View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Teensy 2.0 restarting while sending and receiving data from serial port
  2. Very Stable DAC Output using PDB (Programmable Delay Block) and DAC Buffer
  3. RSS feed
  4. SPI and Serial 2
  5. Teensy 3.1 reads wrong data through I2C
  6. usbMIDI read of analog values uncooperative while multimeter read voltages OK
  7. capacitors best option for removing analog sensor noise?
  8. int[32][32] stops Teensy 3.1 from working. Array too big? issue with Serial?
  9. How do I change the name my Teensy displays when connected as HID device.
  10. Arduino: how to once save date & time to RTC from __TIME__ and later get from RTC?
  11. how to program and code teensy 3.1
  12. Teensy 2.0 dead after one flash?
  13. Exposed ground line a problem in teensy board bount?
  14. Teensyduino OSX10.9 install cannot find Arduino directory
  15. Teensy 3.1 stopped being recognized by my PC
  16. Multiple Teensies simultaneously on one computer ?
  17. Teensy 2.0 voltage and power
  18. GLCD Maximum Panel Size & controller?
  19. SPI on Teensy 3.1 - negative values wrong
  20. Teensy 3.1 + Matlab/Simulink
  21. Teensy 3.1 IntervalTimer code within class problem
  22. Teensy 3.1 Reset
  23. I2C Slave Problems (and Repeated Start
  24. HID problem >64bytes
  25. Change bootloader - aka delete corrupt HalfKay
  26. Teensy 3.1 10 second delay on being able to read on Serial2?
  27. Teensy3.0 - Octows2811 Pinout
  28. [Teensy 3.1] Problems with the ADC for my alpha spectroscopy project
  29. PCB design query
  30. Legally Blind- Need USB MIDI help
  31. MINI54 Custom "teensy-like" Board Programmer
  32. Building Firmata test on ARM Linux
  33. movie2serial sound but no video
  34. TimeAlarms Library: how to disable or kill created Alarm or Timer?
  35. PC communication problems with Teensy 3.0
  36. UART equivalent to Serial.parseInt() ?
  37. Teensy3.1 + CISECO I/O POD uSD (microSD) does not work at all
  38. The LCD12864.h library.. anyone got it working on teensy?
  39. Teensy 3.1 Dead already?
  40. Using external microSD reader with wiz820IO
  41. Teensy 3.1 : Hardware Manager code 10
  42. Connecting Teensy 3.1 to computer requires a button press?
  43. Remapping pin 13
  44. Teensy 3.1 Serial Break?
  45. Servo or PWMServo for 3.1
  46. LD-3361BS 3 digit display - 12 pins
  47. Serial2 on pad 26 and 31 on Teensy 3.1
  48. [ TEENSY3.1, using the 2 ADCs in single ended 16 bits mode ]
