAC failure on Teensy 3.2 and Prop Shield LC ? Or something?
  37. Again: USB MIDI compatiblity with iConnectivity Devices
  38. Teensy 4 and PropShield
  39. Teensy 4 in TS-1 TEENSY- Synth
  40. Serial speed in Windows 10x slower than Linux (Teensy 4.0)
  41. T4 Hardware Serial Voltage Questions
  42. teensy 3.2 vs. 4.0 IntervalTimer
  43. alternative to attachInterrupt() on Teensy 3.6
  44. Teensy 4.0 with OctoWS2811
  45. Attempting to connect an AliExpress 1306 OLED to Teensy 4: insta-death :(
  46. Teensy LC and 3.1 slow usb serial reads
  47. Are SPI3 and SPI4 accessible? Can both MOSI & MISO be used to x-mit simultaneously?
  48. Teensy 3.6 extremely slow serial
  49. How to effectively read speed from incoming pulses
  50. memory area that I should not access(tennsy4.0)
  51. Multiplexing rotary encoders or using port expander. What will work with the library?
  52. T4 killing board
  53. TeensyThreads - restart "ENDED" thread?
  54. how to define separate Wire for 2 SSD1306 OLED Display on Teensy 4.0
  55. Help with broken USB connection - Teensy 3.2
  56. Teensy 4.0 I2S slave problem
  57. Does the Teensy 3.2 gets from the computer the 250mA is it said to provide?
  58. Teensy 4.0 Theoretical Max Clock Speed
  59. Values get cut short from esp8266 Huzzah to Teensy 3.6
  60. connecting pots to Teensy 4.0
  61. Teensy 4 IP Bus Clock
  62. Anyone have experience using the LPSPIx_CFGR0 CIRFIFO bit?
  63. Comparison Teensy 3.2, 3.6, 4.0 DAC Pins where? and ADC sampling rate
  64. MTP responder on Teensy USB2
  65. Is it possible to use FreqMeasure with pins other than the one specified?
  66. Multiple PS4 connected to single dongle
  67. Is it possible to have a high resolution FFT.
  68. Teensy 3.5 question.
  69. Wire library BUFFER_LENGTH. I need a way to change it.
  70. Teensy clock speed not saved on per-sketch basis
  71. Detecting USB modes, specifically joystick
  72. Teensy 4.0 SD footprint
  73. Size of USB RX and TX EndPoints in Teensy 3.2
  74. Teensy 2.0, 3.3V Regulator, and CPU Frequency
  75. Where to find interrupt numbers for Teensy 4? Specifically SPI Frame Complete Int.
  76. How to setup externally triggered DMA transfer from ADC to RAM (T3.5/T4)
  77. Teensy 4.0, use of 2 different i2c bus
  78. T3.6 Analog controlled samplin.
  79. Multiple MCP4922, but the last is clipping the value.
  80. FTM MOD register update on Teensy 3
  81. Teeny 3.5 and nanopb
  82. Teensy 4.0 + RA8875
  83. Power and connection problems teensy to uno serial connection
  84. USB Raw HID
  85. I2C issues with port expander
  86. Issues with compile failure: twi.h: No such file or directory
  87. Level shifter needed for USB input/host port?
  88. Teensy 3.2 USB ID Pin 4 functionality question.
  89. Teensy RawHID appears twice in Windows 10 Device Manager
  90. Flush initial zeros out of Analog Buffer DMA?
  91. Connecting 100K Trim pot to Teensy 3.6
  92. Teensy3.6 + MPU6050 + Wire1 problem
  93. Help understanding odd USB-Serial test results (Teensy 4.0)
  94. Teensy 4.0 and multi-SPI support question
  95. MIDI and Sleep/Wake
  96. FTM Interrupt Service Routine Runs Once
  97. HELP Teensy v4.0 - SE Blank RT Family
  98. Teensuino and can bus transmitting
  99. Not fully receiving CanBus data on Teensy 3.6
  100. DTR Off blocks USB serial receive
  101. Teensy 3.6 + UTFT (latest Versio 283)+ ILI9341 (16bit): Can't compile
  102. Unable to bit-bang SoftwareSerial MIDI DIN pins
  103. USB VID and PID numbers
  104. Teensy 3.6+Arduino ide software+OBD II
  105. Midi Overshoot???
