View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50
  1. Hash noise from display getting into audio when screen updates ..
  2. Toggle output port with register
  3. Teensy 3.2. (Code 43) error on Windows 10
  4. Teensy 4.1 software Serial for one wire bi-directional communication
  5. How to fix the [-Wreorder] warnings?
  6. Teensy 3.2 fails to start up (hardware)
  7. Migrating projec from arduino mega-due to teensy 4.0 because of dual i2c channel need
  8. Help with Teensy 3.2 DIY Project
  9. Serial Flash Examples Not Working For Me
  10. digitalRead not working on pins connected to interrupts - BUG?
  11. Teensy 4.1 MAC Address
  12. Timing the main loop in c on Teensy++ 2.0
  13. Teensy 4.0 Shield ??
  14. T4.0 / 4.1 Analogue read resolution
  15. Teensy 3.1: "Teensy did not respond to a USB-based request to enter program mode."
  16. Usable Baud Rates for Teensy-LC
  17. Teensy 4.0 USB serial with NXP SDK
  18. Teensy 4.1 hard reset
  19. max31855 question calibration not seeing it.
  20. Reset is not pulled low in response to Program
  21. 5V on Vin leads to 4.8V on 3.3V pins?
  22. Audio file from SD (audio shield) stops before end of file while using motors
  23. Wire library
  24. Teensy 4.1 SPRAM chip availability
  25. issues on program with large dataset
  26. Can't Install Teensyduino 1.53 to the Location Provided
  27. Strange GPIO Port Behaviour
  28. uploading hex file via teensy loader
  29. Teensy 4.1 External 3.3V Power
  30. void loop and interfacing the SPI
  31. Boot problems with external power on T3.5
  32. Teensy 4.1 - firmata
  33. Serial monitor issues on Windows 10 - port conflict
  34. How to reset teensy 4.1?
  35. Teensy 4.0 SPI
  36. Teensy 3.2 (and 3.1) occasionally not running on power up!
  37. Teensy freeze when stream from Serial port [ ubuntu18.04 teensy3.6 teensyduino1.53]
  38. Is it possible to connect the usb2 port on Teensy 4.1 to the computer? I have tried b
  39. teensy 3.6 pins 30, 36, 38 documentation error
  40. T4 UART Rx DMA -Disable the Rx FIFO!
  41. Need overview on usage of Quadtimer features on Teensy 4
  42. Teensy 4.x > Teensy 4.x communication usion NRFL2401
  43. Connecting OV7670 to Teensy 4.0 using HW assist
  44. Function to find index in 2D array based on sensor values
  45. RX (D2) why oscillating?
  46. Teensy 3.6 not detecting MCP9808 sensor
  47. Teensy 4.1--Interrupts or polling, and internal SD card
  48. GPS and LoRa modules not working together
  49. Sudden failures
  50. Teensy 4.0 analogRead bug
  51. Teensy4.1 EXT Flash chip
  52. T4.1 - using PSRAM chip as RAM
  53. unable to use setSyncProvider for teensy41 in platformIO
  54. Teensy 4.0 - How to use two I2C ports with two BMP280 on same address?
  55. Teensy 4.1 and sysex MIDI messages in host mode
  56. Optimizacion código teensy 4.1 dac904
  57. Possible teensyduino issue.
  58. Teensy ADC giving higher than possible ADC reading
  59. Teensy 4.1 trouble getting started
  60. Teensy 4.0 USB-MIDI host issue
  61. Query speed limit teensy 4.1
  62. My Teensy LC keeps hanging, then disappearing...
  63. Uploading the scketch file on sdcard to Teensy3.6
  64. Tinsy 4.0 SPI Shift Register Circuit for Active Inductor Controller
  65. Audio Shield SD Card slot issues
  66. Teensy 4.1 binary from alternate toolchain
  67. How to use TimerOne Library with Arduino Uno WiFi Rev2
  68. More questions SPI Manual Correctly Previous Post MAX31855, Screen Freezes why? CLK?
  69. Teensy 4.1 USB host ERROR Followup
  70. synchronize flexPWM modules on teensy 4.0
  71. Compatibility issue for Teensy 3.2 SPI bus with 4.2' epaper display and RFID module
  72. Teensy 4.1 available PWM frequencies
  73. pins for the teensy3.6 and teensy4.0/1 Data Command alternatives
  74. Problem trying to read OV7670 camera under IRQ Teensy 4.0
