- Teensy 4.0 + mcp23017 blink
- T4.0 Sleep modes
- Transpose / Offset incoming MIDI notes down an octave?
- Octows2811 No output
- Programming the Teensy
- Teensy 4 / 4.1 error / fault handling routine
- teensy 4 stopped working with adafruit Tlc59711 library
- Macbook unable to upload code to teensy
- Teensy 3.2 upload issue
- UARTS get mixed up on Teensy 4.1
- Teensy 3.2 and 3.5 EEPROM ISSUES
- KeyboardController::process_bluetooth_HID_data reports bad button press/release data
- MOCD208 opto isolator question
- Using the PGA (Programmable Gain Amplifier) without ADC - Teensy 3.2
- MKL02 not starting up
- Coding Neotrellis M4 with Mic onboard
- Teensy 3.5. Can I ad memory to the TX buffer?
- Disable volume thumbwheel on Audio Adaptor Rev. C
- Recording audio while sensing capacitive touch -- feasible?
- current + voltage measurement with INA260: common ground?
- pointers help for beginner
- ISP and Bootloader
- LED problem with Teensy 4.0 and TFT display
- Teensy stops responding after some time in outdoor installation
- TeensyLC dies on serial
- How to recover after I2C lost on 4.1?
- teency 3.2 and internal clock and backup battery
- Can I use Serial3 on T3.5 with an audio shield?
- Teensy 4.0 and BNO08x on SPI2 hangs
- Teensy 4 All-of-the-Above MIDI + Keyboard
- Irremote Teensy 3.2, enableIRIn() not working
- teensy 4.1 max VIn voltage
- SerialFlash Example Sketch "MP3Player" getting odd error, Teensy3.2
- Servo slows down when called in a class
- Dropped data from T4.X but not T3.X using MATLAB to read output of serial.write()
- Detect Whether SD Card Has Been Unplugged Teensy 4.1
- Teensy 3.6 and 5v tolerance.
- Teensy 4.0 - PC does not reconnect after Watchdog reset
- i2c support for Teensy 4.1
- Teensy 4.0/4.1 Windows PC adding a reset-possability without USB unplug/plug
- Teensy Lc Midi to Output
- Soft reset not working on Ubuntu 20.04 LTS - Please help
- Teensy 4.0 RAWHID from 64 to 1024 bytes (High Speed USB 2.0)
- Random bytes loss on USB serial port
- Teensy 3.5 pin 7 (RX3) conflict with SDI on ILI9341
- Unstable signals with many key presses on a midi keyboard matrix
- SdFat library on Teensy 4.1
- Adafruit_NeoPixel seens to be limited to 110 leds in the string
- 4.0 vs 3.2 with Adafruit 1.3" 240.x240
- How Long Can Teensy 4.1 Run Continuously Without Breaking
- HELP Audio Beeps with Teensy 4.1 and PT8211
- Ethernet on Teensy 4.1 - Beginner
- WS2812SERIAL error with DMAChannel.h
- SerialFlash RawHardwareTest errors, TeensyTransfer not detecing Prop Shield
- External Power and USB on 4.1
- Teensy 4.1 GPIO_6 Register Read Erratic Timing
- larger PSRAM chip
- T4.0 ra8875 display and i2c touch screen ..
- Increase the current consumption from 100mA to 500mA (Teensy 4.0)
- 4.1 w/Audio Shield trying to access 4.1 board SD Card
- Using i2c OLED screen with Teensy 4.1
- Hooking the USB isr on Teensy 4.x
- Problem with Serial Monitor in Arduino IDE
- PS2X_lib not working with Teensy 4.0 or 4.1
- What movie formatting is best for movie2sdcard Processing sketch?
- Teensy 4.1 USB Serial connection
- T3.5: SD.open failing
- Defining a const array with a loop?
- playing samples from SD card strange behavior
- Wire library without I2C Hangup bug
- No /dev device
- Weird Custom Teensy 3.2 Behavior
- Noise on GND When Driving Display with SPI1 on Teensy4.1
- No Teensy boards were found on any USB ports of your computer
- ILI9341_t3 library causing program to freeze
- Teensy 4.1 with HX8357 display issue
- Are D0 and D1 used on a Teensy 4.1
- Can a teensy 4.1 have two SPI buses running simultaneously
- Timerinterrupt for Teensy 4.1
- Teensy LC + Analog Joystick help
- Teensy 2.0 No Blinking and will only work if set to serial+keyboard+mouse+joystick
- teensy 4.1 wire,wire1
- Teensy 4.1 issues with Serial after wiring error
- teensy loader takes 25 seconds to start up
- Teensyduino for Teensy++ 1.0
- Teensy LC and softpot value issues
- Teensy 4.1 EXTMEM not working in header file, section attribute not allowed.
