- Simple Keyboard matrix with Teensy 4.1
- Convert uint16 to int16
- Teensy 4.1 - Multiple MCP3208 (SPI) chips
- I2C between Teensy 3.6 and AM4096 encoder: I cannot find the right packet format!
- Teensy 2.0 pinout?
- Teensy 3.2 "Uknown USB Device"
- is it okay to use analgoWrite() in an ISR?
- T4.1 Interrupts(?), analogRead, usbMIDI problems
- Teensy 4.1 external flash memory read on software level.
- Teensy 4 and 4.1 pre-processor defines?
- Teensyduino 1.53 Audio library issues vs 1.51
- Teensy3.5 RTC- Some basic doubt !
- Keyboard modifier (Not hold the CTRL and the SHIFT)
- Rigid-Flex Custom Teensy 3.2 not loading the firmware
- [4.1] Simple SPI problems - wrong value occasionally sent from MOSI
- Strange behaviour with CapSense on Teensy 3.5
- teensy 3.2 unable to reboot
- ferrite bead teensy 3.x
- Encoder loosing counts
- Teensy 3.5 RTC problem
- CV connection without ground?
- Teensy 4.1 + APA102: which pins support Hardware SPI?
- Using "native" development environment with Teensy 4.1
- How does the MLK02 bootloader identify the target chip?
- Unknown USB Device (Link in Compliance Mode)
- How to reduce code size on teensy 2.0
- analogWrite() to pins 16, 17, 20 and 21 on T4
- Teensy 4.1 USB Host Questions
- teensy 3.5 freezes when data logging
- Teensy 3.2 Problem with Powered USB Hub
- 4.1 HW encoder index use
- Teensy3.5 SD Card File creation timestamp error
- Teensy 3.6 not blinking and program reboot button not working
- Why is serial.write() laggy compared to a normal arduino?
- TLC5940 PWM Frequency does not alter on Teensy 3.2
- Teensy 4.1 Ethernet
- Teensy 3.2 not recognized after programming in 16 Mhz mode (accidentally)
- TeensyStep Re-homing question
- Serial port on Teensy4.1
- How to use the HC-05 with teensy 3.2?
- Need reliable 915mhz units compatible with Teensy4
- Errors in T 4.1 with PSRAM and Flash chips
- Midi input circuit accuracy
- Commenting out the keyboard, mouse, and keymedia on a Teensy 2.0
- Dual Display Problem
- EXTMEM memory test program for testing PSRAM in teensy 4.1
- (Noobs) - rising/fallingEdge... bleed from one pin to another?
- ISR routine does not appear to be passing back boolean?
- UDP Communication between two T4.1 and Ethernet Switch
- Redeclaration error from Teensiduino
- How do I install this code?
- Getting 0-5V on teensy 3.6 analog pin with Bi-Directional Logic Voltage Level Convert
- Strange behaviour MAC/PC - Teensy 4.0
- Teensyv3.5, Serial3, write a black diamond with a white question mark
- Which board should I use to read NAND Flash?
- Teensy 4.0 Running Very Warm on Blink Sketch
- Compiling overclocked firmware problems
- New Teensy 4.1 won't be recognized by Bootloader
- One Component on Teensy 4.1 gets very hot
- Teensy 16bit ADC
- Teensyduino installer doesn't allow arbitrary directory selection
- Is there away to enter program via the loop of your running code?
- Beginner question about the lcd
- Using the MKL04 bootloader chip in DIY circuit to program MK20DX256VLH7 (Teensy 3.2)
- Correct way to use same SPI pins with different SPI master and Slave libraries? T3.6
- Questions about usbMIDI...
- audio library fft beyond 1024
- Using a custom usb_desc.h per-project with platformio?
- Upload program using serial port (Teensy 3.2)
- Teensy 4.0 with Nextion 10.1" Intelligent Series - Teensy HWSERIAL Rx Trouble
- Slow Teensy 3.2 12-bit DAC?
- USB device not recognized
- Teensy 4.0 - shorted 3.3v rail?
- Teensy 4.1 USB serial receive may hang for buffers over 2K
- Confused with the recommended circuitry for ADC on teensy.
- Upload to Teensy 4.0 sets RTC*to bad date in 2050
- Teensy v3.5, USB serial, transferring data between PC and teensy: problem in writing.
- Teensy 4.1 VBAT pins
- Looking for suggestions for touchscreen display for T4.0
- Getting a Teensy 4.1 to work ...