  75. Teensy 4.1 recording sound and saving it to SD card with the correct date
  76. Teensy 4: TFT doesn't work together with encoder when in DMA mode
  77. SPI padding to 8 bits (Teensy 2.0)
  78. Teensy 4.1 Joystick Support
  79. Increase write endurance on Teensy 4.0
  80. Teensy 4.1 SPI1 on W5500 Ethernet module Communication Problem?
  81. Teensy 4 GPIO Interrupt Handler
  82. Frequency meter, inaccurate at Teensy ++2.0
  83. Running 15 servos on Teensy 4.1 - Too much current draw?
  84. Teensy 4.0 Basic SD card usage
  85. Using High Speed Encoders
  86. SD card present switch on Teensy 4.1
  87. use EXTMEM (psram 16mb soldered onto Teensy 4.1 pads) for AudioMemory
  88. rewriting the functions to closed void functions
  89. Teensy 4.0 / 4.1 startup delay of 300 ms
  90. "Serial1 not declared in this scope"
  91. Solution for adding support for pre-compiled Libraries
  92. Bricked Teensy 4.0- not enough stack space?
  93. FreqMeasure Libary Measure Voltage
  94. Teensy and 12v LEDs
  95. SPI Talk conseqcutive check how to:
  96. VBat pin on 3.6 and other boards
  97. Unable to Specify Upload Port for Teensy Loader Using PlatformIO
  98. Teensy 4.1 external oscillator
  99. Teensy 4.1 solder pads for USB ...
  100. SdFat and teensy 3.2 (no longer supported?)
  101. Teensy 4 send multiple MIDI notes at once through USB.
  102. Phase Shift PWM?
  103. Midi Device Name
  104. Encoders jumping positive
  105. Arduino scale & display for food dispenser & weight calculation
  106. Teensy 4.1 ethernet pin hole locations / mechanical drawing
  107. Teensy 4.1 using Ethernet Kit - conflict with LEDs (FastLED)
  108. CANBUS send and receinve
  109. Teensy 4.1: Capture serial break
  110. SPI communications leaking into DAC output
  111. ra8875/GSL1680 .teensy 4.0 ..touch panel functional but an issue
  112. Flying a drone with RC commands from a Teensy - anyone done this? Need help.
  113. '/dev/ttyACM0' not found 1times / 5 not clear why at all
  114. Cutting Vin from Vusb and bricking Teensy 3.2 in the process
  115. Teensy 4.1 How to start using DMA?
  116. Ethernet.begin() upsets state of Pin D13
  117. Sparkfun Autodriver and Teensy 4.0
  118. analogRead() question
  119. can't assign String array to PROGMEM?
  120. MIDI In problem with Teensy 2
  121. Raspberry (wav, mp3, ...) --(I2S)--> Teensy --(USB)--> PC ?
  122. i.MX RT1050 Reference Manual, Rev. 1, 03/2018 in imxrt.h
  123. Teensy 4.1 ethernet webserver problem
  124. MotionCal - Windows
  125. Teensy 3.5 broke (?)
  126. Teensy 4.1 unlabeled pads - where to find documentation
  127. My variable is getting corrupted
  128. Teensy 4.1 Development Board and Adafruit TCA9548A
  129. LIPO for Teensy 4.1 Development Board
  130. Is it possible to change the memory bank of the Teensy 4 for malloc/heap?
  131. RTC on Teensy 4.x
  132. D cache management on Teensy4.0
  133. AnalogRead - random values teensy 3.6
  134. Fried my teensy 3.6
  135. Periodic Noise Spikes When Using Teensy 3.5 ADC
  136. Accessing "Serial port 2" using the Teensy 3.2 bottom pads.
  137. Using the MPU9250 with a complex sketch running 8 motors via UART. Compatibility
  138. Problem using AudioInputI2Sslave and AudioOutputUSB together
  139. Mapping OctoWS2811 pins on Teensy 4
  140. SD card for Teensy 4.1
  141. Teensy4 - Hardware Serial Conflicts?
  142. SDFat linker errors after updating to latest Arduino and Teensyduino tools
  143. Teensy 4.1 ethernet hardware failure
  144. Can the encoder.h library be used with a single-channel rotary incremental encoder?
  145. Is #include "printf.h" compatible with T 3.5?
  146. Mechanical drawings for the Prop Shield With Motion Sensors
  147. Unable to use PSRAM on Teensy 4.1
  148. creating a USB driver with a bulk transfer endpoint
  149. 'SPI_Hardware_t' in 'class SPIClass' does not name a type on Ra8876LiteTeensy