  106. Teensy 3.2 Linux Mint USB Serial connection issues with fix
  107. EE question about crosstalk in wiring to Analog pins
  108. Teensyduino: Add data_lost = Serial.reset(flags)?
  109. Teensy 3.6 differencial max input voltages
  110. Using Teensy+arduino ide software and obdII
  111. Teensy 3.6 and TLC5973 library
  112. Windows 10 midi device naming problem
  113. The Bitshift << drives me crazy, please HELP
  114. Audioshield stuttering playback
  115. AudioOutput I2S does not work with Wire.h
  116. WAV not working on Audio Adaptor Board
  117. Ws2811 pixels occasional flashing when white - even when brightness turned right down
  118. Do ADC and DMA interrupts block each other?
  119. Teensy 3.2 using internal RTC adding crystal
  120. Firing multiple functions with a fixed interval between them - non blocking?
  121. Teensyduino (Arduino 1.8.11) crashing a lot in MacOS Catalina 10.15.2
  122. Code for open gamma spectrometer works on teensy 3.6, fails on teensy 4
  123. Teensy 4.0 - I2C Lcd - Character Corruption with LCDMenuLib2
  124. EEPROM.write blocking main code
  125. Teensy 4 - diagnosing unintentional reset
  126. UART0 RXEDGIE and Serial1 library
  127. Sending analog value as two bytes from teensy 3.6 to HUZZAH over serial
  128. Unable to use the full range of potentiometer
  129. Teensy 3.5 RoHS compliance
  130. Make error 'CORE_PIN0_PORTSET' was not declared in this scope
  131. Teensy 4.0 + Rev C Audio Shield + headphones = no audio
  132. Teensy 4.0 GPIO Output options: drive,speed,slewrate
  133. ADC calibration on Teensy 4.0
  134. Using MicroSD Breakout with Teensy 4.0
  135. Trigger ISR via Software
  136. Debugging encoders on MCP23017 with Teensy 3.6
  137. ArduinioSTL fails to compile
  138. Clock generation unit on Teensy 4.0
  139. Empty placeholders in output of arduino-builder
  140. T3.2 with Capacitive Touch Problem
  141. ADC async clock generation Teensy 4.0
  142. Teensy 4.0 on MacOS
  143. Teensy 4.0 and C++
  144. How to flush cache on T4 (for DMAMEM)?
  145. Library priorities in arduino-builder
  146. 3.3V Line Help
  147. PINA not declared in this scope
  148. IntervalTimer faster than 2us on Teensy 4.0
  149. Serial communication via USB only after Arduino's Serial Monitor was opened?
  150. OCOTP_ANA1 register does not exist?
  151. Unable to compile Mozzi example for Teensy 3.2
  152. Usisng Two sensos on the Teensy 3.6 with Two TX and Rx Pins
  153. Downloading big log files from T3.5 SD to PC (serial)
  154. Teeny 3.6 off battery power peak and Sleep Current Draw
  155. Pins teensy 3.6 to Audio board Rev B
  156. reading analog pins 15 to 20 on Teensy 3.2 / Firmata
  157. Isolate USB on Teensy 4.0?
  158. Current supply limits for 3.3V for Teensy 4?
  159. Need help reading nand chip with teensy
  160. Teensy 3 multi touch report descriptor
  161. Teensy 4.0 Internal Temperature measurement
  162. teensy 4.0 XBAR questions
  163. Teensy 4.0, accesing 24 to 33 pines
  164. Teensy 2.0 and LC Not Writing to USB Serial
  165. Teensy 4.x
  166. Teensy 4.0 and step stipcks hookup.
  167. Teensy 4, Set interrupt priority on given pins
  168. Connecting 2 teensy 4.0 with audio signals
  169. Read Endless Potentiometer
  170. FreqMeasure Teensy 3.2 Library question - measuring Freq and PWM (or low time)
  171. USBHost Midi transmit assistance please
  172. FreqMeasureMulti questions about types of input
  173. Teensy_CLI: Can't seem to get Vscode to use breakpoints.
  174. FreqMeasureMulti on the T4
  175. Arnet NeoPixel SD record
  176. teensy 4 + audio rev d, tutorial issues?