- Duppa i2c encoder on Teensy 3.6
- Teensy 4.0 vs 3.2 speed comparison
- Voltage spike when switching pwm duty cycle
- Part ID on 4.1 PCB
- SPI.transfer() Hangs on in the first call using Teensy 4.0 and CC1101
- teensy 4.0 and Ili9341 2.8"
- Problem with ILI9341_t3 library and Teensy 3.6
- USB Joystick with Teensy 3.2: Which voltage for pots?
- Powering from breadboard power supply friend two Teensy LCs :(
- Teensy 4.1 and 2 x MAX31855 thermocouples SPI problem
- Mysterious Crashes with String Functions
- TimLib.h vs. Time.h
- RTC problem with Teensy 4.0
- Something different about Teensy SPI?
- teensy 4.1 tcp socket issue
- Teensy 4.1 extra memory question
- Curved text on RA8875 display
- Timer interrupts > 1MHz ?
- Replace delay() with a custom function
- Is this a valid method to time code execution?
- Sending MIDI clock
- Teensy 4.1 stepper motor library
- Teensy 4.0 Pinout and SD Card/Ethernet Module Compatibility
- Teensy 4.1 IP Address
- Store variable value to recover after reset
- OLED connection to Teensy 3.5, need HELP please!!
- What pad on the backside of Teensy4.1 is the PROG pad?
- Teensy 3.6 custom design resetting itself regularly
- turning a collins Aerospace RMI-36 VOR/compass display into a clock
- Does the Teensy 4.1 handle the PSRAM refresh time?
- Issue with Teensy LC + Pot 10k for Steering Wheel
- second spi channel ?? teensy 4.1
- Teensy 4.0 and 16 bit resolution PWM duty cycle issue
- When did USBmidi.sendPitchBend change from taking 0-16383 to -8192-+8191?
- Spi devices with different clock speeds
- teensy4.1 with W25Q128
- SDK for Teensy 3.5 USB (C#)
- Theensy3.2 I2C getting wront values from slave
- Teensy 4.1 counter example not working
- Help understanding how I killed my teensy 4.0
- Dimensions and pin locations for Teensy 4.1
- Teensy 4.1 ST7789 Uncanny Eyes works great for 20sec then DACCVIOL MMARVALID Crash
- AD7124 understanding registers how to program them in to the Teensy3.6
- Teesny 4.1 FFT for viberation signal genarated by 3-axis accelerometer ADXL337
- Teensy 4.1 PSRAM Random Access Latency
- 5v power on USB and 5v PIN
- No terminal in ubuntu
- HELP! Adding a new subroutine to my program causes other subroutines to be sporadic
- Teensy 4.0 + nrf24l01
- from camera interface to USB
- IntervalTimer interrupt priority
- Adding Print class printf() format string vs arguments checking
- Teensy or Arduino?
- Tall-Dog Teensy 4.0 Breakout Board Questions
- How do I send a USB Keyboard # key
- IDE crashed, source code file corrupted
- Teensy 4.0 USB serial question
- Teensy 4.0 timer1, one second loop question
- XPlaneRef() Documentation?
- CapacitiveSensor library not working with Teensy 3.5
- Trying to get X-Plane heading bug to move
- Button push help for X-Plane Garmin 430 Nav freq flip flop
- Audio System Design Tool i2sslave
- Teensy 4.0 header for pins 24-33
- Teensy 4.1 Native Ethernet Sending Files from SD Card - Missing Bytes or Packets
- How to use XPlaneRef("sim/instruments/ah_ref_down") command
- Can't send from Serial Plotter to Teensy
- Teensy 2.0, Watchdog Timer and Bootloader
- Using integer math instead of floating point?
- how to access the USB client pins D+ and D-
- Problem passing values thru nested functions
- Teensy LC Code Not Working on External Power
- Using MIDI.h in a class
- Using analogRead and AudioInputAnalog in the Audio Library, is there any workaround?
- Differentiate Teensy 4.1 from 4.0 in Preprocessor?
- ADC and DMA
- Teensy 4.0 + octo ws2812 + sd card +glediator/jinx
- Using ILI9341
- Buzzing noise when recording
- Connecting Teensy 4.1 with nrf24L01+
- psram with qspi flash on teensy 4.1
- Teensy got fried
- teensy_loader_cli and serial port
- Upload an sketch doesnt work.
- Programming a Teensy 3.x, when another is also connected thru USB
- SdFat V2.0b with multiple SD cards?
