- SD card teensy 3.6 SDIO 4 bit transfer mode ?
- Teensy 4 GPIO flag reset
- Arduino IDE crashes after installing teensyduino
- Teensy 4 2nd usb port as DRP
- Check for SD card on t_3.6 or audio-shield
- teensy 4 cap ID
- Setting interrupt priority
- painfully slow SD file copy code / any suggestions?
- I2C woes -
- Teensy 3.6 lost programming
- Ethercat & SPI
- Wave file playback from internal SD card on Teensy 3.5
- Teensy 3.5 I2C tolerance
- Teensy 3.2 won't boot on battery power
- FastCRC on Teensy 4.0 - Change CRC init value?
- Can't upload to Teensy 3.6/4.0 on Debian 10 via Arduino/Platformio
- ADC in AUDIO tool
- Read SD card file values (char string) into an Int array?
- Adafruit TFT ILI9341
- Strange behavior between I2C master and slave
- Huge Latency + Errors when Sending Analog Values using XBees
- Teensy4 startup code weirdness
- DIY Teensy 3.6 MK02 problem
- Dynamically create OctoWS2811 object within in a class's constructor
- Teensy 3.6 random restart issue and random wakeup
- Bricked my Teensy 3.2 on the first try
- Inconsistent readings on T4 A0
- How to store raw wav file to Teensy 3.2+propshield
- Python script to compile and upload code to Teensy
- Teensy 3.5 analog input always returns 65535
- High-speed digital I/O
- Teensy 4.0 USB stream hangs
- Teensy 4.0 w/ TF Mini LIDAR issue
- T3.2: Best/advised way to read bipolar input on A0
- T4 inconsistent pwm width on different pins
- Teensy 4.0 shorted permanently with GND
- Improve ADC Readings Teensy 4
- DIY EEPROM programmer with teensy 3.6
- Help with Teensy hanging SOMETIMES with a MCP23017 connected
- Problems with below 1us IntervalTimer in Teensy 4.0
- ADC library issue: can't find member named setReference
- Teensy Loader on Mac doesn't see my T4
- Teensy LC mono stereo music instrument/piano
- meaning of "with LTO"
- ILI9341_t3 for STM32
- Teensy 3.5 Serial 1 & 2 questions
- Precise Serial Data Output Clock Speed?
- Can enabling the BEE eFUSE cause problems with the Teensy 4?
- Schematics advice/validation
- teensy4 with Makefile built blink example not starting
- Learning Materials for DMA, SPI, and General Hardware Manipulation on Teensy 3.6
- Sending MIDI CC to multiple Channels at once
- Teensy 4.0 External Power
- Teensy 3.2 Pulse Capture.
- Teensy LC USB serial flakiness
- T4 I2C channel 2 not working for me
- Teensy 4.0 : Hardware, software and 3D Mechanical Model questions
- Is writeData16_last during SPI required?
- Reading From the SPI FIFO Registers
- Teensy 4.0 Timer Interrupt
- Teensy 4.0 CAN interfaces
- Teensy3.6 reset ssue while run on battery powered
- Teensy 4.0 SMD Repair - missing capacitor value?
- Multiple SPI-devices configuration
- Teensy 3.5 & wiz820 ethernet UDP speed problem
- Large SPI Transfers on Teensy
- Help with TPM (External clock) on Teensy LC
- TeensyDuino and Notarization
- SD card not being detected or accessible on Teensy 4.0
- Pedvide ADC Library what is "pabdma"?
- Teensy LC Diagnose EEPROM Issue
- Lcd st7063c on teensy 3.2
- No audio from TRS with Teensy 3.2 & Audio Shield after reseating mini usb cable
- Intermitted Static Noise on Teensy 4.0 + Audio Shield in Audio Tutorial
- Configuring Extenal Interrupts (Teensy LC)
- "wfi" on Teensy 4.0 stops millis()
- How to access the internal RTC in a Teensy 4.0?
- Kinetis for Teensy
- Audio input to Teensy while using OctoWS2811 (Nvidia Shield)
- teensy 4 pinout names?
- Teensy 4.0 Makefile. LED not blinking.
- AudioOutputI2S affecting H/W serial transmit?
- Strange works with Teensy 3.2 but not with 3.6
- Hooking into yield()
- Launchpad Mini Mk3 having two Midi interfaces
- T4 w/ST7735 1.44" TFT - Lag time >>>
- where to start to learn programming teensy audio?