  150. int remainder [16] redeclared as different kind of symbol
  151. design tool APPEARS TO BE DOWN
  152. CANBUS not receive all frames
  153. What is the proper way to turn off Teensy 4.1?
  154. Using Teensy Loader on Mac OS X and outdated Getting Started guide
  155. Troubleshooting Potential Dead Board (Teensy 2++)
  156. Reading from one usb port and emulating a usb touch on another
  157. Porting arduino mega code to teensy
  158. Teensy 3.2 with ST7789
  159. MIDI OUT 3.5 TSR mini jack hardware protection
  160. NRF8001 And the Teensy 4.0 Not Working. Problems with PROGMEM and EIMSK
  161. Industrial temperature range, Tensy 4.0
  162. Need clarification on the two 3.3V power output ports and the Vin port
  163. Chromebook Linux Beta Teensy Upload
  164. 10bit PWM signal for servo
  165. Setting SPI clock on T4.0
  166. How does a pin interrupt find it's attached ISR?
  167. How to interpret the difference in memory size between Teensy 4.1 and Due ?
  168. I2C ports on Teensy 4.1
  169. What USB and Port settings for Hardware MIDI on LC?
  170. MISO and MOSI ports for connecting LoRa to Teensy 3.2?
  171. Sn74hc125 tristate required for between each SPI device? And how do you check this?
  172. Teensy 4.1 NativeEthernet fixed address problem
  173. Reading strings of floats and saving in Teensy EEPROM
  174. Pin assignments for Audio Shield with T3.5
  175. ShiftPWM - some LEDs flicker some don't work completely
  176. teensy 3.6. a4 and a5 with i2c
  177. Setup USB Host to talk with hub with two FTDI serial devices
  178. Absolute mouse with teensy 3.2 Android / iOS
  179. AGND DGND audio Noise Problem
  180. Teensy 3.6 sd card data logging not working
  181. SPI chip/slave select in library
  182. First time install of the http://wit-motion.com IMU on Teensy 4.1
  183. Strange code execution bug in teensy 4.1
  184. Sample program to read and write data using the builtin sd card reader of Teensy 4.1
  185. ExFatLogger Not Working on Teensy 4.1
  186. touchRead() but only with bad soldering
  187. Teensy for 4.0 and digishield
  188. Trouble with USB host MIDI devices
  189. Sample programs to gather data from three I2C buses
  190. 64-bit ARM (Raspberry Pi) - Teensyduino 1.53 hangs at end of compile due to firewall?
  191. AudioOutputI2SOct
  192. Mega Tree with Teense
  193. Programming Teensy 4.0 in a Windows10 VirtualBox machine
  194. Teensy 3.2 pins 3 & 4
  195. Digital input pins not all equal?
  196. Clock frequency of Teensy 4.0 / Use with FreqMeasure()
  197. Custom Product ID
  198. Teensy 4 and IRMP
  199. Teensy disappearing from USB
  200. 3.5 inch RPi LCD with Teensy 4.0 problem
  201. Limits of the GUI?
  202. 48kHz for audio shield on T4
  203. 4.0 Running as both USB host and USB device at once
  204. USB audio feedback
  205. USB Host on teensy 4.1, doesn't receive midi from EWI 5000 usb
  206. SPI, Stepper and Healthy Communications
  207. Non-blocking Connect for native ethernet client
  208. AMT102-V encoder index value and Encoder library?
  209. Trying to get Teensy 4.0 and OctoWS2811 with teensystripcontroller and DOF to work
  210. TCXO for Teensy 3.2
  211. General help understanding memory management on Teensy
  212. Blink sketch does nothing on Teensy 4.1
  213. Multiple Servo Delays
  214. Teensy 4.1 to 4.1 TwoWire (i2c) Communiaction Problem
  215. Teensy 3.6 Voltage
  216. Nextion NX4832T035 with Teensy 4.0 questions
  217. Can't flash Teensy 4.0
  218. QT App can't read serial without reset via Arduino Serial Monitor
  219. Teensy3.6 i2c RPi3
  220. Teensy 3.6 ACD current leakage
  221. Teensy 3.5 SerialCom doesn't read
  222. Using a DAC(mcp4821) with teensy that I have tested with an arduino uno.
  223. Multiple functions of potis or encoders
  224. Current Rating for USB Pads on Teensy 3.2
  225. Problems with JOYSTICK_SIZE = 64
  226. Mic GND and stereo jack HPVGND in stereo+mic jack
  227. Teensy 4.1, achieving high quality voltage readings
  228. Teensy 4.1 SPI pinout question
  229. How to use various IC2 busses? Teensy 4.1
  230. TeensyLC SPI, does hardware require MISO?
  231. WS2812Serial 400 or 800 kHz
  232. Need help with teensy 4.0
  233. Teensy 4.1 SPI compile issue: 'SREG' was not declared in this scope
  234. SD open issue
  235. Persistent bug while loading USB serial driver
  236. USB programming via carrier board connector instead of micro-USB
  237. Print Issue
  238. usb.names.h (Device Naming issue)
  239. Setting MIDI Manufacturer and Version info for Teensy 2
  240. How to add a delay to an analog read?
  241. GLEDIATOR with 2048Pixels !! Per port :1024pixel !!! use for 2Port Data Output
  242. USB MIDI clock jitter with ILI9341 display calls -- use two Teensys?
  243. Which pins to use for AudioInputI2S2 on Teensy 4.0
  244. Recorder Example Queue Object
  245. Trying to add pots to my existing midi project. code compiles but pots don't work
  246. Teensy 4.1 died unceremoniously with short between USB VCC and GND
  247. Teensy TimeLib question ...
  248. Teensy 3.5 DMA and PIT1 anomoly
  249. Teensy 4.1 RAM issu
  250. nRF24L01+ & Teensy 3.6 Issues