- Teensy 4.1 AGND (Retired?)
- 16 button Zelda midi controller - trouble with programming Teensy 2.0
- Teensy 4.1 - Alternate Pinout - Source of Truth
- Port Numbering:: Starting at 0 vs 1
- Paul request; Separate Vin/VUSB Teensy 3.2
- How would I use a Teensy 3.5 to wire switches to a flight sim (DCS World)
- Should an Adafruit SD card breakout work with a Teensy 4.0?
- Questions about dc coupled audio input to teensy 4.0/4.1.
- problem - Playing SD files
- FreqMeasure Library - how to get the total count?
- Is there any filter libraries for teensies out there?
- Teensy LC w/ Xinput "This device cannot start. (Code 10)"
- HX8357 SPI frequency with Teensy 4.1 (re-post from Adafruit forum)
- ER-TFTM032-3 - ILI9341 Issue
- portable Arduino-IDE compiler-error 'BUILTIN_SDCARD' was not declared in this scope
- Teensy 4.1 crash, using ILI9341 and ArduinoJson
- Teensy 4.1 onewire-read fails if USB-cabel supplied by USB-power-supply
- Teensy 4.1 GPIO direction switching behavior
- Teensy 4.0 crash with BigNumber variables
- Teensy 3.2 replacement for the Schottsky Diode - mouser part?
- Teensy 3.2 Hanging on RawHID Send
- Can I get a faster sample rate from Prop Shield IMU?
- ILI9341 2.8" - Location of SDIO pin headers?
- Intermittent touch function with 2.8" TFT
- Teensy 3.2 Mouse/RawHID USB Descriptor Failing
- non blocking Ethernet.begin() with cable disconnected & static IP ?
- Adafruit BMP390 over I2C with Wire.h on Teensy 3.6 ok but not for Teensy 4.1
- Aux input to OctoWS2811
- Teensy 4.1 Serial issue (lag)
- placement of zener diode for voltage protection for harware MIDI circuit?
- teensy midi
- max leds for one port
- Custom Teensy 3.6/2.0 Board Feedback
- Two Serial Links on one USB Serial cable
- Trouble using PJRC ILI9341 touchscreen (alternate pins) w/ audio adapter
- Using Sparkfun Flexible OLED Display and Library
- Flash Memory? What do I need to know.
- Teensy LC DAC only outputting 0-1.5V?
- general teensy
- USB Device: Serial + MTP possible?
- Teensy 4, Serial, Processing, FFT, ADC, SmartLED shield v5 [yeah, its a lot]
- Using the builtin LED pin for input (Teensy 3.5)
- Teensy 3.2 DAC output Low Amplitude
- ADCS input
- Teensy current requirements?
- Teensy 4.1 with Ethernet Kit: Sometimes link light not flashing --> no ethernet
- Differential analog read on Teensy 3.5 pins A12/A13: "ADC1: Wrong pin" error
- BMP280 from Adafruit doesn't work on Teeny 3.2
- example waveform.ino
- Configure Teensy 4.0 as both keyboard AND MIDI?
- Joystick.Button(1,1) causes the joystick axis' to jump to 0
- Teensy 4.x where to find documentation about the throughhole-contacts in the middle
- Push button Switch
- Why Setting the Wrong MIDI Baud Rate?
- ILI9341_t3n and 2x Screens on SPI1 - Flashing
- Help for a beginner
- noise on A0 when using audio shield
- DMA parallel output on T4.1
- DIY Teensy 3.2 Board
- Size of the 3.2's ferrite's
- XPLANE dataref-bug?
- Teensy 4.1 Code Pin layout ?
- Teensy 4.0 + Audio Shield - beginner help.
- Want to mirror SPI pins on Teensy4
- Using SPI1 or SPI2 in Radiohead library
- problem with USBhost with more than 1 MIDI port
- Ambient Lighting - Upgraded from UNO R3 to Teensy 4 and there are lots of issues.
- must change library to adress BNO055, help with code needed
- Teensy 4.1 - CPU Heat Limits
- Teensy 4.1 & Teensy 4.0 : Different Behavior with the Watchdog library
- Using a Teensy 4.1 with a remote relay (100 feet away)
- Problem with using Serial.printf/printf outside main.cpp in platformIO
- TouchscreenUSB.press X - Y Values
- easy way to get the name of a device connected to the USB host ?