- super easy.. but im super new and super dumb... pitch bend and pulse width modulatio
- Teensy2.0++ Progmem>53% corrupting USB functionality
- Unable to compile code, even when necessary libraries are present
- Teensy 4 PIT timers and interrupt requests
- Attaching multiple interrupts on Teensy LC
- How do I get the angle out of the MPU9250?
- Send Midi CC to Ableton Surface Control
- External power supply diode
- uSD get corrupted files while reading with a teensy3.2
- teensy 3.5 USB/programming issues
- T4 and DS18B20 not working?
- Teensy 3.6 jumping into bootloader while running code
- Teensy 3.6 pinMode and DSE and SRE configuration for GPIOs
- Teensy3.2 + MPU9250 i2c issue
- Can't program Teensy 4.0 after Vin trace is cut and supplyng external 3.3v
- The state of SPI Flash support
- Offset related to Accelerometer and Gyroscope
- Teensy 3.5 SD Card error
- Teensy 4.0 external memory
- Pixy2 compile errors using teensyduino
- Teensy 4 synchronize ADC sampling with flexPWM timing
- Creating custom version of the framework-arduinoteensy package
- GSL1680 touch screen problems
- "Detecting libraries used... Error compiling for board Teensy 3.2 / 3.1"
- USB Endpoint 1 on Teensy 4.0
- Teensy 4.0 Typing Problems
- Teensy 4.0 and SPH0645 I2S Microphone
- Hi! Please advise about casting
- debug printing using Serial.printf in pwm.c on Teensy 4
- maximum frequency for timer triggered ADC
- problems with Teensy 4 Serial passthrough after 63 characters
- Teensy 4.0 internal ADC Read precision (using SPI Screen, SDCard and DAC)
- Teensy 4.0 - 1.8V Signaling
- Teensy Power Supply
- Question about Teensy 3.2 PIns and their functions
- mulitple arduino development setups on one pc?
- Teensy 4.0 Inconsistent SDIO SD read times
- Simple Piezo, wav and Teensy 4.0
- rotary encoder : hardware debouncing
- Setting up Teensy 4.0 and SD Adaptor
- Teensy 4 and 4pin fan -> problems with rpm speed
- Teensy 3.2 SD card PROBLEM
- OLED 128x64 works with LC but not with 3.6
- Issue Interfacing Flow Sensor Using I2C
- Teensy 4.0 CTS pins
- Teensy 3.2 with usb-c
- Teensy 4.0 is unresponsive after soldering headers
- Timer and register definitions
- limit of attachment size?
- Serial Timing Question on TeesyLC
- Different behaviour with 2 teensy 3.6 > DAC 8562
- teensy 4.0 with TSL2591
- Questions about resistance measurement with midi output
- Mysterious behavior/failure using delay() while receiving data over USB
- T_40 USB Host not working
- How's my crystal layout for Teensy 3.2?
- Seria.print() an uint8_t variable
- confused about Teensy Loader
- Teensy 3.6 SPI and SD interference
- Teensy 3.2 board and SBUS Receiver
- Question about a code I didnt understand I2C / SPI
- Program correctly works only after upload or reboot
- Teensy 4.0 and TFT Touchscreen ILI9341
- A Higher Resolution Micros() For The T4.0
- 3m touchsreen emulation
- rotary encoder interrupts and INPUT vs. INPUT_PULLUP pin mode on Teensy 3.2
- USB Host port connection detection
- Teensy 3.2 touchscreen: How to make send more then 8 bytes?
- Usable flash on Teensy-LC
- Issues debouncing a button on an MCP23008 using OneButton library
- what is the best method for access to interrupt variables?
- Teensy 4.0 + WS2812B Adalight/Ambilight issue (Teensy randomly messed up?)
- FPM10A Fingerprint sensor is there a way to detect finger on arduino start
- Teensy 4.0 midi controlled servo DO NOT WORK, Help!
- Teensy 4.0 timer
- teensy 3.5 mpu 6050 I2C
- Same Address I2C configuration on Teensy 4.0
- Unable to delete a file using SD library
- Reading more than one Digital Input at the same time
- Machine Learning for Drones
- Absolute newbie: Correct way to use audio shield?
- Can 3.3 V be safely applied to a Teensy 4 I/O pin while the Teensy 4 power is off?
- how to use "dir(void (*callback)(char *))"?
