- Issue with Teensy loader when using WSL (Windows Subsystem for Linux)
- Programming from the USB host T3.6
- Schematic error in T4.0 or T4.1 on SD pins
- teensy 4.0 flexSPI slave
- MTP on a teensy3.2
- Teensy is freezing with Ds3132 RTC Module and Fastled
- Using PSRAM Buffer for saving arrays before serial printing
- Strange behavior on certain functions
- What peripherals are affected by the undocumented 24 MHz OSC circuit on Teensy 4.0?
- What is the purpose of these NOPs in Teensy 4.0 initialization?
- Teensy 4.1 no longer connecting to PC
- Teensy 4.1 GPT CAPTURE input / interrupt troubles
- Program esp32 from teensy
- How to get USB connection to Teensy 3.2 to completely disconnect under SW control
- Teensyduino randomly loses USB port while programming 4.1 board
- Install teensy_loader_cli on Linux
- strategy to debug?
- Multiple I2C buses on T4.1
- Funny pin behavior with RF24 and Teensy 4.1
- What next?
- serial input processing -> teensy4
- Big chunks of Teensy4 reference manual is secret?!? Unlike Teensy3.
- Teensy 3.6 boot issues.
- Teensy shutdown when SD card is inserted
- Cannot find A14-A17 on a Teensy 4.1?
- maximum pulse-frequency from quadrature-encoders on Teensy 4.1
- NRF24L01 and Teensy 3.1
- Compiler errors with Adafruit_GFX and SSD1306 128x64 OLED display...
- Intermittent SD initialization with Teensy 4.1
- W25Q128JVSIM not working on Teensy 4.1 but on Audio Shield?
- Unable to flash Teensy4.0 with Arduino
- T4: Triggering DMA SPI transfer from within interrupt
- USBHOST_T36 library is not working on Teensy 4.1 Board
- Power 2 Teensys one USB port
- MIDI benchmark sketch compatible with Teensy LC?
- How to assign sensors to I2C buses T4.1? :confused:
- MAX31865 and Adafruit RTD library on Teensy 4.1 problem
- Audio library, update() function
- Getting optimal SD card performance
- Error Using BNO085 with Teensy 4.0
- rawHID for teensy 4.0 Compling c files for Matlab
- Restore bootloader after accidently downloading .elf file
- Double Precision Floats
- Teensy 4.1 extreme joystick, can't use Joystick.X,Y,Z
- Magnetic linear encoder speed
- Use 2 SPI ports simultaneously in Teensy 3.5
- MIDI read with NRPN
- Teensy 3.2: Is it possible using FreqCount for different Pins (multichannel)?
- Communication over USB fails with additoinal teensy board connected
- Is TeensyStep compatible with Teensy 4.1?
- cores/fs.h
- SPI1 Maximum Speed?
- Teensy 4.1 serial port polarity invert?
- Unable to begin ChibiOS thread (ChRt library, Teensy 4.0)
- Trouble with the Serial Plotter. Using a Mac, Arduino 1.8.5 , TeensyDuino 1.53
- Connect read from each i2c bus T4.1
- Power Teensy using external power without usb
- Teensy Convolution SDR T4 and Audio Board Rev D
- Analog Readings Unstable On MIDI Projects
- Simple dumb LED on PWM pins question
- Teensy 3.2 com problem
- Bel Magnetic SI-46001-F as ethernet connector for teensy 4.1
- Strange behaviour on certain analog reads
- Teensy 4, displaying Serial data via USB is delayed on reboot
- Gamepad emulation using teensy 4.0
- SPI beginTransaction question
- Can PC communicates with teensy via Usbhost pins?
- Disabling IRQ for better performance - Teensy 4.1
- Newbie on PlatformIO with Teensy
- Teensy 4.1 Digital I/O pin map
- Teensy 4.1 Generate 40KHZ Sine Wave
- TeensyLC EEPROM emulation
- Some questions on Teensy4.1 board
- Teensy 4.1 UDP and web server drop packets
- Teensy 3.6 output voltage problems
- Teensy 4.0 compiler issue? Maybe?
- Does Snooze work with teensy 4.1
- "Finished" midi controller with lots of lights and EMI... power distribution question
- printf is blocking my sketch, Help!
- TeensyStep. Why I have to use moveAsync with a while and delay?
