View Full Version : Technical Support & Questions
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Teensy 3.1 Logic Level 5V tolerance
  2. Biquad filter dynamic range
  3. Need Help porting Modbus lib
  4. Serial ports on Linux
  5. Fixed point trigonometry?
  6. Help with interrupt driven ADC
  7. Anyone looked into the new MK22FN1M0VLH12
  8. Thread Safe Teensy 2.0 USB Driver for Windows
  9. Clash of Teensyduino USB and Atmel Jungo... Also TI LDC1000EVM
  10. ShiftMatrixPWM updated for Teensy3 - Almost!
  11. Teensy 2.0 with MPU-6050 Breakout
  12. save and upload HEX file on mac
  13. Errors compiling Fastled library teensy 3.1
  14. mk20dx256 - where is SPI1_SCK?
  15. touchRead on pin 0 not working
  16. ModbusSlave (jpmzometa) ported to Teensy
  17. Trouble Using PulsePosition Library with Shift Register
  18. Teensy++ 2.0 & Serial Port
  19. teensy 3.1 no connection anymore
  20. newbie help - connecting led strip to Teensy 3.1
  21. OctoWS2811 library and teensy 3.1 - issue with leds.show(); command?
  22. Problem displaying bitmap on Adafruit 1.8" TFT shield with MicroSD and Joystick
  23. PS3 macro with teensy++ 2.0
  24. Writing registers from arduino IDE bombs sketch.
  25. Assembly view of compiled code for Teensy 3.1
  26. Differential ADC and AREF
  27. Turn the LED on with assembler code ( Teensy 3.1 )
  28. Teensy 3.1: Problem using I2C on pins 29 & 30
  29. Teensy 3.1: Problem using Serial2 on pins 26 & 31
  30. Teensy 3.1 and CMP0 or CMP1 modules - lockup
  31. MISO, muxing and different Pin Mapping
  32. IC Clock Stretching Implementation for Teensy 3
  33. Teensy 3.1 Data Logging Problem / SD Card / Serial
  34. teensy3 inline asm questions
  35. Teensy 3.0 wire library Send and receive in one sketch
  36. Teensy 3.1 power on issue
  37. Octows2811 MiovieStream
  38. Teensy 3.1 RTC Crystal Placement
  39. Teensy 3.1 with Freescale KDE
  40. Teensy 3.1 + RA8875 with
  41. Unable to compile blinky and usb_keyboard_debug samples
  42. Double divide corrupting on the Teensy 3.1?
  43. Problems with reading MCP3202 SPI ADC on 3.1
  44. External Power for Teensy Issue
  45. Teensy 3.1 not loading sketches
  46. PPM Library Questions
  47. Compiler differences between Teensy++2 and Teensy 3.x
  48. Teensy 3.1, ADXL345, and buttons for keyboard inputs
  49. integer type definitions on Teensy 3.1
  50. RC Servos Killing Teensys
  51. Using a potentiometer to send a keyboard stroke?
  52. Headers in the thru holes? Teensy 3.1
  53. Read the analog pins while sending data through the serial port (Teensy 3.1)
  54. Where is Teensy3Clock instance declared?
  55. aref external is not external but teenys 3.3V ?
  56. Teensy 3.1 external interrupt on multiple pins
  57. ISR on Serial1 Receive help
  58. Teensyduino compatibility with arduino-1.5.4
  59. [Teensy 3.1] Reset while reading USB related registers...
  60. Spectrum Analyzer compile issues
  61. Arduino to Teensy with easytransfer
  62. Has anybody used FlexRam ?
  63. VUSB & VIN - Teensy 3.1
  64. Teensy3 and strncpy_P()
  65. Channel numbering in PulsePosition Library
  66. Adaption of teensy_loader_cli for Teensy 3.1
  67. T3.1 and SD card CS pin
  68. RTC Issue
  69. Teensy 3.1: remote debugging, alternate IDEs?
  70. Off-color WSWS2812B with Teensy 3.1
  71. Teensy 3.1 tutorial 4 help
  72. HT1632C Compatibility
  73. Timer interrupt stops after 5 minutes
  74. T3.1 Components usage
  75. MsTimer2 and Serial / Uart Communication issues?
  76. list of pin modes for teensy 3.1?
