- FTP client to SD card
- T40 Synth ok with Loader 1.49 but 1.52 has distortion.
- MIMRT1062 Serial Downloader
- BNO080 IMU code on teensy 3.6
- Teensy 4.0 Host Hardware Setup to send/receive serial data
- Install problems with Teensyduino 1.52 on Arduino 1.8.12 (Windows Store 1.8.33.0)
- Is it possible to boot from SD Card?
- Teensy 3.5 won't enter program mode
- IMU teensy 3.6
- Teensy 4.x using a Hall Effect Encoder
- Teensy LC. Trying to change the VID/PID and name.
- Teensy 4.0 + SD-Modul not working
- Prop shield, EMI, EMF, noise, PSRR
- Teensy 4.1 ADC.h will not compile
- Can someone help me understand direct port access?
- Teensy 4.0 randomly reset by itself
- Teensy 4.0 ADC SYNCH and 4 channels combined with DMA
- Teensy 3.5 driver issues after windows 10 update
- access to usb pins on teensy 4.1
- Problem with ILI9341 and UART1 on Teensy 3.2
- Teensy ADC resolution
- FreqCount() not working as I expected
- CAN bus write
- Teensy 4.1 flash/psram usage
- Teensy 4.1 NON default SPI pins possible?
- Teensy Audio library block limits
- Teensy 4.1 dying
- Any way to make USB serial monitor non-blocking?
- Teensy 4.1 Pinout from BETA -> Production
- Adafruit_CharacterOLED compilation failure
- Program "curves" for realtime use.
- Can we drive several LED strips indepently attached to a single Teensy 3.x board ?
- Teensy 2++ LED flickers
- Serial communication between instrument and PC through teensy 3.6
- Teensy 2.0 Mystery Vcc Voltage?
- Teensy LC analog pins crosstalk
- T4 SPI port register - how to reset it?
- Teensy boards servicing Manuals(or sheets)
- Pin 13 Problem on Teensy 4.1
- Knob encoder velocity multiplier qestion
- High-Impedance on Boot Triggering Misc outputs
- Teensy4 QuadTimer as 64-bit counter
- Serial.read() not working when printing
- Teensy 4.0, problem with the presentation of 2 pictures
- Teensy 3.2 with external MCP2515/Tranceiver
- Teensy 4.1 E2END value for maximum emulated EEPROM
- Teensy 4.0 serial buffer
- New release for Encoder library?
- Simple Raspberry Pi 4 to Teensy 3.2 Communication
- Teensy 4.1 Working ethernet library for Arduino-IDE
- Teensy 4.1 to MagJack wiring schematic (wanted)
- Teensey++2 - Joystick buttonss - repeating or not working
- Serial5 on teensy 4.0
- Missing the kinetics.h from Teensy 4.0/4.1
- motion sensor
- Serial Comm over USB Teensy 4.1
- Teensy LC on TX2 shows as HIDRAW2 after pressing reset switch
- SD Initialization Failed
- Teensy4 QuadTimer4 losing counts while 1-3 work fine
- 2 MHz PWM of an LED
- Uploading sketches fail to Teensy 4.1
- get objdump.exet show ONLY the code in my sketch and not everythig else?
- Howto analogRead accumulator voltage on Teensy 4.1 w. Teensy Feather Adapter
- Teensy 4.0 crashing or stuck in loop if using SPI1 on lower clock speed.
- Where does STDOUT print to?
- lfo pmw out
- Teensy 3.6: interrupt configured for falling edges fires on both edges
- Bluetooth support for Teensy 4.1, hardware and software
- Teensy 4.0 USB Upload Problems or more
- CPU speed, Wiichuk and Teensy 4.0
- Does SoftwareSerial work on Teensy 4.1?
- USB serial dropping data on Teensy 3.2
- Teensy 4: Global vs local variables speed of execution
- Teensy2.0 and Teensy2.0++
- Teensy 4.0 strange "resets/reboots" driving a Pololu DRV8825
- I think i destroyed my Teensy 4.0
- Odd digitalread problem
- Teensy LC help needed, capturing multiple signals with interrupts.
