View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50
  1. Teensy LC unresponsive
  2. Teensy 4.0: Can I drive an output open drain?
  3. USBHost_t36 failing to claim keyboard for Logitech G502
  4. (teensy 4.0) problem with changing primary i2c pins(18 and 19)
  5. USB HID Not working on some computers
  6. ws2812b + teensy 4.0: LED strip only shows few frames when powered on
  7. T3.6 using VREF and AGND
  8. I2C Slave on T3.6 receiving all messages after first match
  9. T3.6 DMA and DAC
  10. Using a SSD1306 I2C Display with Teensy 3.6
  11. How to connect Teensy 4.0?
  12. use #if __has_include - for something like user_defs.h in Arduino sketch?
  13. AdaFruit Medium 16x32 RGB LED matrix panel
  14. Adafruit Uncanny Eyes project for Teensy 3.1 and 3.2.
  15. Power on reset in Teensy 4.0
  16. How do I software reset the Teensy 3.6?
  17. rosserial compilation error related to PROGMEM or PSTR() for Teensy 4.0 but not 3.1
  18. Use of single pin for serial TX and RX on T4.0
  19. CS Pins expander 74HC154 or MPC23S17 ?
  20. Teensy 3.2 on Mac can't enter program mode
  21. Teensy 4.0 STD Library Compilation Failure
  22. usb host midi sending latency
  23. Making WebUSB Work with the Teensy - What is PluggableUSB?
  24. Teensy 4.0 USB transfers per second
  25. SD works fine on Teensy 4.0 but not SdFat
  26. Stream Data from Serial1 to SD Card, Teensy 3.6
  27. T3.6 MOSFET switch problem
  28. UsbHost, device send messages but does not receive
  29. PWM Interrupt on Teensy 4.0
  30. Teensy 4.0 Serial TX and RX on same pin
  31. New Teensey 4.0 appears DOA
  32. Teensy 4: Build-in SD card on SPI (pins 34-37)
  33. Freqmeasuremulti on T4 don't update readings randomly
  34. Any way to check DMA progress, mid-transfer?
  35. usb host multiple "protocols" via HUB
  36. Changing Crystal frequency with Teensy 3.x
  37. Did I solder on my USB host cable correctly?
  38. Teensy 4.0 and SPI chip select sadness
  39. Firmware Recovery? - Teensy 4.0
  40. TEENSY 4.0 analogWriteFrequency(pin, frequency) PIN TIMERS
  41. Teensy4.0 and _disable_irq in the core code
  42. Where can I find buttons?
  43. wiz610io with Teensy
  44. In need of complete Teensy 4.1 dimensions
  45. No serial port in Arduino
  46. teensy 3.2 and numbers on lcd
  47. T4.1 Schematic
  48. Teensy LC Grounding issue
  49. Teensy 4.0 I2C Slave issue.
  50. Renaming a board in Windows
  51. Teensy 4.1 RTC?
  52. T4.1 ethernet and usb host pin alignments/dimensions
  53. Using DMA to drive PWM signal on Teensy 4.0
  54. FlexCan_T4 to a Unitronics PLC
  55. Teensy 3.6 for scanning Fatar Keyboard - Latency/multiplexers/resistors
  56. Arduino nano 33 BLE One wire with DS18B20
  57. Need help configuring USB descriptor for audio device
  58. Trigger several flashes parallel with optocouplers
  59. Digital Output Pin high Voltage tolerance
  60. Help with Arduino/Teensy 3.2 Joystick
  61. Teensyduino Support for Teensy++ 1.0
  62. Teensy 4.1 and TeensyStep
  63. Soundfontdecoder compatible with Teensy 4.0?
  64. Adafruit ST7789 on Teensy LC SD2Card error with platformio
  65. How to use USB serial? usb_init() not defined
  66. Teensy 4 Not Appearing as USB Device
  67. Teensy 3.6 16bit ADC returning impossible values, please help!
  68. Issues using Xbee Series 3
  69. Read BMI160 senor 6DOF 2 click with Teensy 3.6
  70. Odd problems with serial connection
  71. Arduino IDE 1.8.12 and Audio library trouble - 'FLASHMEM' does not name a type
  72. Wire, I2C & Teensy 4.0
  73. Pulses counting in intervals with teensy 3.2
  74. Teensy 3.2 to 4.0 with a SPI slave throught platformIO
  75. Teensy 3.2 Not Receiving Power From USB
  76. New Teensy 4.1 not recognized by Teensy loader
  77. Will the optimized SD_t3.h work on the T4?
  78. Teensy 4.1 pinout missing details
  79. Teensy and LEDs
  80. Teensy 3.6 Serial Port Not Opening
  81. Teensy 4.0 I2C questions and issues
  82. Question: How do ADC measurements act when Vmeas exceeds Vref?
  83. Got a Teensy 4.1, updated Teensyduino, old working code with ILI9341 DMA broken..
  84. Cardinfo runs OK but any SdFat category fails to init sdcard on T4.1 using TD1.52
  85. T3.2 + Mpu9250/6500 errors, calibration
  86. datasheet for the IC_MKL04Z32_TQFP32 / MKL04
  87. Three wire SPI with Teensy4?
  88. Teensy 4 How to increase speed of my sample readings using both ADCs and 4 Mic inputs
  89. Teensy 4.0 + IRremote Library
  90. Need examples of how to use eventResponder properly
  91. C++ STL on the Teensy 4.0 not possible?
  92. is the LP38691 neccesairy for making a diy teensy?