- ST7735_t3 with 128x96 display on ST7735s
- FreqMeasureMutli Teensy 4.1
- sdfat ls() serial
- Testing Teensy 4.0 and SD card module with SPI to store data on sd card
- Peak tracking problem.
- Memory issue with AudioLibrary Teensyduino since 1.52-1.54b
- Multiplexer Wiring
- How to use CAN bus on Teensy 4.1, 4.0 and 3.2 ?
- How to use the onboard CAN controller (Flex CAN) and a MCP2515 (MCP library)
- Digital Input Problem
- Alternate SPI works on Teensy 3.2 but not 4.1
- Teensy 4.0 ECU - CPU Performance
- No communication with teensy 4.1
- Teensy 3.6 stops working and Orange Led glows up
- I2c communication issue between teensy 4.1 master and slave
- Cant Compile for Teensy++ 2.0
- Connecting audio/midi interface
- Teensy 4.1 & Audio Board Rev D Tutorial 01_04 Issue
- Simulating The Audio Library
- This formula blocks ONLY Serial 1
- Make Teensy act like a USB file system?
- Teensy 4.x: Need help in understanding source code of analogWrite(pin, val)
- USB Host Communicating with a Teensy 4.1
- force small rx/tx buffer for usbmidi teensy 4
- Teensy 3.2 not working as gamepad . Help please
- I2C between 2 teensies only works after restart
- FlexIO3 With DMA
- Toggling PTE6 on Teensy 3.6 to turn 5V USB host power off and on
- Teensy++ 2.0 touchpad scroll help request
- factory restore teensy 3.2
- Teeny 4.1 PWM Input/Output Pins
- Teensy 4.0 ADC analog input multiplexer
- PWM on Teensy 4
- Teensie 4.1 RF interference
- Command Line Build
- Actual current limitation of Teensy 3.2 and rules of thumb about typical/max current
- Having problems with time it takes Snooze to wake up on digital pin
- Permanent ADC damage caused by running this code
- DMAMEM : Long Delay during writing in ISR
- 16-bit PWM on Teensy 4.0 and 4.1?
- Teensy 3.5 ADC_DMA example error
- Teensy 4.1: GPIO Interrupt Priority + general interrupt question counting pulses
- ADC Library on Teensy 4.1
- [USBMIDI] Serial + MIDI, how to deactivate either one ?
- LC draws more current than 3.1 in Snooze modes, does not work on digital
- uniform initialisation, object oriented programming etc.
- KiCAD Frustration
- Teensy40 - only 3.3V power supply?
- Switching off SPI begin/endTransaction for high-speed SPI transfer?
- PIT and External Interrupts
- Seeking for help/guidance with teensy4.0 & audiobreakoutboard for Atis decoding.
- Redefine the RawHid parameters
- counting at 600Mhz
- makefile - interpreting arm-none-eabi-size output - am I over any limit? t4.1
- High speed USB data - custom isochronous usb descriptor?
- Teensy 4.1 ADC Library
- CMSIS RFFT works on 1.48, broken on 1.53?
- AudioEffectChorus issue
- Questions of interrupt priorities.
- Bad datas are print on serial1. I haven't had this problem on Arduino Due.
- Only SCL and SDA pins 18 and 19 work
- Error while setting serial port parameters: 115 200 N 8 1 :confused:
- Teensy 3.2 ADC setting / analogRead Display range
- AS5047, SPI, and Teensy 4.0 always outputs 0
- Timer callback and data access
- Switching from Mega to Teensy
- Teensy 3.2 Strange behavior when measuring AC voltage
- Failing to get Analog Comparator to work
- Freetronics Dot Matrix Display on Teensy 3.6
- SPI: toggling SCK before starting the SPI transfer...
- ACMP Clock speed (Teensy 4.1)
- Exception handling on Teensy
- I2C interrupts on a MCP23017
- Is this a Genuine Teensy 4.1 Board
- USB Serial dying on Ubuntu 18.04
- vtable problem
- order problem
- Teensy 3.6 is SRE configuration possible on SPI pins due to EMI issues?
- fillTriange issue with screen or buffer size?
- Corrupted Data?
- teensy 4.0 GPIO pulse lost at 150MHZ
- 4.1 Error - No SD Card - What am I doing wrong? Help Please!