  177. Fast Input Handling
  178. Teensy 3.6 synch issue on I2C bus
  179. unable to install Teensyduino 1.51 onto Arduino IDE 1.8.12
  180. Circuit Vout Parked at 1.6 volts when Analog pin Attached
  181. TFT touchscreen
  182. lineout level gain
  183. Teensy 4 USB speed
  184. White noise while playing two wav files simultaneously
  185. RA8875 sumotoy library, serial terminal, need help
  186. Ic_mkl02z32_qfn16
  187. OLED display scope integration
  188. Access to USB port via backside pins?
  189. "FLEXIO" units and "NanoEdge placer block" on Teensy 4.0
  190. using Teensy Makefile
  191. Excessive minute delay between compile finishing and uploading
  192. Teensy 4.0 bootloader
  193. Teensy 3.2 does not start if Firmware compiled as MIDI and Teensy is powered over USB
  194. Is there a transistor similar to the SN74LV1T125, but the OE (enable) pad is switched
  195. Any known oddities with Teensy 4, SPI1, asserting CS1?
  196. Sensirion SPS30 Sensor and Teensy 3.6
  197. Movie2Serial - > not zigzag but line by line -> 8x8 WS2812 Matrix with
  198. Prop Shield orientation problem
  199. SIMPLE FAT FS example for Teensy 3.6
  200. SPI MOSI pulled low too late on Teensy 4.0
  201. Teensy 4.0 PCB dimensions / drawings
  202. arrays, buffers, ring buffers and pointers...
  203. Question on SPI Transactions
  204. Project fails when Teensy 4.0 and Rev D audio board are stacked.
  205. Temperature measurement using teensy 3.2, max31855k
  206. Do I solder the microphone on the audio shield?
  207. Is Flight Sim Controls, X-Plane 11 and Teensy 4.0 fully supported and operational ?
  208. Milling machine power feed: TeensyStep / AccelStepper issues ...
  209. Reboot Teensy programmatically ...
  210. Teensy 4.0: check for interrupts enabled, readin PRIMASK
  211. Teensy 4.0 SPI.transfer causing program to hang/die when connected to SPI peripherals
  212. How to code for bi-directional pins?
  213. VRREF_X and VSSA pins in Custom Teensy 3.2
  214. Attempting 1 MHz photodiode with Teensy 4
  215. teensy 3.5 usb port replacement..
  216. Testing feasability
  217. Teensy 4.0 — SPI interference without USB Serial Monitor attached
  218. Teensy 4.0 wrong register in cores analog.c ?
  219. Mechanical drawings for Teensy 4.0
  220. Teensy 4.0 hardware / schematic question
  221. CANBus wiring
  222. Teensy 4.0 Suddenly Stops Working?
  223. Questions about Teensy 4.0 HEX file and boot sequence
  224. Radio interference with SPDIF
  225. ADC Teensy 4.0 using pin 0 and 1
  226. Teesny 3.6 - Serial communication via USB is out unless using SD.begin()
  227. Hi Performance Teensy 4.0 Datalogger with condition based logging
  228. possible to power a voltage divider for a analog in by a digital out?
  229. Help with 3.5 Interval Timer and maybe I2C ?
  230. Teensy 4.0 Secure Firmware Updating
  231. Analog Inputs A10 A11 A21 A22
  232. Teensy 4.0 ADC keeper issue
  233. breakout board for audio project
  234. Frequency generator
  235. ignoring incoming value if it's same as previous incoming value. Or LED freaks out!
  236. Difference between computer-generated midi values and keyboard-generated midi values
  237. Source code needed: How to blink a whole port with grace and style ...
  238. Issue receiving LIDAR serial input
  239. Teensy USB Serial not recognized on device manager
  240. Is FlightsimControls working with TeensyControls 1.51?
  241. Teensy 4.0 Ethernet/Artnet Problem
  242. Teensy 3.2 I2C slave data transfer to Arduino Mega master fails
  243. Help me resurrect a T4. Cap value and other details?
  244. Compiler warning with FlightsimControls ...
  245. BLDC combined with display
  246. MQS on the Teensy 4.0
  247. Processing + Teensy 4.0 - Serial, reprogramming issue.
  248. Teensy 3.6 uploads intermittently
  249. First spiread return false read, other are good
  250. Horrific soldering or something in my code?