- MPU6050 Sketch dont work well
- External Power Source Wiring
- NXP_SDHC.cpp TODO - High Speed Mode
- Teensy 4.1 OctoWS2811.h Examples not working
- Teensy 4.1 Flash Integration and Library???
- Teensy4 ADC pin switching speed
- Teensy 4.0 SPI questions.
- Teensy 4.1 SD card reader doesn't work with any library
- Using EEPROM in Teensy 3.2
- Teensy 4.1 and HC-05
- teensyduino linux installer issue
- Timing a pulse train of microsecond events on a 15Hz period
- Keyboard intercept and passthru?
- Error on second compile after Teensyduino and Arduino update
- USB Serial Communication problems in Windows
- Stacking USB midi commands
- Error opening Com Port to Teensy 3.2 via usb from software on Windows
- Is there a good way to simulate engine acceleration sound
- Fast DAC shield for Teensy
- Weird signal problems using cheap oscilloscope to look at OctoWS2811 adaptor
- Teensy 4.1 + PSRAM + Winbond 25Q128JVSQ: Flash memory tests not working
- ADS1256 and ADXL337
- Weird #define issue during compilation in Teensyduino with Teensy 4.0
- Problem on Teensy 3.6 multiple Serial port
- What does Tools: Optimize : Debug do?
- Teensy 4 SPI polling issue
- Teensy 4.0 and ST7789_t3
- Teensy 3.6 vs Teensy 4.1 RAM memory
- How *loud* should my audio out be?
- Teensy 3.1 + Ethernet adapter: SPI pins assignation
- Thank you
- using parallel ports with teensy 4.0
- ili9341 sleep after 5 min and wake on touch?
- Teensy 4.1, NativeEthernet, and AppleMIDI Tx
- Micro Sd adaptor connection
- Teensy 4.1: USB device on a RPI 3 win10 iot
- Teensy 4,0: Flash another bootloader/same on again?
- section type conflict
- IntervalTimer teensy lc
- Snooze: Calling a function on a pin interrupt?
- Teensy 2.0++ dimensions required
- Non DMA ST7735_t3 Framebuffer vs GFXcanvas16
- SPIFIFO & SPI library
- Teensy4.0 CPU count reset
- Teensy 4.1 timing accuracy help.
- Teensy 4.1 Random Number Hardware
- New Tesnsy 4.0 not being detected
- FastLED compiling error - Teensy LC
- MacOSX with Teensy 4.1 loader loaded before, refuses to load now
- Unwanted Noise: Teensy PT8211 Sine Test
- MIDI device stops working when connected through hub (using USBHost_t36 library)
- OSX 10.14.6 - teensy_serialmon Panic and computer restart.
- Clock of the ADC in the teensy 4.1 not modificable
- NewPing not working with teensy 4.1
- RA8875 SPI Teensy 4.0 can I get a little speedup ?
- Serial communication issues Teensy 3.2 and RoboClaw
- LM324 op-amp output to Teensy 3.2 analog input reads 0.00. Meter shows 2.96v. Help?
- Teensy Loader slow to start up
- Minimizing EMI from Teensy 4.0 ?
- Sketch to test the ili9341 touch sensor with my Teensy 4.0?
- Diagnosing AudioPlaySdRaw failures
- vsCode build results in HEX file that won't upload
- Implementing XY2-100 serial protocol on Teensy 4.1
- Teensy 4.1 + BNO055 does not store heading value on startup
- N64 controller -> USB on Teensy LC; button status 'flickering'
- Teensy 4.0 Serial Driver for Windows 7
- Teensy 4.0 Pin Current Capability
- Teensy 4.1 vs. LiquidCrystal_I2C
- Teensy 4.0 serial USB receive data loss
- Run TeensyLC at 16mhz - with USB libraries
- Diagnose _reboot_Teensyduino_() not working
- HWSERIAL port #define definition doesn't work
- How Can I Use the Teensy 3.6 as Mass Storage Device for the Low Level (UEFI) of Host?
- ADS8321 - Teensy 3.5 interface
- No Teensy boards were found on any USB ports of your computer probleme
- Teensy 4.0 and SD card issues.
- String class warning on Arduino forum
- RA8875_t4 and teensy 4.0 bumping graphics rows down on the display programmatically
- Teensy LC and Wire1
- Ableton keeps muting regardless of button pressing
- BNO080 and Teensy 4.1 and SPI issue
- Teensy 4 vs Mega 2560: External flash memories and SPI
- SK6812 with Paul Stoffregen's WS2812Serial library
- Kicad Teensy 3.5 board doubt