  93. Teensy 4.0 and ST powerSTEP01 stepper driver problem
  94. Is there a Scematic for T4.1? Missing SMD Part
  95. Teensy 3.2 and 4.0 errors with latest IDE and teensyduino's
  96. SPI2 Pins on Teensy 4.1?
  97. TeensyLC USB Serial works on OSX, but not on Windows
  98. Noise when communicating with SPI device on Teensy 4.0
  99. Teensy 4 dead after I2C error
  100. Trying to Debug Teensy 3.x Joystick Software
  101. Targeting Teensy 4.1 uses 5x as much dynamic memory as Teensy 3.6
  102. Portable external power source for Teensy LC
  103. USB **HID** Shield ?
  104. Full motion video + sound on the T4 + ILI9341. Eliminating tearing with ILI9341_t3n..
  105. Diagnose MIDI DIN In Throughput Issue
  106. Teensy 3.2 SD print issues.
  107. Programming a Blank MK20DX256VLH7 chip
  108. T4.x (maybe other) reduce serialEventX overhead on system (worth it?)
  109. T3.6 RTC setting file Date and time in SD card
  110. 4.1 pins descriptions
  111. FlexPWM DMA Triggers on Teensy 4.0
  112. Need advice on compass parts for Teensy units.
  113. Alternatives to Livid Brain
  114. T4 No SPI Slave, No I2C Slave. how to make multiple Teensys talk with more hardware
  115. Teensy LC-Rotary Encoders
  116. Timer & Interrupt, for delay-width-pulse-generator - Teensy 4.0
  117. Teensyduino 1.52 Install Problem
  118. Dual I2C bus for VL53L0X ToF Sensor Array Management
  119. Teensy LC USB MIDI and Windows 7
  120. Arduino <Wire.h> Now supports Wire1, Wire2 & Wire3?
  121. MKL04Z32 Boot Loader for Teensy 3.2
  122. Color 320x240 TFT Touchscreen
  123. More than one USB Serial possible
  124. Can't open Serial Monitor - Board not available
  125. Using Teensy input pin as VCC\GND pin for sensor devices
  126. Teensy 3.6 running 1.52 issues with resistive touch screen
  127. Teensy 4.1 wiring connection
  128. Teensy 3.6 Midi Buffering
  129. Multiple interval timers with encoders T4
  130. Where is the list of pin names for Teensy4 for digital I/O ?
  131. I2C OLED performance on Teensy 4.0 with different clock speeds
  132. New Teensy 4.1 has [no_device] error on MacOS 10.14.6; Teensy 3.6 and 4.0 all work
  133. key matrix 56 keys, no diodes on teensy 4.0
  134. How to use digital outs as a square wave generators?
  135. Serial.printf("String without a terminating linefeed"); Doesn't Display on Monitor
  136. Teensy 3.2 Crystal Oscillator Question
  137. Recieving serial data from iPhone headphone jack
  138. teensy 3.2 no boards found
  139. Drone RC Tx code for Teensy?
  140. Need help with ST7735_t3 library and bmpDraw function! Images are not loading right!
  141. Teensy 4 IntervallTimer interrupts Serial2Event not working
  142. touchRead Sensitivity to Noise and solutions with Teensy 3.6
  143. Dud 3.6, what's the policy of defective parts?
  144. no usb roles on LC after upgrade to 1.52
  145. SPI.transfer hangs in Teensy 4.0 but works good in Teensy 3.2
  146. Teensy 4.1 Cannot access Internal SD card
  147. Teensy 4.0 to communicate with a cloud IoT service at https://thinger.io/
  148. Serial Input Not As Expecting
  149. changing to MIDI mixed messages rather than arrays. ?Method?