  49. Trouble connecting Teensy 3.0 to OSX Mavericks
  50. Audio issues on Teensy 3.1 DAC output
  51. attachInterrupt issue - function seems to be called twice
  52. How do I receive a numlock/capslock LED signal from the PC?
  53. Best Teensy 3.1 Random Number Generator?
  54. Backwash power from Serial1 RX/TX causes teensy++ 2.0 to enter halfkay
  55. Teensy Timer/Counter Example for the T3 & T3.1
  56. Teensy 3.0 analogWriteFrequency code crash
  57. Custom teensy board won't program
  58. Cannot see Teensy 3.1 as a target board in Teensyduino
  59. Teensy 3.1 and OctoWS2811 power pretty good but not perfect
  60. CAN and CANopen
  61. Does teensy3 requires stdlib?
  62. Cutting Vin/Vusb and Dead Teensy 3.1
  63. Using the Open Drain capabilities of the Teensy 3.1 processor
  64. FASTLED and DmxReceiver.h
  65. Getting the LCD to work for Teensy 3.1
  66. SD card initialization breaks DAC functionality
  67. Bootloader for firmware update at customer site
  68. [Question] Teensy 3.1 - programming over Bluetooth connected to pins 7 & 8
  69. Noob question: converting Teensy++ 2.0 to 3.3v
  70. Using mini54 with 48pin K20 chips
  71. Teensy 3.1 PWM resolution
  72. Teensy 3.0/3.1 Lock Bits and Reprogramming
  73. Teensy 3.1 + ENC28J60
  74. Weird digitaiRead() behavior in the SPI part of my project..
  75. Teensy 3.0/3.1 + Atmel Studio 6.1
  76. Teensy 3.0 and digital caliper
  77. Compile error with SevenSeg arduino library when board type set to Teensy 3.0 or 3.1
  78. Teensy 3.1 OctoWS2811 atrifacts only on led2 line
  79. Serial port emulation problems (Teensy 3.1)
  80. AltSoftSerial
  81. Teensy 3 CC Messages Crashing Ableton Live 9
  82. Teensy 3 Cant Do Note on/off with Bounce
  83. Troubleshooting Teensy 3.1 / MCP4725
  84. Teensy 3.1 & freeIMU
  85. Teensy 3.X absolute mouse positioning stuck to primary monitor only?
  86. REsistors for inputs
  87. Can I use the GSM Library from Arduino?
  88. SimpleModbusSlave library not compiling on Teensy 3.1
  89. intermittent problem with Serial and Serial3 reads
  90. MK20 chip not recognised as serial port
  91. Teensy 3.1 Serial Sync?
  92. Teensy3, I2C, Multiple Masters
  93. Errors when trying to use std:deque with Teensy 3
  94. Interrupts missing
  95. Piezos and Potentiometers together
  96. Timer Lib or Timer interrupt for Teensy 3.0/3.1
  97. Teensy 3.1 and Audio Board - No sound, no SD function
  98. Seeking Consulting on Teensy 3.1 ARM Cortex Assembly Language Programming
  99. pc to device HID communication.
  100. UART speed weirdness
  101. Teensy 3.1 only runs code on usb port power from computer and not any other source
  102. What is more precise RTC or Systick?
  103. teensy 3.x, delay needed after pinMode() and digitalRead()
  104. Large delays in code when using Serial.print, etc.
  105. Bounce problem on Pin 0 of Teensy++ 2.0
  106. OctoWS2811 16x16 tiled matrices
  107. OctoWS2811, Bug in library or hardware fault.
  108. Error in Time.cpp ??
  109. how to jump to bootloader (or simply reset) using endpoint0/set_feature
  110. Duplicate usb modem number HELP!
  111. teensyduino headers keep getting in the way
  112. Compiler for Teensy C code?
  113. Teensy 3.1 5V AnalogRead
  114. Lanc port to control camera record
  115. Teensy 3.1 only runs code on upload
  116. Teensy Digital Filter Implementation - Using coefficients
  117. audio shield anomaly
  118. Getting Teensy to work with Pedometer
  119. teensy 3.1 and long strip of Neopixels
  120. New Teensy 3.1 not recognized by Arduino
  121. Teensy 3.1 clock speeds?
  122. Teensu_gateway working over UDP instead of TCP/IP
  123. feasibility of using Teen 3.x with 3 quadrature encoders?