- Teensyduino 1.51 Upload constantly fails, Ubuntu 18.04, Teensy 3.6, Odroid XU-4
- #define, #ifdef, #elsif, #endif?
- Teensy loader not working on Windows 10
- SPI pull up resistors
- HalfKay does not run upon pushbutton press; verified not USB cable issue
- SD Card on Arbitrary SPI Interface
- Teensy 3.6 I2S slave using Yamaha I2S input is not producing audio
- Teensy 4.0 (+AudioShield) running, but not recognized by Mac any more
- Teensy 4.0 adc0/adc1 swapped... possible bug?????
- Teensy 4.0 MIDI circuit
- advanced interrupts in FreqMeasureMulti library
- FreqCount Library, external gate?
- RA8875 latest drivers and best place to find drivers
- Slow clocking IGPIO-pin on Teensy 4.0
- How to connect Teensy 4.0, HC-05 and MPU9250
- Strange behaviour from Teensy 4.0
- Teensy 3.5 ADC functionality
- Teensy 4.0 and USB Touchscreen example no response on Windows 10
- SPEED and SlewRateEnable(SRE) setting on GPIO pin Teensy4.0
- Teensy 3.1/LC with Waveshare 1.54 inch e-paper display
- Teensy 3.6 Custom - Serial Number
- Implementation of WatchDog Timer on Teensy 4
- Teensy LC seems dead after powering a Pro Mini from its Vin...
- Setting up on Linux advice
- Teensy 4 Serial2 with INPUT_PULLUP
- Teensy 4 Serial2 requires Serial2.flush after each Serial2.print
- DMA - ADC measurement sychronized via FTM -> PDB
- Teensy 3.5 is not recognized by Windows 10
- Teensy 4.0 <-> Raspberry Pi 4 serial communication problems.
- i2c_t3 not working anymore?!?
- pins 24 and 25 Teensy LC
- Can Teensy 4.0 use TDM and also have a separate stereo input?
- Maximum Data Rate still 12 Mbit/sec for the Teensy 4.0?
- Teensy 3.2 Reset Pad fell off...
- TS-1 Synth not working with Teensy V4
- Serial Communication Problems Teensy 4.0
- please help with i2s mems mic into audio library
- Pointers... again
- Teensy 4.0 taking forever to upload from Teensyduino, then crashed OSX
- where are definitions of variable/constants shown in PJRC sample C code
- Is it possible to implement non HID device?
- Adc fluctuations teensy 3.6
- T4.0 Hardware Serial Questions: FIFOs & Buffer Sizes, etc.
- Teensy 4 and ESP32 and WiFiNina
- teensy 3.6 power from usb-hub
- Audio Board locking up all boards on I2C
- Audio Library DAC analogReference(EXTERNAL); not working?
- Wiz820io and Teensy 3.2 with different CS and RESET pins
- turning keypad example into midi controller button matrix
- It seems that sprinf is a blocking function? what to do?
- usb-host and hub question
- Problem operand with float
- Button Not Responsive Teensy 3.1
- C++ streams with ChaN FatFS?
- MIDI loopback test fails with large messages on Teensy 3.2 and 3.6
- Random Reset
- loop execution time with dual-issue disabled Teensy 4.0
- Teensy 4.0 System Tick Rate?
- Teensy 3.5: how to prevent damage or bricking?
- sendNow() for usb-host MIDI
- freeMem() for Teensy 4.0
- Teensy LC not resuming from snooze (slleep)
- bug with piezo and wav file
- Accidentally connected +12V to Teensy 3.2 for several seconds; still seems to work?
- What effect does changing ADC0 Reference have on ADC measurement resolution?
- Return type from AudioProcessorUsage() & AudioProcessorUsageMax() functions
- WAV file stops abruptly with static, and a tone
- usb host message when new client is attached
- Data cache demo on Teensy 4.0
- Teensy 3.6 RTC not continues time in hibernation
- Teensy 4 software reset
- 2 Teensy 3.5, SPI Master/Slave Communication
- expected initializer before '.' token error Teensy 4
- Another Teensy 4 unresponsive after programming thread
- Teensy 3.2 external power source
- Making a mechanical keyboard with teensy problem.
- Is it possible to change the PWM frequency for the analog output pins on a Teensy4?
- Compile Errors teensy 3.2 vs 4.0
- MIDI SysEx hello-world for Arturia Beatstep 1