  150. Recruiting
  151. Display refresh Latency
  152. Does the input have already a Schmitt-Trigger?
  153. Simple Keyboard + pushbutton question
  154. Firmware update without button...
  155. Teensy 4.1 with Sunfounder LCD
  156. Teensy 4.0 GPIO Manipulation -- Code Help
  157. PropShield Compatibility
  158. Multiple Instances of USB HID om My Mac
  159. Mac OS X 10.14.2 Problem Installing Teensyduino 1.52
  160. Pulling pin immediately low.
  161. Teensy 4 USB Midi not working - is it dead?
  162. Teensy3.6 keep rebooting when opening Serial Monitor (with reprex)
  163. undefined reference to systick_isr - ros-teensy, CMake compile
  164. Crackling/Clicking noise when note is pressed down (Teensy 4 polyphonic synthesizer).
  165. How to do coding for Ethernet communication in Teensy 4.1
  166. Documentation for HardwareSerial::addStorageForRead()
  167. Teensy 3.5: how to use SPI pins and built in SD card at the same time?
  168. Teensy 4.1 and Encoder library
  169. Teensy 4.0 & teensy4_i2c library - error compiling
  170. Teensy 4.1 USB Host pinout
  171. Teensy 4.0 RTC
  172. Has the Teensy 4.x been tested with USB Hubs? (ERR050101)
  173. USBHost_t36 HUB issue on power up with T4.x connected.
  174. Killed my First Teensy 4.0
  175. Question about Teensy 4.1 memory pads
  176. Glitchy SCK Output when using DMA and SPI
  177. interrupts missing at high rate ( 500k Interrupts/sec ) on Teensy 4.0
  178. Advice on connecting multiple analog inputs to multiple Teensy4s via I2C
  179. error: impossible constraint when compiling audio library for Teensy 4.1
  180. Unable to use full range of slide pot (MIDI)
  181. Audio Adaptor and T3.5 pin 6
  182. Teensy 4.0: assign large chunk of data in RAM
  183. Servo Motor Won't Activate - Can You Help? Animatronics
  184. Teensy 4.0 Secure Firmware
  185. How accurate is elapsedMillis?
  186. DMA SPI Transfer on Teensy 4.0 using KurtE's SPIDMA T4 branch
  187. Trying to use a struct to simplify a function, please help
  188. Tap tempo issue
  189. NRF24L01 + Teensy Potential power issue?
  190. Teensy 4.0 DOA?
  191. Teensy 4.0 current sink/source maximum rating for digital pins
  192. Compile error with noInterrupts() and interrupts()
  193. Interval Timer Library used with tone function
  194. Teensy 4.1 and YM2612
  195. Teensy 4 + ESP8266 over I2C not working
  196. SPI in Registers on Teensy 4.0
  197. Random MIDI messages on serial TX
  198. compilation issues - teensy 4, cmake, startup.c
  199. TyCommander Serial Window. Previous 'send' input gets added to new input
  200. Adafruit IMU not recognized on Wire2
  201. MacOS version of teensyloader disconnecting regularly
  202. Teensy++ 2.0 detached as two HID
  203. KB / Mouse echo
  204. Teensy 3.6 - Multiple SPI DACs
  205. Snooze 6.3.8: Compile error on sleep_usb_serial
  206. Teensy 4.1 and SPI1
  207. Any way to disable I2S MCLK output on T3x and T4x?
  208. My teensy freezes running this code 90% of the time now... Any ideas?
  209. four OLED displays with 2 i2c ports and u8g2lib
  210. Multi EMF Sensors - Problems
  211. Teensy 2 maximum input voltage
  212. It won't compile to a Teensy 3.5
  213. Teensy4.0 and the DRV8825 board
  214. Serial monitor output unexpectedly stops
  215. Teensy 4.0 Mysterious Power-Up Behavior
  216. Teensy 4.1 Pinout
  217. Stacking audio board and Teensy
  218. Teensy 3.2 DIY board bringup - USB not working
  219. Teensy 4.1 ethernet header position mesurements for custom footprint
  220. Sleeping to disable C_DEBUGEN
  221. Triggering ADC with PDB in Teensy 3.6
  222. Updating FTM CnV and C(n+1)V registers in Teensy 3.6
  223. Trying to get rid of Delay in a for loop. Weird consequences :
  224. TeensyDMX and FastLED - cant get them to work simultaneously
  225. xpt2046 touchscreen and teensy 4.0
  226. reuse of unused RX pins
  227. Serial Port teensy Identification/Recognize
  228. Teensy 3.2 Clockspeed Question
  229. smartphone + google + hardware
  230. TEENSY 4.0 Configure Pinning for different use cases
  231. #define to differentiate between Teensy 4.0 and 4.1
  232. Question on the correct usage of the SD Card on Teensy 4.1
  233. Bluetooth communication between Teensy 3.2 and Arduino Uno
  234. OctoWS2811 LED Library questions
  235. For I2C experts
  236. Teensy 4.1 extra pins
  237. Arduino 1.8.12 Refuses to Open
  238. Cheack pin state
  239. Output processed data fast
  240. library botch-iness (newest Adafruit_GFX doesn't work)
  241. altSoftSerial for Teensy 4.0 - Cannot compile
  242. problems in ubuntu
  243. Teensy 4 dynamic memory space
  244. CPU cycles and data extraction
  245. Weird Teensy SPI problem
  246. I need electronics help. #hx711 #teensy3.2 #logic levels #noise #scopePics
  247. External USB for Data / Power
  248. Is a decoupling capacitor necessary for 5v in on the Teensy 4.0?
  249. Killed my first Teensy! Now, why...
  250. timing problem (midi note On/Off)