  124. Teensy 3.1 Diptrace Library
  125. teensy 3.1 : usb_debug_only code compatibility
  126. Teensy 3 + Adafruit nRF8001 BLE, library compile problem
  127. Teensy Loader - Multiple Teensy 3.1s choose which one?
  128. Software for USB communication with Teesny 3+
  129. Noise on DAC (A14) output Teensy 3.1.
  130. Serial Number of Teensy 3.1
  131. Question on USB for Teensy 3.1
  132. Teensy 3.1 Startup 3.3v
  133. C++ and memcpy()
  134. Two channels of Frequency measurement for Arduino MEGA2560
  135. Teensy 2++ faster than ATMEL 328 ??
  136. Teensy 3.1, Overriding Core Libraries in the Arduino IDE
  137. Connecting all inputs/outputs teensy 3.1
  138. Non-standard rotary encoder only counts up
  139. Audio Library FFT with ADC input
  140. Audio Library - "MonoPeakmeterAnalog" wont work on teensy3.1 without audioshield
  141. Schematic for Teensy 3.1 OctoWS2811 adapter card please?
  142. Teensy 3.1 and 7-Segment 4 Digit LED Display
  143. USB Micro pin 4?
  144. analogRead and audio
  145. Multi-device code example for teensy++ 2.0
  146. Wire library versus TimerOne interrupt on Teensy 2
  147. How to know when a Lipo is Dead beyond repair??
  148. Anyone try QEMU and use arm-none-eabi-gdb successfully?
  149. Can a Teensy 2.0 plugged into a USB automatically boot when the PC powers up?
  150. Teensy used as USB keyboard - KVM switch problem
  151. Pasing objects into C++ classes
  152. Teensyduino Installer Not Recognizing Arduino Install
  153. install teensyduino in debian - beaglebone black
  154. Teensy 3.1 Excessive RAM estimates?
  155. teensy 3.0 and RA8875
  156. start up
  157. Analog inputs on teensy 3.1 smt pads, A15-A20
  158. Teensy emulating a Monome/Arduinome for use with serialosc *Solution Needed!!!**
  159. Serial.print problem Teensy 3.1 and teensyDuino
  160. Grounding pin 33 crashes Teensy 3.1
  161. UBX protocol help: configuring a NEO 6M Arduino GPS Module... Fletcher checksum?
  162. Error loading .pde file
  163. Semi obvious question. Teensy 3.0/3.1 Analog pins as Digital Inputs?
  164. Ardino have a standard libraries/util folder?
  165. Teensy 3.1 not working with hmc6343 gyro/accelerometer
  166. teensy 3.1 with iremote
  167. Teensy 3.1 and WaveHC
  168. movie2Serial first try problem
  169. LiquidCrystal_I2C
  170. Is the Octows2811 adapter board compatible with Teensy 3.0?
  171. Teency 3.1 Compatibility with MFRC522 RFID Library
  172. Teensy 3.0/3.1 reset pin assertion
  173. Question on avr_emulation.h for RFM22 lib replacement RadioHead
  174. Teensy 3.1 Mouse control Issues
  175. Question about AudioPlaySdWav.isPlaying() and delay
  176. unresponsive Teensy3.1
  177. RFM69 RF transceiver and Teensy 3.1, TIMER1_COMPA_vect not declared in this scope
  178. tennsy++ 2.0 question
  179. Teensy 3.1 ADC LayOut
  180. Teensy 2 vs Teensy 3 GCC error with C99 struct init by member name
  181. Problems using Adafruit 2.8" LCD with Teensy 3.1
  182. Teensy 3.0 I/O tolerance
  183. Teensy 3.1 Windows USB not detected
  184. Teensy 3.1: 5V Output (USB) & Negative Voltage Input (ADC)
  185. Teensy 3.1 ADC accuracy(repeatability)
  186. T3.1 WIZ820io Safari Webserver Crash
  187. teensy 3.1 died
  188. #define for cortex m4 ?
  189. Is my teensy dead?
  190. Multi HID Emulation
  191. Addressing pins of PORT A or B
  192. Serial port function on Teensy 3.1
  193. Help Needed with Teensy1 Like board :D
  194. OctoWS2811 command reference
  195. Running movie2serial.pde on Raspberry Pi
  196. USB Midi In with Teensy 3.1 and Arturia Analog Factory MIDI controller issues
  197. Suggestions for equivlent of cli/sei on Teensy 3.1
  198. Teensy 3.1 USB Midi - cannot connect to USB Midi Keyboard controller (iPad works ok)
  199. Serial.print blocks when connected to Linux machine
  200. quaternian is changing very very slowly
  201. cannot use teensy 3.1 on fedora 18
  202. Serial Communication Error on Teensy 3.0 -- Com Port Closes After Read/Write Failure
  203. Wire on Teensy 3.1
  204. Arduino Micro Code Creating a Few Errors When Run On Teensy 3.1?
  205. Teensy 3.1 USB connection to Mac flaky
  206. USb MIDI coding
  207. 3.1 Makefiles in plain english.
  208. Teensy 3.1 and Adafruit NeoMatrix Issues
  209. REPORT_ID greater than 256?
  210. Increasing NeoPixel separation
  211. SREG emulation for nested interrupt save/disable; restore state
  212. Cross Compiling for Teensy - Kinda - Scenario Help
  213. How many Teensy 3.1 for video wall?
  214. Is 3.7 volts enough to power Teensy 3.1 + 3.3v sensors?
  215. xbee and octows2811
  216. Teensy 3.1 and USB connect / disconnect
  217. Power supply for octows2811
  218. QueueArray Library not working Teensy 3.1?
  219. elapsedMillis/elapsedMicros limitation - clarification needed
  220. Some questions for starting a new project
  221. Pressure sensor using the Teensy 3.1 ADC very noisy
  222. How to ID multiple Teensy's on COMPORT
  223. Update Teensy remotely without using the pushbutton
  224. Teensy 3.1 and OneWire library issue - errors when compiling - new user
  225. Disabling auto reset
  226. Teensy 3.1: Problem with memory deallocation
  227. Audio adapter schematic
  228. Can't find library mac.h re:artnet implementation
  229. Select Serial1 or Serial2 in function ?
  230. Want to try gcc 4.8.3 ?
  231. Teensy 3.1 - Any way to show CPU speed on my OLED?
  232. My code is hanging processing XBee data on Serial1 on Teensy 3.1
  233. Fast analog-digital conversion
  234. Teensy 3.1: LabVIEW + Controlling Teensy Outputs(IēC/Serial)
  235. Teensy 3.1 USB Serial drops out after 24+ hours
  236. Mini54TAN Bootload miss behaving?
  237. Counting Pulses On Teensy 3.1
  238. Teensy3.1 PlayWavSDcard Beeps
  239. How do you access the builtin RTC?
  240. How to setup LED reference struct
  241. Audio library sample range problem
  242. is there a flightsimcommand limit of only 12?
  243. how to hook i2c multiplexer (SX1509)
  244. Simple questions about R/C channels
  245. Writing on board flash library while keeping similarity to current EEPROM library
  246. Sketch not loading onto teensy 3.1
  247. USB, Serial, RX1 & TX1
  248. Teensy3.0 locking up with liquidcrystalfast
  249. Trouble with Arduino SD library.
  250. Adafruit 2.8" TFT Touch Shield for Arduino for Teensy 3.1