- Voltage / GND question
- One shot timer : Multiple pins with unique intervals
- asynchronous board synching
- HID codes include file
- pow() function alternative
- CAN communication problems
- Teensy 4.1 - Using the internal flash memory
- Teensy 3.2 OctoWS2811
- Interrupts stop working when changing from time source B to time source A
- Issue with PDB and sampling avg ADC?
- Help with pointers
- Teensy 4.1 and Adafruit Fona display keypad example, buttons wont release.
- Teensy 4.1 WS2812B LED Problem
- range of the frequency control input in AudioFilterStateVariable
- Flash - Storing preferences
- Teensy 4.0 with OctoWS2811 - movie2serial and videodisplay random colors
- Teensy 3.5 + wiz850IO hardware not detected
- i.MX RT1170 ??
- Teensy 3.2 no longer reading/executing code properly
- OV7670 correct colors
- Teensy 4.0 components for repair attempt
- Cannot get Teensy_loader for MacOS 10.10 - teensy.dmg "no mountable file system"
- TEENSY 4.1 + NRF24L01 Need Help Please
- Load hex file from SD Card?
- Teensy 4.1 Browning Out - USB Battery Pack
- Teensy 4.1 no headers with ILI9341 blank screen problems... soldering?
- 4.0 5x5 midi having trouble with sysex, dropping values on a loopback test
- [Teensy 3.2] Why is audio dropping out after calling MIDI.begin()?
- GPIO ports and related control register
- midi in (hardware serial) fails after some time
- issues powering Teensy 3.2 via battery
- Powershell serial communication with TeensyLC
- Teensy++, three pins won't go low
- Analyze_FFT256IQ
- USB midi controllers for persons with special needs
- Teensy 4.1 USB host with EC25 LTE module.
- Teensy 4.1 External Supply and Ethernet Port Pin Pitch
- USB overvoltage
- Unable to send notes to USB Hosts, but can receive just fine.
- TEENSY 4.1, proper SCK pin question
- Problems with TFT color display with Teensy 4
- help teensy 4.0
- Teensy 3.5 - Instrumentation Amp for Single-Ended Analog Recording
- Teensy 4.0 not recognized as USB serial device with v1.53 (Windows)
- Replace the W25Q64J with an eMMC 4.5 device
- BUILTIN_SDCARD Not defined
- Teensy 4.1 + hexapode
- T4.1 -> Mega with nrf24 module speed difference assistance
- T4.1 + WS2812B Can I use Serial 8?
- Problems with builtin sd card
- Serial question : Is TX1,RX1 for Serial1 or just Serial? (Ntxt)
- Teensy 4.0 Not Showing Up On Serial Port
- adjusting AUDIO_SAMPLE_RATE_EXACT
- Low output voltage with external power
- Show Timestamping lost in Serial Monitor
- Teensy 2++ Which pin for external power
- Teensy 4.1 Ethernet Error: client.availableForWrite
- Is switching DHCP / static IP possible
- Confirm "Encoder" Library Use With Arduino Due MCU Platform
- Compiler directive to select board
- 16 rgb rotary SPI port expander panel - testers?
- Burning Teensys through USB cable
- PJRC store's ILI9341 w touch does have Tri-state chip?
- Teensy 3.2 won't boot & run w/o USB (FAQ I know, but delay isn't working)
- 4.1 Ethernet Reset U6 pin 5, can I tie into this for a system wide reset?
- Teensy 4 RTC - prevent loader from changing time
- Multichannel audio over IP
- Buydisplay 7" RA8875 ft5206 800 x 480 display jumper re-configuration
- multiplexing touch pins
- Can not create file on SD Card in Teensy 4.1
- Connecting two Teensy 3.2 on OSX
- Only compile specific Audio-lib files included
- I2S and I2C together
- serial communication between two teensies via usb
- Teensy 4.1 USB Host MIDI not working (no Power from 5V USB Pin)
- Questions on Teensy4.1 schematic
- How to deal with GPS data to give direction or a specific path ?
- Teensy 4.1 usb host: Provide own external power
- Teensy linux command line code upload
- Passing Encoder to library
- Teensy 3.2 and reference voltages
- Question on T4.1 Serial Flash (U3)
- Delete this post
- x2 Teensy 3.2 Master and Slave, need direction
- Teensy 4.1: Ethernet Problems
- Encoder.h library from pjrc.com not compiling for teensy 4.0
- Big Sur ?
- ILI9488 and teensy 4 and touch 2046 and ILI9488_T3