- Ferrite 600 and noisy MUXs on T4.1
- Sd-FAT beta library official release for Teensy 4.1
- Mouse control with arcade stick and Teensy LC
- Confusing input read issue with Teensy 3.2
- Help! WS2812Serial + FastLED on Teensy 4.0
- Arduino IDE not working after loading teensyduino
- Issues Linking Eigen lib
- .cpp files not working as I expect
- Upgrading from the 3.6 to 4.1 Power issues
- Weird TFT display like nextion but I2c (Think I bought a unicorn)
- How to reset Teensy4.0 timers for phase syncing PWM signals
- MicroE-506 with AudioControlWM8731master Problem
- USB MIDI confusion
- Teensy 4: Trouble with claiming USB Raw HID
- Teensy 4.1: Storing the value of 18 pins' input quickly
- Monitoring battery voltage with LC
- life expectancy of 3.6
- T4.1 will compile on one computer not a different one
- Teensy 4.1 FastLed Tone() issue
- Maximum current per pin with different applications
- Using one Teensy 3.5 to send signal to three others
- CAN msg buffer mask
- Sysex with Launchpad MK2 and usbhost_t36
- CAN bus transmit speed for 3.2 teensy
- Teensy 4.1 USB Host with external power
- LTC2335-16 CNV input
- adjustTime(number) problem when adding seconds
- teensy_loader_cli with multiple devices connected
- Trying to organize 4 serial commands in 10 mS with machine State, but....
- "Vin" pin too close to confort
- Teensy 4.1: Access built-in SD Card with SPI (NOT SDIO)
- Teensy 3.2 recognized but not uploading
- Teensy 4.0 removed unused usb ports
- USB descriptor for Joystick + Serial causing issue when uploading code
- Snooze library: Teensy 3.6 wakes up after few minutes without signals on input pin
- MQTT/TCP connection stability problem on Teensy 4.1 with W5500
- Way to differentiate between T4.0 and T4.1 ?
- Teensy 3.x Timers issue when trying to compile code using a NodeMCU.
- Data lost on Serial1 with Onewire?
- No USB serial with Teensy 4.x compiled Optimize: Debug
- RTC Registers and Millisecond Precision from Teensy 4.0?
- Sensor (ADXL345 3 axis accelerometer) acting different when combined with Teensy 4.0
- Teensy 4.1 5v pin tolerance question
- Mixing 4 hall sensors with ppm channels to PPM output
- Loader crashes, Monitor closed, Linux
- SPI pins teensy 4.1
- Teensy 4.1 with audio shield questions
- Teensy 4 - Master i2c, DMA possible?
- Teensy Loader 1.53 does not recognise the Teensy 3.2 board
- Teensy 3.6 interrupt on Analog pins
- Want to buy Teensy 4.1 in quantity.
- What would cause code to execute perfectly with wire.h, but malfunction with i2c_t3.h
- teensy 3.2 scl speed
- Controlling Multiple Servos with Teensy 3.6
- correct way yo hook up crystal
- Teensy LC EEPROM overwrites memory on power cycle?
- SQPI on Teensy 4.1
- Teensy 4.1: I think I made a mistake on my carrier board
- Possible to use Teensy 4.0 as just Serial and Audio?
- Teensy 4.1 Ethernet Kit - Available Pre-assembled?
- PFC Precision Flight Controls help on calibration
- Teensy 4.1 MQTT
- Maximum Teensy 3.6 RTC value
- Upload problem with Teensyduino and platformIO
- Issues with unique_ptr
- Teensy 2.0++ matrix keypad library written in C?
- Teensy 4.1 -- Serial.readStringUntil problem
- SPI CN0391 question reflection on the MOSI, MISO line=?
- uSD corrupted on Teensy 3.6
- Teensy 4.1 Teensduino SPI.setSCK(27) does not reassign the clock pin?
- description of pins wrong?
- Dead Teensy 3.2
- Teensy 3.2 - Sd card reader partition error
- 3 UM7s and 2 FSRs sending data to a microSD at high rates
- TEENSY 4.0 reading wrong data on GY-521 MPU6050 Breakout Board
- making teensy show up as mouse only
- Teensyduino USB Serial: Power Consumption Issue
- Teensy 2.0 button matrix and windows joystick controller
- MPU6050 IMU code works with Arduino but not TEENSY 4.0
- Sub-microsecond delay on Teensy 4
- Teensy 4.1 Fast PWM Library?
- Ethernet lwip Boards.txt hack? where is it documented?
- Teensy 4.1 unknown pin/pads question?
- Grayhill 63R128 and teensy connection
- Does T4.0 have PORTS - like read 8 pins at once?
- Is my I2C dead? How best to troubleshoot?