  77. ADC noise with OctoWS2811?
  78. Teensy 3.1: Interference between SDwrite and I2C?
  79. Teensy3.1 Audio Shield Glitch in Play Wav Sound
  80. I2c get stuck with daisy chained Attiny85
  81. uText library with UTFT on the Teensy 3/3.1
  82. Where does teensyduino put .lst, .o, .hex files?
  83. [Class] FIR filter with MATLAB coefficients
  84. Processing, USB Serial and Teensy 3.0/3.1
  85. Accessing Clock
  86. Serial and mixed up characters
  87. Serial port issue
  88. Noob help needed - Teensy 3.1 and WS2812B Strip
  89. flash helper macros from AVR, when within ARM code
  90. Teensy on LabVIEW with LINX Project
  91. Using hardware SPI on Teensy 3 Audio Shield
  92. Cannot program teensy 1.0!
  93. AGND or GND
  94. constant error;Unable find Teensy Loader. Is the Teensy Loader application running?
  95. is making ROM / flash dumps possible?
  96. Analog read is not sensitive
  97. roblems with uart buffer capacity teensy 2 + +
  98. Teensyduino run on STM32F104 or Stellaris ARM controllers?
  99. Adapter schematics
  100. Using a 5v sensor with a Teensy 3.1
  101. Logic levels between Teensy 3.x, HC164, and Servos
  102. Multiple SPI devices, multiple implementations fighting over resources
  103. Any experiences with FeRAM's?
  104. New Pulse Position Modulation (PPM) Library
  105. Teensy 3.1 USB Serial connection as HOST to a USB to Serial Adaptor
  106. Problem with Serial Monitor function
  107. How to use Serial.readBytesUntil?
  108. Teensy 3.1 and the Encoder library with interrupts
  109. Teensy 3.1 not working after soldering the headers.
  110. Teensy 3.1 burned - help needed
  111. Teensy 3.1 and Meyhew Led Rings Library
  112. Compile Errors with imported Librarys
  113. Teensy 3.1: ADC Measurement, SD logging, problem with Sample Rate?
  114. Burned ferrite element between USB shield and ground pin on Teensy 3.1
  115. Timer1 v Teensy3, Teensy3.1? AltSoftSerial?
  116. Norton reports Suspicious.Cloud.7.EP in Windows 8 and deletes TeensyDuino.exe
  117. Analog Audio Problems
  118. How many bytes can send with Teensy3.1 via USB ?
  119. teensy 3.1 SD.open file modified time always Jan 1, 2000
  120. Teensy 3.1 Loader
  121. Teensy Audio board vs Rogue Robotics uMP3
  122. Power Teensy 3.x from regulated 3.3V? / External Power while USB connected?
  123. Teensy 3.1 Watchdog timer & serial monitor
  124. library conflict with redefining << operator?
  125. Update on Arduino IDE delays when Tools selected and Bluetooth present
  126. How can I read MIDI outputs
  127. Workin' on a keyboard..
  128. Tennsy help using maxbotix ultrasonic and BLE
  129. unable to establish serial communication on 2nd port with Teensy 3.1
  130. Teensy 3.1 to MIDI synthesizer --> with usb to MIDI link?
  131. kameleon
  132. GND and 3.3 V pins at the end of the Teensy 3.1
  133. Teensy 2.0 and keypad
  134. Problem with SdFile open on Teensy 3.1
  135. Which Pins should I power. Teensy 3.0
  136. I gave my Teensy a virus, and now I can't flash it
  137. 5v AREF on Teensy 3.1?
  138. Too many strings or to much serial output
  139. Teensy 3.1 CapacitiveSensor Problem
  140. Teensy 3.1 serial usb data rate into C# program
  141. OctWS2811 Library and Moving ports from C to E
  142. Xplane Teensy - Custom dataref issue
  143. serial connection issues, Windows and Chrome app
  144. Teensy seems dead
  145. Programming Teensy 3.0/3.1 from OS X command line
  146. Teensy 3.1 and RFM12B
  147. Teensy 3.1 Make Issues ("No such file or Directory")
  148. changing the name of the device
  149. Teensy 2.0 footprint
  150. Touch Sensor Teensy3.1 v Arduino Uno
  151. OnStep telescope control on teensy.
  152. Teensy 3.1 pullup activated by pinMode INPUT?
  153. Teensy 3.1 and raspberry pi data communication
  154. Teensy3.1 and "7 TFT
  155. bad encoder ?