- Teensy 4.1 USB Host Question
- 4.1 HW Encoder (more questions)
- sinf() on Teensy 4.0
- Teensy 4.1 as an SPI Slave
- Teensy 4.1 Has anyone managed to do Ethernet with selfmade board layout?
- mcp23s17 and sumotoy gpio_MCP23S17
- got the Teensy 4.1! Can I drive servos at 125 Hz?
- Teensy 4.1 freezes after receiving serial command
- Teensy4.0 ST7735 Freezing when using frame buffer.
- PWM Control of Brightness for TI TPS61165
- hid with MacOS catalina
- Teensy 4.1 ON/OFF Pin Access/Use
- Low USB connection latency on Teensy 4.0 + google chrome's new USB function
- I am having problem loading i2c_t3 library
- PPM and Joystick optimisation
- Problems with Teensy 3.6 Serial2 Tx buffers.
- Teensy4.0 and MCP23008 i2c issue
- I2S adafruit 98357a buzz, no audio
- teensy_loader_cli can't find baord
- midi in with 3.5mm connector overvoltage protection cuircuit
- SPI pin as Digital?
- MD_MAX72xx using HW SPI on Teensy
- Alternative FastLED and PWM 3.3v to 5V high speed digital isolators
- Cannot get DAC to work on custom teensy 3.6 board with 144LQFP chip version
- Teensy 3.2 RTC DST support
- Teensy 3.2 USB Keyboard Controller
- Teensy 4.1 and NativeEthernet lib Error
- Teensy LC and Teensy 4.0 output delay.
- TimeLib return type
- SSD1351 OLED display using HW SPI on Teensy 41
- hex file too large message
- Firmware update and communication using WIFI/Bluetooth and Teensy 4.x
- Using Teensy 4.1 as a Telnet Server
- A Long Road Already, Just Want to Compile and Upload
- Irregular SPI Behavior
- Converting pot reading range from 1.0 to 0.0
- very noisy differential amp setup
- Using Joystick and RawHID on Teensy 4.1
- Teensy 4.0 not showing up as 16c0:0486 but 1fc9:0135
- T4.1 NativeEthernet - Advanced Chat Server not working w/Telnet
- 4.1 with battery, single USB to program and charge. Device not recognized.
- Problem reading from SD card directly into PSRAM
- Initializing Variables in PSRAM from Audio Library Files?
- Teens 4.0 TLC59116 Led Driver
- Walking backwards in an SD directory
- Teensy 4.1 Audio and st7789_t3 SPI drop outs
- Teensy 4.0 How to write to LPI2C registers?
- Teensy 4.1 possible to hook up sdram?
- Is there any way to force an array to be in Teensy 3.6 SRAM_U?
- Problem with DS18B20 temperature sensor on Teensy4.1
- Encoder not working properly
- Wavetable Synth with TFT ILI9341 Display, interpolating issues
- Wavetable Synth Distortion issues with Audio Shield
- Power both Teensy 3.2 and Octo board
- ILI9341 - MISO pin unconnected
- Teensyduino code location
- interrupts on pins 13 & 14 doens't work
- ILI9488_t3 and alternative pins for CS, DC
- Cannot get serial data to work when connecting external power supply ground
- XPT2046 Library for SPI-1
- 5v encoder and Teensy 4.1 board
- Help! Very weird issue with FastLED + WS2812Serial
- AltSoftSerial on Teensy 4.1 - What pins should I use?
- FrequencyTimer2 change duty cycle
- Stepper Won't Reverse, Instead Cooks Eggs
- Ethernet (TCP) problems with Teensy 4.1
- Serial monitor can't read from Teensy 3.6 on Ubuntu 20.04 but can on Windows10
- Setting i2c pins in teensy 4.1
- Can't compile anything for my Teensies.
- Teensy 4.1 and WS2811 pixels
- Teensy 4.x Serial ports hanging?
- Two usb client ports
- Teensy4.1 Encoder-Problems
- DMA to PLL?
- Creating 150khz sine wave
- Interval Timer, Function Pointers, and Variables.
- Do I need to use a resistor with this SSR?
- Teensy 4.0 FOR statement not working
- Teensy 4.0 freezes using Snooze and EEPROM.put
- running NativeEthernet flat out....but why is delay needed?
- Using USB2 on Teensy 3.6
- No longer able to write to Teensy ++ 2.0
- need advises for designing low noise circuits
- GPS reception blocked by RFI
- For Teensy 4.x: Is it possible to switch pin 13 to off or low during boot?
- UDP Broadcast with NativeEthernet?
- IntervalTimer inaccuracy? Discipline? Scope Video included
- Teensy 3.5 Use of A10 as digital write.
- Teensy 2 renaming game controllers