- Need to confirm PWM math and syntax
- Weird crashes on dynamic memory assignments?
- Need table of Teensy4 interrupt mask names
- Compiled for Teensy 4.0 (IMXRT1062), This board is: Teensy 4.1 (IMXRT1062)
- .ARM.exidx section question
- Teensy4 PWM frequency modulation and overhead questions
- Teensy 2.0++: Best way to measure code execution time in C?
- Custom Teensyduino HID Type Not Seen by Software
- How do I correct an analog axis bouncing?
- Exposing the HardwareSerial ring buffers?
- Expression pedal
- Signal Problem; game controller with Teensy3.2 and Tekscan Flexiforce Sensor
- Sample code using GPIO?
- Possible error in Teensy Loader for i.MX RT
- How do I remove the Flight Sim C and serial debug USB data from the Joystick program?
- Where is Teensy Loader on my Mac? OS X 10.12
- Teensy 4.1 I2C slave crashing after data request
- Teensy 4.1 Ethernet shield was not found
- WebUSB DFU to program teensy 4.x
- swap out ili9341 to ra8875 display
- Teensy 4.1 ethernet "receiver not active" error
- TLC5940 led driver on Teensy 4.0
- Teensy 3.2 dma dac normalizing output for varying frequencies
- Interfacing DAC1220 20 bit DAC with Teensy 3.5
- FreqMeasureMulti speed issue?
- Solid State Relay not working w/ Teensy
- Teensy 4.1 CLI linux flashing
- which part of this switch/case function determines each cases run-length?
- No sound when reading SD files with Audio Board and Teensy 3.2
- Choose speed in USBHost_t36 library
- Teensy4 PWM interrupt config
- multiple dallastemperature bus question
- Teensy4.1 fusemap confusion... my MAC entries appear to be programmed already...
- Teensy 3.5 USB Serial to Linux Debian 4.19 x86_64
- Different SPI Behavior on Teensy 4.0 and 4.1
- Glitch when Playing Audio from SD card in Teensy 3.2
- BuyDisplay ER-TFTM050A2-3(CTP) 5" capacitive touch ra8875
- Can't find other device with i2c
- Teensy 4.1 as SPI Slave with both MISO and MOSI functioning
- What's the status of Xbee wrt to Teensy4
- Teensy 3.2 HELP! What's this capacitor?
- Thanks for fixing my problem before I reported it!
- Exponential Moving Average - How does it work?
- Audio bridge to Ethernet, is it possible?
- Can I disable pull-up at boot?
- Timing issues with OctoWS2811 and pedvide's ADC/DMA library on Teensy 4.0
- How do I "bake" a file into the firmware
- Burnt IC question
- Oled onPin 24 and 25 Teensy 4.1
- Interactions between Wire1 & Wire2 I2C busses on Teensy 3.5?
- Teensy 4.1 connector drawing
- Changing/setting UART for use with Rosserial
- Teensy 4.1 external flash memory question.
- Double char array
- How many elapsedMicros can you use on the teensy 4?
- Firmware.hex File
- Color 320x240 TFT Touchscreen, ILI9341 Controller Chip - Can colors be changed
- Audio + Teensy 4.1 problem
- Teensy Audio + Ethernet
- Library for Teensy 4.1 PHY?
- Pin Configuration for SSR
- Detect Teensy 4.0 USB serial port
- Teensy 3.6 won't communicate with Raspberri Pi Serial
- Teensy 4.1 PWM on D13 Invalid
- custom board layout for teensy
- Changing analogRead resolution
- Send multiple frames with Flexcan?
- Synchronisation between two Teensy 4.0 / 4.1?
- Problem with parsenumber
- Compile Error Issue While Adding a New Board Type
- Teensy++ 2.0 HID interfaces swapping
- T3.6: How to detect when a new USB device is connected to the host port/hub
- When halfkay (teensy4.1) loads a new program, how much flash does it erase?
- Naming controllers?
- Teensy4 with different analogWriteResolution settings on each pin
- Teensy 3.5 Analog Read - Some queries
- Using Teensyduino or another language like C++
- USB connector part number needed
- Teensy 4.0 Serial.read fails with AudioOutputTDM2
- Question about low level timing
- Teensy 4.1 faulty voltage regulator?
- Rotary encoders for flightsim panel
- Bug in Teensyduino 1.53? ADC examples not working
- The right library for SD Card with Teensy3.5
- interfacing of Teensy 4.0 with mpu9250