  156. USB SerialEvent or ISR on Teensy 3.1?
  157. Measuring voltage on the Teensy 3.1
  158. CC3000 mixed with other SPI perihperals
  159. Teensy 3.1 without micro USB connector -- am I out of luck?
  160. 3D Printer Software with Teensy 3.1
  161. Teensy 3.1 and 9DOF Stick I2C
  162. Teensy3.1 Audio adaptor Headphones and Line output
  163. dual audio shield and wav loops
  164. Teensy 3.1 + FASTLED problem
  165. AVR/teensy 2 and crc16.h
  166. Adding a new USB type
  167. Teensy 3.1: Low, High and/or Band-Pass Filters
  168. Newbie looking for Starting Off info...
  169. My computer crashed during the erase stage...
  170. Teensy 3.1 and ILI9340 Display Issue
  171. Teensy 3.1 hangs / does not boot when using a battery operated latching power switch
  172. Detect USB connected
  173. Arduino IDE crashes on startup with Cannot launch Java application error
  174. Setup for level shifting i2c
  175. Structure of code affects performance?!
  176. Developing with multiple Teensys from Arduino IDE
  177. Teensy 3.1 ADC saturation at 0.5V
  178. 128x64 OLEd with Teensy 2.0
  179. Teensy 3.1 assembly language use of LDR/STR ???
  180. Software Jump Bootlader, Teensy 3.1 (Or, use the DAC pin as a digital output?)
  181. Teensy 3.1 I/O Ports
  182. Teensy 3.1 locking up on unconfigured pins during startup
  183. Teensy 3.1 Proximity Sensors
  184. Compile and load blink to teensy3.1without ardunio but don't working
  185. Help me measure VREF on teensy 3 and 3.1
  186. Converting Hexapod code from fixed point to floating point... Performance differences
  187. LIN network - how do use LINbreak detect interrupt in receiving LIN Message.
  188. Large transfers over serial on Teensy 3.1.
  189. Is my Teensy 3.1 dead?
  190. Adjust the BIAS_VOLT and ADC_VOL
  191. Problems with longer (~40m) OneWire Teensy 3.0 Communication
  192. Teensy 3.1 RTC...Is 4.2-3.7V safe & functional for Vbat?
  193. Possibility of reading Vin on Teensy 3.1
  194. Windows 7 blue screen on shutdown
  195. Teensy ++ 2.0 shows up as USB Input Device (rather than COM port)
  196. Malloc error on Teensy 3.1 using Mac OS 10.9 and Arduino IDE
  197. ADC Offset using MOSFET Switch
  198. Teensy 2.0 Locking Up?
  199. AREF not working as expected
  200. Which IC gets fried?
  201. FreeIMU
  202. WIZ820 and Ethernet libraries (teensy 3.1)
  203. Global and static variables not behaving as expected.
  204. The only program that runs is Blinky
  205. WDT question
  206. question about the max data amount to send per second via usb
  207. teensy 3.1 elapsedMicros seems to have bugs
  208. Problem with Teensyduino Driver
  209. Please help - Issues with Pixelcontroller and WS2801 pixels.
  210. USB Midi hangs when no
  211. GLCD MTB-368 (122*32 SED1520) with openGLCD and Teensy 3.0
  212. Teensy 2.0 Reboot issue
  213. CC3000 with adafruit library, non-blocking?
  214. Teensy 3.1 Using Extra Serial connections
  215. Teensy 3.1 Voltage sensing and low battery alert
  216. Teensy USB MIDI - receive SysEx messages
  217. "device node not found" ???
  218. Are resistors necessary between Octo and ws2811 strands
  219. Teensy 3.1 post mortem
  220. do we need to programme 74hc4067?
  221. Keyboard Emulator and OCTO how too.
  222. Teensy wont load after disconnecting power
  223. Teensy Not Recognized by Teensy Loader
  224. Eagle schematics
  225. Before I begin soldering: How should I assign pins using TeeOcto?
  226. LCD programming help needed
  227. Teensy 3.1 not recognized by PC
  228. Teensy 3.1 Analog to digital converter value jumps like digital IO pin hysteresis
  229. Uploading firmware with serial port
  230. PulsePosition Library Question
  231. Emulating a USB hub with two or more virtual HID devices connected
  232. where and how often is leds.begin() used
  233. Question: What things to look for: Arduino and Teensy 3.X library compatibility?
  234. Teensy 3.1 and TinyWebServer Library
  235. Ballistics instrumentation
  236. Teensy 3.1 Variable sizes
  237. teensy3.1 problem with Wire.endTransmission(false) in i2c_t3
  238. Safe to hook LiON battery to Vbat?
  239. Teensy 2.0 not recognized in Windows 8.1
  240. X-Plane NAV/COM coarse up/down
  241. Encoders
  242. Touch library and static electricity
  243. FreqMeasure freezing
  244. Servo rotation question regarding PulsePosition Library
  245. Wyse 50 terminal keyboard Teensy 2.0
  246. usbMIDI.sendPitchBend input values
  247. Teensy 2.0 under OSX 10.9.4 isn't detected
  248. I2C waiting for interrupt flag
  249. Teensy 3.1 Analogue Out and Audio
  250. Teensy 3.1: Working without Mini54
